Fendt Combine IDEAL 10 GEN 3 Part Catalog 2023-2025
- Download this document, you need 8625 Gallons
Brand: Fendt
Type of Machine: Combine
Type of Manual: Part Catalog
Model: Fendt IDEAL 10 GEN 3 Combine
Serial Number: ZN2G0010H03030001-50999
Publication Date: 2023-2025
Number of Pages: 2412 Pages
00-TOC TABLE OF CONTENT PAG 00-TOC Tech Spec Notes Ref
01-000-TOC GENERAL INFORMATION PAG 01-000-TOC Tech Spec Notes Ref
FILTERS GUIDE PAG 01-0001
BELTS GUIDE - RIGHT SIDE PAG 01-0002
BELTS GUIDE - LEFT SIDE PAG 01-0003
SENSORS GUIDE PAG 01-0004
SENSORS GUIDE PAG 01-0005
PAINTS GUIDE PAG 01-0006
02-000-TOC ENGINE ACW120763A D4276LE121 T4F PAG 02-000-TOC Tech Spec Notes Ref
ENGINE BRACKET PAG 02-0001
CRANKCASE PAG 02-0002
CRANKCASE PAG 02-0003
TIMING GEARS & HOUSING PAG 02-0004
FLYWHEEL & HOUSING PAG 02-0005
CRANKSHAFT & PISTONS PAG 02-0006
CRANKSHAFT & PISTONS PAG 02-0007
CAMSHAFT & VALVE MECHANISM PAG 02-0008
CYLINDER HEAD & VALVE MECHANISM PAG 02-0009
VALVE ROCKER COVER PAG 02-0010
AIR INTAKE PAG 02-0011
EXHAUST MANIFOLD PAG 02-0012
EXHAUST MANIFOLD PAG 02-0013
EXHAUST MANIFOLD PAG 02-0014
TURBOCHARGER PAG 02-0015
EXHAUST GAS RECIRCULATION (EGR) PAG 02-0016
EXHAUST GAS RECIRCULATION (EGR) PAG 02-0017
OIL PUMP & SUMP PAG 02-0018
OIL PUMP & SUMP PAG 02-0019
OIL COOLER & OIL FILTER PAG 02-0020
COOLANT PIPING PAG 02-0021
COOLANT PIPING PAG 02-0022
COOLANT PUMP & THERMOSTAT PAG 02-0023
FUEL INJECTION SYSTEM PAG 02-0024
FUEL FILTERS PAG 02-0025
FUEL FILTER PAG 02-0026
ELECTRONIC ENGINE MANAGEMENT - SENSOR PAG 02-0027
ELECTRONIC ENGINE MANAGEMENT - SENSOR PAG 02-0028
ELECTRONIC ENGINE MANAGEMENT - WIRING HARNESS PAG 02-0029
ELECTRONIC ENGINE MANAGEMENT - BRACKET PAG 02-0030
WIRING HARNESS - INJECTOR PAG 02-0031
BELT TENSIONER PAG 02-0032
ENGINE GASKET KITS PAG 02-0033
SPECIAL OVERHAUL PARTS PAG 02-0034
03-000-TOC ENGINE ACX2417030 D4276LE122 STAGE 5 PAG 03-000-TOC Tech Spec Notes Ref
ENGINE BRACKET PAG 03-0001
CRANKCASE PAG 03-0002
TIMING GEARS & HOUSING PAG 03-0003
FLYWHEEL & HOUSING PAG 03-0004
CRANKSHAFT & PISTONS PAG 03-0005
CAMSHAFT & VALVE MECHANISM PAG 03-0006
CYLINDER HEAD & VALVE MECHANISM PAG 03-0007
VALVE ROCKER COVER PAG 03-0008
AIR INTAKE PAG 03-0009
EXHAUST MANIFOLD PAG 03-0010
EXHAUST MANIFOLD PAG 03-0011
EXHAUST MANIFOLD PAG 03-0012
TURBOCHARGER PAG 03-0013
EXHAUST GAS RECIRCULATION (EGR) PAG 03-0014
EXHAUST GAS RECIRCULATION (EGR) PAG 03-0015
OIL PUMP & SUMP PAG 03-0016
OIL PUMP & SUMP PAG 03-0017
OIL COOLER & OIL FILTER PAG 03-0018
COOLANT PIPING PAG 03-0019
COOLANT PIPING PAG 03-0020
COOLANT PUMP & THERMOSTAT PAG 03-0021
FUEL INJECTION SYSTEM PAG 03-0022
FUEL FILTER PAG 03-0023
ELECTRONIC ENGINE MANAGEMENT - SENSOR PAG 03-0024
ELECTRONIC ENGINE MANAGEMENT - WIRING HARNESS PAG 03-0025
ELECTRONIC ENGINE MANAGEMENT - BRACKET PAG 03-0026
WIRING HARNESS - INJECTOR PAG 03-0027
BELT TENSIONER PAG 03-0028
ENGINE GASKET KITS PAG 03-0029
SPECIAL OVERHAUL PARTS PAG 03-0030
04-000-TOC ENGINE INSTALLATION PAG 04-000-TOC Tech Spec Notes Ref
ENGINE, ALTERNATOR, STARTER MOTOR & OIL DRAIN PAG 04-0001
ENGINE, ALTERNATOR, STARTER MOTOR & OIL DRAIN PAG 04-0002
ENGINE, ALTERNATOR, STARTER MOTOR & OIL DRAIN PAG 04-0003
ENGINE, ALTERNATOR, STARTER MOTOR & OIL DRAIN PAG 04-0004
ENGINE - OIL DRAINAGE SYSTEM PAG 04-0005
ENGINE BRACKET PAG 04-0006
ENGINE BLOCK HEATER PAG 04-0007
ENGINE BLOCK HEATER PAG 04-0008
COOLING - FAN DRIVE PAG 04-0009
COOLING - FAN & FAN SHROUD PAG 04-0010
COOLING - FAN & FAN SHROUD PAG 04-0011
COOLING - FAN PAG 04-0012
COOLING - HOSES PAG 04-0013
COOLING - HOSES PAG 04-0014
COOLING - EXPANSION TANK PAG 04-0015
COOLING - FAN SHROUD & SUPPORT PAG 04-0016
COOLING - FAN SHROUD & SUPPORT PAG 04-0017
COOLING - FAN SHROUD & SUPPORT PAG 04-0018
COOLING - RADIATOR & COOLERS PAG 04-0019
COOLING - RADIATOR & COOLERS PAG 04-0020
COOLING - PLUGS PAG 04-0021
DUST ASPIRATOR PAG 04-0022
ENGINE AIR FILTER PAG 04-0023
EXHAUST SYSTEM PAG 04-0024
EXHAUST SYSTEM - COVER PAG 04-0025
EXHAUST SYSTEM - COVER PAG 04-0026
EXHAUST SYSTEM - COVER PAG 04-0027
EXHAUST SYSTEM - COVER PAG 04-0028
EXHAUST SYSTEM - SENSORS PAG 04-0029
DEF SYSTEM PAG 04-0030
DEF - FILTERS PAG 04-0031
EXHAUST - DEF TANK (COMPONENTS) PAG 04-0032
FUEL - TANK (COMPONENTS) PAG 04-0033
FUEL - TANK (COMPONENTS) PAG 04-0034
FUEL - TANK (COMPONENTS) PAG 04-0035
FUEL - TANK (COMPONENTS) PAG 04-0036
FUEL - TANK (COMPONENTS) PAG 04-0037
FUEL - TANK (COMPONENTS) PAG 04-0038
FUEL - LINES PAG 04-0039
AIR COMPRESSOR - COMPRESSOR & LINES PAG 04-0040
AIR COMPRESSOR - COMPRESSOR & LINES PAG 04-0041
AIR COMPRESSOR - TANK PAG 04-0042
AIR COMPRESSOR - LINES AND FITTINGS PAG 04-0043
AIR COMPRESSOR - LINES AND FITTINGS PAG 04-0044
05-000-TOC DRIVE SYSTEM PAG 05-000-TOC Tech Spec Notes Ref
ENGINE GEARBOX PAG 05-0001
ENGINE GEARBOX PAG 05-0002
ENGINE GEARBOX (COMPONENTS) PAG 05-0003
ENGINE GEARBOX (COMPONENTS) PAG 05-0004
HEADER DRIVE - BOTTOM PAG 05-0005
HEADER DRIVE - BOTTOM PAG 05-0006
HEADER DRIVE - BOTTOM PAG 05-0007
HEADER DRIVE - BOTTOM PAG 05-0008
HEADER DRIVE - BOTTOM PAG 05-0009
HEADER DRIVE - BOTTOM PAG 05-0010
HEADER DRIVE - BOTTOM PAG 05-0011
HEADER DRIVE - BOTTOM PAG 05-0012
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 05-0013
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 05-0014
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 05-0015
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 05-0016
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 05-0017
GEARBOX (COMPONENTS) - HEADER DRIVE PAG 05-0018
FIXED SPEED HEADER DRIVE - TOP PAG 05-0019
FIXED SPEED HEADER DRIVE - TOP PAG 05-0020
FIXED SPEED HEADER DRIVE - TOP PAG 05-0021
FIXED SPEED HEADER DRIVE - TOP PAG 05-0022
FIXED SPEED HEADER DRIVE - TOP PAG 05-0023
FIXED SPEED HEADER DRIVE - TOP PAG 05-0024
VARIABLE SPEED HEADER DRIVE - TOP PAG 05-0025
VARIABLE SPEED HEADER DRIVE - TOP PAG 05-0026
VARIABLE SPEED HEADER DRIVE - SHEAVE PAG 05-0027
VARIABLE SPEED HEADER DRIVE - TOP PAG 05-0028
VARIABLE SPEED HEADER DRIVE - TOP PAG 05-0029
VARIABLE SPEED HEADER DRIVE - SHEAVE PAG 05-0030
GEARBOX (COMPONENTS) - FIXED SPEED HEADER DRIVE PAG 05-0031
GEARBOX (COMPONENTS) - FIXED SPEED HEADER DRIVE PAG 05-0032
GEARBOX (COMPONENTS) - VARIABLE SPEED HEADER DRIVE PAG 05-0033
GEARBOX (COMPONENTS) - VARIABLE SPEED HEADER DRIVE PAG 05-0034
SHAFT (COMPONENTS) PAG 05-0035
TIE ROD - HEADER DRIVE PAG 05-0036
SHEAVE - HEADER DRIVE PAG 05-0037
FEEDER CONVEYOR DRIVE - FIXED SPEED PAG 05-0038
FEEDER CONVEYOR DRIVE - TWO SPEED PAG 05-0039
FEEDER CONVEYOR DRIVE - TWO SPEED PAG 05-0040
BEATER DRIVE - SINGLE SPEED ROTOR DRIVE PAG 05-0041
BEATER DRIVE - SINGLE SPEED ROTOR DRIVE PAG 05-0042
BEATER DRIVE - TWO SPEED ROTOR DRIVE PAG 05-0043
BEATER DRIVE - TWO SPEED ROTOR DRIVE PAG 05-0044
BEATER DRIVE - SHIELD PAG 05-0045
SINGLE AND DUAL ROTOR DRIVE - FIXED SPEED PAG 05-0046
SINGLE AND DUAL ROTOR DRIVE - FIXED SPEED PAG 05-0047
SINGLE AND DUAL ROTOR DRIVE - FIXED SPEED PAG 05-0048
DUAL ROTOR DRIVE - FIXED SPEED PAG 05-0049
DUAL ROTOR DRIVE - FIXED SPEED PAG 05-0050
GEARBOX (COMPONENTS) - FIXED SPEED PAG 05-0051
GEARBOX (COMPONENTS) - FIXED SPEED PAG 05-0052
UNIVERSAL JOINT (COMPONENTS) PAG 05-0053
DUAL ROTOR DRIVE - 2 SPEEDS PAG 05-0054
DUAL ROTOR DRIVE - 2 SPEEDS PAG 05-0055
DUAL ROTOR DRIVE - 2 SPEEDS PAG 05-0056
DUAL ROTOR DRIVE - 2 SPEEDS PAG 05-0057
DUAL ROTOR DRIVE - 2 SPEEDS PAG 05-0058
DUAL ROTOR DRIVE - 2 SPEEDS PAG 05-0059
DUAL ROTOR DRIVE - 2 SPEEDS PAG 05-0060
GEARBOX (COMPONENTS) - ROTOR DRIVE PAG 05-0061
GEARBOX (COMPONENTS) - ROTOR DRIVE PAG 05-0062
GEARBOX (COMPONENTS) - ROTOR DRIVE PAG 05-0063
GEARBOX - COOLING PAG 05-0064
GEARBOX - COOLING PAG 05-0065
GEARBOX - COOLING PAG 05-0066
COUNTERSHAFT - DRIVE PAG 05-0067
IDLER ARM PAG 05-0068
SHAKER SHOE DRIVE PAG 05-0069
CLEANING FAN - DRIVE PAG 05-0070
GRAIN ELEVATOR - DRIVE PAG 05-0071
GRAIN ELEVATOR - SECONDARY DRIVE PAG 05-0072
GRAIN BIN UNLOADING - DRIVE PAG 05-0073
GRAIN BIN UNLOADING - DRIVE PAG 05-0074
GRAIN BIN UNLOADING - DRIVE PAG 05-0075
GRAIN BIN UNLOADING - DRIVE PAG 05-0076
GRAIN BIN UNLOADING - DRIVE PAG 05-0077
GRAIN BIN UNLOADING - DRIVE PAG 05-0078
GEARBOX (COMPONENTS) - GRAIN BIN UNLOADING PAG 05-0079
GEARBOX (COMPONENTS) - GRAIN BIN UNLOADING PAG 05-0080
GEARBOX (COMPONENTS) - GRAIN BIN UNLOADING PAG 05-0081
STRAW CHOPPER - DRIVE PAG 05-0082
STRAW CHOPPER - DRIVE PAG 05-0083
STRAW CHOPPER - DRIVE PAG 05-0084
STRAW CHOPPER - DRIVE PAG 05-0085
06-000-TOC AXLES PAG 06-000-TOC Tech Spec Notes Ref
FRONT AXLE - STANDARD PAG 06-0001
FRONT AXLE - STANDARD PAG 06-0002
FRONT AXLE - PARALEVEL PAG 06-0003
FRONT AXLE - PARALEVEL PAG 06-0004
FRONT AXLE - PARALEVEL PAG 06-0005
FRONT AXLE - TRACKS PAG 06-0006
FRONT AXLE - TRACKS PAG 06-0007
PULLED REAR AXLE - PIN PAG 06-0008
REAR AXLE - PIN PAG 06-0009
REAR AXLE - 2 WHEEL DRIVE PAG 06-0010
REAR AXLE - 2 WHEEL DRIVE - (COMPONENTS) PAG 06-0011
REAR AXLE - 2 WHEEL DRIVE - (COMPONENTS) PAG 06-0012
REAR AXLE - 4 WHEEL DRIVE PAG 06-0013
REAR AXLE - 4 WHEEL DRIVE - (COMPONENTS) PAG 06-0014
REAR AXLE - 4 WHEEL DRIVE - (COMPONENTS) PAG 06-0015
REAR AXLE - 4 WHEEL DRIVE - (COMPONENTS) PAG 06-0016
REAR AXLE - 4 WHEEL DRIVE - (COMPONENTS) PAG 06-0017
REAR AXLE - 4 WHEEL DRIVE - (COMPONENTS) PAG 06-0018
REAR AXLE - 4 WHEEL DRIVE - (COMPONENTS) PAG 06-0019
HITCH PAG 06-0020
HITCH PAG 06-0021
HITCH - 3RD AXLE PAG 06-0022
HITCH DROP PIN PAG 06-0023
HITCH - AUTOMATIC PAG 06-0024
HITCH - AUTOMATIC PAG 06-0025
07-000-TOC STEERING SYSTEM PAG 07-000-TOC Tech Spec Notes Ref
STEERING WHEEL & COLUMN PAG 07-0001
HYDRAULIC LINES PAG 07-0002
HYDRAULIC LINES PAG 07-0003
HYDRAULIC LINES PAG 07-0004
HYDRAULIC LINES - PRESSURE SWITCH PAG 07-0005
08-000-TOC DRIVETRAIN SYSTEM PAG 08-000-TOC Tech Spec Notes Ref
TRANSMISSION - STANDARD PAG 08-0001
TRANSMISSION - PARALEVEL PAG 08-0002
TRANSMISSION - DUAL WHEELS PAG 08-0003
TRANSMISSION - TRACKS PAG 08-0004
TRANSMISSION - TRACKS PAG 08-0005
TRANSMISSION - TRACKS PAG 08-0006
TRANSMISSION - TRACKS PAG 08-0007
FINAL DRIVE (COMPONENTS) - WHEELS PAG 08-0008
FINAL DRIVE (COMPONENTS) - TRACKS PAG 08-0009
FINAL DRIVE (COMPONENTS) - TRACKS PAG 08-0010
FINAL DRIVE (COMPONENTS) - TRACKS PAG 08-0011
FINAL DRIVE (COMPONENTS) - TRACKS PAG 08-0012
GEARBOX - HOUSING PAG 08-0013
GEARBOX - HOUSING PAG 08-0014
GEARBOX - MAIN SHAFT PAG 08-0015
GEARBOX - INTERMEDIATE SHAFT PAG 08-0016
GEARBOX - BEVEL PINION SHAFT PAG 08-0017
GEARBOX - DIFFERENTIAL PAG 08-0018
ACV0764940_2 GEARBOX - PIPING PAG 08-0019
ACV0764940_3 GEARBOX - VALVE PAG 08-0020
ACV0764940_4 GEARBOX - OIL FILLING AND MEASUREMENT PAG 08-0021
ACV0764940_5 GEARBOX - OIL COOLER PAG 08-0022
ACV0764940_6 GEARBOX - HYDRAULIC PUMP PAG 08-0023
ACV0764940_7 GEARBOX - SUCTION LINE PAG 08-0024
09-000-TOC BRAKE SYSTEM PAG 09-000-TOC Tech Spec Notes Ref
BRAKE PEDALS PAG 09-0001
BRAKE LINES - STANDARD & TRACKS PAG 09-0002
BRAKE LINES - PARALEVEL PAG 09-0003
ACV0764940_9 DISC BRAKES PAG 09-0004
DISC BRAKES PAG 09-0005
ACV0764940_8 PARKING BRAKE PAG 09-0006
10-000-TOC HYDRAULIC SYSTEM PAG 10-000-TOC Tech Spec Notes Ref
OIL TANK PAG 10-0001
OIL TANK PAG 10-0002
HYDRAULIC PUMP - STANDARD STEERING PAG 10-0003
HYDRAULIC PUMP - IDEALDRIVE PAG 10-0004
IDEALDRIVE PAG 10-0005
MAIN PLUMBING PAG 10-0006
ENGINE GEARBOX - HYDRAULIC PAG 10-0007
ENGINE GEARBOX - HYDRAULICS PAG 10-0008
HYDRAULIC PROPEL - STANDARD & PARALEVEL PAG 10-0009
HYDRAULIC PROPEL - STANDARD & PARALEVEL PAG 10-0010
HYDRAULIC PROPEL - TRACKS PAG 10-0011
HYDRAULIC PROPEL - TRACKS PAG 10-0012
HYDRAULIC MOTOR - COMPONENTS PAG 10-0013
HYDRAULIC PROPEL PAG 10-0014
HYDRAULIC PROPEL PAG 10-0015
HYDRAULIC PROPEL PAG 10-0016
HYDRAULIC PROPEL PAG 10-0017
REAR AXLE - 4 WHEEL DRIVE PAG 10-0018
REAR AXLE - 4 WHEEL DRIVE PAG 10-0019
REAR AXLE - 4 WHEEL DRIVE PAG 10-0020
3RD AXLE PAG 10-0021
FRONT AXLE - STANDARD & TRACKS PAG 10-0022
FRONT AXLE - PARALEVEL PAG 10-0023
FRONT AXLE - PARALEVEL PAG 10-0024
FRONT AXLE - VALVE BLOCK (COMPONENTS) PAG 10-0025
FRONT AXLE - VALVE BLOCK (COMPONENTS) PAG 10-0026
CUTTING HEADER - LIFTING - STANDARD PAG 10-0027
CUTTING HEADER - LIFTING - PARALEVEL PAG 10-0028
CUTTING HEADER - SUSPENSION PAG 10-0029
CUTTING HEADER - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 10-0030
CUTTING HEADER - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 10-0031
CUTTING HEADER - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 10-0032
CUTTING HEADER - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 10-0033
CUTTING HEADER - VALVE BLOCK (COMPONENTS) PAG 10-0034
QUICK HYDRAULIC COUPLERS (MULTI-FASTER) PAG 10-0035
CUTTING HEADER PAG 10-0036
CUTTING HEADER PAG 10-0037
CUTTING HEADER PAG 10-0038
CUTTING HEADER - VALVE BLOCK (COMPONENTS) PAG 10-0039
QUICK HYDRAULIC COUPLERS (MULTI-FASTER) PAG 10-0040
CUTTING HEADER - REVERSER PAG 10-0041
CUTTING HEADER - REVERSER - VALVE BLOCK (COMPONENTS) PAG 10-0042
CONCAVE ADJUSTMENT PAG 10-0043
CONCAVE ADJUSTMENT - VALVE BLOCK (COMPONENTS) PAG 10-0044
ROTOR REVERSER - 2 SPEEDS PAG 10-0045
GRAIN BIN PAG 10-0046
GRAIN BIN - VALVE BLOCK (COMPONENTS) PAG 10-0047
GRAIN BIN - VALVE BLOCK (COMPONENTS) PAG 10-0048
GRAIN BIN - VALVE BLOCK (COMPONENTS) PAG 10-0049
GRAIN BIN - VALVE BLOCK (COMPONENTS) PAG 10-0050
GRAIN BIN - WITH HYDRAULIC GATES PAG 10-0051
GRAIN BIN - WITH HYDRAULIC EXTENSIONS PAG 10-0052
UNLOADER SWING PAG 10-0053
SPILL SAVER PAG 10-0054
BOOST PUMP PAG 10-0055
BOOST PUMP - VALVE BLOCK (COMPONENTS) PAG 10-0056
BOOST PUMP (UNLOADER) - FIXED SPEED HEADER DRIVE PAG 10-0057
BOOST PUMP (UNLOADER) - VARIABLE SPEED HEADER DRIVE PAG 10-0058
GRASS SEED - STREAMER 140 & 210 PAG 10-0059
STRAW SPREADER - STANDARD STEERING PAG 10-0060
STRAW SPREADER - STANDARD STEERING PAG 10-0061
STRAW SPREADER - IDEALDRIVE PAG 10-0062
STRAW SPREADER - IDEALDRIVE PAG 10-0063
ACTIVESPREAD - STANDARD STEERING PAG 10-0064
ACTIVESPREAD - STANDARD STEERING PAG 10-0065
ACTIVESPREAD - IDEALDRIVE PAG 10-0066
ACTIVESPREAD - IDEALDRIVE PAG 10-0067
ACTIVESPREAD SWINGFLOW - STANDARD STEERING PAG 10-0068
ACTIVESPREAD SWINGFLOW - IDEALDRIVE PAG 10-0069
ACTIVESPREAD SWINGFLOW PAG 10-0070
ACTIVESPREAD SWINGFLOW - VALVE BLOCK (COMPONENTS) PAG 10-0071
PASSIVESPREAD - IDEALDRIVE PAG 10-0072
CHAFF SPREADER PAG 10-0073
CHAFF SPREADER PAG 10-0074
CHAFF SPREADER PAG 10-0075
LUBRICATION PIPES - PARALEVEL PAG 10-0076
LUBRICATION PIPES - STANDARD & TRACKS PAG 10-0077
11-000-TOC ELECTRICAL SYSTEM PAG 11-000-TOC Tech Spec Notes Ref
SENSORS - HYDRAULIC PAG 11-0001
SENSORS - GRAIN BIN PAG 11-0002
SENSORS - GROUND DRIVE PAG 11-0003
SENSORS - ROTOR DRIVE PAG 11-0004
LIGHTING - ROAD LIGHTS PAG 11-0005
LIGHTING - ROAD LIGHTS PAG 11-0006
LIGHTING - ROAD LIGHTS PAG 11-0007
LIGHTING - ROAD LIGHTS PAG 11-0008
LIGHTING - ROAD LIGHTS PAG 11-0009
LIGHTING - ROAD LIGHTS PAG 11-0010
LIGHTING - ROAD LIGHTS PAG 11-0011
LIGHTING - ROAD LIGHTS PAG 11-0012
LIGHTING - ROAD LIGHTS PAG 11-0013
LIGHTING - ROAD LIGHTS PAG 11-0014
LIGHTING - ROAD LIGHTS PAG 11-0015
LIGHTING - ROAD LIGHTS PAG 11-0016
LIGHTING - ROAD LIGHTS PAG 11-0017
LIGHTING - ROAD LIGHTS PAG 11-0018
LIGHTING - FRONT LIGHTS PAG 11-0019
LIGHTING - FRONT LIGHTS PAG 11-0020
LIGHTING - FRONT LIGHTS PAG 11-0021
WORK LIGHTS PAG 11-0022
WORK LIGHTS PAG 11-0023
WORK LIGHTS - REAR AXLE PAG 11-0024
WIRING HARNESS - REAR LIGHTING PAG 11-0025
WIRING HARNESS - REAR LIGHTING PAG 11-0026
WIRING HARNESS - REAR LIGHTING PAG 11-0027
WIRING HARNESS - REAR LIGHTING PAG 11-0028
WIRING HARNESS - REAR LIGHTING PAG 11-0029
LIGHTING - ROOF PAG 11-0030
LIGHTING - ROOF PAG 11-0031
LIGHTING - ROTARY BEACON PAG 11-0032
LIGHTING - ROTARY BEACON PAG 11-0033
UNLOADER - ROTARY BEACON PAG 11-0034
BATTERIES & CABLES PAG 11-0035
BATTERIES & CABLES PAG 11-0036
BATTERIES & CABLES PAG 11-0037
BATTERIES & CABLES PAG 11-0038
BATTERIES & CABLES PAG 11-0039
BATTERIES & CABLES PAG 11-0040
BATTERIES & CABLES - (MAIN CIRCUIT FUSES) PAG 11-0041
MAIN HARNESS PAG 11-0042
MAIN HARNESS PAG 11-0043
MAIN HARNESS PAG 11-0044
MAIN HARNESS PAG 11-0045
MAIN HARNESS PAG 11-0046
MAIN HARNESS PAG 11-0047
MAIN HARNESS PAG 11-0048
MAIN HARNESS PAG 11-0049
MAIN HARNESS PAG 11-0050
MAIN HARNESS PAG 11-0051
WIRING HARNESS - FEEDER CONVEYOR PAG 11-0052
WIRING HARNESS - FEEDER CONVEYOR PAG 11-0053
WIRING HARNESS - FEEDER CONVEYOR PAG 11-0054
WIRING HARNESS - FEEDER CONVEYOR PAG 11-0055
WIRING HARNESS - FEEDER CONVEYOR PAG 11-0056
WIRING HARNESS - FRONT AXLE PAG 11-0057
WIRING HARNESS - FRONT AXLE PAG 11-0058
WIRING HARNESS - FRONT AXLE PAG 11-0059
WIRING HARNESS - FRONT AXLE PAG 11-0060
WIRING HARNESS - FRONT AXLE PAG 11-0061
WIRING HARNESS - FRONT AXLE PAG 11-0062
WIRING HARNESS - REAR AXLE - 2 WHEEL DRIVE PAG 11-0063
WIRING HARNESS - REAR AXLE - 2 WHEEL DRIVE PAG 11-0064
WIRING HARNESS - REAR AXLE - 4 WHEEL DRIVE PAG 11-0065
WIRING HARNESS - REAR AXLE - 4 WHEEL DRIVE PAG 11-0066
WIRING HARNESS - IDEALDRIVE PAG 11-0075
WIRING HARNESS - IDEALDRIVE PAG 11-0076
GROUND DRIVE - IDEALDRIVE PAG 11-0077
GROUND DRIVE - IDEALDRIVE PAG 11-0078
GROUND DRIVE PAG 11-0079
WIRING HARNESS - CAB PAG 11-0080
WIRING HARNESS - CAB PAG 11-0081
WIRING HARNESS - CAB PAG 11-0082
WIRING HARNESS - CAB PAG 11-0083
WIRING HARNESS - CAB PAG 11-0084
WIRING HARNESS - CAB PAG 11-0085
WIRING HARNESS - CAB PAG 11-0086
WIRING HARNESS - CAB PAG 11-0087
WIRING HARNESS - ENGINE PAG 11-0088
WIRING HARNESS - ENGINE PAG 11-0089
WIRING HARNESS - CONCAVE ADJUSTMENT PAG 11-0090
WIRING HARNESS - CONCAVE ADJUSTMENT PAG 11-0091
WIRING HARNESS - CLEANING SHOE PAG 11-0092
WIRING HARNESS - CLEANING SHOE PAG 11-0093
WIRING HARNESS - GRAIN BIN PAG 11-0094
WIRING HARNESS - GRAIN BIN PAG 11-0095
WIRING HARNESS - GRAIN BIN PAG 11-0096
WIRING HARNESS - GRAIN BIN PAG 11-0097
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0098
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0099
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0100
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0101
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0102
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0103
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0104
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0105
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0106
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0107
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0108
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0109
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0110
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0111
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0112
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0113
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0114
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0115
WIRING HARNESS - GRAIN BIN UNLOADING PAG 11-0116
WIRING HARNESS - VERTICAL KNIFE PAG 11-0117
WIRING HARNESS - VERTICAL KNIFE PAG 11-0118
WIRING HARNESS - STRAW CHOPPER PAG 11-0119
WIRING HARNESS - STRAW CHOPPER PAG 11-0120
WIRING HARNESS - STRAW CHOPPER PAG 11-0121
WIRING HARNESS - STRAW CHOPPER PAG 11-0122
WIRING HARNESS - STRAW CHOPPER & TAILBOARD PAG 11-0123
WIRING HARNESS - STRAW CHOPPER & TAILBOARD PAG 11-0124
WIRING HARNESS - STRAW CHOPPER & TAILBOARD PAG 11-0125
WIRING HARNESS - STRAW SPREADER PAG 11-0126
WIRING HARNESS - STRAW SPREADER PAG 11-0127
WIRING HARNESS - STRAW DEFLECTOR PAG 11-0128
WIRING HARNESS - STRAW DEFLECTOR PAG 11-0129
WIRING HARNESS - ACTIVESPREAD PAG 11-0130
WIRING HARNESS - ACTIVESPREAD PAG 11-0131
WIRING HARNESS - ACTIVESPREAD PAG 11-0132
WIRING HARNESS - ACTIVESPREAD PAG 11-0133
WIRING HARNESS - ACTIVESPREAD PAG 11-0134
WIRING HARNESS - ACTIVESPREAD PAG 11-0135
WIRING HARNESS - ACTIVESPREAD PAG 11-0136
WIRING HARNESS - ACTIVESPREAD SWINGFLOW PAG 11-0137
WIRING HARNESS - ACTIVESPREAD SWINGFLOW PAG 11-0138
WIRING HARNESS - CHAFF SPREADER PAG 11-0139
WIRING HARNESS - CHAFF SPREADER PAG 11-0140
WIRING HARNESS - CHAFF SPREADER PAG 11-0141
GRAIN LOSS MONITOR - NO AUTOMATION PAG 11-0142
GRAIN LOSS MONITOR - NO AUTOMATION PAG 11-0143
GRAIN LOSS MONITOR - NO AUTOMATION PAG 11-0144
GRAIN LOSS MONITOR - NO AUTOMATION PAG 11-0145
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0146
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0147
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0148
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0149
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0150
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0151
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0152
GRAIN LOSS MONITOR - SELF ADJUST PAG 11-0153
YIELD MONITOR SYSTEM PAG 11-0154
YIELD MONITOR SYSTEM PAG 11-0155
360° CAMERA SYSTEM - CAMERA READY PAG 11-0156
360° CAMERA SYSTEM - CAMERA READY PAG 11-0157
360° CAMERA SYSTEM PAG 11-0158
360° CAMERA SYSTEM PAG 11-0159
360° CAMERA SYSTEM PAG 11-0160
360° CAMERA SYSTEM PAG 11-0161
WITHOUT REAR CAMERA PAG 11-0162
REAR CAMERA PAG 11-0163
REAR CAMERA PAG 11-0164
QUAD CAMERA DISPLAY MONITOR PAG 11-0165
CAMERA - QUAD PAG 11-0166
TAILLIGHT - UNLOADER TUBE PAG 11-0167
TAILLIGHT - UNLOADER TUBE PAG 11-0168
TAILLIGHT - UNLOADER TUBE PAG 11-0169
TAILLIGHT - UNLOADER TUBE PAG 11-0170
TAILLIGHT - UNLOADER TUBE PAG 11-0171
TAILLIGHT - UNLOADER TUBE PAG 11-0172
TAILLIGHT - UNLOADER TUBE PAG 11-0173
TAILLIGHT - UNLOADER TUBE PAG 11-0174
TAILLIGHT - UNLOADER TUBE PAG 11-0175
ACTUATOR - LADDER PAG 11-0176
ACTUATOR - LADDER PAG 11-0177
ACTUATOR - LADDER PAG 11-0178
ACTUATOR - LADDER PAG 11-0179
ACTUATOR - LADDER PAG 11-0180
12-000-TOC CAB PAG 12-000-TOC Tech Spec Notes Ref
CAB SUPPORT PAG 12-0001
CAB FRAME PAG 12-0002
CAB FRAME PAG 12-0003
ROOF PAG 12-0004
ROOF - TRIM PAG 12-0005
WASHER & WIPER PAG 12-0006
CAB GLASS PAG 12-0007
DOOR - LEFT SIDE PAG 12-0008
TRIM PAG 12-0009
CAB - NOISE REDUCTION PAG 12-0010
CAB - NOISE REDUCTION PAG 12-0011
CAB - INTERIOR EQUIPMENTS PAG 12-0012
CAB - COOL BOX PAG 12-0013
OPERATOR SEAT - STANDARD PAG 12-0014
OPERATOR SEAT - DELUXE PAG 12-0015
OPERATOR SEAT (COMPONENTS) - DELUXE PAG 12-0016
OPERATOR SEAT - DELUXE PAG 12-0017
OPERATOR SEAT - IDEALDRIVE PAG 12-0018
OPERATOR SEAT (COMPONENTS) PAG 12-0019
OPERATOR SEAT (COMPONENTS) PAG 12-0020
PASSENGER SEAT PAG 12-0021
PASSENGER SEAT PAG 12-0022
ARMREST PAG 12-0023
CONTROL PANEL - ADJUSTING DEVICE PAG 12-0024
MONITOR - SWIVEL ARM PAG 12-0025
MONITOR - SWIVEL ARM PAG 12-0026
ARMREST - IDEALDRIVE PAG 12-0027
ARMREST - IDEALDRIVE PAG 12-0028
ARMREST - BASE PAG 12-0029
MOBILE PHONE HOLDER PAG 12-0030
MOBILE PHONE HOLDER PAG 12-0031
TABLET HOLDER - SWIVEL ARM PAG 12-0032
TABLET HOLDER - SWIVEL ARM PAG 12-0033
RADIO AND ANTENNA PAG 12-0034
RADIO AND ANTENNA PAG 12-0035
SPEAKERS - NO SUBWOOFER PAG 12-0036
SPEAKERS - SUBWOOFER PAG 12-0037
SPEAKERS - SUBWOOFER PAG 12-0038
REAR VIEW MIRROR PAG 12-0039
PLATFORM & LADDER - WITH WHEELS PAG 12-0040
PLATFORM & LADDER - WITH WHEELS PAG 12-0041
PLATFORM & LADDER - WITH TRACKS PAG 12-0042
PLATFORM & LADDER - WITH TRACKS PAG 12-0043
PLATFORM EXTENSION PAG 12-0044
PLATFORM EXTENSION PAG 12-0045
PLATFORM EXTENSION PAG 12-0046
PLATFORM EXTENSION PAG 12-0047
STEPS - LADDER PAG 12-0048
LATCH - LADDER PAG 12-0049
LATCH - LADDER PAG 12-0050
WHEEL CHOCKS PAG 12-0051
WHEEL CHOCKS - FOLDING LADDER PAG 12-0052
TOOLS PAG 12-0053
FIRE EXTINGUISHER PAG 12-0054
FIRE EXTINGUISHER PAG 12-0055
FIRE EXTINGUISHER PAG 12-0056
13-000-TOC AIR CONDITIONING AND HEATING SYSTEM PAG 13-000-TOC Tech Spec Notes Ref
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 13-0001
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 13-0002
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 13-0003
HVAC LINES PAG 13-0004
HVAC LINES PAG 13-0005
14-000-TOC CHASSIS PAG 14-000-TOC Tech Spec Notes Ref
FRAME - BOTTOM PAG 14-0001
FRAME - BOTTOM PAG 14-0002
FRAME - BOTTOM PAG 14-0003
FRAME - BOTTOM PAG 14-0004
FRAME - BOTTOM PAG 14-0005
FRAME - TOP PAG 14-0006
FRAME - TOP PAG 14-0007
FRAME - TOP PAG 14-0008
TWIN ROTOR - WEAR PLATE PAG 14-0009
TWIN ROTOR - WEAR PLATE PAG 14-0010
TWIN ROTOR - WEAR PLATE PAG 14-0011
TWIN ROTOR - WEAR PLATE PAG 14-0012
PROCESSOR DOORS - DUAL ROTOR PAG 14-0013
PROCESSOR DOORS - DUAL ROTOR PAG 14-0014
PROCESSOR DOORS - DUAL ROTOR PAG 14-0015
PROCESSOR DOORS - DUAL ROTOR PAG 14-0016
PROCESSOR DOORS - DUAL ROTOR PAG 14-0017
PROCESSOR DOORS - DUAL ROTOR PAG 14-0018
PROCESSOR DOORS - DUAL ROTOR PAG 14-0019
PROCESSOR DOORS - DUAL ROTOR PAG 14-0020
BATTERY CARRIER AND TOOL BOX PAG 14-0021
STONE TRAP SLIDE - STANDARD PAG 14-0022
STONE TRAP SLIDE - PARALEVEL PAG 14-0023
STONE TRAP SLIDE - DUAL WHEELS PAG 14-0024
STONE TRAP SLIDE - TRACKS PAG 14-0025
STONE TRAP PAG 14-0026
STONE TRAP - COVER (LARGE GRAIN) PAG 14-0027
SHIELDS - CLEANING FAN PAG 14-0028
SHIELDS - CLEANING FAN PAG 14-0029
SHIELDS - CLEANING FAN PAG 14-0030
SHIELDS - CLEANING FAN PAG 14-0031
SHIELDS - CLEANING FAN PAG 14-0032
SHIELDS - CLEANING FAN PAG 14-0033
SHIELDS - BOTTOM PAG 14-0034
SHIELDS - BOTTOM PAG 14-0035
SHIELDS - BOTTOM PAG 14-0036
SHIELDS - BOTTOM PAG 14-0037
SHIELDS - BOTTOM PAG 14-0038
SHIELDS - BOTTOM PAG 14-0039
HEADER DRIVE - SHIELD PAG 14-0040
REAR PANEL - SINGLE SPEED PAG 14-0041
REAR PANEL - TWO SPEED PAG 14-0042
ENGINE ACCESS - LADDER PAG 14-0043
ENGINE ACCESS - DECK PLATES PAG 14-0044
ENGINE ACCESS - DECK PLATES PAG 14-0045
ENGINE ACCESS - DECK PLATES PAG 14-0046
ENGINE ACCESS - RAILING PAG 14-0047
ENGINE ACCESS - RAILING PAG 14-0048
FUEL - TANK BRACKET PAG 14-0049
ENGINE COVER PAG 14-0050
ENGINE COVER PAG 14-0051
ENGINE COVER PAG 14-0052
SHEET METAL - BRACKETS PAG 14-0053
SHEET METAL - BRACKETS PAG 14-0054
HINGE - SIDE PANELS PAG 14-0055
SHEET METAL - GRAIN BIN DOOR PAG 14-0056
SHEET METAL - GRAIN BIN DOOR PAG 14-0057
SHEET METAL - REAR RIGHT PAG 14-0058
SHEET METAL - RIGHT SIDE PAG 14-0059
STRUT - RIGHT SIDE PAG 14-0060
PANEL - AIR BOX PAG 14-0061
SHEET METAL - REAR PAG 14-0062
SHEET METAL - REAR PAG 14-0063
SHEET METAL - LEFT SIDE PAG 14-0064
SHEET METAL - LEFT SIDE PAG 14-0065
SHEET METAL - LEFT SIDE PAG 14-0066
STRUT - LEFT SIDE PAG 14-0067
SHEET METAL - REAR LEFT PAG 14-0068
LATCH - REAR LEFT PAG 14-0069
THRESHING MECHANISM - ACCESS PAG 14-0070
THRESHING MECHANISM - ACCESS PAG 14-0071
HANDLES PAG 14-0072
STRAW CHOPPER - SHIELD PAG 14-0073
STRAW CHOPPER - SHIELD PAG 14-0074
SIGNALING PANELS PAG 14-0075
SIGNALING PANELS PAG 14-0076
SIGNALING PANELS PAG 14-0077
SIGNALING PANELS PAG 14-0078
15-000-TOC DECALS PAG 15-000-TOC Tech Spec Notes Ref
DECALS - STANDARD PAG 15-0001
DECALS - SIDE PAG 15-0002
DECALS - SPEED PAG 15-0003
DECALS - SAFETY & WARNING PAG 15-0004
DECALS - SAFETY & WARNING PAG 15-0005
DECALS - SAFETY & WARNING PAG 15-0006
DECALS - SAFETY & WARNING PAG 15-0007
DECALS - SAFETY & WARNING PAG 15-0008
DECALS - SAFETY & WARNING PAG 15-0009
16-000-TOC WHEELS PAG 16-000-TOC Tech Spec Notes Ref
FRONT WHEELS - STANDARD - 1000_55 R32 PAG 16-0001
FRONT WHEELS - STANDARD - 800_70R38 PAG 16-0002
FRONT WHEELS - STANDARD - 800_70R38 PAG 16-0003
FRONT WHEELS - STANDARD - 900_60R38 PAG 16-0004
FRONT WHEELS - STANDARD - 710_70R42 PAG 16-0005
FRONT WHEELS - PARALEVEL - 800_70R38 PAG 16-0006
FRONT WHEELS - PARALEVEL - 900_60R38 PAG 16-0007
FRONT WHEELS - DUAL WHEELS - 520_85R42 PAG 16-0008
FRONT WHEELS - DUAL WHEELS - 580_85R42 PAG 16-0009
FRONT WHEELS - DUAL WHEELS - 620_70R42 PAG 16-0010
FRONT WHEELS - DUAL WHEELS - 710_70R42 PAG 16-0011
REAR WHEELS - 520_80R26 PAG 16-0012
REAR WHEELS - 620_70R26 PAG 16-0013
REAR WHEELS - 750_65R26 PAG 16-0014
REAR WHEELS - 520_85R30 PAG 16-0015
REAR WHEELS - 710_60R30 PAG 16-0016
TRACKS PAG 16-0017
TRACK ROLLER PAG 16-0018
TRACK ROLLER PAG 16-0019
TRACKS - FRONT PAG 16-0020
TRACKS - REAR PAG 16-0021
TRACKS - TENSIONER PAG 16-0022
TRACKS - BOGIE PAG 16-0023
TRACKS - WHEELS PAG 16-0024
TRACKS - CYLINDER PAG 16-0025
TRACKS - SCRAPERS PAG 16-0026
TRACKS - WHEELS PAG 16-0027
17-000-TOC FEEDING SYSTEM PAG 17-000-TOC Tech Spec Notes Ref
SHIELD PLATE PAG 17-0001
TILT FRAME PAG 17-0002
TILT FRAME PAG 17-0003
HEADER LOCK PAG 17-0004
HEADER LOCK PAG 17-0005
PITCH FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 17-0006
PITCH FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 17-0007
PITCH FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 17-0008
PITCH FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 17-0009
PITCH FRAME - FEEDER SEALING PAG 17-0010
PITCH FRAME - FEEDER SEALING PAG 17-0011
FEEDER FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 17-0012
FEEDER FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 17-0013
FEEDER FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 17-0014
FEEDER FRAME - MANUAL CUTTING ANGLE ADJUSTMENT PAG 17-0015
FEEDER FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 17-0016
FEEDER FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 17-0017
FEEDER FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 17-0018
FEEDER FRAME - HYDRAULIC CUTTING ANGLE ADJUSTMENT PAG 17-0019
FEEDER BOTTOM PLATE - STANDARD PAG 17-0020
FEEDER BOTTOM PLATE - STANDARD PAG 17-0021
FEEDER BOTTOM - HIGH WEAR PAG 17-0022
FEEDER BOTTOM - HIGH WEAR PAG 17-0023
UPPER SHAFT PAG 17-0024
UPPER SHAFT PAG 17-0025
FEED DRUM PAG 17-0026
FEEDER CHAIN PAG 17-0027
FEEDER CHAIN PAG 17-0028
DUST EJECTOR PAG 17-0029
DUST EJECTOR PAG 17-0030
DUST EJECTOR - PIPES PAG 17-0031
DUST EJECTOR - PIPES PAG 17-0032
DUST EJECTOR - HYDRAULIC MOTOR PAG 17-0033
DUST EJECTOR - HYDRAULIC MANIFOLD PAG 17-0034
FEEDER HOUSE COUPLING - RIGHT SIDE PAG 17-0035
FEEDER HOUSE COUPLING - LEFT SIDE PAG 17-0036
FEEDER HOUSE COUPLING PAG 17-0037
MULTI-CONNECTOR PAG 17-0038
FEEDER SHIELD - RIGHT SIDE PAG 17-0039
FEEDER SHIELD - RIGHT SIDE PAG 17-0040
FEEDER SHIELD - RIGHT SIDE PAG 17-0041
FEEDER SHIELD - RIGHT SIDE PAG 17-0042
FEEDER SHIELD - RIGHT SIDE PAG 17-0043
FEEDER SHIELD - LEFT SIDE PAG 17-0044
FEEDER SHIELD - LEFT SIDE PAG 17-0045
FEEDER SHIELD - LEFT SIDE PAG 17-0046
FEEDER SHIELD - LEFT SIDE PAG 17-0047
FEEDER SHIELD - LEFT SIDE PAG 17-0048
SHIELDS - UPPER HEADER DRIVE PAG 17-0049
SHIELDS - UPPER HEADER DRIVE PAG 17-0050
18-000-TOC THRESHING SYSTEM PAG 18-000-TOC Tech Spec Notes Ref
ROTOR FEEDER - STANDARD PAG 18-0001
ROTOR FEEDER - HIGH WEAR PAG 18-0002
ROTOR FEEDER - COVER PAG 18-0003
DUAL ROTOR - ROTOR INLET PAG 18-0004
DUAL ROTOR - ROTOR INLET PAG 18-0005
DUAL ROTOR - RIGHT ROTOR PAG 18-0006
DUAL ROTOR - LEFT ROTOR PAG 18-0007
DUAL ROTOR - CONCAVE ADJUSTMENT PAG 18-0008
DUAL ROTOR - ROTOR DISCHARGE PAG 18-0009
DUAL ROTOR - ROTOR DISCHARGE PAG 18-0010
DUAL ROTOR - ROTOR DISCHARGE PAG 18-0011
DUAL ROTOR - GRATES SUPPORT PAG 18-0012
IMPELLER - UNLOADER COVER PAG 18-0013
CONCAVE - SMALL GRAIN - STANDARD PAG 18-0014
CONCAVE - SMALL GRAIN - MIDDLE SPECS PAG 18-0015
CONCAVE - SMALL GRAIN - MIDDLE SPECS PAG 18-0016
CONCAVE - SMALL GRAIN - HIGH CAPACITY PAG 18-0017
CONCAVE - SMALL GRAIN - HIGH CAPACITY PAG 18-0018
CONCAVE - LARGE GRAIN PAG 18-0019
CONCAVE - LARGE GRAIN PAG 18-0020
CONCAVE - LARGE GRAIN PAG 18-0021
SEPARATOR GRATES - SMALL GRAIN PAG 18-0022
SEPARATOR GRATES - LARGE GRAIN PAG 18-0023
SEPARATOR GRATES - LARGE GRAIN PAG 18-0024
RETURN PAN PAG 18-0025
RETURN PAN PAG 18-0026
RETURN PAN PAG 18-0027
RETURN PAN PAG 18-0028
RETURN PAN PAG 18-0029
RETURN PAN - RIGHT SIDE PAG 18-0030
RETURN PAN - RIGHT SIDE PAG 18-0031
RETURN PAN - LEFT SIDE PAG 18-0032
RETURN PAN - LEFT SIDE PAG 18-0033
19-000-TOC CLEANING SYSTEM PAG 19-000-TOC Tech Spec Notes Ref
CLEANING FAN - FRAME PAG 19-0001
CLEANING FAN - FANNING MILL PAG 19-0002
PITMAN SHAFT PAG 19-0003
STRATIFICATION PAN PAG 19-0004
STRATIFICATION PAN PAG 19-0005
STRATIFICATION PAN PAG 19-0006
STRATIFICATION PAN PAG 19-0007
STRATIFICATION PAN PAG 19-0008
CHAFFER FRAME PAG 19-0009
CHAFFER FRAME PAG 19-0010
CHAFFER FRAME PAG 19-0011
SIEVE FRAME PAG 19-0012
SIEVE FRAME PAG 19-0013
SIEVE FRAME - 4 CHANNEL PAG 19-0014
SIEVE FRAME - 4 CHANNEL PAG 19-0015
SIEVE FRAME - 4 CHANNEL PAG 19-0016
SIEVE & CHAFFER - WIND WINGS PAG 19-0017
DISCHARGE EXTENSION - CHAFF SPREADER PAG 19-0018
DISCHARGE EXTENSION - STRAW SPREADER PAG 19-0019
SIEVE & CHAFFER - SMALL GRAIN PAG 19-0020
SIEVE - LARGE GRAIN PAG 19-0021
CHAFFER - LARGE GRAIN PAG 19-0022
TAILINGS ELEVATOR - STANDARD PAG 19-0023
TAILINGS ELEVATOR - HIGH WEAR PAG 19-0024
TAILINGS ELEVATOR - STANDARD PAG 19-0025
TAILINGS ELEVATOR - STANDARD PAG 19-0026
TAILINGS ELEVATOR - HIGH WEAR PAG 19-0027_1
TAILINGS ELEVATOR - HIGH WEAR PAG 19-0028
TAILINGS ELEVATOR - GEARBOX (COMPONENTS) PAG 19-0029
20-000-TOC GRAIN BIN AND ELEVATOR SYSTEM PAG 20-000-TOC Tech Spec Notes Ref
GRAIN BIN _ 12500L PAG 20-0001
GRAIN BIN _ 12500L PAG 20-0002
GRAIN BIN _ 12500L - RIGHT SIDE PAG 20-0003
GRAIN BIN _ 12500L - REAR PANEL PAG 20-0004
GRAIN BIN _ 12500L - ACCESS DOOR PAG 20-0005
GRAIN BIN _ 17100L PAG 20-0006
GRAIN BIN _ 17100L PAG 20-0007
GRAIN BIN _ 17100L - RIGHT SIDE PAG 20-0008
GRAIN BIN _ 17100L - REAR PANEL PAG 20-0009
GRAIN BIN _ 17100L - ACCESS DOOR PAG 20-0010
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0011
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0012
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0013
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0014
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0015
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0016
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0017
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0018
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0019
GRAIN BIN _ 12500L - EXTENSION (HYDRAULIC) PAG 20-0020
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0021
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0022
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0023
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0024
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0025
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0026
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0027
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0028
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0029
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0030
GRAIN BIN _ 17100L - EXTENSION (HYDRAULIC) PAG 20-0031
GRAIN BIN _ 12500L - UNLOADER GATE (MANUAL) PAG 20-0032
GRAIN BIN _ 12500L - UNLOADER GATE (HYDRAULIC) PAG 20-0033
GRAIN BIN _ 17100L - UNLOADER GATE (HYDRAULIC) PAG 20-0034
GRAIN BIN - UNLOADER GATE (HYDRAULIC) PAG 20-0035
SUMP & TURRET - 12500L PAG 20-0036
SUMP & TURRET - 12500L PAG 20-0037
SUMP & TURRET - 12500L PAG 20-0038
SUMP & TURRET - 12500L PAG 20-0039
SUMP & TURRET - 17100L PAG 20-0040
SUMP & TURRET - 17100L PAG 20-0041
SUMP & TURRET - 17100L PAG 20-0042
SUMP & TURRET - 17100L PAG 20-0043
UNLOADER _ CRADLE - 12500L PAG 20-0044
UNLOADER _ CRADLE - 17100L PAG 20-0045
UNLOADER TUBE - 12500L PAG 20-0046
UNLOADER TUBE - 12500L PAG 20-0047
UNLOADER TUBE - 12500L PAG 20-0048
UNLOADER TUBE - 12500L PAG 20-0049
UNLOADER TUBE - 12500L PAG 20-0050
UNLOADER TUBE - 12500L PAG 20-0051
UNLOADER TUBE - 12500L PAG 20-0052
UNLOADER TUBE - 12500L PAG 20-0053
UNLOADER TUBE - 12500L PAG 20-0054
UNLOADER TUBE - 12500L PAG 20-0055
UNLOADER TUBE - 12500L PAG 20-0056
UNLOADER TUBE - 12500L PAG 20-0057
UNLOADER TUBE - 12500L PAG 20-0058
UNLOADER TUBE - 12500L PAG 20-0059
UNLOADER TUBE - 12500L PAG 20-0060
UNLOADER TUBE - 17100L PAG 20-0061
UNLOADER TUBE - 17100L PAG 20-0062
UNLOADER TUBE - 17100L PAG 20-0063
UNLOADER TUBE - 17100L PAG 20-0064
UNLOADER TUBE - 17100L PAG 20-0065
UNLOADER TUBE - 17100L PAG 20-0066
UNLOADER TUBE - 17100L PAG 20-0067
UNLOADER TUBE - 17100L PAG 20-0068
UNLOADER TUBE - 17100L PAG 20-0069
UNLOADER TUBE - 17100L PAG 20-0070
UNLOADER TUBE - 17100L PAG 20-0071
UNLOADER TUBE - 17100L PAG 20-0072
UNLOADER TUBE - 17100L PAG 20-0073
UNLOADER TUBE - 17100L PAG 20-0074
UNLOADER TUBE - 17100L PAG 20-0075
UNLOADER TUBE - 17100L PAG 20-0076
UNLOADER TUBE - 17100L PAG 20-0077
UNLOADER TUBE - 17100L PAG 20-0078
UNLOADER TUBE - 17100L PAG 20-0079
BIN UNLOADER AUGER - 12500L PAG 20-0088
BIN UNLOADER AUGER - 17100L PAG 20-0089
BIN UNLOADER AUGER - 17100L PAG 20-0090
BIN UNLOADER AUGER - 17100L PAG 20-0091
BIN UNLOADER AUGER - 17100L PAG 20-0092
BIN UNLOADER AUGER - 17100L PAG 20-0093
BIN UNLOADER AUGER - 17100L PAG 20-0094
BIN UNLOADER AUGER - 17100L PAG 20-0095
BIN UNLOADER AUGER - 17100L PAG 20-0096
BIN UNLOADER AUGER - 17100L PAG 20-0097
BIN UNLOADER AUGER - 17100L PAG 20-0098
SPILL SAVER - SMALL PAG 20-0099
SPILL SAVER - SMALL PAG 20-0100
SPILL SAVER - LOW CAPACITY PAG 20-0101
SPILL SAVER - LARGE PAG 20-0102
SPILL SAVER - LARGE PAG 20-0103
SPILL SAVER - HIGH CAPACITY PAG 20-0104
GRAIN ELEVATOR PAG 20-0105
GRAIN ELEVATOR - BIN LOADER PAG 20-0106
GRAIN ELEVATOR - BIN LOADER PAG 20-0107
GRAIN ELEVATOR - BIN LOADER PAG 20-0108
GRAIN ELEVATOR - FILLING AUGER PAG 20-0109
GRAIN ELEVATOR - FILLING AUGER PAG 20-0110
GRAIN ELEVATOR - ELEVATOR AUGER PAG 20-0111
GRAIN ELEVATOR - ELEVATOR AUGER PAG 20-0112
GRAIN ELEVATOR - ELEVATOR AUGER PAG 20-0113
GRAIN ELEVATOR - ELEVATOR AUGER PAG 20-0114
GRAIN ELEVATOR - CLEANOUT DOORS PAG 20-0115
21-000-TOC DISCHARGE SYSTEM PAG 21-000-TOC Tech Spec Notes Ref
STRAW CHOPPER - BRACKETS PAG 21-0001
STRAW CHOPPER - BRACKETS PAG 21-0002
STRAW CHOPPER - BRACKETS PAG 21-0003
STRAW CHOPPER - HOUSING PAG 21-0004
STRAW CHOPPER - HOUSING PAG 21-0005
STRAW CHOPPER PAG 21-0006
STRAW CHOPPER PAG 21-0007
STRAW CHOPPER PAG 21-0008
STRAW CHOPPER PAG 21-0009
STRAW CHOPPER PAG 21-0010
STRAW CHOPPER PAG 21-0011
STRAW CHOPPER - KNIFE PAG 21-0012
STRAW CHOPPER - KNIFE PAG 21-0013
STRAW CHOPPER - KNIFE PAG 21-0014
STRAW CHOPPER - COVER PAG 21-0015
STRAW DEFLECTOR - COVER PAG 21-0016
STRAW DEFLECTOR - COVER PAG 21-0017
STRAW DEFLECTOR - MANUAL ADJUSTABLE PAG 21-0018
STRAW DEFLECTOR - MANUAL ADJUSTABLE PAG 21-0019
STRAW DEFLECTOR - ELECTRICAL ADJUSTMENT PAG 21-0020
STRAW DEFLECTOR - ELECTRICAL ADJUSTMENT PAG 21-0021
STRAW DEFLECTOR PAG 21-0022
ACTIVESPREAD - COVER PAG 21-0023
ACTIVESPREAD - MANUAL ADJUSTABLE PAG 21-0024
ACTIVESPREAD - MANUAL ADJUSTABLE PAG 21-0025
ACTIVESPREAD - ELECTRICAL ADJUSTMENT PAG 21-0026
ACTIVESPREAD - ELECTRICAL ADJUSTMENT PAG 21-0027
ACTIVESPREAD - ELECTRICAL ADJUSTMENT PAG 21-0028
ACTIVESPREAD PAG 21-0029
ACTIVESPREAD PAG 21-0030
ACTIVESPREAD PAG 21-0031
ACTIVESPREAD - GASKETS PAG 21-0032
ACTIVESPREAD - GASKETS PAG 21-0033
ACTIVESPREAD - GASKETS PAG 21-0034
ACTIVESPREAD - GASKETS PAG 21-0035
ACTIVESPREAD - DEFLECTOR PAG 21-0036
ACTIVESPREAD - DEFLECTOR PAG 21-0037
ACTIVESPREAD - DEFLECTOR PAG 21-0038
ACTIVESPREAD - DEFLECTOR PAG 21-0039
STRAW SPREADER PAG 21-0040
STRAW SPREADER PAG 21-0041
CHAFF SPREADER PAG 21-0042
CHAFF SPREADER - MANUAL ADJUSTABLE PAG 21-0043
CHAFF SPREADER - ELECTRICAL ADJUSTMENT PAG 21-0044
22-000-TOC PRECISION FARMING SYSTEMS PAG 22-000-TOC Tech Spec Notes Ref
GUIDANCE - MODULE PAG 22-0001
GUIDANCE - MODULE PAG 22-0002
GUIDANCE - MODULE PAG 22-0003
AGCO CONNECTIVITY MODULE (ACM) PAG 22-0004
AGCO CONNECTIVITY MODULE (ACM) PAG 22-0005
GUIDANCE RECEIVER - NOVATEL PAG 22-0006
GUIDANCE RECEIVER - TRIMBLE PAG 22-0007
TRIMBLE - UPGRADE PAG 22-0008
ANTENNA - NOVATEL PAG 22-0009
ANTENNA - NOVATEL PAG 22-0010
23-000-TOC ACCESSORIES PAG 23-000-TOC Tech Spec Notes Ref
ACCESSORIES - BLOCK HEATER PAG 23-0001
BLOCK HEATER PAG 23-0002
DEF FILL KIT PAG 23-0003
DEF DRAIN SYSTEM PAG 23-0004
LOCKABLE FUEL TANK CAP PAG 23-0005
DOOR STOPPER PAG 23-0006
DOOR STOPPER PAG 23-0007
SMART DEVICE MOUNTING PAG 23-0008
SMART DEVICE MOUNTING PAG 23-0009
MULTIPLE CAMERA DISPLAY PAG 23-0010
360° CAMERA SYSTEM PAG 23-0011
REAR VIEW CAMERA PAG 23-0012
GUIDANCE PAG 23-0013
GUIDANCE - TRIMBLE PAG 23-0014
GUIDANCE PAG 23-0015
NOVATEL UPGRADE PAG 23-0016
SIDE SUN VISOR PAG 23-0017
LADDER ACTUATOR PAG 23-0018
ADVANCED LIGHTING PAG 23-0019
LIGHTS - REAR AXLE PAG 23-0020
REAR AXLE - 4 WHEEL DRIVE PAG 23-0021
COVER - AXLE PAG 23-0022
ACCESSORIES - 3RD AXLE PAG 23-0023
ACCESSORIES - 3RD AXLE PAG 23-0024
ACCESSORIES - 3RD AXLE PAG 23-0025
REMOVABLE - FEEDER PAG 23-0026
FEEDER FLOOR PAG 23-0027
WEAR RESISTANT BOTTOM PAG 23-0028
FLIP-UP HEADER LIGHT PAG 23-0029
ACCESSORIES - FOLDING CUTTER BAR LIGHT PAG 23-0030
CONVERSION KIT - AUTODOCK PAG 23-0031
AUTOMATIC DOCK - UNIVERSAL PAG 23-0032
QUICK HYDRAULIC COUPLERS (MULTI-FASTER) - UNIVERSAL PAG 23-0033
COUPLING - HEADER PAG 23-0034
CUTTING HEADER - SUSPENSION PAG 23-0035
CUTTING HEADER - REVERSER PAG 23-0036
CORN HEADER FOLDING HYDRAULIC PAG 23-0037
STONE TRAP - COVER (LARGE GRAIN) PAG 23-0038
JUMPER KIT - AUTOMATIC HEADER HEIGHT CONTROL PAG 23-0039
JUMPER HARNESS PAG 23-0040
JUMPER HARNESS PAG 23-0041
JUMPER HARNESS - DUST EJECTOR PAG 23-0042
JUMPER CONNECTOR PAG 23-0043
EGR JUMPER PAG 23-0044
JUMPER HARNESS PAG 23-0045
HITCH DROP PIN PAG 23-0046
HITCH PAG 23-0047
SPOUT SOCK (SMALL) PAG 23-0048
SPOUT SOCK (LARGE) PAG 23-0049
TAILINGS ELEVATOR - HATCHS PAG 23-0050
ACCESSORIES - TAILINGS ELEVATOR - HATCHS PAG 23-0051
ACCESSORIES - TAILINGS ELEVATOR - COVER (LARGE GRAIN) PAG 23-0052
FRAME PAG 23-0053
SENSOR - CRADLE PAG 23-0054
SENSOR - CRADLE PAG 23-0055
GRAIN BIN CORNERS PAG 23-0056
GRAIN BIN CORNERS - LOW CAPACITY PAG 23-0057
GRAIN BIN CORNERS - HIGH CAPACITY PAG 23-0058
GRAIN BIN UNLOADING - SPEED REDUCTION PAG 23-0059
LIFTING MECHANISM PAG 23-0060
KIT - ACTIVE TAILBOARD PAG 23-0061
KIT - PASSIVE TAILBOARD POWERED PAG 23-0062
PASSIVE TAILBOARD POWERED - COVER PAG 23-0063
WIRING HARNESS - PASSIVE TAILBOARD POWERED PAG 23-0064
PASSIVE TAILBOARD POWERED - ELECTRICAL ADJUSTMENT PAG 23-0065
CHAFFER ACTUATOR REPAIR PAG 23-0066
SIEVE & CHAFFER - LARGE GRAIN PAG 23-0067
SIEVE & CHAFFER - LARGE GRAIN PAG 23-0068
SIEVE & CHAFFER - LARGE GRAIN PAG 23-0069
SIEVE & CHAFFER - LARGE GRAIN PAG 23-0070
SIEVE & CHAFFER - LARGE GRAIN PAG 23-0071
SIEVE & CHAFFER - SMALL GRAIN PAG 23-0072
SIEVE & CHAFFER - SMALL GRAIN PAG 23-0073
SIEVE & CHAFFER - SMALL GRAIN PAG 23-0074
SIEVE & CHAFFER - SMALL GRAIN PAG 23-0075
SIEVE & CHAFFER - SMALL GRAIN PAG 23-0076
CHAFF SPREADER - MANUAL ADJUSTABLE PAG 23-0077
DEFLECTOR KIT - SMALL GRAIN PAG 23-0078
GRASS SEED (LOW CAPACITY UNLOADER) PAG 23-0079
GRASS SEED (LOW CAPACITY UNLOADER) PAG 23-0080
GRASS SEED - STREAMER 140 & 210 PAG 23-0081
GRASS SEED (HIGH CAPACITY UNLOADER) PAG 23-0082
GRASS SEED (HIGH CAPACITY UNLOADER) PAG 23-0083
WARNING SIGNS PAG 23-0084
Brand: Fendt
HITCH PAG 06-0020
HITCH PAG 06-0021
ROOF PAG 12-0004
TRIM PAG 12-0009
ARMREST PAG 12-0023
TOOLS PAG 12-0053
HANDLES PAG 14-0072
TRACKS PAG 16-0017
HITCH PAG 23-0047
FRAME PAG 23-0053
