Fendt Sprayer 344 355 366 Rogator Parts Catalog FR300MY2020 2020
Brand: Fendt
Type of Machine: Sprayer
Model: Fendt 344, 355, 366 Rogator 2020
Serial Number: XRRF03XXXLV001001-999999
Year of Manufacture: 2020
Number of Pages: 526 Pages
Axle Installation - Fixed
Axle Installation - Steering
Track Width - From 1.50 M Until 1.80 M
Track Width - From 1.90 M Until 2.25 M
Track Width - Axle With Suspension
Frame And Suspension
Fender Support Assembly
Boom Support
Support Platform
Bottom Plate
Locking Kit - Chemical Eductor
Drawbar And Hitch
Drawbar And Hitch - Trailer Coupler
Drawbar And Hitch - Drawbar Hitch
Bracket - Fixed
Bracket - Bearing Kingpin
Bearing - Kit Linear King Pin
Steering - From 1.50 M Until 1.80 M
Steering - From 1.80 M Until 2.25 M
Driveshaft - Pto
Drive Shaft - Cover
Driveshaft - Support
Pto - Drive Bearing Support
Air - Installation
Brake Booster
Valve - Mat - Air
Valve - Mat - Load-Dependent
Brake System - Hydraulic
Spindle Cable Brake
Spindle Cable Brake - France
Air System
Air - Tank
Pump - 85 Cc
Hydraulic Power Supply - Pto
Hydraulic Power Supply - Tube Assembly Ls
Hydraulic Power Supply - Tube Assembly Open Center
Steering - Tubes And Hoses
Support Beam - Manual Operating
Support Beam - Cylinder
Support - Cylinder
Tractor - Tubes And Hoses
Tank - Fittings
Filter - Return
Cooler - Installation
Hydr. Connect. - Axle With Suspension
Hydraulic Valve - Center Frame
Hydraulic Valve
Boom Block - Hydraulic Hoses
Lift Arm - Cylinder
Balancer - Cylinders
Mainfold Assembly - Cylinder
Ram - Tilting
Boom Fold Assembly - Cylinder
Boom Folding 3m - Cylinder 24 Meter
Hydraulic Cooler - Aftermarket
Hydraulic Lines - 24 12 M
Hydraulic Lines - Xx 15 M
Hydraulic Lines - 36 24 12 M
Harness - Chassis Short
Harness - Chassis Long
Fuse Box - Wire Harness
Steering - Sensor
Product Tank - Sensor
Tank Installation - Sensor
Tank - Alarm
Cooler - Harness
Center Frame - Harness
Multi-Function Handle - Stand Alone
Iso Ready Wiring Group - Harness
Novatel
Tail Light Rear Assembly
Beacon Amber
Worklights Control Center And Injector
Work Light - 2 Fold
Work Light - 3 Fold
Rear View Camera
Rear View Camera - Center Frame
Rear View Camera - Monitor
Console - X 25
Platform
Mounting Unit - Left Hand
Mounting Unit - Right Hand
Cover - Right Hand Installation
Fender - 2.55 Meter
Fender - 3.00 Meter
Decals - Tank Assembly
Safety - Decal
Safety - Decals
Track Width - Wheels
Product Containment
Tank Installation Inside - Assembly
Tank Installation Outside - 4400 L
Tank Installation Outside - 5500 L
Tank Installation Outside - 6600 L
Tank - Lid
Tank - Bulkhead
Tank - Rinse Assembly, With Pressure Washer
Tank Installation - Mixing Chamber Installation
Tank Installation - Nozzle Assembly
Tank Installation - Water Tank Front
Tank Water Dual - Installation
Tank Water Dual - Hose Assembly
Tank Water Dual - Level Indicator Assembly
Primary Product Distribution
Valve - 5 Way Manual
5 Way - 2 Inch
Valve - 5 Way Electric
5 Way - 2 Inch Electric
5 Way - 2 Inch Electric Stainless Steel
Plumbing Assembly - Reload
Valve Installation - Transfer
3 Inch Ball Valve Assembly - Standard Port Ball Valves
Adapter Assembly Camlock - 3 Inch
Plumbing Assembly - Press 3 Inch
2 Way - Valve - Fast Discharge
Strainer - Full Port Flange W 80 Mesh
Adapter Assembly 3 Inch - No Self Priming
Strainer - Manifold 12 Mesh
Strainer - Manifold
Strainer - Reload
Tank Filling - Quick Attach Installation
Pump Centrifugal
Pump Centrifugal - 3.00 X 2.00 9306c
Pump Centrifugal - 3.00 X 2.00 9306s Stainless Steel
Autofill Assembly - Ecomatic
Flow Meter Assembly - Standard Flow
Suction Hose Assembly
Hose Suction Assembly - 2 Inch
Hose Suction Assembly - 3 Inch
Adapter Assembly - Self Priming
Adapter Assembly - No Extern Fast Fill
Plumbing Suction - 2 Inch
Plumbing Suction - 3 Inch
Chemical Eductor Plumbing - Manual
Chemical Eductor Plumbing - Electrical
Chemical Eductor Installation - Transfer
Chemical Eductor - Handgun Option
Secondary Product Distribution
Plumbing Assembly - 24 12 M
Plumbing Assembly - 27 15 M
Plumbing Assembly - 28 15 M
Plumbing Assembly - 30 15 M
Tube - 36 24 12 M
E Nozzle - 24 12 M
E Nozzle - 27 15 M
E Nozzle - 28 15 M
E Nozzle - 30 15 M
E Nozzle - 36 24 12 M
E Nozzle 2 + 2 - Installation
E Nozzle 2 Way - Installation
E Nozzle 3 Way - Installation
E Nozzle 4 Way - Installation
E Nozzle 5 Way - Installation
Battery Booster
Arag - 24 12 M
Arag - 27 15 M
Arag - 28 15 M
Arag - 30 15 M
Arag - 36 24 12 M
Plumbing Central Frame - 2 Fold
Plumbing Central Frame - 3 Fold
Plumbing Assembly - Middle
Plumbing Assembly - High Flow
Manifold Assembly - Recirculation
Hose Guide Assembly - 2 Fold
Hose Guide - 3 Fold
Endrow Plug - Aluminium
Endrow Nozzle - Options
Booms
Lift Installation - Until 30 M
Lift Installation - From 30 M
Center Frame - Until 30 M
Center Frame - From 30 M
Triangle Assembly
Stabiliser Bar - Reinforcement
Stabiliser Bar
Boomstop Assembly
Cover - Middle
Cover - Sensor
Cover Inside
Balancer - Installation Sensor
Support Bracket - Hose
Bracket Boom Support - 24 M
Bracket Boom Support - From 24 M
Bracket Boom Support - 3 Fold
Bracket Installation - 28 15 M
Breakaway Section - 2 Fold
Breakaway Section - 3 Fold
Yoke Assembly - 2 Fold
Yoke Assembly - 3 Fold
Boom Installation - 2 Fold
Boom Installation - 3 Fold
Boom Assembly - 24 12 M Tr 4 R Lh
Boom Assembly - 24 12 M Tr 4 R Rh
Boom Assembly - 27 15 M Tr 4 R Lh
Boom Assembly - 27 15 M Tr 4 R Rh
Boom Assembly - 28 15 M Tr 4 R Lh
Boom Assembly - 28 15 M Tr 4 R Rh
Boom Assembly - 30 15 M Tr 4 R Lh
Boom Assembly - 30 15 M Tr 4 R Rh
Boom Assembly - 36 24 12 M Lh
Boom Assembly - 36 24 12 M Rh
2nd Hinge - 3 Fold
Boom Position Indicator - 2 Fold
Boom Position Indicator - 3 Fold
Protection - 2 Fold
Protection - 3 Fold
Ground Touch Sensor - 2 Fold
Ground Touch Sensor - 3 Fold
Country Specs
Reeler Hose Air - Zeca 15 Mm
Air Hose Installation - Tank Reeler
Water Reeler - Cleaning
Warning Wide Load - Eu
Theft Protection
Sign Installation, Slow Moving Vehicle
Wheel Chock Installation
Connector - Service Kit
Brand: Fendt
Boom Support
Support Platform
Bottom Plate
Drawbar And Hitch
Bracket - Fixed
Driveshaft - Pto
Drive Shaft - Cover
Air - Installation
Brake Booster
Valve - Mat - Air
Spindle Cable Brake
Air System
Air - Tank
Pump - 85 Cc
Support - Cylinder
Tank - Fittings
Filter - Return
Hydraulic Valve
Lift Arm - Cylinder
Ram - Tilting
Steering - Sensor
Tank - Alarm
Cooler - Harness
Novatel
Beacon Amber
Work Light - 2 Fold
Work Light - 3 Fold
Rear View Camera
Console - X 25
Platform
Fender - 2.55 Meter
Fender - 3.00 Meter
Safety - Decal
Safety - Decals
Product Containment
Tank - Lid
Tank - Bulkhead
5 Way - 2 Inch
Strainer - Manifold
Strainer - Reload
Pump Centrifugal
Tube - 36 24 12 M
E Nozzle - 24 12 M
E Nozzle - 27 15 M
E Nozzle - 28 15 M
E Nozzle - 30 15 M
Battery Booster
Arag - 24 12 M
Arag - 27 15 M
Arag - 28 15 M
Arag - 30 15 M
Arag - 36 24 12 M
Hose Guide - 3 Fold
Booms
Triangle Assembly
Stabiliser Bar
Boomstop Assembly
Cover - Middle
Cover - Sensor
Cover Inside
2nd Hinge - 3 Fold
Protection - 2 Fold
Protection - 3 Fold
Country Specs
Theft Protection
