Fendt Farmer 300Ci Tranmission Gearbox - Service Training
Brand: Fendt
Type of Manual: Gearbox - Service Training Manual
Model: Fendt Farmer 300Ci Tractor Farmer 200 V/F/P/S
Publication Number: X990.005.409.010
Number of Pages: 506 Pages
History of the Farmer 300 C / Ci tractor range
Technical Data Farmer 307 / 308 / 309 Ci
Synchronised overdrive gearbox
Transmission schematic
Rear wheel differential with mufti-disc lock
Rear wheel differential lock with locking pins
Gear change box - drive shaft with reversing gearbox
Gear change box - fine gear countershaft (slow - medium - fast)
Gear change box - overdrVe (25,30, 40 km/h)
Gear change box pinion shaft (1st, 2nd, 3rd gear)
Gear change box - gear cluster
"Hare/tortoise" reduction gears and constant front wheel drive
Intermediate gear front wheel drVe
Gear change box shift gate
Gear change box / Side-mounted gearshift assembbly
Clutch actuation system
Installation and removal of dual clutch
Front PTO gearbox
Front PTO fitting instructions
Rear PTO lever
Rear PTO actuating cylinder
Setting rear PTO clutch
Rear PTO 540 / Ground speed PTO 1000
Rear PTO 540 / 750 / 1000
Repairing front-wheel drive clutch
Front wheel drive (electro-hydrauk)
Turboclutch (technical drawing)
Testing stall speed (turboclutch)
Installation and removal of turboclutch
Enhanced hydraulics system key
Valve unit: rear PTO / rear diff. lock/ 4-WD
Checking oil pressure in enhanced actuation system
Brand: Fendt
Front PTO gearbox
Rear PTO lever
