Fendt Large Rectangular Baler 12130 Parts Catalog 00731079 09.2012
Brand: Fendt
Type of Machine: Hay Equipment, Large Rectangular Baler
Model: Fendt 12130 Large Rectangular Baler
Publication Date: 09.2012
Number of Pages: 536 Pages
Drive System
Main Drive
Clutch - Flywheel
Drive Shaft
Secondary Drive Shaft
Primary Drive Shaft - Ce
Brake - Flywheel
Mounting - Flywheel
Mounting - Gearbox
Gearbox
Gearbox Assembly
Auxiliary Drive - Left Hand
Auxiliary Drive - Right Hand
Shaft And Sprocket - Auxiliary
Slip Clutch - Auxiliary
Drive - Cutter
Gearbox Assembly - Cutter
Slip Clutch - Cutter
Pick-Up - Hydraulics
Hydraulic - Front
Hydraulic Valve Assembly - Bale Density
Hydraulic Reservoir
Bale Density - Hydraulics
Brake Hydraulics - Single Axle
Brake Hydraulics - Tandem Axle
Steering Lock - Tandem Axle
Blower Hydraulics
Blower
Hydraulics - Cutter
Hydraulic Cylinder Assembly
Hydraulics - Bale Ejector
Gta I Console And Mounting - Ce
Gta Ii Console And Mounting - Ce
Gta C1000 Console And Mounting - Ce
Gta Mounting - Option
Wiring - Control Box
Wiring - Upper
Wiring - Lower
Electrical Kit
Wiring - Cutter
Lights - Ce
Bale Chute - Roller
Harness Service Parts
Bale Feeding System
Windguard
Roller - Windguard
Wrapper, Wear Plate And Scraper - Mounting
Pickup Flotation
Pickup Augers
Pickup Drive - Left Hand
Pickup Drive - Right Hand
Pickup Clutch
Pickup Reel
Pickup Shields - Left Hand
Pickup Shields - Right Hand
Shield Mounting - Left Hand
Shield Mounting - Right Hand
Gauge Wheel - Pick-Up
Pickup Augers - Adapter
Mounting - Cutter
Cutter
Rotor - Cutter
Knife Assembly
Bale Forming System
Packer - Feeding Auger
Mounting - Packer Crank
Crank - Packer
Stuffer Drive - Left Hand
Stuffer Drive - Right Hand
Clutch - Dog
Brake Assembly
Chute - Feeder
Struts And Wrappers - Packer
Linkage - Stuffer Clutch
Holding Finger - Stuffer Chamber
Mounting - Connecting Rods
Connecting Rod Lube
Plunger
Mounting - Stripper
Bale Knotting System
Mounting - Needle
Knotter Mounting
Knotter
Knotter Slacker - Upper
Main Shaft Assembly - Knotter
Head - Knotter
Knotter Clutch
Knotter Brake
Twine Finger And Hay Dog - Knotter
Tensioner
Mounting - Star Wheel
Star Wheel Tower
Linkage - Star Wheel
Star Wheel
U-Joint - Star Wheel
Knotter Arm Mounting
Tensioner - Lower
Tension Arm
Knotter Monitor
Mounting - Knotter Lube Pump
Knotter Lube Pump
Knotter Lube
Knotter Lube Valve - Primary
Knotter Lube Valve - Secondary
Knotter - Service Parts
Bale Ejecting System
Mounting - Bale Ejector
Mounting - Roller Bale Chute
Hitch And Jack Mounting
Plunger Rails, Knives And Hay Dog
Bale Density Doors
Hood And Mounting
Shields - Top
Knotter Shields - Ce
Twine Box Mounting - Left Hand
Twine Box Mounting - Right Hand
Twine Box - Left Hand
Twine Box - Right Hand
Support - Left Hand
Support - Right Hand
Door Assembly - Left Hand
Door Assembly - Right Hand
Shield Assembly - Left Hand
Shield Assembly - Right Hand
Drive Shields - Auxiliary
Shields - Single Axle
Shields - Tandem Axle
Mounting - Handrail
Tool Box
Decals - Logo
Decals - Operational
Axles, Spindles, And Wheels
Axle Mounting - Single Axle
Axle Assembly - Tandem Axle
Axle Assembly - Steering
Hub Assembly - Steering
Brake Assembly - Single Axle
Brake Assembly - Left Hand
Brake Assembly - Right Hand
Brakes - Steering
Brakes - Rigid
Park Brake - Single Axle
Park Brake - Tandem Axle
Actuator Assembly - Park Brake
Air Brakes - Single Axle
Air Brakes - Tandem Axle
Auto Brake - Ce
Gta I Console Kit - Ce
Gta Ii Console Kit - Ce
Gta Ii Tractor Kit - Ce
Gta C1000 Console Kit - Ce
Bale Chute Kit
Drive Shaft Kit - Primary
Shear Bolt Kits
Hydraulic Blower Kit
Bale Ejector Kit
Roller Bale Chute Kit
Bale Weight And Length Kit
Bale Weight Kit
Module Kit
Module Harness Kit
Telemetry Kit
Telemetry Installation Kit
Anti Drift Kit - Bale Ejector
Roller Kit - Windguard
Gauge Wheel Kit - Removable
Gauge Wheel Storage Kit
Hydraulic Jack Kit
Blower Relief Valve Kit
