Fendt Combine 9470X Parts Catalog 3906268 05.2020
Brand: Fendt
Type of Machine: Combine
Model: Fendt 9470X Combine
Serial Number: 62000-63999, 500000001-999, 500400001-999 AL
Publication Date: 05.2020
Number of Pages: 999 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Air Intake & Exhaust
Turbocharger
Oil Pump And Sump
Oil Cooler And Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment - Engine Type Awf
Engine Overhaul Parts
Engine Installation
Filters Guide
Engine Brackets
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Cooling System - Fan Cowl
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank (Components)
Drive System
Drive Belt System - Left Side
Drive Belt System - Right Side
Hydrostatic Pump & Power Take-Off
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Threshing Mechanism - Drive
Rotor Feeder - Drive
Rotor - Drive
Rotor Variator - Drive
Countershaft - Drive
Cylinder Variator - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - Low Speed
Counter Drive
Grain Elevator - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Chaff Spreader - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 4 Wheels Drive
Hitch
Steering Column
Steering Column (Components)
Steering - Hydraulic Lines
Steering - Rear Axle - 2 Wheels Drive
Steering - Rear Axle - 4 Wheels Drive
Front Axle & Gearbox - Shield
Front Axle & Gearbox - Standard
Front Axle & Gearbox - Autolevel
Final Drive (Components)
Gearbox (Components)
Gear Lever System
Brake Pedal
Brake System - Standard
Brake System - Autolevel
Brake System - (Components)
Hydraulic Oil Tank
Hydraulic Propel
Front Axle
Cutting Header - Lifting - Standard
Cutting Header - Lifting - Autolevel
Cutting Header - Lifting - Lift Ram
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Tilt
Cutting Header - Reverser
Beater - Variator
Motor - Variator
Autolevel - Hydraulic Cylinder
Autolevel
Grain Bin Unloading
Chaff Spreader
Maxi Spreader
Front Lighting
Rear Lighting
Number Plate - Lighting
Work Lights - Straw Hood
Rotary Beacon
Reversing Light
Battery & Cables
Electrical Parts
Electrical System - Components
Harness - Front Lighting
Harness - Cab Roof
Harness - Cab
Harness - Control Console
Harness - Cutting Header
Harness - Harvest Function
Harness - Thresher Concave
Harness - Grain Bin
Harness - Right Side
Harness - S.C.R. System
Harness - Engine
Harness - Rotor
Harness - Vertical Knives
Harness - Yield Monitor & Moisture Sensor
Harness - Sieves & Loss
Harness - Straw Hood
Computer Harness
Computer Harness - Current Supply
Electrical Box
Electrical Box - Autolevel
Straw Chopper
Straw Deflector
Harness - Maxi Spreader
Agcommand
Control Console
Datavision
Rear View Mirror
Access Ladder
Access Ladder - Extension - Autolevel
Air Conditioning
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Rotor
Frame - Straw Hood
Tool Box
Stone Trap
Front Guards
Engine Access - Deck & Ladder
Engine Access - Handrail
Engine Cover
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Signaling Panels
Decals - Right Side
Decals - Left Side
Decals - Safety & Warning
Front Wheels
Wheel Wrench
Feeding System
Shield Plate
Tilt Frame
Feeder Frame
Feeder Frame - Maize
Upper Shaft
Feed Drum
Feeder Chain
Shield
Threshing System
Thresher Concave
Thresher Concave - Maize
Rear Beater
Concave Adjustment
Rotor Feeder
Rotor Inlet
Rotor
Rotor Discharge
Separator Grates
Return Pan
Cleaning System
Cleaning Fan
Cleaning Fan - Shield
Cleaning Fan - Fanning Mill
Pitman Shaft
Stratification Pan
Chaffer Frame
Sieve Frame
Sieve Frame - Repair Kit
Chaffer
Chaffer - Maize
Sieve
Tailings Elevator
Tailings Elevator - Angle Drive
Grain Bin And Elevator System
Grain Bin
Grain Bin - Extension
Grain Bin - Unloader Gate
Grain Elevator
Grain Elevator - Yield Monitor & Moisture Sensor
Grain Elevator - Filling Auger
Discharge System
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Chopper - Maize
Straw Deflector - Manual Handle
Maxi Chaff Spreader
Maxi Chaff Spreader - Maize
Precision Farming Systems
Guidance Receiver
Accessories - Additional Fuel Filter
Accessories - Beater
Accessories - Variable Speed Fan Drive
Accessories - Rear Axle 4 Wd
Accessories - Wheels Wedges
Accessories - Perforated Covers For Pea
Accessories - Rotor - Blanking Plate
Accessories - Reinforcement Fan Housing
Accessories - Feeder Conveyor
Accessories - Header Additional Lifting Ram
Accessories - Rotor Inlet
Accessories - Agcommand
CONVERSION KIT - WHEAT TO MAIZE
Brand: Fendt
Engine Assemblies
Turbocharger
Oil Pump And Sump
Fuel Filters
Starter Motor
Fan Drive
Engine Installation
Filters Guide
Engine Brackets
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Drive System
Rotor - Drive
Counter Drive
Rear Axle Support
Hitch
Steering Column
Gear Lever System
Brake Pedal
Hydraulic Oil Tank
Hydraulic Propel
Front Axle
Cutting Header
Beater - Variator
Motor - Variator
Autolevel
Grain Bin Unloading
Chaff Spreader
Maxi Spreader
Front Lighting
Rear Lighting
Rotary Beacon
Reversing Light
Battery & Cables
Electrical Parts
Harness - Cab Roof
Harness - Cab
Harness - Grain Bin
Harness - Engine
Harness - Rotor
Computer Harness
Electrical Box
Straw Chopper
Straw Deflector
Agcommand
Control Console
Datavision
Rear View Mirror
Access Ladder
Air Conditioning
Frame - Lower
Frame - Beater
Frame - Rotor
Frame - Straw Hood
Tool Box
Stone Trap
Front Guards
Engine Cover
Sheet Metal - Rear
Signaling Panels
Decals - Right Side
Decals - Left Side
Front Wheels
Wheel Wrench
Feeding System
Shield Plate
Tilt Frame
Feeder Frame
Upper Shaft
Feed Drum
Feeder Chain
Shield
Threshing System
Thresher Concave
Rear Beater
Concave Adjustment
Rotor Feeder
Rotor Inlet
Rotor
Rotor Discharge
Separator Grates
Return Pan
Cleaning System
Cleaning Fan
Pitman Shaft
Stratification Pan
Chaffer Frame
Sieve Frame
Chaffer
Chaffer - Maize
Sieve
Tailings Elevator
Grain Bin
Grain Elevator
Discharge System
Maxi Chaff Spreader
Guidance Receiver
