Fendt Medium Square Baler 1270 1270 S Parts Catalog 1637499 05.2004
Brand: Fendt
Type of Machine: Hay Equipment, Medium Square Baler
Model: Fendt 1270, 1270 S Medium Square Baler
Serial Number: HT85100
Publication Date: 05.2004
Number of Pages: 329 Pages
Linkage - Hitch Safety Chain
Transmission - Type 2 1-3 8 X 21 Splines - Auto Lock
Transmission - Type 3 1-3 4 X 20 Splines - Auto Lock
Transmission - Flywheel
Gearbox
Cutter Gearbox Assembly
Chain Drive - Left Side
Chain Drive - Right Side
Chain Drive
Chain Drive - Clutch
Cutter Drive Assembly - Left
Clutch - With Cutter
Pick-Up
Pick-Up - Without Cutters
Pick-Up - With Cutter
Pick-Up - With Cutter - Fitting
Pick-Up - With Cutter - Rotor
Pick-Up - Knives
Pick-Up - Knives - Continued
Pick-Up - With Cutter - Cowl
Pick-Up - Suspension
Chain Drive - With Cutter - Left Side
Chain Drive - With Cutter - Right Side
Clutch - Pickup
Chain Drive - Rotor
Shields - Left Side
Shields - With Cutter - Left Side
Shields - Right Side - Without Cutter
Shields - With Cutter - Right Side
Wheel - Pickup
Electrical
Sensors Harness
Sensors Harness - Control Box
Sensors Harness - Top
Sensors Harness - Bottom
Lighting Equipment - Front
Lighting Equipment - Rear
Lighting Equipment
Electrical Plug
Charge And Plunger
Finger
Hay Check
Charge And Plunger - Without Cutters
Charge And Plunger - With Cutters
Plunger - Shaft
Plunger
Bale Chute
Knotter
Needle
Knotter - Tension Adjusting
Frame
Knotter Control - Cam Assembly
Knotter - Brakes
Knotter Control - Frame
Star Wheel
Knotter - Reflector
Lubrication - Feeder
Lubrication
Lubrication - Kit
Lubrication - Front
Lubrication - Pump
Lubrication - Rear
Lubrication - Rear Valve
Lubrication - Front Valve
Lubrication - Primary Valve
Lubrication - Tank
Lubrication - Grease Pump
Mainframe Wheels And Shield Assemblies
Bale Tensioner
Bale Tensioner - Door
Shields - Front
Shields - Upper Compoments
Shields - Knotter
Shields - Without Cutters
Shields - Tandem - Right Side
Shields - Tandem
Shields - Tandem - Ladder Rails
Shields - Tubular Support Stays
Twine Box - Left Side
Twine Box - Right Side
Twine Box - Front Left
Twine Box - Left Rear
Twine Box - Front Right
Twine Box - Right Rear
Axle - Tandem
Brake System - Tandem - Rigid Axle
Brake System - With Pneumatic Brake
Handbrake - Control Linkage - Tandem
Handbrake - Control Linkage - Actuator
Steering Axle - Tandem
Brake System - Tandem - Steering Axle - Left Side
Brake System - Tandem - Steering Axle - Right Side
Wheel - Tandem
Hydraulics
Hydraulic - Front
Hydraulic Flow Control - Valve - Bale Tensioner
Hydraulic Cylinder
Hydraulic - Bale Tensioner
Hydraulic - Bale Ejector
Hydraulic - Valve
Hydraulic - Knives
Hydraulic Cylinder - Knives
Knotter - Blower Kit
Knotter - Blower Kitit (Continued)
Knotter - Fan
Knotter Blower Kit
Accessories And Decals
Decals - Twine Box
Electrical - Kit
Knotter - Kit
Accessories And Decals - Shear Bolt - Kit
Bale Chute - Roller Kit
Bale Chute - Roller Kit (Continued)
Fieldstar
Literature
Brand: Fendt
Gearbox
Chain Drive
Pick-Up
Pick-Up - Knives
Clutch - Pickup
Chain Drive - Rotor
Shields - Left Side
Wheel - Pickup
Electrical
Sensors Harness
Lighting Equipment
Electrical Plug
Charge And Plunger
Finger
Hay Check
Plunger - Shaft
Plunger
Bale Chute
Knotter
Needle
Frame
Knotter - Brakes
Star Wheel
Knotter - Reflector
Lubrication
Lubrication - Kit
Lubrication - Front
Lubrication - Pump
Lubrication - Rear
Lubrication - Tank
Bale Tensioner
Shields - Front
Shields - Knotter
Shields - Tandem
Axle - Tandem
Wheel - Tandem
Hydraulics
Hydraulic - Front
Hydraulic Cylinder
Hydraulic - Valve
Hydraulic - Knives
Knotter - Fan
Knotter Blower Kit
Decals - Twine Box
Electrical - Kit
Knotter - Kit
Fieldstar
Literature
