Fendt Large Rectangular Baler 12130 Parts Catalog 79036165 07.2020
Brand: Fendt
Type of Machine: Hay Equipment, Large Rectangular Baler
Model: Fendt 12130 Large Rectangular Baler
Serial Number: EHB15101 - 99999999
Publication Date: 07.2020
Number of Pages: 433 Pages
Drive System
Belts & Filters Guide
Main Drive
Clutch - Flywheel
Drive Shaft
Secondary Drive Shaft
Primary Drive Shaft - Ce
Brake - Flywheel
Mounting - Flywheel
Mounting - Gearbox
Gearbox Assembly
Auxiliary Drive - Left Hand
Auxiliary Drive - Right Hand
Shaft And Sprocket - Auxiliary
Slip Clutch - Auxiliary
Drive - Cutter
Gearbox Assembly - Cutter
Slip Clutch - Cutter
Chain Lube
Pick-Up - Hydraulics
Hydraulic - Front
Hydraulic Valve Assembly - Bale Density
Hydraulic Reservoir
Bale Density - Hydraulics
Brake Hydraulics - Single Axle
Brake Hydraulics - Tandem Axle
Steering Lock - Tandem Axle
Blower Hydraulics
Blower
Hydraulics - Cutter
Hydraulic Cylinder Assembly
Hydraulics - Bale Ejector
Hydraulics - Bale Chute Lift
Jack - Hydraulic
Gta C1000 Console And Mounting - Ce
Gta Mounting - Option
Wiring - Control Box
Wiring - Upper
Wiring - Lower
Electrical Kit
Wiring - Cutter
Lights - Ce
Bale Chute - Roller
Electrical Connectors - Weather Pack
Electrical Connectors - Amp, Deutsch And Weatherpack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Deutsch And Metri-Pack
Bale Feeding System
Windguard
Roller - Windguard
Wrapper, Wear Plate And Scraper - Mounting
Pickup Flotation
Pickup Augers
Pickup Drive - Left Hand
Pickup Drive - Right Hand
Pickup Clutch
Pickup Reel
Pickup Shields - Left Hand
Pickup Shields - Right Hand
Shield Mounting - Left Hand
Shield Mounting - Right Hand
Gauge Wheel - Pick-Up
Pickup Augers - Adapter
Mounting - Cutter
Cutter
Rotor - Cutter
Knife Assembly
Bale Forming System
Packer - Feeding Auger
Mounting - Packer Crank
Crank - Packer
Stuffer Drive - Left Hand
Stuffer Drive - Right Hand
Clutch - Dog
Brake Assembly
Chute - Feeder
Struts And Wrappers - Packer
Linkage - Stuffer Clutch
Holding Finger - Stuffer Clutch
Mounting - Connecting Rods
Connecting Rod Lube
Plunger
Mounting - Stripper
Bale Knotting System
Mounting - Needle
Knotter Mounting
Knotter
Main Shaft Assembly - Knotter
Knotter Slacker - Upper
Head - Knotter
Knotter Clutch
Knotter Brake
Twine Finger And Hay Dog - Knotter
Tensioner
Mounting - Star Wheel
Star Wheel Tower
Linkage - Star Wheel
Star Wheel
U-Joint - Star Wheel
Knotter Arm Mounting
Tensioner - Lower
Tension Arm
Knotter Monitor
Mounting - Knotter Lube Pump
Knotter Lube Pump
Knotter Lube
Knotter Lube Valve - Primary
Knotter Lube Valve - Secondary
Knotter - Service Parts
Bale Ejecting System
Selectable Ejector
Mounting - Bale Ejector
Mounting - Roller Bale Chute
Bale Weight - Mounting
Hitch And Jack Mounting
Plunger Rails, Knives And Hay Dog
Bale Density Doors
Hood And Mounting - Ce
Shields - Top
Knotter Shields - Ce
Twine Box Mounting - Left Hand
Twine Box Mounting - Right Hand
Twine Can - Left Hand
Twine Can - Right Hand
Support - Left Hand
Support - Right Hand
Door Assembly - Left Hand
Door Assembly - Right Hand
Shield Assembly - Left Hand
Shield Assembly - Right Hand
Drive Shields - Auxiliary
Shields - Single Axle
Shields - Tandem Axle
Mounting - Handrail
Tool Box
Decals - Logo
Decals - Operational
Axles, Spindles, And Wheels
Axle Mounting - Single Axle
Axle Assembly - Tandem Axle
Axle - Steering
Axle - Rigid
Hub Assembly
Hub And Spindle - Single Axle
Brake Assembly - Left Hand
Brake Assembly - Right Hand
Brake System - Steering
Brake System - Rigid
Park Brake - Single Axle
Park Brake - Tandem Axle
Actuator Assembly - Park Brake
Air Brake - Single Axle
Air Brake - Tandem Axle
Auto Brake - Ce
Gta C1000 Console Kit - Ce
Roller Bale Chute Kit
Drive Shaft Kit - Primary
Shear Bolt Kits
Selectable Ejector Kit
Roller Kit - Windguard
Gauge Wheel Kit - Removable
Hydraulic Jack Kit
Blower Relief Valve Kit
Bale Weight Kit
Module Kit
Module Harness Kit
Knotter Trip Kit
Knotter Trip Kit - Motor
Telemetry Kit
Telemetry Installation Kit
Extension Kit - Hitch
