Fendt Round Baler 4160V 4180V Parts Catalog 1764992120 01.2020
Brand: Fendt
Type of Machine: Hay Equipment, Round Baler
Model: Fendt 4160V, 4180V
Publication Date: 01.2020
Number of Pages: 468 Pages
Drive System
Propeller Shaft - Overrunning
Universal Joint - Overrunning
Propeller Shaft - Over-Run Clutch, Pin-Type Safety Clutch
Gear Box 540
Gear Box 540 - Spare Parts
Gear Box 540 - Drive Mechanism
Gear Box 1000
Gear Box 1000 - Drive Mechanism
Drive Mechanism - Chains, Gears
Drive Mechanism - Chain Tensioner
Belt
Belt Guide
Tailgate - Cylinder
Tailgate - Hose Connection
Tailgate - Shut-Of Cock
Roller With Net
Net Wrapping
Belt Tensioner - 180 Bar
Belt Tensioner - 140 Bar
Pick-Up - Without Knives
Pick-Up - 7 13 Knives
Pick-Up - 17 25 Knives
Pick-Up - Hydraulic Block
Pick-Up - Without Hydraulic Block
Indicator - Bale Diameter
Indicator - Bale Shape
Adaptors - Bale Shape
Lights
Light Harness
Wiring Harness
Control Console - Agco Pro
Adapter Cable - Agco Pro
Control Console - Agco Control
Adapter Cable - Agco Control
Lubrication System
Central Chain Lubrication
Central Chain Lubrication - Pump
Bale Feeding System
Pick-Up 2,00 M - Chassis
Pick-Up 2,00 M - Support Bracket
Pick-Up 2,00 M - Protection - Inertia Wheel
Pick-Up 2,00 M - Bearing
Pick-Up 2,00 M - Tine Arm
Pick-Up 2,25 M - Frame
Pick-Up 2,25 M - Support Bracket
Pick-Up 2,25 M - Protection - Inertia Wheel
Pick-Up 2,25 M - Bearing
Pick-Up 2,25 M - Tine Arm
Pick-Up 2,40 M - Frame
Pick-Up 2,40 M - Support Bracket
Pick-Up 2,40 M - Guards
Pick-Up 2,40 M - Bearing
Pick-Up 2,40 M - Tine Arm
Case Assembly - Pick-Up 2,00 M
Housing - Pick-Up 2,25 M
Housing - Pick-Up 2,40 M
Pickup Augers - Pick-Up 2,00 M
Pickup Augers - Pick-Up 2,25 M
Pickup Augers - Pick-Up 2,40 M
Feed Auger Drive - Chain
Feed Auger Drive - Pick-Up 2,00 M
Feed Auger Drive - Pick-Up 2,25 M
Feed Auger Drive - Pick-Up 2,40 M
Chain Tensioner
Chain Tensioner - Fixed Floor
Rotor - Without Knives
Rotor - 13 Knives
Rotor - 17 Knives
Rotor - 25 Knives
Scrapers - Without Knives
Scrapers - 13 Knives
Scrapers - 17 Knives
Scrapers - 25 Knives
Fixed Floor - Without Knives
Floor - 13 Knives
Floor - 17 Knives
Floor - 25 Knives
Floor - 17 25 Knives
Header - 13 Knives
Header - 17 Knives
Header - 25 Knives
Support Bracket - Knives
Low Holder Sheet Metal - Pick-Up 2,00 M
Low Holder Sheet Metal - Pick-Up 2,25 M
Roll Holders - Pick-Up 2,00 M
Roll Holders - Pick-Up 2,25 M
Roll Holders Movable - Pick-Up 2,25 M
Roll Holders Movable - Pick-Up 2,40 M
Roll Holders - Limitation
Guide Wheels 6 Pr - Rigid
Guide Wheels 10 Pr - Rigid
Guide Wheels 6 Pr
Guide Wheels 10 Pr
Bale Forming System
Roller Front - Lubricated
Roller Front - Grease Lines
Roller Rear - Lubricated
Roller Rear - Grease Lines
Roller Rear - Lifetime Lubricated
Roller With Net - Support Bracket
Roller With Net - Cover Sheet
Roller With Net - Propel
Binding System
Support For Net Roll
Support For Net Roll - Crank
Support For Net Roll - Brake Assembly
Support For Net Roll - Swivel Arm
Net Wrapping - Adaptors
Net Wrapping - Frame
Net Wrapping - Cutting Device
Net Wrapping - Net Length Regulation
Net Wrapping - Clamping Parts
Net Wrapping - Support For Net Roll
Twine Can
Twine Box - Support Bracket
Twine Wrapping - Frame
Twine Wrapping - Cutting Device
Twine Wrapping - Drive - Independent
Twine Wrapping - Drive Device Assembly
Twine Wrapping - Twine Thrower
Twine Wrapping - Main Drive
Twine Wrapping - Deflector Plate
Twine Wrapping - Scrapers
Net Spreading Unit - Attachments
Bale Ejecting System
Bale Kicker
Axle - 80mm
Brake Axle - 80mm
Axle - Fixing Parts
Air Brake - Brake Valve
Air Brake - Air Tank
Air Brake
Hydraulic Brake Assy
Frame
Frame - Scrapers
Tailgate
Tailgate - Angle
Tailgate - Locking Kit
Arm
Arm - Kit, Pin
Arm - Spring
Arm - Locking Kit
Tie Rods
Tie Rods - Towing Eye
Tie Rods - Accessories Section
Retainer
Jack Assembly
Access - Ladder
Hoop Guard - Pick-Up
Protective Housing - Right Hand
Protective Housing - Left Hand
Protective Housing - Gas Spring
Protective Housing - Bracket
Locking Right - 2,00 M
Locking Left - 2,00 M
Locking Right - 2,25 M
Locking Left - 2,25 M
Locking Right - 2,40 M
Locking Left - 2,40 M
Protective Cover - Basic Version
Protective Cover - Net Wrapping
Protective Cover - Twine Wrapping
Stickers - Logo
Decals - Function
Decals - Safety
Stickers - Safety
Warning Signs - Attachments
Spindles And Wheels
Wheels - 15.0 55-17
Wheels - 19.0 45-17
Wheels - 500 45-22.5
Wheels - 500 50-22.5
Wheels - 500 55-20
Wheels - 500 60-22.5
Immobilizer System
Safety Chain
Wedge - Ng 46
Wedge - Ng 53
Pick-Up - Conversion Kit
Brand: Fendt
Drive System
Gear Box 540
Gear Box 1000
Belt
Belt Guide
Tailgate - Cylinder
Roller With Net
Net Wrapping
Lights
Light Harness
Wiring Harness
Lubrication System
Bale Feeding System
Chain Tensioner
Rotor - 13 Knives
Rotor - 17 Knives
Rotor - 25 Knives
Floor - 13 Knives
Floor - 17 Knives
Floor - 25 Knives
Header - 13 Knives
Header - 17 Knives
Header - 25 Knives
Guide Wheels 6 Pr
Guide Wheels 10 Pr
Bale Forming System
Binding System
Twine Can
Bale Kicker
Axle - 80mm
Brake Axle - 80mm
Axle - Fixing Parts
Air Brake
Frame
Frame - Scrapers
Tailgate
Tailgate - Angle
Arm
Arm - Kit, Pin
Arm - Spring
Arm - Locking Kit
Tie Rods
Retainer
Jack Assembly
Access - Ladder
Stickers - Logo
Decals - Function
Decals - Safety
Stickers - Safety
Spindles And Wheels
Wheels - 15.0 55-17
Wheels - 19.0 45-17
Wheels - 500 55-20
Immobilizer System
Safety Chain
Wedge - Ng 46
Wedge - Ng 53
