Fendt Medium Square Baler 1290 1290 S Parts Catalog 1637492 10.2007
Brand: Fendt
Type of Machine: Hay Equipment, Medium Square Baler
Model: Fendt 1290, 1290 S Medium Square Baler
Serial Number: 74100
Publication Date: 10.2007
Number of Pages: 385 Pages
Linkage - Safety Chain
Transmission - Drive Shaft
Transmission - Secondary
Transmission - Type 2 1 -3 8 X 21 Splines - Auto Lock
Transmission - Type 3 1 -3 4 X 20 Splines - Auto Lock
Transmission - Flywheel
Transmission - Flywheel Brake
Transmission - Flywheel Clutch
Gearbox - Attachment
Gearbox
Chain Drive - Left Side
Chain Drive - Right Side
Chain Drive
Chain Drive - Clutch
Cutter Drive Assembly - Left
Cutter Drive Assembly - Left - Clutch
Cutter Gearbox
Pick-Up
Pick-Up - Windguard - Up To H.P 74100
Pick-Up - Windguard - From H.P 74101
Pick-Up - Wrapper & Shields
Pick-Up - Cutter
Pick-Up - Cutter - Windguard - Up To H.P 74100
Pick-Up - Cutter - Windguard - From H.P 74101
Pick-Up - Cutter - Attachment
Pick-Up - Cutter - Rotor
Pick-Up - Cutter - Wrapper & Shields - Up To H.P 74100
Pick-Up - Cutter - Wrapper & Shields - From H.P 74101
Pick-Up - Flotation
Chain Drive - Cutter - Left Side - Up To H.P 74100
Chain Drive - Cutter - Left Side - From H.P 74101
Chain Drive - Cutter - Right Side - Up To H.P 74100
Chain Drive - Cutter - Right Side - From H.P 74101
Pick-Up - Clutch
Pick-Up - Rotor
Shields - Left Side
Shields - Right Side
Shields - Cutter - Left Side - Up To H.P 74100
Shields - Cutter - Left Side - From H.P 74101
Shields - Cutter - Right Side - Up To H.P 74100
Shields - Cutter - Right Side - From H.P 74101
Shields - Without Cutter
Shields - With Cutter
Pick-Up - Gauge Wheel
Electrical Wiring
Sensors Harness
Electrical Wiring - Cutter
Electrical Wiring - Kit
Lighting Equipment - Front
Lighting
Lighting - Working Light
Electrical Plug
Fieldstar - Up To Serial Or Engine Number ...
Fieldstar - From Serial Or Engine Number ...
Stuffer
Feeder - Arm
Feeder
Hay Dog
Feeder - Brake
Stuffer - Without Cutter
Stuffer - Cutter
Stuffer - Linkage & Door
Plunger
Bale Chute
Knotter
Needle
Knotter - Tension Adjusting
Knotter - Twine Tensioner - Arm
Knotter - Attachment
Frame
Knotter Control - Cam Assembly
Knotter - Knotter Head
Knotter - Clutch
Knotter - Brake
Knotter Control
Star Wheel
Knotter - Reflector
Knotter Blower
Knotter Blower - Up To Serial Or Engine Number Hr 74496
Knotter Blower - From Serial Or Engine Number Hr 74497
Lubrication - Feeder
Lubrication
Lubrication - Kit
Lubrication - Front
Lubrication - Rear
Lubrication - Pump
Lubrication - Rear Valve - Up To H.P 74100
Lubrication - Rear Valve - From H.P 74101
Lubrication - Front Valve - Up To H.P 74100
Lubrication - Front Valve - From H.P 74101
Lubrication - Primary Valve - Up To H.P 74100
Lubrication - Primary Valve - From H.P 74101
Lubrication - Tank
Lubrication - Grease Pump
Frame, Wheels & Shields
Bale Chamber
Bale Chamber - Doors & Arms
Shields - Hood & Fitting
Shields - Top
Shields - Knotter
Shields - Left Side - Without Cutter
Shields - Left Side - With Cutter
Shields - Right Side - Without Cutter
Shields - Right Side - With Cutter
Shields - Tandem Axle - Right Side
Shields - Tandem Axle - Ladder
Shields - Crawl Of Safety
Twine Box - Tandem Axle
Twine Box - Front Left
Twine Box - Left Rear - Up To H.R 74388
Twine Box - Left Rear - From H.R 74389
Twine Box - Front Right
Twine Box - Right Rear - Up To H.R 74388
Twine Box - Right Rear - From H.R 74389
Tandem Axle
Tandem Axle - Steering Axle
Tandem Axle - Brake - Rigid Axle
Tandem Axle - Brake - Steering Axle - Left Side
Tandem Axle - Brake - Steering Axle - Right Side
Wheel - Tandem Axle
Braking
Braking - With Pneumatic Brake
Parking Brake - Control Linkage - Tandem Axle
Parking Brake - Actuator
Hydraulic
Hydraulic - Front
Hydraulic Control - Valve - Bale Chamber
Hydraulic Cylinder
Hydraulic - Bale Chamber
Hydraulic - Bale Ejector
Hydraulic Control - Valve - Bale Ejector
Hydraulic - Cutter
Hydraulic - Valve
Decals & Attachments
Decals - Twine Box
Decals - Bale Chamber
Attachments - Pull Eye Bolt
Attachments - Shear Bolt
Attachments - Transmission
Attachments - Bale Chute
Attachments - Knotter Blower
Attachments - Hydraulic - Load Sensing
Attachments - Fieldstar - Up To Serial Or Engine Number ...
Attachments - Fieldstar - From Serial Or Engine Number ...
Literature
