Fendt Sprayer 645 Rogator Parts Catalog FR645MY2020 2020
Brand: Fendt
Type of Machine: Sprayer
Model: Fendt 645 Rogator 2020
Serial Number: XRRF0645XLV001001-999999
Year of Manufacture: 2020
Number of Pages: 945 Pages
Engine Acw749061a 74 Lftn
Instructions - Parts Lists And Illustrations
Engine Identification
Engine Assemblies
Cylinder Block - Service Parts
Electronic Engine Management
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Valve Mechanism - Service Parts
Cylinder Head - Service Parts
Valve Rocker Cover
Intake Manifold
Turbocharger - Service Parts
Oil Pump And Sump
Oil Pump - Service Parts
Oil Cooler And Filter
Crankcase Ventilation
Crankcase Ventilation - Service Parts
Coolant Pump And Thermostat
Coolant Pump - Service Parts
Fuel Injection System
Fuel Injection Pump - Service Parts
Fuel Filters
Fuel Filters - Service Parts
Alternator - Service Parts
Air Compressor
Air Conditioning Compressor
Exhaust Aftertreatment - Service Parts
Engine Gasket Kits
Engine Overhaul Parts
Special Overhaul Parts
Engine Installation
Overview - Filters
Hose Installation - Fuel Group
Fuel Filter - Water Separator
Hydraulic - Tank Assembly
Hvac Group - Cat 4
Air Intake Group - 7.4 Liter
Engine Mounting Group - 7.4 Liter
Coupler - 145 Cc
Dipstick - 7.4 Liter
Coupler Assembly - 7.4 Liter
Cooler - Combi-Instrument
Grill Assembly - Cooler
Tube Assembly - Charge Air Cooler
Tube Assembly - Water Cooled Radiator
Hose Installation - Cooler
Surge Tank - Coolant
Tube Assembly - Exhaust
Eat Installation
Exhaust System - Sensor
Pressure Sensor - Def System Installation
Insulation - Exhaust Installation
Tank Assembly - Def
Pump Installation - Def
Dosing Module - Def
Hose Installation - Def
Axle Installation - 85 Cc
Bracket - Axle Installation
Wheel Arm
Sensor Assembly - Axle
Cover Installation - Wheel
Plate Installation - Hoses
Track Width - Installation
Frame And Suspension
Bottom Plate - Plate
Fender Support Assembly
Engine - Cover Plate
Battery - Box
Lock Tank Front
Locking Kit - Chemical Eductor
Eat Installation - Bracket
Support Bracket - Cabin
Suspension Assembly - Unit
Suspension Unit - Lf Rr
Suspension Unit - Rf Lr
Cylinder - Suspension
Cylinder - Suspension Assembly Front
Cylinder - Suspension Assembly Rear
Orbitrol - Installation
Steering Cylinder - Installation
Steering - Axle Installation
Steering - Hose Installation
Steering - Tube Assembly
Piping - Steering
Hydraulic Lift Pump - Installation
Hydraulic Pump - 145 Cc
Transmission - Gft 8130
Gearbox Assembly - Gft 8130
Hydraulic Motor - 85 Cc
Brake Pedal - Valve Installation
Air System
Air System - With Trailer Brake
Components Installation - Air System
Air System - Without Trailer Brake
Air System - Air Dryer
Air - Tank
Valve Installation - Pressure Control
Trailer - Hose Installation
Coupler Assembly - Trailer Brake
Valve Installation - Brake Valve
Valve Installation - Quick Coupling
Valve Installation - Trailer
Hose Installation - Trailer
Hydraulic Valve - Center Frame
Hydraulic Valve
Boom Block - Hydraulic Hoses
Mainfold Assembly - Cylinder
Hydraulic Tank Assembly
Suction Line - Hydraulic Tank
Pump Assembly - Service Parts
Pump - 45 Cc
Hydraulic Pump - Tube Assembly Ls
Hose Installation - Spray Pump
Manifold Assembly - Front
Tube Assembly - Chassis
Manifold Assembly - Rear
Hose Installation - Drive
Hose Installation - Suspension
Hose Installation - Suspended
Tube Assembly - Drive, 85cc
Hose Installation - Radiator
Hose Installation - Hitch Cilinder
Lift Arm - Cylinder
Balancer - Cylinders
Hose Installation - Brake Assembly
Hose Installation - Pedal Brake
Brake Valve - Accumulator And Valve
Ram - Tilting
Boom Fold Assembly - Cylinder
Boom Folding 3m - Cylinder 24 Meter
Hose Installation - Steering
Hose Installation - Orbitrol
Hydraulic Lines - 24 12 M
Hydraulic Lines - Xx 15 M
Hydraulic Lines - Xx 18 M
Auxiliary Hydraulics - Valve - Mat
Harness - Chassis
Harness - Battery
Battery - Installation
Electrical Components - Installation
Center Frame - Harness
Harness Steering
Road Lights
Tail Light Rear Assembly
Worklight
Light Group - Cab
Worklight Installation - Cabin
Worklight Installation - Boomrest
Worklight - Rear
Work Light - 2 Fold
Worklights Control Center And Injector
Beacon Amber
Light Group - Beacon
Camera - Drawbar And Hitch
Camera - Center Frame
Auxiliary Hydraulics - Control Part
Mounting Plate - Bottom
Windscreen Wash-Inst - Pump
Antenna - N-Trip
Radio
Structure - Vision Cab
Roof - Lower
Glass - Rear
Glass - Common
Glass Door Assembly
Floor Mat - Group
Headliner Group
Air Conditioner And Heater - Auto Temp Control
Mirror - Group
Sun-Shield Assy - Front
Sun-Shield Assy - Back
Wiper Group - Front
Washer Assembly - Group
Light Group - Cab Interior
Group - Cab Harness
Module Assembly, Gateway
Satellite Radio - Antenna
Antenna Group - Radio
No Radio - Group
Radio Speaker Group - Deluxe
Seat - Base
Storage - Left Hand
Interior - Trim Group
Storage - Right Hand
Trim Group, Cab - Back
Mounting Group - Operator Cab Seat Assembly
Seat Group, Operator - Grammer
Seat Group - Instructor Seat
Cooler Group
Terminal - Display
Monitor Assembly - Nt01
Mounting Group - Nt01
Console Installation - Group
Armrest - Group
Armrest - Support Bracket
Armrest
Steering Column Assembly
A C Group - Hose Installation
Heater - Hoses
Fender - 2.55 Meter
Fender - 3.00 Meter
Fender - Assembling Parts
Fender Support Assembly - Front
Bumper - Front
Storage Box - Staircase
Storage Box - Chemicals
Storage Box - Cabin
Cover - Engine
Cover - Cooler
Cover - Wheel
Decals - Tank
Safety - Decals
Track Width - Wheels
Product Containment
Tank Installation - Outside
Tank - Lid
Tank - Bulkhead
Fuel Tank Cover - Seal
Tank Installation - Inside
Tank - Rinse Assembly, With Pressure Washer
Tank Installation - Nozzle Assembly
Tank Installation - Mixing Chamber Installation
Level Indicator - Tank
Clean Water Tank - Level Indicator Assembly
Tank Water Dual - Installation
Primary Product Distribution
Valve - 5 Way Manual
5 Way - 2 Inch
Valve - 5 Way Electric
5 Way - 2 Inch Electric
5 Way - 2 Inch Electric Stainless Steel
Plumbing Assembly - Reload
Valve Installation - Transfer
3 Inch Ball Valve Assembly - Standard Port Ball Valves
Adapter Assembly Camlock - 3 Inch
Plumbing Assembly - Press 3 Inch
2 Way - Valve - Fast Discharge
Strainer - Full Port Flange W 80 Mesh
Adapter Assembly 3 Inch - No Self Priming
Strainer - Manifold 12 Mesh
Strainer - Manifold
Strainer - Reload
Tank Filling - Quick Attach Installation
Pump Centrifugal
Pump Centrifugal - 3.00 X 2.00 9306s Stainless Steel
Pump Centrifugal - 3.00 X 2.00 9306c
Autofill Assembly - Ecomatic
Flow Meter Assembly - Standard Flow
Suction Pipe - 2 Inch
Hose Suction Assembly - 2 Inch
Suction Pipe - 3 Inch
Hose Suction Assembly - 3 Inch
Adapter Assembly - Self Priming
Adapter Assembly - No Extern Fast Fill
Plumbing Suction - 2 Inch
Plumbing Suction - 3 Inch
Chemical Eductor Plumbing - Manual
Chemical Eductor Plumbing - Electrical
Chemical Eductor Installation - Transfer
Chemical Eductor - Handgun Option
Secondary Product Distribution
Plumbing Assembly - 24 12 M
Plumbing Assembly - 24 18 M
Plumbing Assembly - 27 18 M
Plumbing Assembly - 27 15 M
Plumbing Assembly - 28 15 M
Plumbing Assembly - 28 18 M
Plumbing Assembly - 30 15 M
Plumbing Assembly - 30 18 M
Plumbing Assembly - 32 18 M
Plumbing Assembly - 33 18 M
Plumbing Assembly - 36 18 M
E Nozzle - 24 12 M
E Nozzle - 24 18 M
E Nozzle - 27 15 M
E Nozzle - 27 18 M
E Nozzle - 28 15 M
E Nozzle - 28 18 M
E Nozzle - 30 15 M
E Nozzle - 30 18 M
E Nozzle - 32 18 M
E Nozzle - 33 18 M
E Nozzle - 36 18 M
E Nozzle 2 + 2 - Installation
E Nozzle 2 Way - Installation
E Nozzle 3 Way - Installation
E Nozzle 4 Way - Installation
E Nozzle 5 Way - Installation
Battery Booster
Arag - 24 12 M
Arag - 24 18 M
Arag - 27 15 M
Arag - 27 18 M
Arag - 28 15 M
Arag - 28 18 M
Arag - 30 15 M
Arag - 30 18 M
Arag - 32 18 M
Arag - 33 18 M
Arag - 36 18 M
Plumbing Central Frame - 2 Fold
Plumbing Assembly - Middle
Plumbing Assembly - High Flow
Manifold Assembly - Recirculation
Plumbing Assembly - Boom Folding 1.5m
Hose Guide Assembly - 2 Fold
Plumbing Assembly 5 Way - Boom Folding 3m
Plumbing Assembly 2+2 Way - Boom Folding 3m
Endrow Plug - Aluminium
Endrow Nozzle - Options
Booms
Lift Installation
Center Frame - Until 30 M
Center Frame - From 30 M
Triangle Assembly
Stabiliser Bar - Reinforcement
Stabiliser Bar
Boomstop Assembly
Cover - Middle
Cover - Sensor
Cover Inside
Balancer - Installation Sensor
Support Bracket - Hose
Bracket Boom Support
Bracket Boom Support - 24 12 M
Bracket Boom Support - 27, 28, 30m
Bracket Boom Support - Boom Folding 3m
Bracket Installation - 28 15 M
Breakaway Section - 2 Fold
Yoke Assembly - Until 30 M
Yoke Assembly - From 30 M
Boom Installation - 2 Fold
Boom Assembly - 24 12 M Tr 4 R Lh
Boom Assembly - 24 12 M Tr 4 R Rh
Boom Assembly - 24 18 M Tr 4 R Lh
Boom Assembly - 24 18 M Tr 4 R Rh
Boom Assembly - 27 18 M Tr 4 R Lh
Boom Assembly - 27 18 M Tr 4 R Rh
Boom Assembly - 27 15 M Tr 4 R Lh
Boom Assembly - 27 15 M Tr 4 R Rh
Boom Assembly - 28 18 M Tr 4 R Lh
Boom Assembly - 28 18 M Tr 4 R Rh
Boom Assembly - 28 15 M Tr 4 R Lh
Boom Assembly - 28 15 M Tr 4 R Rh
Boom Assembly - 30 18 M Tr 4 R Lh
Boom Assembly - 30 18 M Tr 4 R Rh
Boom Assembly - 30 15 M Tr 4 R Lh
Boom Assembly - 30 15 M Tr 4 R Rh
Boom Assembly - 32 18 M Tr 4 R Lh
Boom Assembly - 32 18 M Tr 4 R Rh
Boom Assembly - 33 18 M Tr 4 R Lh
Boom Installation - 33 18 M Tr 4 R Rh
Boom Assembly - 36 18 M Tr 4 R Lh
Boom Assembly - 36 18 M Tr 4 R Rh
Boom Position Indicator - 2 Fold
Protection - 2 Fold
Ground Touch Sensor - 2 Fold
Boom Folding 3m - Assembly Lh
Boom Folding 3m - Assembly Rh
Boom Folding 1.5m - Assembly
Country Specs
Reflector - Rear
Reflector - Side
Novatel
Trimble - Harness
Reeler Hose Air - Zeca 15 Mm
Water Reeler - Cleaning
Warning Wide Load - Eu
Sign Installation, Slow Moving Vehicle
Hitch - Manual
Hitch - Automatic
License Plate Bracket Installation
Light Installation - Track Width 2.55
Wheel Chock Installation
Suitcase - Spare Parts
Brand: Fendt
Engine Assemblies
Valve Rocker Cover
Intake Manifold
Oil Pump And Sump
Fuel Filters
Air Compressor
Engine Gasket Kits
Engine Installation
Overview - Filters
Hvac Group - Cat 4
Coupler - 145 Cc
Eat Installation
Tank Assembly - Def
Dosing Module - Def
Wheel Arm
Battery - Box
Lock Tank Front
Piping - Steering
Air System
Air - Tank
Hydraulic Valve
Pump - 45 Cc
Lift Arm - Cylinder
Ram - Tilting
Harness - Chassis
Harness - Battery
Harness Steering
Road Lights
Worklight
Light Group - Cab
Worklight - Rear
Work Light - 2 Fold
Beacon Amber
Antenna - N-Trip
Radio
Roof - Lower
Glass - Rear
Glass - Common
Glass Door Assembly
Floor Mat - Group
Headliner Group
Mirror - Group
Wiper Group - Front
Group - Cab Harness
No Radio - Group
Seat - Base
Storage - Left Hand
Cooler Group
Terminal - Display
Armrest - Group
Armrest
Heater - Hoses
Fender - 2.55 Meter
Fender - 3.00 Meter
Bumper - Front
Storage Box - Cabin
Cover - Engine
Cover - Cooler
Cover - Wheel
Decals - Tank
Safety - Decals
Product Containment
Tank - Lid
Tank - Bulkhead
5 Way - 2 Inch
Strainer - Manifold
Strainer - Reload
Pump Centrifugal
E Nozzle - 24 12 M
E Nozzle - 24 18 M
E Nozzle - 27 15 M
E Nozzle - 27 18 M
E Nozzle - 28 15 M
E Nozzle - 28 18 M
E Nozzle - 30 15 M
E Nozzle - 30 18 M
E Nozzle - 32 18 M
E Nozzle - 33 18 M
E Nozzle - 36 18 M
Battery Booster
Arag - 24 12 M
Arag - 24 18 M
Arag - 27 15 M
Arag - 27 18 M
Arag - 28 15 M
Arag - 28 18 M
Arag - 30 15 M
Arag - 30 18 M
Arag - 32 18 M
Arag - 33 18 M
Arag - 36 18 M
Booms
Lift Installation
Triangle Assembly
Stabiliser Bar
Boomstop Assembly
Cover - Middle
Cover - Sensor
Cover Inside
Protection - 2 Fold
Country Specs
Reflector - Rear
Reflector - Side
Novatel
Trimble - Harness
Hitch - Manual
Hitch - Automatic
