Fendt Sprayer RG1300C Rogator Chassis Parts Catalog 652464 2018-2021
Brand: Fendt
Type of Machine: Sprayer
Type of Manual: Chassis Parts Catalog
Model: Fendt RG1300C Rogator Chassis (2018-2021)
Serial Number: .JXXX1001 - ..MXXX9999
Year of Manufacture: 2018, 2019, 2020, 2021
Number of Pages: 1048 Pages
Belts & Filters Guide
Engine Acw6677560 84 Awf-Hla
Engine Assemblies - 8.4 Liter
Electronic Engine Management
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Valve Rocker Cover
Intake Manifold
Exhaust Manifold - M12 Turbo Mounting Stud Bolts
High Pressure Turbocharger - M12 Turbo Mounting Stud Bolts
Low Pressure Turbocharger And Icac - M12 Turbo Mounting Stud Bolts
Oil Pump And Sump
Oil Cooler And Filter
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Fan Drive
Air Compressor
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine V835277885 84 Awf-Hla
Coolant Piping - Up To Engine Serial Number D79603
Coolant Piping - Starting From Engine Serial Number D79604
Engine V835277817 84 Awf-Hla
Engine Installation
Engine Installation, Agco Power, 8.4 Liter
Engine Mount Group - 8.4 Liter
Alternator Assembly
Cooling Group - 8.4 Liter
Cooling Package
Condenser Bracket - Air Conditioner
Drive Group - Fan And Alternator
Fuel Tank Installation, Locking Cap
Fuel Line Installation, Standard
Fuel Line Installation, 2nd, Fuel And Water Seperator
Fuel Filter, Complete
Def Tank Group, Non-Locking, 8.4 Liter
Def Tank Group
Non Def Group
Electrical Caps Installation, Less Regulated Countries
Exhaust Group, 8.4 Liter, Tier 4 Final
Scr-Vertical - Tier 4, Final Compliant
Exhaust Installation, Less Regulated Countries - 8.4 Liter
Installation-Air Intake
Air Cleaner, Psd10
2 Wheel Steering Axle
4 Wheel Steering - Rear Axle Installation
4 Wheel Steering - Hydraulic Installation
Electrical Installation, 4 Wheel Steering
Wheel Angle Sensor Installation
Drive Hose Kit, 2 Wheel Steering
Drive Hose Kit - 4 Wheel Steering
Hydraulic Track Adjust, Automatic - Hydraulic Installation
Hydraulic Track Adjust Valve - Front
Hydraulic Track Adjust Valve - Rear
Hydraulic Track Adjust Group, Standard
Hydraulic Track Adjust Cylinder
Hose Kit - Hydraulic Track Adjust
Manual Track Adjust Assembly
Manual Track Adjust - Hydraulic Installation
Manual Track Adjust - Bulkhead
Steering Column Assembly
Steering Control
Steering Cylinder Installation, Front - Hydraulic
Steering Pump - Priority Valve Assembly
Air System
Air System Group
Air Tank Installation
Control Valve Assembly, Rear
Control Valve Assembly, Front
Air Dryer, Single Canister
Air Governor
High Volume Air Dryer Option - 2015-2019
High Volume Air Dryer Option - 2020 - 2021
No High Volume Air Dryer Option
O-Ring Kit, Rogator
Hydraulic Cap Plug Installation - 1300
Hydraulic Accumulator Installation
Hydraulic Tank Installation
Hydraulic Tank Assembly
Hydraulic Tank Heater, 1000 Watt, 120 Volt
Hydraulic Tank Heater, 1000 Watt, 240 Volt - Less Regulated Countries
Hydraulic Component Installation - Brake Installation
Manifold Assembly, Hydraulic Return
Hydraulic Return Manifold Assembly
Park And Ladder Valve Assembly
Brake Pedal Valve Assembly
Hydraulic Installation, Drive Pumps - 900 1100 1300
Hydro Pump Drive Kit - 900 1100 1300
Hydraulic Drive Pump,210cc, C - 900 1100 1300
Hydraulic Installation, Drive Wheel - 1300
Gearbox, 609, 22.1 1 Ratio, 110cc, 2.5l - 1300
Hydraulic Drive Motor, 110cc, With Speed Sensor - 1300
Hydraulic Installation, Drive Wheel, 1300
Gearbox, 609, 31.7 1, 110cc, 2.5l - 1300
Puller For Brake Circlip
Hydraulic Ladder Cylinder Assembly
Drive Hose Kit - 900 1100 1300
Hydraulic Installation, Routing Accessories
Auxiliary Hose Kit - C Series
Back Up Alarm
Fuse Installation - Battery
Fuse Installation - Cab
Clamping Installation
Electric Horn Installation
Harness Installation, Cable, Chassis, Domestic, Air Ride
Harness Installation, Wheel Leg, Sauer
Headlight, Right, C120, Rear Mount - Boomrest
Headlight, Left, C120, Rear Mount - Boomrest
Boom Rest Light Installation
Lighting Group, Double Hid
Light Assembly, Left, Double Hid
Light Assembly, Right, Double Hid
Lighting Group, Led
Light Assembly, Led Generation 4 - Left Hand
Light Assembly, Led Generation 4 - Right Hand
Lighting Group, Standard Lights
Light Assembly, Left - Halogen
Light Assembly, Right - Halogen
Radio Installation, Cd, Xm ,Blue Tooth, Usb
Powerstrip Assembly
Speaker Assembly - Radio Accessory Kit
System Connector Installation, Combo
Antenna
Antenna Base Assembly
Armrest Installation - Rogator
Arm Rest
Armrest - Virtual Terminal Installation
Armrest - Terminal Support
Armrest - Camera Cables
Armrest Adjust Mechanism, Right Hand
Audio Group
Beacon Assembly
Controls Arrangement, Front
Cover Assembly - Right Hand
Dash Panel Assembly
Dome Housing Bracket Installation
Glass Hammer Assembly
Heat Barrier Installation
Inner Roof Arrangement
Outer Roof Assembly
Interior Trim
Interior Trim Arrangement
Mirror Installation, Standard
Mirror Installation, Heated And Adjustable
Mirror Mounting Group
Convex Mirror Installation
Mounting Group - Seat
Seat Group, Basic - Air
A2000 Passive Suspension Service Kit
Passive Seat Suspension Kit
Compressor Service Kit - Passive
Seat - Knobs Assembly Kit
Seat Group, Deluxe
Seat Group, Leather - Passive
Seat Group, Leather Vented - Semi Active Suspension
Trainer Seat, Cloth
Trainer Seat, Leather
Semi Active Seat Suspension Kit, Left Hand Air Tank
Wiper Group
Wiper Motor, 1 Inch Shaft, Left Hand, 85
Hvac Group
Hvac Unit - Auto Control
Air Conditioning High Pressure Switch Assembly
Standard Chassis - 2018 - 2019
Anti-Roll Bar Assembly
Standard Chassis - 2020 - 2021
Frame Assembly, Rogator - 2018 - 2019
Frame Assembly, Rogator - 2020 - 2021
Crossmember Assembly
Eye Bolt Assembly
Boom Stop Bracket Assembly, Left Hand
Boomrest Installation, Domestic
Boomrest Installation, Non Domestic
Mirror Mount Assembly - Left Hand
Deflector Cover Installation
Deflector And Cover Support Assembly, Left Front
Deflector And Cover Support Assembly, Right Front
Deflector And Cover Support Assembly, Left Rear
Deflector And Cover Support Assembly, Right Rear
Entrance Installation, Front, Rogator
Handrail Installation, Front
Platform Installation, Front
Ladder Installation - Front
Ladder - Front
Fender Option, Floater - 2 Wheel Steering
Fender Option, Floater - 4 Wheel Steering
Fender Option, Row Crop - 2 Wheel Steering
Fender Option, Row Crop - 4 Wheel Steering
Grill Assembly
Hood Installation
Hood Group
Hood Support Group
Hood Support Bracket Group
Tool Box Group, Right Hand
Tool Box Assembly, Right Hand
Tool Box Hand Rinse Tank
Ppe Box Tank Assembly, Left Hand
Decal Installation - Electric
Engine Decal Installation
Wheel Hardware Installation
Tire And Wheel Assembly, Vf380 90r46 - Goodyear, Firestone, Michelin, Telleborg
Tire And Wheel Assembly, 380 90r46, Goodyear
Tire And Wheel Assembly, 320 90r50, Titan
Tire And Wheel Assembly, 480 80r42, Titan
Tire And Wheel Assembly, 620 70r38, Michelin
Tire And Wheel Assembly, 650 65r42, R1w, Goodyear
Precision Farming Systems
Antenna Installation, Phoenix 300, Gps
Antenna Installation - Vd03
Cable Installation, Rgl 600, Agcontrol
Cable Installation, Rgl 600, Raven
Camera Kit, Agcam
Camera Installation
Camera Installation, 9 Inch Monitor
Camera Installation, 9 Inch Monitor - 2020 - 2021
Camera Installation - Single
Camera Ready Installation - Nt01
Camera Ready System
Camera Ready System - 9 Inch Display
Console Installation - Without Gps, Viper 4, Raven, Ag
Controller-Vd0x W Gyro 3g, Modem
Controller-Vd0x W Gyro Cdma, Modem
Controller Installation, Raven V4
Gps Installation - Raven
Gps Ready Installation
Gateway Assembly
Gateway, Mid Spec, Lte
Gateway, Mid Spec, Gsm
Gps Installation, Phoenix 200 - 2018
Lightbar Installation, Rgl 600, Rg
Lightbar Kit, Rgl 600, Raven - Agcontrol
Monitor Kit, 9 Inch - Quad Camera Display Monitor
Novatel, Ready Receiver - Smart 6
Novatel, Ready Receiver - Smart 7
Plug Installation - 9 Inch Display
Plug Installation - Camera (Agcam)
Plug Installation - Lightbar
Radar Installation
Slingshot Installation, 2.0, Verizon
Slingshot Installation, Ready, Raven
Slingshot Installation, Verizon
Slingshot Installation, No Gps, Cab
Smartrax, Electrical Installation - 2018
Trimble, Sub-Meter - Receiver
Weather Station
Weather Station - Control Installation, Raven, Viper 4
Pressure Washer - Option
Pressure Washer Reel Assembly
Pressure Washer Assembly
Pressure Washer Plumbing Installation
No Pressure Washer Option
Ag Control Installation - Option
Field Accessory - Antenna
Field Accessories, Auto Guide Ready Bracket - Real Time Kinematic
Field Accessories, Brake Release
Field Accessories - Camera Adapter, Motec
Field Accessories - Camera (Agcam)
Field Accessories - Camera Cables
Field Accessories - Camera Monitor
Field Accessories - Ecology Drain
Field Accessories, Fuel Water Separator
Field Accessories, Halogen, Cab Lights, Rear
Field Accessories, Led, Cab Lights, Rear
Field Accessories, High Frequency Shocks
Field Accessories, Hood Lights, Led - Led
Field Accessories, Modem Satellite
Field Accessories, Power Mirror Installation
Field Accessories - Power Strip
Field Accessories - Pressure Washer
Field Accessories - Radio, Deluxe Xm
Field Accessories - Radio Installation, Blue Tooth, Usb
Field Accessories - Satellite Antenna Installation
Field Accessories, Smartrax, Raven
Hydraulic Valve Assembly, Smartrax
Field Accessories, Weather Station, Raven - Viper 4
Field Kit, Cac Tube - Charge Air Cooler
Field Kit, Park Brake Switch Rework - 1300
Field Kit, Steer Fitting Rework
Field Service Kits
Kit-Rework, Oil Fill Access
Paint Kit - Scr
