Fendt Combine Ideal 9 GEN3 2023-2025 Parts Catalog
- Download this document, you need 8625 Gallons
Brand: Fendt
Type of Machine: Combine
Model: Fendt Ideal 9 GEN3 2023-2025 Combine
Publication Date: 2023-2025
Number of Pages: 2599 Pages
-Toc Table Of Content
-000-Toc General Information
Filters Guide
Belts Guide - Right Side
Belts Guide - Left Side
Sensors Guide
Paints Guide
-000-Toc Engine Acx2846390 D3876le124c T3_Lrc
Engine - Retainer
Crankcase
Timing Gears & Housing
Flywheel & Housing
Crankshaft & Pistons
Camshaft & Valve Mechanism
Cylinder Head & Valve Mechanism
Valve Rocker Cover
Air Intake
Exhaust Manifold
Turbocharger
Oil Pump & Sump
Oil Cooler & Oil Filter
Coolant Piping
Coolant Pump & Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management - Sensor
Electronic Engine Management - Wiring Harness
Electronic Engine Management - Bracket
Wiring Harness - Injector
Belt Tensioner
Engine Gasket Kits
Special Overhaul Parts
-000-Toc Engine Acx2840010 D3876le123d T4f
-000-Toc Engine Acx2841630 D3876le126c Stage 5
-000-Toc Engine Installation
Engine, Alternator, Starter Motor & Oil Drain
Engine - Oil Drainage System
Engine Block Heater
Engine Bracket
Cooling - Fan Drive
Cooling - Fan & Fan Shroud
Cooling - Fan
Cooling - Hoses
Cooling - Expansion Tank
Cooling - Fan Shroud & Support
Cooling - Radiator & Coolers
Cooling - Plugs
Exhaust System
Engine Air Filter
Dust Aspirator
Exhaust System - Cover
Exhaust System - Sensors
Def System
Def - Filters
Exhaust - Def Tank (Components)
Fuel - Tank (Components)
Fuel - Lines
Air Compressor - Compressor & Lines
Air Compressor - Tank
Air Compressor - Lines And Fittings
-000-Toc Drive System
Engine Gearbox
Engine Gearbox (Components)
Header Drive - Bottom
Gearbox (Components) - Header Drive
Fixed Speed Header Drive - Top
Gearbox (Components) - Fixed Speed Header Drive
Shaft (Components)
Variable Speed Header Drive - Top
Variable Speed Header Drive - Sheave
Sheave - Header Drive
Gearbox (Components) - Variable Speed Header Drive
Tie Rod - Header Drive
Feeder Conveyor Drive - Fixed Speed
Feeder Conveyor Drive - Two Speed
Beater Drive - Single Speed Rotor Drive
Beater Drive - Two Speed Rotor Drive
Beater Drive - Shield
Single And Dual Rotor Drive - Fixed Speed
Universal Joint (Components)
Dual Rotor Drive - 2 Speeds
Gearbox (Components) - Rotor Drive
Idler Arm
Gearbox - Cooling
Countershaft - Drive
Shaker Shoe Drive
Cleaning Fan - Drive
Grain Elevator - Drive
Grain Elevator - Secondary Drive
Grain Bin Unloading - Drive
Gearbox (Components) - Grain Bin Unloading
Straw Chopper - Drive
-000-Toc Axles
Front Axle - Standard
Front Axle - Paralevel
Front Axle - Tracks
Pulled Rear Axle - Pin
Rear Axle - Pin
Rear Axle - 2 Wheel Drive
Rear Axle - 2 Wheel Drive - (Components)
Rear Axle - 4 Wheel Drive
Rear Axle - 4 Wheel Drive - (Components)
Hitch
Hitch - 3rd Axle
Hitch Drop Pin
Hitch - Automatic
-000-Toc Steering System
Steering Wheel & Column
Hydraulic Lines
Hydraulic Lines - Pressure Switch
-000-Toc Drivetrain System
Transmission - Standard
Transmission - Paralevel
Transmission - Dual Wheels
Transmission - Tracks
Final Drive (Components) - Wheels
Final Drive (Components) - Tracks
Gearbox
Gearbox - Housing
Gearbox - Main Shaft
Gearbox - Intermediate Shaft
Gearbox - Bevel Pinion Shaft
Gearbox - Differential
Gearbox - Piping
Gearbox - Valve
Gearbox - Oil Filler & Measurement
Gearbox - Oil Cooler
Gearbox - Hydraulic Pump
Gearbox - Suction Line
-000-Toc Brake System
Brake Pedals
Brake Lines - Standard & Tracks
Brake Lines - Paralevel
Disc Brakes
-000-Toc Hydraulic System
Oil Tank
Hydraulic Pump - Standard Steering
Hydraulic Pump - Idealdrive
Idealdrive
Main Plumbing
Engine Gearbox - Hydraulic
Engine Gearbox - Hydraulics
Hydraulic Propel - Standard & Paralevel
Hydraulic Propel - Tracks
Hydraulic Motor - Components
Hydraulic Propel
Hydrostatic Transmission - Hydrostatic Pump (Components)
3rd Axle
Front Axle - Standard & Tracks
Front Axle - Valve Block (Components)
Cutting Header - Lifting - Standard
Cutting Header - Lifting - Paralevel
Cutting Header - Suspension
Cutting Header - Manual Cutting Angle Adjustment
Cutting Header - Hydraulic Cutting Angle Adjustment
Cutting Header - Valve Block (Components)
Quick Hydraulic Couplers (Multi-Faster)
Cutting Header
Cutting Header - Reverser
Cutting Header - Reverser - Valve Block (Components)
Concave Adjustment
Concave Adjustment - Valve Block (Components)
Rotor Reverser - 2 Speeds
Grain Bin
Grain Bin - Valve Block (Components)
Grain Bin - With Hydraulic Gates
Grain Bin - With Hydraulic Extensions
Unloader Swing
Spill Saver
Boost Pump
Boost Pump - Valve Block (Components)
Boost Pump (Unloader) - Fixed Speed Header Drive
Boost Pump (Unloader) - Variable Speed Header Drive
Grass Seed (Low Capacity Unloader)
Grass Seed - Streamer 140 & 210
Straw Spreader - Standard Steering
Straw Spreader - Idealdrive
Activespread - Standard Steering
Activespread - Idealdrive
Activespread Swingflow - Standard Steering
Activespread Swingflow - Idealdrive
Activespread Swingflow - Valve Block (Components)
Passivespread - Idealdrive
Chaff Spreader
Lubrication Pipes - Paralevel
Lubrication Pipes - Standard & Tracks
-000-Toc Electrical System
Sensors - Hydraulic
Sensors - Grain Bin
Sensors - Ground Drive
Sensors - Rotor Drive
Lighting - Road Lights
Front Lighting - Valance
Lighting - Front Lights
Work Lights
Work Lights - Rear Axle
Wiring Harness - Rear Lighting
Lighting - Roof
Lighting - Rotary Beacon
Unloader - Rotary Beacon
Batteries & Cables
Batteries & Cables - (Main Circuit Fuses)
Main Harness
Wiring Harness - Feeder Conveyor
Wiring Harness - Front Axle
Wiring Harness - Rear Axle - 2 Wheel Drive
Wiring Harness - Rear Axle - 4 Wheel Drive
Wiring Harness - 3rd Axle
Wiring Harness - Idealdrive
Wiring Harness - Cab
Wiring Harness - Engine
Ground Drive - Idealdrive
Ground Drive
Wiring Harness - Concave Adjustment
Wiring Harness - Cleaning Shoe
Wiring Harness - Grain Bin
Wiring Harness - Grain Bin Unloading
Wiring Harness - Vertical Knife
Wiring Harness - Straw Chopper
Wiring Harness - Straw Chopper & Tailboard
Wiring Harness - Straw Spreader
Wiring Harness - Straw Deflector
Wiring Harness - Activespread
Wiring Harness - Activespread Swingflow
Wiring Harness - Chaff Spreader
Grain Loss Monitor - No Automation
Grain Loss Monitor - Self Adjust
Yield Monitor System
360° Camera System - Camera Ready
360° Camera System
Without Rear Camera
Rear Camera
Quad Camera Display Monitor
Camera - Quad
Taillight - Unloader Tube
Actuator - Ladder
-000-Toc Cab
Cab Support
Cab Frame
Roof
Roof - Trim
Washer & Wiper
Cab Glass
Door - Left Side
Trim
Cab - Noise Reduction
Cab - Interior Equipments
Cab - Cool Box
Operator Seat - Standard
Operator Seat - Deluxe
Operator Seat (Components) - Deluxe
Operator Seat - Idealdrive
Passenger Seat
Armrest
Control Panel - Adjusting Device
Monitor - Swivel Arm
Armrest - Idealdrive
Armrest - Base
Mobile Phone Holder
Tablet Holder - Swivel Arm
Radio And Antenna
Speakers - No Subwoofer
Speakers - Subwoofer
Rear View Mirror
Platform & Ladder - With Wheels
Platform & Ladder - With Tracks
Platform Extension
Steps - Ladder
Latch - Ladder
Tools
Wheel Chocks
Wheel Chocks - Folding Ladder
Fire Extinguisher
-000-Toc Air Conditioning And Heating System
Hvac System (Heating, Ventilation & Air Conditioning)
Hvac Lines
-000-Toc Chassis
Frame - Bottom
Frame - Top
Twin Rotor - Wear Plate
Processor Doors - Dual Rotor
Battery Carrier And Tool Box
Stone Trap Slide - Standard
Stone Trap Slide - Paralevel
Stone Trap Slide - Dual Wheels
Stone Trap Slide - Tracks
Stone Trap
Stone Trap - Cover (Large Grain)
Shields - Cleaning Fan
Shields - Bottom
Header Drive - Shield
Rear Panel - Single Speed
Rear Panel - Two Speed
Engine Access - Ladder
Engine Access - Deck Plate
Engine Access - Railing
Fuel - Tank Bracket
Engine Cover
Sheet Metal - Brackets
Hinge - Side Panels
Sheet Metal - Grain Bin Door
Sheet Metal - Rear Right
Sheet Metal - Right Side
Strut - Right Side
Panel - Air Box
Sheet Metal - Rear
Sheet Metal - Left Side
Strut - Left Side
Sheet Metal - Rear Left
Latch - Rear Left
Threshing Mechanism - Access
Handles
Straw Chopper - Shield
Signaling Panels
-000-Toc Decals
Decals - Standard
Decals - Speed
Decals - Safety & Warning
-000-Toc Wheels
Front Wheels - Standard - 800_70r32
Front Wheels - Standard - 900_60r32
Front Wheels - Standard - 1000_55 R32
Front Wheels - Standard - 1050_50r32
Front Wheels - Standard - 800_70r38
Front Wheels - Standard - 900_60r38
Front Wheels - Standard - 710_70r42
Front Wheels - Paralevel - 900_60r32
Front Wheels - Paralevel - 800_70r38
Front Wheels - Paralevel - 900_60r38
Front Wheels - Dual Wheels - 520_85r42
Front Wheels - Dual Wheels - 580_85r42
Front Wheels - Dual Wheels - 620_70r42
Front Wheels - Dual Wheels - 710_70r42
Rear Wheels - 520_80r26
Rear Wheels - 620_70r26
Rear Wheels - 750_65r26
Rear Wheels - 520_85r30
Rear Wheels - 710_60r30
Tracks
Track Roller
Tracks - Front
Tracks - Rear
Tracks - Tensioner
Tracks - Bogie
Tracks - Wheels
Tracks - Cylinder
Tracks - Scrapers
-000-Toc Feeding System
Shield Plate
Tilt Frame
Header Lock
Pitch Frame - Manual Cutting Angle Adjustment
Pitch Frame - Hydraulic Cutting Angle Adjustment
Pitch Frame - Feeder Sealing
Feeder Frame - Manual Cutting Angle Adjustment
Feeder Frame - Hydraulic Cutting Angle Adjustment
Feeder Bottom Plate - Standard
Feeder Bottom - High Wear
Upper Shaft
Feed Drum
Feeder Chain
Dust Ejector
Dust Ejector - Pipes
Dust Ejector - Hydraulic Motor
Dust Ejector - Hydraulic Manifold
Feeder House Coupling - Right Side
Feeder House Coupling - Left Side
Multi-Connector
Feeder Shield - Right Side
Feeder Shield - Left Side
Shields - Upper Header Drive
-000-Toc Threshing System
Rotor Feeder - Standard
Rotor Feeder - High Wear
Rotor Feeder - Cover
Dual Rotor - Rotor Inlet
Dual Rotor - Right Rotor
Dual Rotor - Left Rotor
Dual Rotor - Concave Adjustment
Dual Rotor - Rotor Discharge
Dual Rotor - Grates Support
Impeller - Unloader Cover
Concave - Small Grain - Standard
Concave - Small Grain - Middle Specs
Concave - Small Grain - High Capacity
Concave - Large Grain
Separator Grates - Small Grain
Separator Grates - Large Grain
Return Pan
Return Pan - Right Side
Return Pan - Left Side
-000-Toc Cleaning System
Cleaning Fan - Frame
Cleaning Fan - Fanning Mill
Pitman Shaft
Stratification Pan
Chaffer Frame
Sieve Frame
Sieve Frame - 4 Channel
Sieve & Chaffer - Wind Wings
Discharge Extension - Chaff Spreader
Discharge Extension - Straw Spreader
Sieve & Chaffer - Small Grain
Sieve - Large Grain
Chaffer - Large Grain
Tailings Elevator - Standard
Tailings Elevator - High Wear
Tailings Elevator - Gearbox (Components)
-000-Toc Grain Bin And Elevator System
Grain Bin _ 12500l
Grain Bin _ 12500l - Right Side
Grain Bin _ 12500l - Rear Panel
Grain Bin _ 12500l - Access Door
Grain Bin _ 17100l
Grain Bin _ 17100l - Right Side
Grain Bin _ 17100l - Rear Panel
Grain Bin _ 17100l - Access Door
Grain Bin _ 12500l - Extension (Hydraulic)
Grain Bin _ 17100l - Extension (Hydraulic)
Grain Bin _ 12500l - Unloader Gate (Manual)
Grain Bin _ 12500l - Unloader Gate (Hydraulic)
Grain Bin _ 17100l - Unloader Gate (Hydraulic)
Grain Bin - Unloader Gate (Hydraulic)
Sump & Turret - 12500l
Sump & Turret - 17100l
Unloader _ Cradle - 12500l
Unloader _ Cradle - 17100l
Unloader Tube - 12500l
Unloader Tube - 17100l
Bin Unloader Auger - 12500l
Bin Unloader Auger - 17100l
Spill Saver - Small
Spill Saver - Low Capacity
Spill Saver - Large
Spill Saver - High Capacity
Grain Elevator
Grain Elevator - Bin Loader
Grain Elevator - Filling Auger
Grain Elevator - Elevator Auger
Grain Elevator - Cleanout Doors
-000-Toc Discharge System
Straw Chopper - Brackets
Straw Chopper - Housing
Straw Chopper
Straw Chopper - Knife
Straw Chopper - Cover
Straw Deflector - Cover
Straw Deflector - Manual Adjustable
Straw Deflector - Electrical Adjustment
Straw Deflector
Activespread - Cover
Activespread - Manual Adjustable
Activespread - Electrical Adjustment
Activespread
Activespread - Gaskets
Activespread - Deflector
Straw Spreader
Chaff Spreader - Manual Adjustable
Chaff Spreader - Electrical Adjustment
-000-Toc Precision Farming Systems
Guidance - Module
Agco Connectivity Module (Acm)
Guidance Receiver - Novatel
Guidance Receiver - Trimble
Trimble - Upgrade
Antenna - Novatel
-000-Toc Accessories
Accessories - Block Heater
Block Heater
Def Fill Kit
Def Drain System
Lockable Fuel Tank Cap
Door Stopper
Smart Device Mounting
Multiple Camera Display
Rear View Camera
Guidance
Guidance - Trimble
Novatel Upgrade
Ladder Actuator
Advanced Lighting
Lights - Rear Axle
Cover - Axle
Accessories - 3rd Axle
Removable - Feeder
Feeder Floor
Wear Resistant Bottom
Flip-Up Header Light
Accessories - Folding Cutter Bar Light
Conversion Kit - Autodock
Automatic Dock - Universal
Quick Hydraulic Couplers (Multi-Faster) - Universal
Coupling - Header
Corn Header Folding Hydraulic
Jumper Kit - Automatic Header Height Control
Jumper Harness
Jumper Harness - Dust Ejector
Jumper Connector
Egr Jumper
Spout Sock (Small)
Spout Sock (Large)
Tailings Elevator - Hatchs
Accessories - Tailings Elevator - Hatchs
Accessories - Tailings Elevator - Cover (Large Grain)
Frame
Sensor - Cradle
Grain Bin Corners
Grain Bin Corners - Low Capacity
Grain Bin Corners - High Capacity
Grain Bin Unloading - Speed Reduction
Lifting Mechanism
Kit - Active Tailboard
Kit - Passive Tailboard Powered
Passive Tailboard Powered - Cover
Wiring Harness - Passive Tailboard Powered
Passive Tailboard Powered - Electrical Adjustment
Chaffer Actuator Repair
Sieve & Chaffer - Large Grain
Conversion Kit - Large Grain
Conversion Kit - Dry Small Grain
Deflector Kit - Small Grain
Grass Seed (High Capacity Unloader)
Warning Plates
Brand: Fendt
Filters Guide
Sensors Guide
Paints Guide
Engine - Retainer
Crankcase
Flywheel & Housing
Valve Rocker Cover
Air Intake
Exhaust Manifold
Turbocharger
Oil Pump & Sump
Coolant Piping
Fuel Filters
Belt Tensioner
Engine Gasket Kits
Engine Block Heater
Engine Bracket
Cooling - Fan Drive
Cooling - Fan
Cooling - Hoses
Cooling - Plugs
Exhaust System
Engine Air Filter
Dust Aspirator
Def System
Def - Filters
Fuel - Lines
Engine Gearbox
Shaft (Components)
Idler Arm
Gearbox - Cooling
Shaker Shoe Drive
-000-Toc Axles
Front Axle - Tracks
Rear Axle - Pin
Hitch
Hitch - 3rd Axle
Hitch Drop Pin
Hitch - Automatic
Hydraulic Lines
Gearbox
Gearbox - Housing
Gearbox - Piping
Gearbox - Valve
Brake Pedals
Disc Brakes
Oil Tank
Idealdrive
Main Plumbing
Hydraulic Propel
3rd Axle
Cutting Header
Concave Adjustment
Grain Bin
Unloader Swing
Spill Saver
Boost Pump
Chaff Spreader
Sensors - Hydraulic
Sensors - Grain Bin
Work Lights
Lighting - Roof
Batteries & Cables
Main Harness
Ground Drive
360° Camera System
Without Rear Camera
Rear Camera
Camera - Quad
Actuator - Ladder
-000-Toc Cab
Cab Support
Cab Frame
Roof
Roof - Trim
Washer & Wiper
Cab Glass
Door - Left Side
Trim
Cab - Cool Box
Passenger Seat
Armrest
Armrest - Base
Mobile Phone Holder
Radio And Antenna
Rear View Mirror
Platform Extension
Steps - Ladder
Latch - Ladder
Tools
Wheel Chocks
Fire Extinguisher
Hvac Lines
-000-Toc Chassis
Frame - Bottom
Frame - Top
Stone Trap
Shields - Bottom
Fuel - Tank Bracket
Engine Cover
Hinge - Side Panels
Strut - Right Side
Panel - Air Box
Sheet Metal - Rear
Strut - Left Side
Latch - Rear Left
Handles
Signaling Panels
-000-Toc Decals
Decals - Standard
Decals - Speed
-000-Toc Wheels
Tracks
Track Roller
Tracks - Front
Tracks - Rear
Tracks - Tensioner
Tracks - Bogie
Tracks - Wheels
Tracks - Cylinder
Tracks - Scrapers
Shield Plate
Tilt Frame
Header Lock
Upper Shaft
Feed Drum
Feeder Chain
Dust Ejector
Multi-Connector
Return Pan
Pitman Shaft
Stratification Pan
Chaffer Frame
Sieve Frame
Sieve - Large Grain
Grain Bin _ 12500l
Grain Bin _ 17100l
Spill Saver - Small
Spill Saver - Large
Grain Elevator
Straw Chopper
Straw Deflector
Activespread
Straw Spreader
Guidance - Module
Trimble - Upgrade
Antenna - Novatel
Block Heater
Def Fill Kit
Def Drain System
Door Stopper
Rear View Camera
Guidance
Guidance - Trimble
Novatel Upgrade
Ladder Actuator
Advanced Lighting
Lights - Rear Axle
Cover - Axle
Removable - Feeder
Feeder Floor
Coupling - Header
Jumper Harness
Jumper Connector
Egr Jumper
Spout Sock (Small)
Spout Sock (Large)
Frame
Sensor - Cradle
Grain Bin Corners
Lifting Mechanism
Warning Plates
