154
618,398
Fendt Round Baler Rotana 160 V COMBI Parts Catalog 4906992120 10.2020
Brand: Fendt
Type of Machine: Hay Equipment, Round Baler
Model: Fendt Rotana 160 V Combi
Publication Date: 10.2020
Number of Pages: 487 Pages
Drive System
Propeller Shaft - Overrunning
Universal Joint - Overrunning
Gear Box 540
Gear Box 540 - Spare Parts
Gear Box 540 - Drive Mechanism
Gear Box 1000
Gear Box 1000 - Drive Mechanism
Drive Mechanism - Chains, Gears
Drive Mechanism - Chain Tensioner
Belt
Belt Guide
Tailgate - Cylinder
Tailgate - Hose Connection
Tailgate - Shut-Of Cock
Roller With Net
Net Wrapping
Belt Tensioner - 180 Bar
Pick-Up - 7 13 Knives
Pick-Up - Hydraulic Block
Pick-Up - 17 25 Knives
Undercarriage - Front
Hydraulic Block
Undercarriage - Middle
Undercarriage Rear - Hydraulic Block
Undercarriage Rear - Bale Transfer Area
Undercarriage Rear - Film Clamping Device
Undercarriage Rear - Wrapping Table
Undercarriage Rear - Wrapping Frame
Undercarriage Rear - Assembling Parts
Indicator - Bale Diameter
Indicator - Bale Shape
Adaptors - Bale Shape
Wire Harness - Light
Harness - Work Lights
Wiring Harness - Work Lights
Harness - Round Baler
Control Console - Agco Pro
Adapter Cable - Agco Pro
Wiring Harness - Can - Tailgate
Wiring Harness - Bale Wrapper
Control Console - Control Unit
Control-Box
Sensors - Emergency Stop
Lubrication System
Central Chain Lubrication
Central Chain Lubrication - Pump
Bale Feeding System
Pick-Up 2,25 M - Frame
Pick-Up 2,25 M - Support Bracket
Pick-Up 2,25 M - Guards
Pick-Up 2,25 M - Bearing
Pick-Up 2,25 M - Tine Arm
Pick-Up 2,40 M - Frame
Pick-Up 2,40 M - Support Bracket
Pick-Up 2,40 M - Guards
Pick-Up 2,40 M - Bearing
Pick-Up 2,40 M - Tine Arm
Housing - Pick-Up 2,25 M
Housing - Pick-Up 2,40 M
Pickup Augers - Pick-Up 2,25 M
Pickup Augers - Pick-Up 2,40 M
Feed Auger Drive - Chain
Feed Auger Drive - Pick-Up 2,25 M
Feed Auger Drive - Pick-Up 2,40 M
Chain Tensioner
Rotor - 13 Knives
Rotor - 17 Knives
Rotor - 25 Knives
Scrapers - 13 Knives
Scrapers - 17 Knives
Scrapers - 25 Knives
Floor - 13 Knives
Floor - 17 Knives
Floor - 25 Knives
Floor - 17 25 Knives
Header - 13 Knives
Header - 17 Knives
Header - 25 Knives
Support Bracket - Knives
Roll Holders Movable - Pick-Up 2,25 M
Roll Holders Movable - Pick-Up 2,40 M
Guide Wheels 10 Pr
Bale Forming System
Roller Front - Lubricated
Roller Front - Grease Lines
Roller Rear - Lubricated
Roller Rear - Grease Lines
Roller With Net - Support Bracket
Roller With Net - Cover Sheet
Roller With Net - Propel
Binding System
Support For Net Roll
Support For Net Roll - Crank
Support For Net Roll - Brake Assembly
Support For Net Roll - Swivel Arm
Net Wrapping - Adaptors
Net Wrapping - Frame
Net Wrapping - Cutting Device
Net Wrapping - Net Length Regulation
Net Wrapping - Clamping Parts
Bale Wrapping System
Bale Wrapper - Frame
Bale Wrapper - Guide Wrapping Ring
Bale Wrapper - Drive Inside
Bale Wrapper - Drive External
Bale Wrapper - Chain
Bale Wrapper - Sensor Mount
Wrapping Table - Frame
Wrapping Table - Roller.
Wrapping Table - Belt
Wrapping Table - Pick-Up Landwheel
Wrapping Table - Transmission Parts
Film Clamping Device - Guards
Wrapping Ring
Stretcher Units
Hoop Guard - Right Hand
Hoop Guard - Left Hand
Axle
Air Brake - Brake Valve
Air Brake - Air Tank
Air Brake - Diaphrag.Accumulator
Hydraulic Brake Assy
Frame
Frame - Scrapers
Tailgate
Tailgate - Angle
Tailgate - Locking Kit
Arm
Arm - Kit, Pin
Arm - Spring
Arm - Locking Kit
Tie Rods
Tie Rods - Towing Eye
Tie Rods - Accessories Section
Retainer
Jack Assembly
Access - Ladder
Hoop Guard - Pick-Up
Protective Cover - Pickup Drive
Protective Housing
Protective Housing - Right Hand
Protective Housing - Left Hand
Protective Housing - Rear
Protective Cover - Basic Version
Protective Cover - Net Wrapping
Undercarriage Rear - Carrier
Undercarriage Rear - Fixing Parts
Undercarriage Rear - Retainer
Undercarriage Rear - Toolbox
Undercarriage Rear - Gears, Camera
Undercarriage Rear - Bracket
Undercarriage Rear - Cover Assembly
Undercarriage Rear - Adaptors
Undercarriage Rear - Protective Cover
Undercarriage Rear - Mud Guard
Undercarriage Rear - Warning Signs - Support Bracket
Undercarriage Rear - Frame
Label - Logo
Label - Function
Decals - Safety
Label - Safety
Stickers - Function
Stickers - Safety
Spindles And Wheels
Wheels - 620 55 R26,5
Wheels - 600 55-26.5
Immobilizer System
Wedge - Ng 53
Adapter Assembly - Rubber Mat
Roller 3. Table
Undercarriage Rear - Valve - Bale Rotation
Bale Tipper
Adaptor Usa - Universal Joint
Pick-Up
Dry Material
