Fendt Combine 6335C PL-I Parts Catalog 6246187 03.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 6335C PL-I Combine (Stage 4 / Tier 4F)
Serial Number: 564110001-097, ZN205641X03010098-999
Publication Date: 03.2019
Number of Pages: 1039 Pages
Engine V835277150 84 Awf
Engine Assemblies
Cylinder Block - Up To Engine Serial Number C52250
Cylinder Block - Starting From Engine Serial Number C52251
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
High Pressure Turbocharger
Low Pressure Turbocharger And Icac
Oil Pump And Sump
Oil Cooler And Filter - Up To Engine Serial Number C52250
Oil Cooler And Filter - Starting From Engine Serial Number C52251
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters - Starting From Engine Serial Number B50000
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine V835277731 84 Awf-Hla
Exhaust Manifold - M12 Turbo Mounting Stud Bolts
High Pressure Turbocharger - M12 Turbo Mounting Stud Bolts
Low Pressure Turbocharger And Icac - M12 Turbo Mounting Stud Bolts
Fuel Filters
Engine Installation
Engine Installation - Fan
Engine Installation - Engine Brackets
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Collector Brush
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank - (Components)
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank (Components)
Fuel System - Fuel Tank Bracket
Drive System
Belts & Link Chains - Left Side
Belts & Link Chains - Right Side
Hydrostatic Pump - Drive
Hydrostatic Pump - (Components)
Rotary Filter And Dust Aspiration - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Crop Elevator - Reverse Drive
Cylinder Variator
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Rear Axle - 4 Wheels Drive - Weight
Towing Hook
Towing Hook Cuna
Towing Hook Rockinger
Frame And Suspension
Frame
Beater - Body
Steering Column
Front Axle
Front Axle - Shield
Front Axle - Left Side
Front Axle - Right Side
Reduction Gear - Left Side
Reduction Gear - Right Side
Reduction Gear - (Components)
Gearbox - Gear Lever
Gearbox
Brake Caliper - (Components)
Brake Pedal
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Tilt
Cutting Header - Lifting
Cylinder Head Automatic Function Control Valve - (Components)
Cutting Table Flotation
Lateral Header Flotation Control Valve - (Components)
Steering
Steering - Rear Axle - 4 Wheels Drive
Hydraulic Levelling - Rear
Hydraulic Levelling
Control Valve
Control Valve (Header) - (Components)
Pipes Reel
Reel Speed Control
Reel Speed Proportional Control Unit - (Components)
Electrohydraulic Engagement Control Valve - With Straw Chopper
Electrohydraulic Engagement Control Valve - (Components)
Central Lubrification
Pipe Union
Front Lighting
Front Lighting - Roof
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Work Lights - For Folding Cutter Bar
Number Plate - Lighting
Battery & Main Switch - Battery Box & Battery Cable
Power Distributor Center Electrical
Harness - Left Side
Harness - Right Side
Harness - Cab - Control Console
Harness - Cab - Steering
Harness - Cab
Harness - Cab - Roof
Harness - Front Axle
Harness - Rear Axle
Harness - Grain Tank
Harness - Engine Tier 4f Stage 4
Harness - Oil Tank
Harness - Multi Crop Separator
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness - Vertical Knives Control
Harness Shield
Return Auger - Sensors
Rear View Camera
Rear View Camera - Secondary
Agcommand
Seat Holder
Seat - (Components)
Platform
Platform & Protective Mat
Access Ladder
Footstep - Left Side
Footstep - Right Side
Refrigerator
Control Console
Control Console (Components)
Monitoring Display
Rear View Mirror
Air Conditioning
Air Conditioning - (Components)
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Access Ladder
Engine Compartment - Service Hatch
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Decals - Safety
Front Wheels
Rear Wheels - 2 Wheels Drive
Rear Wheels - 4 Wheels Drive
Rear Wheels - Weight
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Floating Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Collector Drum
Crop Elevator - Lifting
Threshing System
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Rear Beater
Concave - Control System
Concave - Deflector Plate
Multi Crop Separator - Left Side
Multi Crop Separator - Right Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker - Body
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Electrical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Tank
Grain Tank - Extension
Grain Tank - Filling Auger
Connecting Box - (Components)
Grain Tank Unloading - Drain Pipe
Grain Tank Unloading - Inner Protection
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Lifting Tools
Tool Box - Tools
Tool Box - Bracket
Additional Fire Extinguisher
Air Compressor
Equipment - Official Approval
Accessories - Additional Fuel Filter
Accessories - Dust Collector Brush
Accessories - Fuel Tank Cover
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Front Axle - Shield
Accessories - Beater - Blanking Plate
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Modular Grain Pan
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Inner Protection Of Grain Tank Unloading
Accessories - Rubber Spout Long
Accessories - Additional Fire Extinguisher
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Led Work Lights
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Multimedia Navigation
Accessories - Autoradio
Accessories - Tool Box
Accessories - Kit Return Camera
Conversion Kit - Wheat To Maize
CONVERSION KIT - WHEAT TO MAIZE
Brand: Fendt
Engine Assemblies
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
Oil Pump And Sump
Coolant Piping
Starter Motor
Fan Drive
Fuel Filters
Engine Installation
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Drive System
Cylinder Variator
Shaker Shoe - Drive
Rear Axle Support
Towing Hook
Towing Hook Cuna
Frame
Beater - Body
Steering Column
Front Axle
Front Axle - Shield
Gearbox
Brake Pedal
Hydraulic Oil Tank
Hydraulic Propel
Cutting Header
Steering
Hydraulic Levelling
Control Valve
Pipes Reel
Reel Speed Control
Pipe Union
Front Lighting
Rear Lighting
Rotary Beacon
Harness - Left Side
Harness - Cab
Harness - Rear Axle
Harness - Oil Tank
Harness Shield
Rear View Camera
Agcommand
Seat Holder
Seat - (Components)
Platform
Access Ladder
Refrigerator
Control Console
Monitoring Display
Rear View Mirror
Air Conditioning
Sheet Metal - Rear
Decals - Safety
Front Wheels
Wheels Wedges
Feeding System
Threshing System
Rear Beater
Straw Walker - Body
Straw Walker
Swather Rake
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Sieve
Tailings Elevator
Grain Elevator
Grain Tank
Discharge System
Straw Deflector
Lifting Tools
Tool Box - Tools
Tool Box - Bracket
Air Compressor
