702,019
Fendt Combine 6335C PL Parts Catalog 3906394 03.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 6335C PL Combine (Stage 3B / Tier 4I)
Serial Number: 564100001-084
Publication Date: 03.2019
Number of Pages: 772 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Air Intake & Exhaust
Turbocharger
Oil Pump And Sump
Oil Cooler And Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Engine Installation
Engine Installation - Fan
Engine Installation - Engine Brackets
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen & Attachments
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank - (Components)
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank (Components)
Fuel System - Fuel Tank Bracket
Drive System
Belts & Link Chains - Left Side
Belts & Link Chains - Right Side
Hydrostatic Pump - Drive
Rotary Filter And Dust Aspiration - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Air Conditioning - Drive
Cylinder Variator
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Towing Hook
Towing Hook Cuna
Frame And Suspension
Frame
Beater - Body
Steering Column
Front Axle
Front Axle - Left Side
Front Axle - Right Side
Reduction Gear - Left Side
Reduction Gear - Right Side
Reduction Gear
Gearbox - Gear Lever
Gearbox
Brake Caliper - (Components)
Brake Pedal
Brake Master Cylinder & Brake Control Valve - (Components)
Parking Brake - Pedal
Parking Brake - Pedal (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydrostatic Pump
Hydrostatic Pump - (Components)
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Motor
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Tilt
Cutting Header - Lifting
Flow Capacity Reduction Solenoid Valve - (Components)
Cutting Table Flotation
Lateral Header Flotation Control Valve - (Components)
Steering
Steering - Rear Axle - 4 Wheels Drive
Control Valve (Header)
Control Valve (Header) - (Components)
Hydraulic Levelling
Pipes Reel
Reel Speed Control
Electrohydraulic Engagement Control Valve - With Straw Chopper
Electrohydraulic Engagement Control Valve - (Components)
Pipe Union
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Battery Box & Battery Cable
Harness - Front Lighting
Harness - Cab - Control Console
Harness - Gearbox Sensors
Harness - Fuse Carrier
Electronic Box - (Components)
Harness - Grain Tank
Harness - Multi Crop Separator
Harness - Rear Body
Harness - Engine
Harness - Control Valve
Harness - Control Unit
Harness - Vertical Knives Control
Harness - Hydraulic Levelling
Harness - Hydraulic Oil Tank & Hydrostatic Pump
Harness - Straw Walker Loss
Harness - Straw Chopper
Harness Shield
Return Auger - Sensors
Seat Holder
Platform & Protective Mat
Access Ladder
Access Ladder - Extension
Footstep - Left Side
Footstep - Right Side
Rear View Mirror
Air Conditioning
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Access Ladder
Engine Compartment - Service Hatch
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Decals - Safety
Front Wheels
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Lower Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Collector Drum
Crop Elevator - Lifting
Crop Elevator - Reverse Drive
Threshing System
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Rear Beater
Concave - Control System
Concave - Grain & Maize
Concave - Deflector Plate
Multi Crop Separator - Left Side
Multi Crop Separator - Right Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker - Body
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Tank
Grain Tank - Extension
Grain Tank - Filling Auger
Connecting Box - (Components)
Grain Tank Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Lifting Tools
Number Plate
Tool Box - Tools
Tool Box - Bracket
Additional Fire Extinguisher
Air Compressor
Equipment - Official Approval
Accessories - Additional Fuel Filter
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Seed Riddle - Elec. Adjustable
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Parking Brake
Conversion Kit - Wheat To Maize
Filters
FILTERS
