Hyundai
86
176,834
Fendt Combine IDEAL 9 GEN 3 Parts Catalog 2023-2024
Brand: Fendt
Type of Machine: Combine
Model: Fendt IDEAL 9 GEN 3 Combine
Publication Date: 2023-2024
Number of Pages: 2443 Pages
00-TOC TABLE OF CONTENT PAG 00-TOC Tech Spec Notes Ref
01-000-TOC GENERAL INFORMATION PAG 01-000-TOC Tech Spec Notes Ref
FILTERS GUIDE PAG 01-0001
BELTS GUIDE - RIGHT SIDE PAG 01-0002
BELTS GUIDE - LEFT SIDE PAG 01-0003
SENSORS GUIDE PAG 01-0004
SENSORS GUIDE PAG 01-0005
PAINTS GUIDE PAG 01-0006
02-000-TOC ENGINE ACX2846390 D3876LE124C T3_LRC PAG 02-000-TOC Tech Spec Notes Ref
ENGINE - RETAINER PAG 02-0001
CRANKCASE PAG 02-0002
TIMING GEARS & HOUSING PAG 02-0003
FLYWHEEL & HOUSING PAG 02-0004
CRANKSHAFT & PISTONS PAG 02-0005
CAMSHAFT & VALVE MECHANISM PAG 02-0006
CYLINDER HEAD & VALVE MECHANISM PAG 02-0007
VALVE ROCKER COVER PAG 02-0008
AIR INTAKE PAG 02-0009
EXHAUST MANIFOLD PAG 02-0010
EXHAUST MANIFOLD PAG 02-0011
TURBOCHARGER PAG 02-0012
EXHAUST GAS RECIRCULATION (EGR) PAG 02-0013
EXHAUST GAS RECIRCULATION (EGR) PAG 02-0014_1
OIL PUMP & SUMP PAG 02-0015
OIL COOLER & OIL FILTER PAG 02-0016
COOLANT PIPING PAG 02-0017
COOLANT PUMP & THERMOSTAT PAG 02-0018
FUEL INJECTION SYSTEM PAG 02-0019
FUEL FILTERS PAG 02-0020
ELECTRONIC ENGINE MANAGEMENT - SENSOR PAG 02-0021
ELECTRONIC ENGINE MANAGEMENT - WIRING HARNESS PAG 02-0022
ELECTRONIC ENGINE MANAGEMENT - BRACKET PAG 02-0023
ELECTRONIC ENGINE MANAGEMENT - BRACKET PAG 02-0024
WIRING HARNESS - INJECTOR PAG 02-0025
BELT TENSIONER PAG 02-0026
ENGINE GASKET KITS PAG 02-0027
SPECIAL OVERHAUL PARTS PAG 02-0028
03-000-TOC ENGINE ACX2840010 D3876LE123D T4F PAG 03-000-TOC Tech Spec Notes Ref
ENGINE - RETAINER PAG 03-0001
CRANKCASE PAG 03-0002
TIMING GEARS & HOUSING PAG 03-0003
FLYWHEEL & HOUSING PAG 03-0004
CRANKSHAFT & PISTONS PAG 03-0005
CAMSHAFT & VALVE MECHANISM PAG 03-0006
CYLINDER HEAD & VALVE MECHANISM PAG 03-0007_1
VALVE ROCKER COVER PAG 03-0008
AIR INTAKE PAG 03-0009
EXHAUST MANIFOLD PAG 03-0010
EXHAUST MANIFOLD PAG 03-0011
TURBOCHARGER PAG 03-0012
TURBOCHARGER PAG 03-0013
EXHAUST GAS RECIRCULATION (EGR) PAG 03-0014
EXHAUST GAS RECIRCULATION (EGR) PAG 03-0015
EXHAUST GAS RECIRCULATION (EGR) PAG 03-0016
OIL PUMP & SUMP PAG 03-0017
OIL COOLER & OIL FILTER PAG 03-0018
COOLANT PIPING PAG 03-0019
COOLANT PUMP & THERMOSTAT PAG 03-0020
FUEL INJECTION SYSTEM PAG 03-0021
FUEL FILTERS PAG 03-0022
ELECTRONIC ENGINE MANAGEMENT - SENSOR PAG 03-0023
ELECTRONIC ENGINE MANAGEMENT - WIRING HARNESS PAG 03-0024
ELECTRONIC ENGINE MANAGEMENT - BRACKET PAG 03-0025
ELECTRONIC ENGINE MANAGEMENT - BRACKET PAG 03-0026
WIRING HARNESS - INJECTOR PAG 03-0027
BELT TENSIONER PAG 03-0028
ENGINE GASKET KITS PAG 03-0029
SPECIAL OVERHAUL PARTS PAG 03-0030
04-000-TOC ENGINE ACX2841630 D3876LE126C STAGE 5 PAG 04-000-TOC Tech Spec Notes Ref
ENGINE - RETAINER PAG 04-0001
CRANKCASE PAG 04-0002
TIMING GEARS & HOUSING PAG 04-0003
FLYWHEEL & HOUSING PAG 04-0004
CRANKSHAFT & PISTONS PAG 04-0005
CAMSHAFT & VALVE MECHANISM PAG 04-0006
CYLINDER HEAD & VALVE MECHANISM PAG 04-0007
VALVE ROCKER COVER PAG 04-0008
AIR INTAKE PAG 04-0009
EXHAUST MANIFOLD PAG 04-0010
EXHAUST MANIFOLD PAG 04-0011
TURBOCHARGER PAG 04-0012
EXHAUST GAS RECIRCULATION (EGR) PAG 04-0013
EXHAUST GAS RECIRCULATION (EGR) PAG 04-0014
EXHAUST GAS RECIRCULATION (EGR) PAG 04-0015
OIL PUMP & SUMP PAG 04-0016
OIL COOLER & OIL FILTER PAG 04-0017
COOLANT PIPING PAG 04-0018
COOLANT PUMP & THERMOSTAT PAG 04-0019
FUEL INJECTION SYSTEM PAG 04-0020
FUEL FILTERS PAG 04-0021
ELECTRONIC ENGINE MANAGEMENT - SENSOR PAG 04-0022
ELECTRONIC ENGINE MANAGEMENT - WIRING HARNESS PAG 04-0023
ELECTRONIC ENGINE MANAGEMENT - BRACKET PAG 04-0024,04-0025
WIRING HARNESS - INJECTOR PAG 04-0026
BELT TENSIONER PAG 04-0027
ENGINE GASKET KITS PAG 04-0028
SPECIAL OVERHAUL PARTS PAG 04-0029
05-000-TOC ENGINE INSTALLATION PAG 05-000-TOC Tech Spec Notes Ref
ENGINE, ALTERNATOR, STARTER MOTOR & OIL DRAIN PAG 05-0001 to 05-0006
ENGINE - OIL DRAINAGE SYSTEM PAG 05-0007
ENGINE BRACKET PAG 05-0008
ENGINE BLOCK HEATER PAG 05-0009
ENGINE BLOCK HEATER PAG 05-0010
COOLING - FAN DRIVE PAG 05-0011
COOLING - FAN & FAN SHROUD PAG 05-0012
COOLING - FAN PAG 05-0013
COOLING - HOSES PAG 05-0014
COOLING - HOSES PAG 05-0015
COOLING - EXPANSION TANK PAG 05-0016
COOLING - FAN SHROUD & SUPPORT PAG 05-0017
COOLING - FAN SHROUD & SUPPORT PAG 05-0018
COOLING - RADIATOR & COOLERS PAG 05-0019
COOLING - PLUGS PAG 05-0020
DUST ASPIRATOR PAG 05-0021
ENGINE AIR FILTER PAG 05-0022
EXHAUST SYSTEM PAG 05-0023
EXHAUST SYSTEM PAG 05-0024
EXHAUST SYSTEM - COVER PAG 05-0025 to 05-0029
EXHAUST SYSTEM - SENSORS PAG 05-0030, 05-0031
DEF SYSTEM PAG 05-0032, 05-0033
DEF - FILTERS PAG 05-0034
EXHAUST - DEF TANK (COMPONENTS) PAG 05-0035
FUEL - TANK (COMPONENTS) PAG 05-0036 to 05-0038
FUEL - LINES PAG 05-0039,05-0040
AIR COMPRESSOR - COMPRESSOR & LINES PAG 05-0041
AIR COMPRESSOR - TANK PAG 05-0042
AIR COMPRESSOR - LINES AND FITTINGS PAG 05-0043
06-000-TOC DRIVE SYSTEM PAG 06-000-TOC Tech Spec Notes Ref
ENGINE GEARBOX PAG 06-0001
ENGINE GEARBOX PAG 06-0002
ENGINE GEARBOX (COMPONENTS) PAG 06-0003
ENGINE GEARBOX (COMPONENTS) PAG 06-0004
HEADER DRIVE - BOTTOM PAG 06-0005
HEADER DRIVE - BOTTOM PAG 06-0006
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 06-0007
HEADER DRIVE - BOTTOM PAG 06-0008 to 06-0012
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 06-0009
HEADER DRIVE - BOTTOM PAG 06-0013
HEADER DRIVE - BOTTOM PAG 06-0015
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 06-0011
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 06-0014
HEADER DRIVE - BOTTOM PAG 06-0017
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 06-0016
FIXED SPEED HEADER DRIVE - TOP PAG 06-0019
FIXED SPEED HEADER DRIVE - TOP PAG 06-0020
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 06-0018
GEARBOX (COMPONENTS) - FIXED SPEED HEADER DRIVE PAG 06-0021
GEARBOX (COMPONENTS) - FIXED SPEED HEADER DRIVE PAG 06-0022
FIXED SPEED HEADER DRIVE - TOP PAG 06-0023
FIXED SPEED HEADER DRIVE - TOP PAG 06-0024
GEARBOX (COMPONENTS) - VARIABLE SPEED HEADER DRIVE PAG 06-0036
TIE ROD - HEADER DRIVE PAG 06-0037
GEARBOX (COMPONENTS) - VARIABLE SPEED HEADER DRIVE PAG 06-0035
FEEDER CONVEYOR DRIVE - FIXED SPEED PAG 06-0038
FEEDER CONVEYOR DRIVE - TWO SPEED PAG 06-0039
FEEDER CONVEYOR DRIVE - TWO SPEED PAG 06-0040
BEATER DRIVE - SINGLE SPEED ROTOR DRIVE PAG 06-0041
BEATER DRIVE - SINGLE SPEED ROTOR DRIVE PAG 06-0042
BEATER DRIVE - TWO SPEED ROTOR DRIVE PAG 06-0043
BEATER DRIVE - TWO SPEED ROTOR DRIVE PAG 06-0044
BEATER DRIVE - SHIELD PAG 06-0045
SINGLE AND DUAL ROTOR DRIVE - FIXED SPEED PAG 06-0046 to 06-0048
DUAL ROTOR DRIVE - FIXED SPEED PAG 06-0049
DUAL ROTOR DRIVE - FIXED SPEED PAG 06-0050
GEARBOX (COMPONENTS) - FIXED SPEED PAG 06-0051
GEARBOX (COMPONENTS) - FIXED SPEED PAG 06-0052
UNIVERSAL JOINT (COMPONENTS) PAG 06-0053
DUAL ROTOR DRIVE - 2 SPEEDS PAG 06-0054 to 06-0059
GEARBOX (COMPONENTS) - ROTOR DRIVE PAG 06-0060 to 06-0062
IDLER ARM PAG 06-0063
GEARBOX - COOLING PAG 06-0064
GEARBOX - COOLING PAG 06-0065
GEARBOX - COOLING PAG 06-0066
COUNTERSHAFT - DRIVE PAG 06-0067
SHAKER SHOE DRIVE PAG 06-0068
CLEANING FAN - DRIVE PAG 06-0069
GRAIN ELEVATOR - DRIVE PAG 06-0070
GRAIN ELEVATOR - SECONDARY DRIVE PAG 06-0071
GRAIN BIN UNLOADING - DRIVE PAG 06-0072 to 06-0077
GEARBOX (COMPONENTS) - GRAIN BIN UNLOADING PAG 06-0078
STRAW CHOPPER - DRIVE PAG 06-0081
STRAW CHOPPER - DRIVE PAG 06-0082
GEARBOX (COMPONENTS) - GRAIN BIN UNLOADING PAG 06-0079
STRAW CHOPPER - DRIVE PAG 06-0083
07-000-TOC AXLES PAG 07-000-TOC Tech Spec Notes Ref
GEARBOX (COMPONENTS) - GRAIN BIN UNLOADING PAG 06-0080
FRONT AXLE - STANDARD PAG 07-0001
FRONT AXLE - STANDARD PAG 07-0002
FRONT AXLE - PARALEVEL PAG 07-0003
FRONT AXLE - PARALEVEL PAG 07-0004
FRONT AXLE - PARALEVEL PAG 07-0005
FRONT AXLE - TRACKS PAG 07-0006_1
FRONT AXLE - TRACKS PAG 07-0007
PULLED REAR AXLE - PIN PAG 07-0008
REAR AXLE - PIN PAG 07-0009
REAR AXLE - 2 WHEEL DRIVE - (COMPONENTS) PAG 07-0011
REAR AXLE - 2 WHEEL DRIVE PAG 07-0010
REAR AXLE - 2 WHEEL DRIVE - (COMPONENTS) PAG 07-0012 to 07-0017
REAR AXLE - 4 WHEEL DRIVE PAG 07-0014
HITCH PAG 07-0021
REAR AXLE - 4 WHEEL DRIVE PAG 07-0014_1
HITCH PAG 07-0022
HITCH - 3RD AXLE PAG 07-0023
HITCH DROP PIN PAG 07-0024
HITCH - AUTOMATIC PAG 07-0025
08-000-TOC STEERING SYSTEM PAG 08-000-TOC Tech Spec Notes Ref
HITCH - AUTOMATIC PAG 07-0026
STEERING WHEEL & COLUMN PAG 08-0001
09-000-TOC DRIVETRAIN SYSTEM PAG 09-000-TOC Tech Spec Notes Ref
HYDRAULIC LINES PAG 08-0003
TRANSMISSION - PARALEVEL PAG 09-0002
TRANSMISSION - STANDARD PAG 09-0001
TRANSMISSION - TRACKS PAG 09-0004 to 09-0006
FINAL DRIVE (COMPONENTS) - WHEELS PAG 09-0008
TRANSMISSION - TRACKS PAG 09-0007
FINAL DRIVE (COMPONENTS) - TRACKS PAG 09-0009 to 09-0012
GEARBOX PAG 09-0013
GEARBOX - HOUSING PAG 09-0014
GEARBOX - HOUSING PAG 09-0015
GEARBOX - SUCTION LINE PAG 09-0025
10-000-TOC BRAKE SYSTEM PAG 10-000-TOC Tech Spec Notes Ref
BRAKE PEDALS PAG 10-0001
BRAKE LINES - STANDARD & TRACKS PAG 10-0002
BRAKE LINES - PARALEVEL PAG 10-0003
DISC BRAKES PAG 10-0004
DISC BRAKES PAG 10-0005
PARKING BRAKE PAG 10-0006
11-000-TOC HYDRAULIC SYSTEM PAG 11-000-TOC Tech Spec Notes Ref
OIL TANK PAG 11-0001
OIL TANK PAG 11-0002
HYDRAULIC PUMP - STANDARD STEERING PAG 11-0003
HYDRAULIC PUMP - IDEALDRIVE PAG 11-0004
IDEALDRIVE PAG 11-0005
ENGINE GEARBOX - HYDRAULIC PAG 11-0007
MAIN PLUMBING PAG 11-0006
ENGINE GEARBOX - HYDRAULICS PAG 11-0008
HYDRAULIC PROPEL - STANDARD & PARALEVEL PAG 11-0009
HYDRAULIC PROPEL - STANDARD & PARALEVEL PAG 11-0010
HYDRAULIC PROPEL - TRACKS PAG 11-0012
HYDRAULIC PROPEL - TRACKS PAG 11-0011
HYDRAULIC MOTOR - COMPONENTS PAG 11-0013
HYDRAULIC PROPEL PAG 11-0014 to 11-0017
REAR AXLE - 4 WHEEL DRIVE PAG 11-0018 to 11-0020
3RD AXLE PAG 11-0021
FRONT AXLE - STANDARD & TRACKS PAG 11-0022
FRONT AXLE - PARALEVEL PAG 11-0023
FRONT AXLE - PARALEVEL PAG 11-0024
FRONT AXLE - VALVE BLOCK (COMPONENTS) PAG 11-0025
FRONT AXLE - VALVE BLOCK (COMPONENTS) PAG 11-0026
CUTTING HEADER - LIFTING - STANDARD PAG 11-0027
CUTTING HEADER - LIFTING - PARALEVEL PAG 11-0028
CUTTING HEADER - SUSPENSION PAG 11-0029
CUTTING HEADER - MANUAL CUTTING ANGLE ADJUSTMENT PAG 11-0030
CUTTING HEADER - MANUAL CUTTING ANGLE ADJUSTMENT PAG 11-0031
CUTTING HEADER - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 11-0032 to 11-0035
QUICK HYDRAULIC COUPLERS (MULTI-FASTER) PAG 11-0038
CUTTING HEADER - VALVE BLOCK (COMPONENTS) PAG 11-0036
CUTTING HEADER - VALVE BLOCK (COMPONENTS) PAG 11-0037
CUTTING HEADER PAG 11-0039
CUTTING HEADER PAG 11-0041
CUTTING HEADER PAG 11-0040
CUTTING HEADER - VALVE BLOCK (COMPONENTS) PAG 11-0042
QUICK HYDRAULIC COUPLERS (MULTI-FASTER) PAG 11-0043
CUTTING HEADER - REVERSER PAG 11-0044
CUTTING HEADER - REVERSER - VALVE BLOCK (COMPONENTS) PAG 11-0045
CONCAVE ADJUSTMENT PAG 11-0046
CONCAVE ADJUSTMENT - VALVE BLOCK (COMPONENTS) PAG 11-0047
ROTOR REVERSER - 2 SPEEDS PAG 11-0048
GRAIN BIN PAG 11-0049
GRAIN BIN - VALVE BLOCK (COMPONENTS) PAG 11-0050 to 11-0053
GRAIN BIN - WITH HYDRAULIC GATES PAG 11-0054
GRAIN BIN - WITH HYDRAULIC EXTENSIONS PAG 11-0055
UNLOADER SWING PAG 11-0056
SPILL SAVER PAG 11-0057
BOOST PUMP - VALVE BLOCK (COMPONENTS) PAG 11-0059
BOOST PUMP PAG 11-0058
BOOST PUMP - VALVE BLOCK (COMPONENTS) PAG 11-0060
BOOST PUMP (UNLOADER) - FIXED SPEED HEADER DRIVE PAG 11-0061
GRASS SEED (LOW CAPACITY UNLOADER) PAG 11-0063
BOOST PUMP (UNLOADER) - VARIABLE SPEED HEADER DRIVE PAG 11-0062
GRASS SEED - STREAMER 140 & 210 PAG 11-0064
STRAW SPREADER - STANDARD STEERING PAG 11-0065
STRAW SPREADER - STANDARD STEERING PAG 11-0066
STRAW SPREADER - IDEALDRIVE PAG 11-0067
STRAW SPREADER - IDEALDRIVE PAG 11-0068
ACTIVESPREAD - STANDARD STEERING PAG 11-0069
ACTIVESPREAD - STANDARD STEERING PAG 11-0070
ACTIVESPREAD - IDEALDRIVE PAG 11-0071
ACTIVESPREAD - IDEALDRIVE PAG 11-0072
ACTIVESPREAD SWINGFLOW - STANDARD STEERING PAG 11-0073
ACTIVESPREAD SWINGFLOW - IDEALDRIVE PAG 11-0074
PASSIVESPREAD - IDEALDRIVE PAG 11-0077
ACTIVESPREAD SWINGFLOW PAG 11-0075
ACTIVESPREAD SWINGFLOW - VALVE BLOCK (COMPONENTS) PAG 11-0076
CHAFF SPREADER PAG 11-0078
CHAFF SPREADER PAG 11-0080
LUBRICATION PIPES - PARALEVEL PAG 11-0081
CHAFF SPREADER PAG 11-0079
LUBRICATION PIPES - STANDARD & TRACKS PAG 11-0082
12-000-TOC ELECTRICAL SYSTEM PAG 12-000-TOC Tech Spec Notes Ref
SENSORS - HYDRAULIC PAG 12-0001
SENSORS - GRAIN BIN PAG 12-0002
SENSORS - GROUND DRIVE PAG 12-0003
SENSORS - ROTOR DRIVE PAG 12-0004
LIGHTING - ROAD LIGHTS PAG 12-0005 to 12-0018
FRONT LIGHTING - VALANCE PAG 12-0019
LIGHTING - FRONT LIGHTS PAG 12-0020
LIGHTING - FRONT LIGHTS PAG 12-0021
LIGHTING - FRONT LIGHTS PAG 12-0022
WORK LIGHTS PAG 12-0023
WORK LIGHTS PAG 12-0024
WIRING HARNESS - REAR LIGHTING PAG 12-0026
WORK LIGHTS - REAR AXLE PAG 12-0025
WIRING HARNESS - REAR LIGHTING PAG 12-0027
WIRING HARNESS - REAR LIGHTING PAG 12-0028
LIGHTING - ROOF PAG 12-0029
LIGHTING - ROOF PAG 12-0030
LIGHTING - ROTARY BEACON PAG 12-0031
LIGHTING - ROTARY BEACON PAG 12-0032
UNLOADER - ROTARY BEACON PAG 12-0033
BATTERIES & CABLES PAG 12-0034 to 12-0039
BATTERIES & CABLES - (MAIN CIRCUIT FUSES) PAG 12-0040
MAIN HARNESS PAG 12-0041 to 12-0050
WIRING HARNESS - FEEDER CONVEYOR PAG 12-0051 to 12-0054
WIRING HARNESS - FRONT AXLE PAG 12-0055 to 12-0062
WIRING HARNESS - REAR AXLE - 2 WHEEL DRIVE PAG 12-0063 to 12-0066
WIRING HARNESS - 3RD AXLE PAG 12-0067
WIRING HARNESS - 3RD AXLE PAG 12-0068
WIRING HARNESS - IDEALDRIVE PAG 12-0069 to 12-0076
WIRING HARNESS - CAB PAG 12-0077 to 12-0083
WIRING HARNESS - ENGINE PAG 12-0084 to 12-0088
GROUND DRIVE - IDEALDRIVE PAG 12-0089
GROUND DRIVE - IDEALDRIVE PAG 12-0090
GROUND DRIVE PAG 12-0091
WIRING HARNESS - CONCAVE ADJUSTMENT PAG 12-0092
WIRING HARNESS - CONCAVE ADJUSTMENT PAG 12-0093
WIRING HARNESS - CLEANING SHOE PAG 12-0094
WIRING HARNESS - CLEANING SHOE PAG 12-0095
WIRING HARNESS - GRAIN BIN PAG 12-0096 to 12-0099
WIRING HARNESS - GRAIN BIN UNLOADING PAG 12-0100 to 12-0118
WIRING HARNESS - VERTICAL KNIFE PAG 12-0119
WIRING HARNESS - VERTICAL KNIFE PAG 12-0120
WIRING HARNESS - STRAW CHOPPER PAG 12-0122 to 12-0131
WIRING HARNESS - STRAW CHOPPER & TAILBOARD PAG 12-0132 to 12-0134
WIRING HARNESS - STRAW DEFLECTOR PAG 12-0135
WIRING HARNESS - STRAW DEFLECTOR PAG 12-0136
WIRING HARNESS - STRAW SPREADER PAG 12-0137
WIRING HARNESS - STRAW SPREADER PAG 12-0138
WIRING HARNESS - STRAW SPREADER PAG 12-0139
WIRING HARNESS - ACTIVESPREAD PAG 12-0140 to 12-0147
WIRING HARNESS - ACTIVESPREAD SWINGFLOW PAG 12-0149
WIRING HARNESS - ACTIVESPREAD SWINGFLOW PAG 12-0148
WIRING HARNESS - CHAFF SPREADER PAG 12-0150 to 12-0152
CHAFF SPREADER PAG 12-0153
GRAIN LOSS MONITOR - NO AUTOMATION PAG 12-0154
GRAIN LOSS MONITOR - NO AUTOMATION PAG 12-0155
GRAIN LOSS MONITOR - NO AUTOMATION PAG 12-0156
GRAIN LOSS MONITOR - SELF ADJUST PAG 12-0161 to 12-0165
YIELD MONITOR SYSTEM PAG 12-0166
YIELD MONITOR SYSTEM PAG 12-0167
360° CAMERA SYSTEM - CAMERA READY PAG 12-0168
360° CAMERA SYSTEM - CAMERA READY PAG 12-0169
360° CAMERA SYSTEM PAG 12-0170 to 12-0172
WITHOUT REAR CAMERA PAG 12-0174
REAR CAMERA PAG 12-0175
REAR CAMERA PAG 12-0176
QUAD CAMERA DISPLAY MONITOR PAG 12-0177
CAMERA - QUAD PAG 12-0178
TAILLIGHT - UNLOADER TUBE PAG 12-0179 to 12-0187
ACTUATOR - LADDER PAG 12-0188 to 12-0192
13-000-TOC CAB PAG 13-000-TOC Tech Spec Notes Ref
CAB SUPPORT PAG 13-0001
CAB FRAME PAG 13-0002
CAB FRAME PAG 13-0003
ROOF PAG 13-0004
ROOF - TRIM PAG 13-0005
WASHER & WIPER PAG 13-0006
CAB GLASS PAG 13-0007
DOOR - LEFT SIDE PAG 13-0008
TRIM PAG 13-0009
CAB - NOISE REDUCTION PAG 13-0010
CAB - NOISE REDUCTION PAG 13-0011
CAB - INTERIOR EQUIPMENTS PAG 13-0012
CAB - COOL BOX PAG 13-0013
OPERATOR SEAT - STANDARD PAG 13-0014
OPERATOR SEAT - DELUXE PAG 13-0015
OPERATOR SEAT - DELUXE PAG 13-0017
OPERATOR SEAT (COMPONENTS) - DELUXE PAG 13-0016
OPERATOR SEAT - IDEALDRIVE PAG 13-0018
OPERATOR SEAT (COMPONENTS) PAG 13-0019
OPERATOR SEAT (COMPONENTS) PAG 13-0020
PASSENGER SEAT PAG 13-0021
PASSENGER SEAT PAG 13-0022
ARMREST PAG 13-0023
CONTROL PANEL - ADJUSTING DEVICE PAG 13-0024
MONITOR - SWIVEL ARM PAG 13-0025
MONITOR - SWIVEL ARM PAG 13-0026
ARMREST - IDEALDRIVE PAG 13-0027
ARMREST - IDEALDRIVE PAG 13-0028
ARMREST - BASE PAG 13-0029
MOBILE PHONE HOLDER PAG 13-0030
MOBILE PHONE HOLDER PAG 13-0031
TABLET HOLDER - SWIVEL ARM PAG 13-0032
TABLET HOLDER - SWIVEL ARM PAG 13-0033
RADIO AND ANTENNA PAG 13-0034
RADIO AND ANTENNA PAG 13-0035
SPEAKERS - NO SUBWOOFER PAG 13-0036
SPEAKERS - SUBWOOFER PAG 13-0037
REAR VIEW MIRROR PAG 13-0038
PLATFORM & LADDER - WITH WHEELS PAG 13-0039 to 13-0043
PLATFORM EXTENSION PAG 13-0045 to 13-0048
STEPS - LADDER PAG 13-0049
LATCH - LADDER PAG 13-0051
LATCH - LADDER PAG 13-0050
TOOLS PAG 13-0052
WHEEL CHOCKS PAG 13-0053
FIRE EXTINGUISHER PAG 13-0055 to 13-0056
14-000-TOC AIR CONDITIONING AND HEATING SYSTEM PAG 14-000-TOC Tech Spec Notes Ref
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 14-0001 to 14-0003
HVAC LINES PAG 14-0004
HVAC LINES PAG 14-0005
15-000-TOC CHASSIS PAG 15-000-TOC Tech Spec Notes Ref
FRAME - BOTTOM PAG 15-0001 to 15-0005
FRAME - TOP PAG 15-0006
TWIN ROTOR - WEAR PLATE PAG 15-0008
FRAME - TOP PAG 15-0007
TWIN ROTOR - WEAR PLATE PAG 15-0009
TWIN ROTOR - WEAR PLATE PAG 15-0010
TWIN ROTOR - WEAR PLATE PAG 15-0011
PROCESSOR DOORS - DUAL ROTOR PAG 15-0012 to 15-0016
STONE TRAP SLIDE - STANDARD PAG 15-0017
STONE TRAP SLIDE - PARALEVEL PAG 15-0018
STONE TRAP SLIDE - DUAL WHEELS PAG 15-0019
STONE TRAP SLIDE - TRACKS PAG 15-0020
STONE TRAP PAG 15-0021
STONE TRAP - COVER (LARGE GRAIN) PAG 15-0022
SHIELDS - CLEANING FAN PAG 15-0023 to 15-0028
SHIELDS - BOTTOM PAG 15-0029 to 15-0033
HEADER DRIVE - SHIELD PAG 15-0034
REAR PANEL - SINGLE SPEED PAG 15-0035
REAR PANEL - TWO SPEED PAG 15-0036
ENGINE ACCESS - LADDER PAG 15-0037
ENGINE ACCESS - DECK PLATES PAG 15-0038
ENGINE ACCESS - DECK PLATES PAG 15-0039
ENGINE ACCESS - RAILING PAG 15-0040 to 15-0042
FUEL - TANK BRACKET PAG 15-0043
ENGINE COVER PAG 15-0044
ENGINE COVER PAG 15-0045
SHEET METAL - BRACKETS PAG 15-0047
HINGE - SIDE PANELS PAG 15-0048
SHEET METAL - GRAIN BIN DOOR PAG 15-0049
SHEET METAL - GRAIN BIN DOOR PAG 15-0050
SHEET METAL - REAR RIGHT PAG 15-0051
SHEET METAL - RIGHT SIDE PAG 15-0052
STRUT - RIGHT SIDE PAG 15-0053
PANEL - AIR BOX PAG 15-0054
SHEET METAL - REAR PAG 15-0055
SHEET METAL - LEFT SIDE PAG 15-0056
SHEET METAL - LEFT SIDE PAG 15-0057
SHEET METAL - LEFT SIDE PAG 15-0058
STRUT - LEFT SIDE PAG 15-0059
SHEET METAL - REAR LEFT PAG 15-0060
LATCH - REAR LEFT PAG 15-0061
THRESHING MECHANISM - ACCESS PAG 15-0062
THRESHING MECHANISM - ACCESS PAG 15-0063
HANDLES PAG 15-0064
STRAW CHOPPER - SHIELD PAG 15-0065
STRAW CHOPPER - SHIELD PAG 15-0066
SIGNALING PANELS PAG 15-0067
SIGNALING PANELS PAG 15-0068
SIGNALING PANELS PAG 15-0069
SIGNALING PANELS PAG 15-0070
16-000-TOC DECALS PAG 16-000-TOC Tech Spec Notes Ref
DECALS - STANDARD PAG 16-0001
DECALS PAG 16-0002
DECALS - SPEED PAG 16-0003
DECALS - SAFETY & WARNING PAG 16-0004 to 16-0009
17-000-TOC WHEELS PAG 17-000-TOC Tech Spec Notes Ref
FRONT WHEELS - STANDARD - 800_70 R32 PAG 17-0001
FRONT WHEELS - STANDARD - 800_70 R32 PAG 17-0002
FRONT WHEELS - STANDARD - 900_60 R32 PAG 17-0003
FRONT WHEELS - STANDARD - 1000_55 R32 PAG 17-0004
FRONT WHEELS - STANDARD - 1050_50 R32 PAG 17-0005
FRONT WHEELS - STANDARD - 800_70 R38 PAG 17-0006
FRONT WHEELS - STANDARD - 800_70 R38 PAG 17-0007
FRONT WHEELS - STANDARD - 900_60 R38 PAG 17-0008
FRONT WHEELS - STANDARD - 710_70 R42 PAG 17-0009
FRONT WHEELS - PARALEVEL - 900_60 R32 PAG 17-0010
FRONT WHEELS - PARALEVEL - 800_70 R38 PAG 17-0011
FRONT WHEELS - PARALEVEL - 900_60 R38 PAG 17-0012
FRONT WHEELS - DUAL WHEELS - 520_85 R42 PAG 17-0013 to 17-0016
REAR WHEELS - 520_80 R26 PAG 17-0017 to 17-0021
TRACKS PAG 17-0022
TRACK ROLLER PAG 17-0023
TRACK ROLLER PAG 17-0024
TRACKS - FRONT PAG 17-0025
TRACKS - REAR PAG 17-0026
TRACKS - TENSIONER PAG 17-0027
TRACKS - BOGIE PAG 17-0028
TRACKS - CYLINDER PAG 17-0030
TRACKS - WHEELS PAG 17-0029
TRACKS - SCRAPERS PAG 17-0031
18-000-TOC FEEDING SYSTEM PAG 18-000-TOC Tech Spec Notes Ref
SHIELD PLATE PAG 18-0001
TILT FRAME PAG 18-0002
TILT FRAME PAG 18-0003
HEADER LOCK PAG 18-0004
HEADER LOCK PAG 18-0005
PITCH FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 18-0006
PITCH FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 18-0007
PITCH FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 18-0008
PITCH FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 18-0009
PITCH FRAME - FEEDER SEALING PAG 18-0010
PITCH FRAME - FEEDER SEALING PAG 18-0011
FEEDER FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 18-0012 to 18-0015
FEEDER FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 18-0016 to 18-0019
FEEDER BOTTOM PLATE - STANDARD PAG 18-0020
FEEDER BOTTOM PLATE - STANDARD PAG 18-0021
FEEDER BOTTOM - HIGH WEAR PAG 18-0022
FEEDER BOTTOM - HIGH WEAR PAG 18-0023
UPPER SHAFT PAG 18-0024
UPPER SHAFT PAG 18-0025
FEED DRUM PAG 18-0026
FEEDER CHAIN PAG 18-0027 to 18-0030
DUST EJECTOR - PIPES PAG 18-0031
DUST EJECTOR - PIPES PAG 18-0032
DUST EJECTOR - HYDRAULIC MOTOR PAG 18-0033
DUST EJECTOR - HYDRAULIC MANIFOLD PAG 18-0034
FEEDER HOUSE COUPLING - RIGHT SIDE PAG 18-0035
FEEDER HOUSE COUPLING - LEFT SIDE PAG 18-0036
FEEDER HOUSE COUPLING PAG 18-0037
MULTI-CONNECTOR PAG 18-0038
FEEDER SHIELD - RIGHT SIDE PAG 18-0039 to 18-0043
FEEDER SHIELD - LEFT SIDE PAG 18-0044 to 18-0048
SHIELDS - UPPER HEADER DRIVE PAG 18-0049
SHIELDS - UPPER HEADER DRIVE PAG 18-0050
19-000-TOC THRESHING SYSTEM PAG 19-000-TOC Tech Spec Notes Ref
ROTOR FEEDER - STANDARD PAG 19-0001
ROTOR FEEDER - HIGH WEAR PAG 19-0002
ROTOR FEEDER - COVER PAG 19-0003
DUAL ROTOR - ROTOR INLET PAG 19-0004 to 19-0006
DUAL ROTOR - LEFT ROTOR PAG 19-0007
DUAL ROTOR - CONCAVE ADJUSTMENT PAG 19-0008
DUAL ROTOR - ROTOR DISCHARGE PAG 19-0009 to 19-0011
DUAL ROTOR - GRATES SUPPORT PAG 19-0012
IMPELLER - UNLOADER COVER PAG 19-0013
CONCAVE - SMALL GRAIN - STANDARD PAG 19-0014
CONCAVE - SMALL GRAIN - MIDDLE SPECS PAG 19-0015
CONCAVE - SMALL GRAIN - MIDDLE SPECS PAG 19-0016
CONCAVE - SMALL GRAIN - HIGH CAPACITY PAG 19-0017
CONCAVE - SMALL GRAIN - HIGH CAPACITY PAG 19-0018
CONCAVE - LARGE GRAIN PAG 19-0019
CONCAVE - LARGE GRAIN PAG 19-0020
CONCAVE - LARGE GRAIN PAG 19-0021
SEPARATOR GRATES - SMALL GRAIN PAG 19-0022 to 19-0024
RETURN PAN PAG 19-0025 to 19-0029
RETURN PAN - RIGHT SIDE PAG 19-0030
RETURN PAN - RIGHT SIDE PAG 19-0031
RETURN PAN - LEFT SIDE PAG 19-0032
RETURN PAN - LEFT SIDE PAG 19-0033
20-000-TOC CLEANING SYSTEM PAG 20-000-TOC Tech Spec Notes Ref
CLEANING FAN - FRAME PAG 20-0001
CLEANING FAN - FANNING MILL PAG 20-0002
PITMAN SHAFT PAG 20-0003
STRATIFICATION PAN PAG 20-0004
STRATIFICATION PAN PAG 20-0005
CHAFFER FRAME PAG 20-0007
CHAFFER FRAME PAG 20-0008
STRATIFICATION PAN PAG 20-0006
CHAFFER FRAME PAG 20-0009
CHAFFER FRAME PAG 20-0010
SIEVE FRAME PAG 20-0011 to 20-0013
SIEVE FRAME - 4 CHANNEL PAG 20-0014 to 20-0016
SIEVE & CHAFFER - WIND WINGS PAG 20-0017
DISCHARGE EXTENSION - CHAFF SPREADER PAG 20-0018
DISCHARGE EXTENSION - STRAW SPREADER PAG 20-0019
SIEVE & CHAFFER - SMALL GRAIN PAG 20-0020
SIEVE - LARGE GRAIN PAG 20-0021
CHAFFER - LARGE GRAIN PAG 20-0022
TAILINGS ELEVATOR - STANDARD PAG 20-0023
TAILINGS ELEVATOR - HIGH WEAR PAG 20-0024
TAILINGS ELEVATOR - STANDARD PAG 20-0025
TAILINGS ELEVATOR - HIGH WEAR PAG 20-0026
TAILINGS ELEVATOR - GEARBOX (COMPONENTS) PAG 20-0027
21-000-TOC GRAIN BIN AND ELEVATOR SYSTEM PAG 21-000-TOC Tech Spec Notes Ref
GRAIN BIN _ 12500L PAG 21-0001
GRAIN BIN _ 12500L PAG 21-0002
GRAIN BIN _ 12500L - RIGHT SIDE PAG 21-0003
GRAIN BIN _ 12500L - REAR PANEL PAG 21-0004
GRAIN BIN _ 12500L - ACCESS DOOR PAG 21-0005
GRAIN BIN _ 17100L PAG 21-0006
GRAIN BIN _ 17100L PAG 21-0007
GRAIN BIN _ 17100L - RIGHT SIDE PAG 21-0008
GRAIN BIN _ 17100L - REAR PANEL PAG 21-0009
GRAIN BIN _ 17100L - ACCESS DOOR PAG 21-0010
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 21-0011 to 21-0021
GRAIN BIN _ 12500L - UNLOADER GATE (MANUAL) PAG 21-0022
GRAIN BIN _ 12500L - UNLOADER GATE (HYDRAULIC) PAG 21-0023
GRAIN BIN _ 17100L - UNLOADER GATE (HYDRAULIC) PAG 21-0024
GRAIN BIN - UNLOADER GATE (HYDRAULIC) PAG 21-0025
SUMP & TURRET - 12500L PAG 21-0026 to 21-0033
UNLOADER _ CRADLE - 12500L PAG 21-0034
UNLOADER _ CRADLE - 17100L PAG 21-0035
UNLOADER TUBE - 12500L PAG 21-0036 to 21-0070
BIN UNLOADER AUGER - 12500L PAG 21-0071 to 21-0088
SPILL SAVER - SMALL PAG 21-0089
SPILL SAVER - SMALL PAG 21-0090
SPILL SAVER - LOW CAPACITY PAG 21-0091
SPILL SAVER - LARGE PAG 21-0092
SPILL SAVER - LARGE PAG 21-0093
SPILL SAVER - HIGH CAPACITY PAG 21-0094
GRAIN ELEVATOR PAG 21-0095
GRAIN ELEVATOR - BIN LOADER PAG 21-0096
GRAIN ELEVATOR - BIN LOADER PAG 21-0097
GRAIN ELEVATOR - FILLING AUGER PAG 21-0098
GRAIN ELEVATOR - ELEVATOR AUGER PAG 21-0099 to 21-0103
22-000-TOC DISCHARGE SYSTEM PAG 22-000-TOC Tech Spec Notes Ref
STRAW CHOPPER - BRACKETS PAG 22-0001 to 22-0003
STRAW CHOPPER - HOUSING PAG 22-0004
STRAW CHOPPER - HOUSING PAG 22-0005
STRAW CHOPPER PAG 22-0006 to 22-0011
STRAW CHOPPER - KNIFE PAG 22-0012 to 22-0015
STRAW DEFLECTOR - COVER PAG 22-0016
STRAW DEFLECTOR - COVER PAG 22-0017
STRAW DEFLECTOR - MANUAL ADJUSTABLE PAG 22-0018
STRAW DEFLECTOR - MANUAL ADJUSTABLE PAG 22-0019
STRAW DEFLECTOR - ELECTRICAL ADJUSTMENT PAG 22-0020
STRAW DEFLECTOR - ELECTRICAL ADJUSTMENT PAG 22-0021
STRAW DEFLECTOR PAG 22-0022
ACTIVESPREAD - COVER PAG 22-0023
ACTIVESPREAD - MANUAL ADJUSTABLE PAG 22-0024
ACTIVESPREAD - MANUAL ADJUSTABLE PAG 22-0025
ACTIVESPREAD - ELECTRICAL ADJUSTMENT PAG 22-0026
ACTIVESPREAD - ELECTRICAL ADJUSTMENT PAG 22-0027
ACTIVESPREAD - ELECTRICAL ADJUSTMENT PAG 22-0028
ACTIVESPREAD PAG 22-0029
ACTIVESPREAD PAG 22-0030
ACTIVESPREAD PAG 22-0031
ACTIVESPREAD - GASKETS PAG 22-0032 to 22-0035
ACTIVESPREAD - DEFLECTOR PAG 22-0036 to 22-0039
STRAW SPREADER PAG 22-0040 to 22-0042
CHAFF SPREADER - MANUAL ADJUSTABLE PAG 22-0043
CHAFF SPREADER - ELECTRICAL ADJUSTMENT PAG 22-0044
23-000-TOC PRECISION FARMING SYSTEMS PAG 23-000-TOC Tech Spec Notes Ref
GUIDANCE - MODULE PAG 23-0001 to 23-0003
AGCO CONNECTIVITY MODULE (ACM) PAG 23-0004
AGCO CONNECTIVITY MODULE (ACM) PAG 23-0005
GUIDANCE RECEIVER - NOVATEL PAG 23-0006
GUIDANCE RECEIVER - TRIMBLE PAG 23-0007
TRIMBLE - UPGRADE PAG 23-0008
ANTENNA - NOVATEL PAG 23-0009
ANTENNA - NOVATEL PAG 23-0010
24-000-TOC ACCESSORIES PAG 24-000-TOC Tech Spec Notes Ref
ACCESSORIES - BLOCK HEATER PAG 24-0001
BLOCK HEATER PAG 24-0002
DEF FILL KIT PAG 24-0003
DEF DRAIN SYSTEM PAG 24-0004
LOCKABLE FUEL TANK CAP PAG 24-0005
DOOR STOPPER PAG 24-0006
DOOR STOPPER PAG 24-0007
SMART DEVICE MOUNTING PAG 24-0008
SMART DEVICE MOUNTING PAG 24-0009
MULTIPLE CAMERA DISPLAY PAG 24-0010
360° CAMERA SYSTEM PAG 24-0011
REAR VIEW CAMERA PAG 24-0012
GUIDANCE PAG 24-0013
GUIDANCE - TRIMBLE PAG 24-0014
GUIDANCE PAG 24-0015
NOVATEL UPGRADE PAG 24-0016
SIDE SUN VISOR PAG 24-0017
LADDER ACTUATOR PAG 24-0018
ADVANCED LIGHTING PAG 24-0019
LIGHTS - REAR AXLE PAG 24-0020
REAR AXLE - 4 WHEEL DRIVE PAG 24-0021
COVER - AXLE PAG 24-0022
ACCESSORIES - 3RD AXLE PAG 24-0023
ACCESSORIES - 3RD AXLE PAG 24-0024
ACCESSORIES - 3RD AXLE PAG 24-0025
REMOVABLE - FEEDER PAG 24-0026
FEEDER FLOOR PAG 24-0027
WEAR RESISTANT BOTTOM PAG 24-0028
FLIP-UP HEADER LIGHT PAG 24-0029
ACCESSORIES - FOLDING CUTTER BAR LIGHT PAG 24-0030
CONVERSION KIT - AUTODOCK PAG 24-0031
AUTOMATIC DOCK - UNIVERSAL PAG 24-0032
QUICK HYDRAULIC COUPLERS (MULTI-FASTER) - UNIVERSAL PAG 24-0033
COUPLING - HEADER PAG 24-0034
CUTTING HEADER - SUSPENSION PAG 24-0035
CUTTING HEADER - REVERSER PAG 24-0036
CORN HEADER FOLDING HYDRAULIC PAG 24-0037
STONE TRAP - COVER (LARGE GRAIN) PAG 24-0038
JUMPER KIT - AUTOMATIC HEADER HEIGHT CONTROL PAG 24-0039
JUMPER HARNESS PAG 24-0040
JUMPER HARNESS PAG 24-0041
JUMPER HARNESS - DUST EJECTOR PAG 24-0042
JUMPER CONNECTOR PAG 24-0043
EGR JUMPER PAG 24-0044
JUMPER HARNESS PAG 24-0045
HITCH DROP PIN PAG 24-0046
HITCH PAG 24-0047
SPOUT SOCK (SMALL) PAG 24-0048
SPOUT SOCK (LARGE) PAG 24-0049
TAILINGS ELEVATOR - HATCHS PAG 24-0050
ACCESSORIES - TAILINGS ELEVATOR - HATCHS PAG 24-0051
ACCESSORIES - TAILINGS ELEVATOR - COVER (LARGE GRAIN) PAG 24-0052
FRAME PAG 24-0053
SENSOR - CRADLE PAG 24-0054
SENSOR - CRADLE PAG 24-0055
GRAIN BIN CORNERS PAG 24-0056
GRAIN BIN CORNERS - LOW CAPACITY PAG 24-0057
GRAIN BIN CORNERS - HIGH CAPACITY PAG 24-0058
GRAIN BIN UNLOADING - SPEED REDUCTION PAG 24-0059
LIFTING MECHANISM PAG 24-0060
KIT - ACTIVE TAILBOARD PAG 24-0061
KIT - PASSIVE TAILBOARD POWERED PAG 24-0062
PASSIVE TAILBOARD POWERED - COVER PAG 24-0063
WIRING HARNESS - PASSIVE TAILBOARD POWERED PAG 24-0064
PASSIVE TAILBOARD POWERED - ELECTRICAL ADJUSTMENT PAG 24-0065
CHAFFER ACTUATOR REPAIR PAG 24-0066
SIEVE & CHAFFER - LARGE GRAIN PAG 24-0067 to 24-0076
CONVERSION KIT - LARGE GRAIN PAG 24-0077
CONVERSION KIT - DRY SMALL GRAIN PAG 24-0078
CHAFF SPREADER - MANUAL ADJUSTABLE PAG 24-0079
DEFLECTOR KIT - SMALL GRAIN PAG 24-0080
GRASS SEED (LOW CAPACITY UNLOADER) PAG 24-0081
GRASS SEED (LOW CAPACITY UNLOADER) PAG 24-0082
GRASS SEED - STREAMER 140 & 210 PAG 24-0083
GRASS SEED (HIGH CAPACITY UNLOADER) PAG 24-0084
GRASS SEED (HIGH CAPACITY UNLOADER) PAG 24-0085
WARNING SIGNS PAG 24-0086
