Fendt Combine 9490X Parts Catalog 6246078 07.2020
Brand: Fendt
Type of Machine: Combine
Model: Fendt 9490X Combine
Serial Number: 502000001-999, 502400001-999 AL
Publication Date: 07.2020
Number of Pages: 760 Pages
Engine V835477030 98 Awf
Engine Assemblies - Engine Serial Number Range A55788-A64773
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
High Pressure Turbocharger
Low Pressure Turbocharger And Icac
Oil Pump And Sump
Oil Cooler And Filter
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Installation
Filters Guide
Engine Brackets
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Oil Cooler
Cooling System - Fan Cowl
Cooling System - Rotary Screen
Rotary Screen Brush - Maize
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank (Components)
Fuel Tank (Components)
Fuel Lines
Drive System
Drive Belt System - Left Side
Drive Belt System - Right Side
Hydrostatic Pump & Power Take-Off
Feeder Conveyor - Drive
Feeder Reverser - Drive
Threshing Mechanism - Drive
Rotor Feeder - Drive
Rotor - Drive
Rotor Variator
Countershaft - Drive
Cylinder Variator - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - Low Speed
Grain Elevator - Drive
Grain Bin Unloading - Drive
Cleaning Fan - Drive
Straw Chopper - Drive
Chaff Spreader - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Wheel Motor (Components)
Hitch
Steering Column
Steering Column (Components)
Steering - Hydraulic Lines
Steering - Rear Axle
Front Axle & Gearbox - Shield
Front Axle & Gearbox - Standard
Final Drive (Components)
Gearbox (Components)
Gear Lever System
Brake Pedal
Brake System - Standard
Brake System - (Components)
Hydraulic Oil Tank
Hydraulic Pump - Valve Block (Components)
Hydraulic Propel - Only For Wheels Configuration
Hydraulic Propel - Only For Half-Tracks Configuration
Front Axle
Front Axle - Valve Block (Components)
Cutting Header - Lifting
Cutting Header - Lifting - Valve Block (Components)
Cutting Header - Lifting - Lift Ram
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Flow Divider Valve (Components)
Cutting Header - Valve Block (Components)
Cutting Header - Tilt - Accumulator
Cutting Header - Reverser
Beater - Variator
Motor - Variator
Grain Bin Unloading
Unloader & Threshing
Unloader & Threshing - Valve Block (Components)
Maxi Spreader
Maxi Spreader - Valve Block (Components)
Chaff Spreader
Grease Lines
Sensors Guide
Front Lighting
Rear Lighting
Number Plate - Lighting
Work Lights
Work Lights - Roof
Work Lights - Discharging Tube For Grain Tank
Rotary Beacon
Battery & Cables
Harness - Front Axle
Harness - Rear Axle
Harness - Cab
Harness - Cab Roof
Harness - Steering Column
Harness - Control Console
Harness - Grain Bin
Harness - Left Side
Harness - Right Side
Harness - Engine
Harness - Oil Level
Harness - Rotor
Harness - Yield Monitor & Moisture Sensor
Harness - Sieves & Loss
Harness - Straw Hood
Harness - Straw Deflector
Harness - Maxi Spreader
Electrical Box - Front
Electrical Box - Rear
Return Auger - Returns Volume Sensor
Constant Flow Sensor
Taskdoc
Agcommand
Rear View Camera
Rear View Camera - Secondary
Seat Holder
Seat - (Components)
Control Console
Control Console (Components)
Monitoring Display
Monitoring Display - Yield Monitor & Moisture Sensor
Rear View Mirror
Platform - Right Side
Platform - Left Side
Platform Extension - Left Side
Access Ladder
Air Conditioning
Air Conditioning (Components)
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Rotor
Frame - Straw Hood
Tool Box
Stone Trap
Front Guards
Front Guards - Right Side
Front Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Engine Cover
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Signaling Panels
Decals - Safety & Warning
Decals - Drive System
Tracks
Front Wheels
Front Wheels - Bolts Safety Markers
Wheels Wedges - Right Side
Feeding System
Tools
Shield Plate
Tilt Frame
Feeder Frame
Upper Shaft
Feed Drum
Feeder Chain
Shield
Threshing System
Thresher Concave
Thresher Concave - Maize
Rear Beater
Concave Adjustment
Rotor Feeder
Rotor Inlet
Rotor
Rotor - Anti-Winding
Rotor - Rear Seals
Rotor Discharge
Separator Grates
Return Pan
Cleaning System
Cleaning Fan
Cleaning Fan - Shield
Cleaning Fan - Fanning Mill
Pitman Shaft
Stratification Pan
Chaffer Frame
Sieve Frame
Chaffer
Chaffer - Maize & Soya
Sieve
Tailings Elevator
Tailings Elevator - Angle Drive (Components)
Grain Bin And Elevator System
Grain Bin
Grain Bin - Extension
Grain Bin - Unloader Gate
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Short
Grain Bin Unloading - Long
Grain Bin Unloading - Spill Saver
Grain Elevator - With Moisture Sensor
Grain Elevator
Grain Elevator - Filling Auger
Discharge System
Straw Chopper
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Chopper - Maize
Straw Deflector
Maxi Chaff Spreader
Maxi Chaff Spreader - Maize
Chaff Spreader - Tray
Precision Farming Systems
Guidance Receiver
Accessories - Additional Fuel Filter
Accessories - Rotary Screen Brush
Accessories - Dust Accumulation (Engine Compartment)
Accessories - Variable Speed Fan Drive
Accessories - Rear Axle 4 Wd
Accessories - Feeder Accumulation (Rotor Inlet)
Accessories - Rotor - Blanking Plate
Accessories - Rotor - Anti-Winding
Accessories - Rotor - Rear Seals
Accessories - Perforated Covers For Pea
Accessories - Grass Seed Auger
Accessories - Drum Speed Reduction
Accessories - Maxi Chaff Spreader
Accessories - Chaff Spreader - Tray
Accessories - Led Work Lights
Accessories - Flip-Up Header Light
Accessories - Extensions For Wheels 1050 50r32
Accessories - Autoradio
Accessories - Multimedia Navigation
Accessories - Agcommand
Accessories - Autoguide
Accessories - 360° View Camera
Accessories - Rear View Camera
Conversion Kit - Wheat To Maize
Kit Reinforcement Bearing
Kit Fan Cover & Screen
KIT REINFORCEMENT FAN HOUSING
Brand: Fendt
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
Oil Pump And Sump
Coolant Piping
Fuel Filters
Starter Motor
Fan Drive
Engine Installation
Filters Guide
Engine Brackets
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Fuel Lines
Drive System
Rotor - Drive
Rotor Variator
Rear Axle Support
Hitch
Steering Column
Gear Lever System
Brake Pedal
Hydraulic Oil Tank
Front Axle
Cutting Header
Beater - Variator
Motor - Variator
Grain Bin Unloading
Maxi Spreader
Chaff Spreader
Grease Lines
Sensors Guide
Front Lighting
Rear Lighting
Work Lights
Work Lights - Roof
Rotary Beacon
Battery & Cables
Harness - Rear Axle
Harness - Cab
Harness - Cab Roof
Harness - Grain Bin
Harness - Left Side
Harness - Engine
Harness - Oil Level
Harness - Rotor
Taskdoc
Agcommand
Rear View Camera
Seat Holder
Seat - (Components)
Control Console
Monitoring Display
Rear View Mirror
Access Ladder
Air Conditioning
Frame - Lower
Frame - Beater
Frame - Rotor
Frame - Straw Hood
Tool Box
Stone Trap
Front Guards
Engine Cover
Sheet Metal - Rear
Signaling Panels
Tracks
Front Wheels
Feeding System
Tools
Shield Plate
Tilt Frame
Feeder Frame
Upper Shaft
Feed Drum
Feeder Chain
Shield
Threshing System
Thresher Concave
Rear Beater
Concave Adjustment
Rotor Feeder
Rotor Inlet
Rotor
Rotor - Rear Seals
Rotor Discharge
Separator Grates
Return Pan
Cleaning System
Cleaning Fan
Pitman Shaft
Stratification Pan
Chaffer Frame
Sieve Frame
Chaffer
Sieve
Tailings Elevator
Grain Bin
Grain Elevator
Discharge System
Straw Chopper
Straw Deflector
Maxi Chaff Spreader
Guidance Receiver
