Fendt Sprayer 645 Rogator Parts Catalog FR645MY2018 2018
Brand: Fendt
Type of Machine: Sprayer
Model: Fendt 645 Rogator 2018
Serial Number: XRRF0645XJV001001-XRRF0645XJV001099
Year of Manufacture: 2018
Number of Pages: 1031 Pages
Overview - Filters
Oil Cooler And Filter
Hose Installation - Fuel Group
Fuel Filters
Electronic Engine Management
Fuel Filter - Water Separator
Exhaust Aftertreatment
Hydraulic Pump - 145 Cc
Components Installation - Air System
Hydraulic - Tank Assembly
Hvac Group - Cat 4
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Starter Motor
Crankshaft And Pistons
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Oil Pump And Sump
Coolant Pump And Thermostat
Fuel Injection System
Grill Assembly - Cooler
Cooler - Combi-Instrument
Insulation - Exhaust Installation
Engine Mounting Group - 7.4 Liter
Coupler - 145 Cc
Cooler Group - 7.4 Liter
Tube Assembly - Coolant
Hose Installation - Cooler
Dipstick - 7.4 Liter
Closed Crankcase Ventilation (Ccv) - 7.4 Liter
Coupler Assembly - 7.4 Liter
Air Intake Group - 7.4 Liter
Exhaust Group - 7.4 Liter
Exhaust Group - Sensor
Tube Assembly - Exhaust
Eat Installation - 7.4 Liter
Dosing Module - Def
Pump Installation - Def
Hose Installation - Def
Tank Assembly - Def
Air Compressor
Air Conditioning Compressor
Engine Overhaul Parts
Special Overhaul Parts
Track Width - Installation
Axle Installation - 85 Cc
Wheel Arm
Bracket - Axle Installation
Cover Installation - Wheel
Plate Installation - Hoses
Sensor Assembly - Axle
Frame And Suspension
Bottom - Plate
Fender Support Assembly
Engine - Cover Plate
Battery - Box
Lock Tank Front
Support Bracket - Cabin
Suspension Assembly - Unit
Suspension Unit - Lf Rr
Suspension Unit - Rf Lr
Cylinder - Suspension
Cylinder - Suspension Assembly Front
Cylinder - Suspension Assembly Rear
Orbitrol - Installation
Steering Cylinder - Installation
Steering - Hose Installation
Steering - Axle Installation
Steering - Tube Assembly
Piping - Steering
Hydraulic Pump - Installation
Hydraulic Motor - 85 Cc
Gearbox Assembly - Gft 8130
Transmission - Gft 8130
Brake Pedal - Valve Installation
Air System
Air System - With Trailer Brake
Air System - Without Trailer Brake
Air System - Air Dryer
Air - Tank
Valve Installation - Pressure Control
Trailer - Hose Installation
Coupler Assembly - Trailer Brake
Valve Installation - Brake Valve
Valve Installation - Quick Coupling
Valve Installation - Trailer
Hose Installation - Trailer
Boom Center - Pommier
Hydraulic Installation - Pommier
Hydraulic Block - Boom Block
Valve Installation - Norac
Boom Block - Tubes And Hoses
Mainfold Assembly - Cylinder
Balancer - Cylinder
Hydraulic Cylinder - Tilting
Hydraulic Tank Assembly
Suction Line - Hydraulic Tank
Pump Assembly - Service Parts
Pump - 45 Cc
Brake Valve - Accumulator And Valve
Hydraulic Pump - Tube Assembly Ls
Manifold Assembly - Front
Manifold Assembly - Rear
Tube Assembly - Drive, 85cc
Hose Installation - Drive
Tube Assembly - Chassis
Hose Installation - Suspension
Hose Installation - Suspended
Hose Installation - Boom Block
Hose Installation - Spray Pump
Hose Installation - Fan
Hose Installation - Oil Cooler
Hose Installation - Hitch Cilinder
Hose Installation - Brake Assembly
Hose Installation - Pedal Brake
Boom Fold Assembly - Cylinder
Boom Folding 3m - Cylinder 24 Meter
Hydraulic Lines - 24 12 M
Hydraulic Lines - Xx 15 M
Hydraulic Lines - Xx 18 M
Hose Installation - Steering
Hose Installation - Orbitrol
Hydraulic Block - Boom Center
Lift Arm - Cylinder
Harness - Chassis
Harness - Battery
Battery - Installation
Computer Harness - Installation
Center Frame - Harness
Harness Steering
Road Lights
Tail Light Rear Assembly
Worklight Installation - Cabin
Worklight Installation - Boomrest
Work Light - 2 Fold
Worklights Control Center And Injector
Worklight - Rear
Light Group - Beacon
Worklight
Light Group - Cab
Beacon Amber
Camera - Drawbar And Hitch
Camera - Center Frame
Mounting Plate - Bottom
Windscreen Wash-Inst - Pump
Radio
Structure - Vision Cab
Roof - Lower
Glass - Rear
Glass - Common
Glass Door Assembly
Floor Mat - Group
Headliner Group
Air Conditioner And Heater - Auto Temp Control
Mirror - Group
Sun-Shield Assy - Front
Sun-Shield Assy - Back
Wiper Group - Front
Washer Assembly - Group
Light Group - Cab Interior
Group - Cab Harness
Module Assembly, Gateway
Antenna - N-Trip
Satellite Radio - Antenna
Antenna Group - Radio
No Radio - Group
Radio Speaker Group - Deluxe
Seat - Base
Storage - Left Hand
Storage - Right Hand
Interior - Trim Group
Trim Group, Cab - Back
Mounting Group - Operator Cab Seat Assembly
Seat Group, Operator - Grammer
Seat Group - Instructor Seat
Cooler Group
Terminal - Display
Mounting Group - Nt01
Console Installation - Group
Armrest - Group
Armrest - Support Bracket
Armrest
Monitor Assembly - Nt01
Steering Column Assembly
A C Group - Hose Installation
Heater - Hoses
Fender - 2.55 Meter
Fender - 3.00 Meter
Fender - Assembling Parts
Fender Support Assembly - Front
Storage Box - Staircase
Storage Box - Chemicals
Cover - Engine
Bumper - Front
Cover - Cooler
Storage Box - Cabin
Cover - Wheel
Decals - Tank
Safety - Decals
Track Width - Wheels
Product Containment
Tank Installation - Inside
Tank Installation - Outside
Tank Water Dual - Installation
Clean Water Tank - Level Indicator Assembly
Tank Installation - Nozzle Assembly
Tank - Rinse Assembly, With Pressure Washer
Tank - Lid
Fuel Tank Cover - Seal
Tank - Bulkhead
Level Indicator - Tank
Tank Installation - Mixing Chamber Installation
Primary Product Distribution
Valve - 5 Way Electric
Plumbing Assembly - Reload
Plumbing Assembly - Press 3 Inch
2 Way - Valve - Fast Discharge
Strainer - Full Port Flange W 80 Mesh
Adapter Assembly 3 Inch - No Self Priming
Valve - 5 Way Manual
5 Way - 2 Inch
5 Way - 2 Inch Electric
5 Way - 2 Inch Electric Stainless Steel
Strainer - Manifold 12 Mesh
Strainer - Manifold
Valve Installation - Transfer
Adapter - 3 Inch
Strainer - Reload
Adapter Assembly Camlock - 3 Inch
Tank Filling - Quick Attach Installation
Pump Centrifugal - 3.00 X 2.00 9306c
Pump Centrifugal - 3.00 X 2.00 9306s Stainless Steel
Autofill Assembly - Ecomatic
Flow Meter Assembly - Standard Flow
3 Inch Ball Valve Assembly - Standard Port Ball Valves
Hose Suction Assembly - 3 Inch
Suction Pipe - 3 Inch
Adapter Assembly - No Extern Fast Fill
Adapter Assembly - Self Priming
Plumbing Suction - 2 Inch
Plumbing Suction - 3 Inch
Chemical Eductor Plumbing - Transfer
Nozzle Assembly - Rinse Bottle
Chemical Eductor Installation - Transfer
Chemical Eductor - Handgun Option
Secondary Product Distribution
Plumbing Assembly - 24 12 M
Plumbing Assembly - 24 18 M
Plumbing Assembly - 27 15 M
Plumbing Assembly - 27 18 M
Plumbing Assembly - 28 15 M
Plumbing Assembly - 28 18 M
Plumbing Assembly - 30 15 M
Plumbing Assembly - 30 18 M
Plumbing Assembly - 32 18 M
Plumbing Assembly - 33 18 M
Plumbing Assembly - 36 18 M
E Nozzle 2 + 2 - 24 12 M
E Nozzle 2 + 2 - Installation
E Nozzle 2 + 2 - 24 18 M
E Nozzle 2 + 2 - 27 15 M
E Nozzle 2 + 2 - 27 18 M
E Nozzle 2 + 2 - 28 15 M
E Nozzle 2 + 2 - 28 18 M
E Nozzle 2 + 2 - 30 15 M
E Nozzle 2 + 2 - 30 18 M
E Nozzle 2 + 2 - 32 18 M
E Nozzle 2 + 2 - 33 18 M
E Nozzle 2 + 2 - 36 18 M
E Nozzle 2 Way - 24 12 M
E Nozzle 2 Way - Installation
E Nozzle 2 Way - 24 18 M
E Nozzle 2 Way - 27 15 M
E Nozzle 2 Way - 27 18 M
E Nozzle 2 Way - 28 15 M
E Nozzle 2 Way - 28 18 M
E Nozzle 2 Way - 30 15 M
E Nozzle 2 Way - 30 18 M
E Nozzle 2 Way - 32 18 M
E Nozzle 2 Way - 33 18 M
E Nozzle 2 Way - 36 18 M
E Nozzle 5 Way - 24 12 M
E Nozzle 5 Way - Installation
E Nozzle 5 Way - 24 18 M
E Nozzle 5 Way - 27 15 M
E Nozzle 5 Way - 27 18 M
E Nozzle 5 Way - 28 15 M
E Nozzle 5 Way - 28 18 M
E Nozzle 5 Way - 30 15 M
E Nozzle 5 Way - 30 18 M
E Nozzle 5 Way - 32 18 M
E Nozzle 5 Way - 33 18 M
E Nozzle 5 Way - 36 18 M
Arag - 24 12 M
Arag - 24 18 M
Arag - 27 15 M
Arag - 27 18 M
Arag - 28 15 M
Arag - 28 18 M
Arag - 30 15 M
Arag - 30 18 M
Arag - 32 18 M
Arag - 33 18 M
Arag - 36 18 M
Valve Electric - 1.00 Inch
Plumbing Central Frame - 2 Fold
Plumbing Assembly - Middle
Hose Guide Assembly - 2 Fold
Plumbing Assembly - High Flow
Plumbing Assembly - Boom Folding 1.5m
Plumbing Assembly 2 Way - Boom Folding 3m
Plumbing Assembly 5 Way - Boom Folding 3m
Bracket Boom Support - 27, 28, 30m
Manifold Assembly - Recirculation
Endrow Plug - Aluminium
Endrow Nozzle - Options
Booms
Center Frame - Balance Cylinder
Center Frame - Shock Absorber
Stabiliser Bar - Reinforcement
Triangle Assembly - Center Frame
Stabiliser Bar
Cover - Middle
Cover - Sensor
Cover Inside
Balancer - Installation Sensor
Support Bracket - Hose
Boom Sensor Assembly - Bracket
Boomstop Assembly
Sensors - Hc 5
Bracket Boom Support - 24 12 M
Bracket Boom Support - Boom Folding 3m
Bracket Installation - 28 15 M
Lift Installation
Breakaway Section - 2 Fold
Yoke Assembly - Installation
Yoke Assembly - Until 30 M
Boom Installation - 2 Fold
Boom Assembly - 24 12 M Tr 4 R Lh
Boom Assembly - 24 12 M Tr 4 R Rh
Boom Assembly - 24 18 M Tr 4 R Lh
Boom Assembly - 24 18 M Tr 4 R Rh
Boom Assembly - 27 15 M Tr 4 R Lh
Boom Assembly - 27 15 M Tr 4 R Rh
Boom Assembly - 27 18 M Tr 4 R Lh
Boom Assembly - 27 18 M Tr 4 R Rh
Boom Assembly - 28 15 M Tr 4 R Lh
Boom Assembly - 28 15 M Tr 4 R Rh
Boom Assembly - 28 18 M Tr 4 R Lh
Boom Assembly - 28 18 M Tr 4 R Rh
Boom Assembly - 30 15 M Tr 4 R Lh
Boom Assembly - 30 15 M Tr 4 R Rh
Boom Assembly - 30 18 M Tr 4 R Lh
Boom Assembly - 30 18 M Tr 4 R Rh
Boom Assembly - 32 18 M Tr 4 R Lh
Boom Assembly - 32 18 M Tr 4 R Rh
Boom Assembly - 33 18 M Tr 4 R Lh
Boom Installation - 33 18 M Tr 4 R Rh
Boom Assembly - 36 18 M Tr 4 R Lh
Boom Assembly - 36 18 M Tr 4 R Rh
Protection - 2 Fold
Norac - Components
Boom Position Indicator - 2 Fold
Sensors - Hc 3
Boom Sensor - Hc 3
Boom Sensor - Hc 5
Harness Installation - Norac
Norac - Harness
Boom Folding 3m - Assembly Lh
Boom Folding 3m - Assembly Rh
Boom Folding 1.5m - Assembly
Country Specs
Reflector - Rear
Reflector - Side
Water Reeler - Cleaning
Reeler Hose Air - Zeca 15 Mm
Warning Wide Load - Eu
Sign Installation, Slow Moving Vehicle
Drawbar Hitch - Manual
Drawbar And Hitch - Hitch Installation
License Plate Bracket Installation
Light Installation - Track Width 2.55
Nozzle
Wheel Chock Installation
Trimble - Harness
Novatel
Connector - Service Kit
Suitcase - Spare Parts
Recommended Dealer List - Basic
Recommended Dealer List - Advanced
