Fendt Sprayer 355 366 Rogator Parts Catalog FR355366MY2019 2019
Brand: Fendt
Type of Machine: Sprayer
Model: Fendt 355, 366 Rogator 2019
Serial Number: XRRF03XXXKV001001-XRRF03XXXKV001072
Year of Manufacture: 2019
Number of Pages: 492 Pages
Axle Installation - Fixed
Axle Installation - Steering
Track Width - From 1.50 M Until 1.80 M
Track Width - From 1.90 M Until 2.25 M
Frame And Suspension
Fender Support Assembly
Boom Support
Support Platform
Bottom Plate
Drawbar And Hitch
Drawbar And Hitch - Trailer Coupler
Drawbar And Hitch - Drawbar Hitch
Support Beam - Cylinder
Bracket - Fixed
Bracket - Bearing Kingpin
Bearing - Kit Linear King Pin
Steering - From 1.50 M Until 1.80 M
Steering - From 1.80 M Until 2.25 M
Driveshaft - Pto
Drive Shaft - Cover
Driveshaft - Support
Pto - Drive Bearing Support
Air - Installation
Brake Booster
Valve - Mat - Air
Valve - Mat - Load-Dependent
Brake System - Hydraulic
Spindle Cable Brake
Spindle Cable Brake - France
Air System
Air - Tank
Pump - 85 Cc
Hydraulic Power Supply - Pto
Hydraulic Power Supply - Tube Assembly Ls
Hydraulic Power Supply - Tube Assembly Open Center
Steering - Tubes And Hoses
Support Beam - Manual Operating
Tractor - Tubes And Hoses
Tank - Fittings
Filter - Return
Support - Cylinder
Cooler - Installation
Valve Installation - Norac
Hydraulic Block - Boom Center
Hydraulic Block - Boom Block
Boom Center - Pommier
Boom Block - Tubes And Hoses
Lift Arm - Cylinder
Balancer - Cylinder
Mainfold Assembly - Cylinder
Yoke Assembly - Installation
Hydraulic Cylinder - Tilting
Boom Fold Assembly - Cylinder
Boom Folding 3m - Cylinder 24 Meter
Hydraulic Cooler - Aftermarket
Hydraulic Lines - 24 12 M
Hydraulic Lines - Xx 15 M
Harness - Chassis Long
Fuse Box - Fuse Box
Steering - Sensor
Product Tank - Sensor
Tank - Alarm
Cooler - Harness
Center Frame - Harness
Multi-Function Handle - Stand Alone
Iso Ready Wiring Group - Harness
Novatel
Tail Light Rear Assembly
Beacon Amber
Worklights Control Center And Injector
Work Light - 2 Fold
Rear View Camera
Rear View Camera - Center Frame
Rear View Camera - Monitor
Console - X 25
Platform
Storage - Right Hand
Storage - Left Hand
Cover - Right Hand Installation
Fender - 2.55 Meter
Fender - 3.00 Meter
Stickers - Tank Assembly
Safety - Decals
Safety - Decal
Track Width - Wheels
Product Containment
Tank Installation Inside - Assembly
Tank Installation Outside - 5500 L
Tank Installation Outside - 6600 L
Tank - Lid
Tank - Bulkhead
Tank - Rinse Assembly, With Pressure Washer
Tank Installation - Water Tank Front
Tank Water Dual - Installation
Tank Water Dual - Hose Assembly
Tank Water Dual - Level Indicator Assembly
Tank Installation - Mixing Chamber Installation
Tank Installation - Nozzle Assembly
Primary Product Distribution
Pump Centrifugal
Pump Centrifugal - 3.00 X 2.00 9306c
Pump Centrifugal - 3.00 X 2.00 9306s Stainless Steel
Valve - 5 Way Manual
Valve - 5 Way Electric
5 Way - 2 Inch
5 Way - 2 Inch Electric
5 Way - 2 Inch Electric Stainless Steel
Plumbing Suction - 2 Inch
2 Way - Valve - Fast Discharge
Hose Suction Assembly - 2 Inch
Valve Installation - Transfer
Plumbing Suction - 3 Inch
Plumbing Assembly - Press 3 Inch
Hose Suction Assembly - 3 Inch
Strainer - Full Port Flange W 80 Mesh
Flow Meter Assembly - Standard Flow
Plumbing Assembly - Reload
Suction Hose Assembly
3 Inch Ball Valve Assembly - Standard Port Ball Valves
Adapter Assembly - Self Priming
Adapter Assembly 3 Inch - No Self Priming
Strainer - Manifold 12 Mesh
Strainer - Manifold
Strainer - Reload
Tank Filling - Quick Attach Installation
Adapter Assembly - No Extern Fast Fill
Adapter Assembly Camlock - 3 Inch
Chemical Eductor Plumbing - Manual
Chemical Eductor Plumbing - Electrical
Chemical Eductor Installation - Transfer
Chemical Eductor - Handgun Option
Autofill Assembly - Ecomatic
Secondary Product Distribution
Plumbing Assembly - 24 12 M
Plumbing Assembly - 27 15 M
Plumbing Assembly - 28 15 M
Plumbing Assembly - 30 15 M
E Nozzle - 24 12 M
E Nozzle - 27 15 M
E Nozzle - 28 15 M
E Nozzle - 30 15 M
E Nozzle 2 + 2 - Installation
E Nozzle 2 Way - Installation
E Nozzle 4 Way - Installation
E Nozzle 5 Way - Installation
Battery Booster
Arag - 24 12 M
Arag - 27 15 M
Arag - 28 15 M
Arag - 30 15 M
Plumbing Central Frame - 2 Fold
Plumbing Assembly - Middle
Plumbing Assembly - High Flow
Manifold Assembly - Recirculation
Valve Electric - 1.00 Inch
Hose Guide Assembly - 2 Fold
Endrow Plug - Aluminium
Endrow Nozzle - Options
Booms
Lift Installation - Until 30 M
Center Frame - Until 28 M
Stabiliser Bar - Reinforcement
Stabiliser Bar
Cover - Middle
Cover - Sensor
Balancer - Installation Sensor
Cover Inside
Center Frame - Balance Cylinder
Triangle Assembly - Until 30 M
Support Bracket - Hose
Boom Sensor - Hc 3
Sensors - Hc 3
Boom Sensor Assembly - Bracket
Harness Installation - Norac
Norac - Components
Norac - Harness
Boom Sensor - Hc 5
Sensors - Hc 5
Boomstop Assembly
Boom Position Indicator - 2 Fold
Bracket Boom Support - 24 M
Bracket Boom Support - From 24 M
Breakaway Section - 2 Fold
Bracket Installation - 28 15 M
Boom Installation - 2 Fold
Boom Assembly - 24 12 M Tr 4 R Lh
Boom Assembly - 24 12 M Tr 4 R Rh
Boom Assembly - 27 15 M Tr 4 R Lh
Boom Assembly - 27 15 M Tr 4 R Rh
Boom Assembly - 28 15 M Tr 4 R Lh
Boom Assembly - 28 15 M Tr 4 R Rh
Boom Assembly - 30 15 M Tr 4 R Lh
Boom Assembly - 30 15 M Tr 4 R Rh
Protection - 2 Fold
Country Specs
Reeler Hose Air - Zeca 15 Mm
Air Hose Installation - Tank Reeler
Water Reeler - Cleaning
Warning Wide Load - Eu
Theft Protection
Sign Installation, Slow Moving Vehicle
Wheel Chock Installation
Connector - Service Kit
Brand: Fendt
Boom Support
Support Platform
Bottom Plate
Drawbar And Hitch
Bracket - Fixed
Driveshaft - Pto
Drive Shaft - Cover
Air - Installation
Brake Booster
Valve - Mat - Air
Spindle Cable Brake
Air System
Air - Tank
Pump - 85 Cc
Tank - Fittings
Filter - Return
Support - Cylinder
Lift Arm - Cylinder
Balancer - Cylinder
Fuse Box - Fuse Box
Steering - Sensor
Tank - Alarm
Cooler - Harness
Novatel
Beacon Amber
Work Light - 2 Fold
Rear View Camera
Console - X 25
Platform
Storage - Left Hand
Fender - 2.55 Meter
Fender - 3.00 Meter
Safety - Decals
Safety - Decal
Product Containment
Tank - Lid
Tank - Bulkhead
Pump Centrifugal
5 Way - 2 Inch
Strainer - Manifold
Strainer - Reload
E Nozzle - 24 12 M
E Nozzle - 27 15 M
E Nozzle - 28 15 M
E Nozzle - 30 15 M
Battery Booster
Arag - 24 12 M
Arag - 27 15 M
Arag - 28 15 M
Arag - 30 15 M
Booms
Stabiliser Bar
Cover - Middle
Cover - Sensor
Cover Inside
Boom Sensor - Hc 3
Sensors - Hc 3
Norac - Components
Norac - Harness
Boom Sensor - Hc 5
Sensors - Hc 5
Boomstop Assembly
Protection - 2 Fold
Country Specs
Theft Protection
