Fendt Combine 6335C Parts Catalog 6246186 08.2020
Brand: Fendt
Type of Machine: Combine
Model: Fendt 6335C Combine (Stage 4 / Tier 4F & Tier 2)
Serial Number: 564010001-199, ZN205640X03010200-999
Publication Date: 08.2020
Number of Pages: 1044 Pages
Engine V835277150 84 Awf
Engine Assemblies
Cylinder Block - Up To Engine Serial Number C52250
Cylinder Block - Starting From Engine Serial Number C52251
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
High Pressure Turbocharger
Low Pressure Turbocharger And Icac
Oil Pump And Sump
Oil Cooler And Filter - Up To Engine Serial Number C52250
Oil Cooler And Filter - Starting From Engine Serial Number C52251
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters - Starting From Engine Serial Number B50000 Jld291001
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine V835277731 84 Awf-Hla
Exhaust Manifold - M12 Turbo Mounting Stud Bolts
High Pressure Turbocharger - M12 Turbo Mounting Stud Bolts
Low Pressure Turbocharger And Icac - M12 Turbo Mounting Stud Bolts
Fuel Filters
Engine Installation
Engine Installation - Fan
Engine Brackets
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Rotary Screen Brush
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank (Components)
Fuel Tank (Components)
Fuel Tank Bracket
Air Compressor
Drive System
Drive Belt System - Left Side
Drive Belt System - Right Side
Hydrostatic Pump & Power Take-Off - Drive
Hydrostatic Pump - Drive
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Cylinder Variator
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Front Axle - Shield
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive - (Components)
Rear Axle - 4 Wheels Drive - Weight
Tow Hook
Tow Hook - Cuna
Tow Hook - Rockinger
Steering Column
Steering Column (Components)
Steering - Hydraulic Lines
Final Drive (Components)
Gearbox
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Caliper - (Components)
Parking Brake - Hydraulic
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Cutting Header - Lifting
Cylinder Head Automatic Function Control Valve - (Components)
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Tilt
Cutting Table Flotation
Lateral Header Flotation Control Valve - (Components)
Reel Speed Control
Reel Speed Proportional Control Unit - (Components)
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Control Valve (Header + Grain Tank Unloading)
Control Valve (Header + Grain Tank Unloading) - (Components)
Grain Bin Unloading
Pipes Reel
Electrohydraulic Engagement Control Valve - With Straw Chopper
Electrohydraulic Engagement Control Valve - (Components)
Pipe Union
Central Lubrification
Front Lighting
Front Lighting - Roof
Rear Lighting
Rear Lighting - Reverse Gear
Number Plate - Lighting
Rotary Beacon
Flip-Up Header Light
Battery & Cables
Power Distributor Center Electrical
Harness - Right Side
Harness - Left Side
Harness - Front Axle
Harness - Rear Axle
Harness - Rear Axle - 2 Wheels Drive
Harness - Rear Axle - 4 Wheels Drive
Harness - Cab
Harness - Cab - Roof
Harness - Control Console
Harness - Steering
Harness
Harness - Engine
Harness - Hydraulic Oil Tank
Harness - Multi Crop Separator
Harness - Grain Bin
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness - Vertical Knives Control
Return Auger - Sensors
Rear View Camera
Rear View Camera - Secondary
Taskdoc
Agcommand
Seat Holder
Seat - (Components)
Refrigerator
Control Console
Control Console (Components)
Monitoring Display
Feeder Reverser - Lever
Rear View Mirror
Platform - Right Side
Platform - Left Side
Access Ladder
Air Conditioning
Air Conditioning - (Components)
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box - Tools
Tool Box
Stone Trap
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Sheet Metal - Straw Hood
Number Plate
Signaling Panels
Decals - Safety & Warning
Tracks (7 Rollers)
Front Wheels
Rear Wheels - 2 Wheels Drive
Rear Wheels - 4 Wheels Drive
Rear Wheels - Weight
Wheels Wedges
Lifting Tools
Feeding System
Tools
Shield Plate
Tilt Frame
Tilt Frame - Control Lever
Feeder Frame
Upper Shaft - Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum - Link Belt
Collector Drum
Shields
Lifting
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Rear Beater
Concave - Control System
Concave - Rice
Multi Crop Separator - Right Side
Multi Crop Separator - Left Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Electrical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Bin
Grain Bin - Access Ladder
Grain Bin - Extension
Grain Bin - Unloader Gate
Grain Bin Unloading - Inner Protection
Grain Bin Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Elevator - Filling Auger
Connecting Box - (Components)
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Precision Farming Systems
Guidance Receiver
Accessories - Additional Fuel Filter
Accessories - Rotary Screen Brush
Accessories - Fuel Tank Cover
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Front Axle
Accessories - Tracks (7 Rollers)
Accessories - Beater - Blanking Plate
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Modular Grain Pan
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Grain Tank - Filling Auger
Accessories - Inner Protection Of Grain Tank Unloading
Accessories - Rubber Spout Long
Accessories - Additional Fire Extinguisher
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Led Work Lights
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Multimedia Navigation
Accessories - Autoradio
Accessories - Tool Box
Accessories - Kit Return Camera
Accessories - Autoguide
Accessories - Tilting Frame Tie Rod
Conversion Kit - Wheat To Rice
Conversion Kit - Rice To Wheat
Conversion Kit - Rice To Maize
Conversion Kit - Wheat To Maize
CONVERSION KIT - WHEAT TO MAIZE
Brand: Fendt
Engine Assemblies
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
Oil Pump And Sump
Coolant Piping
Starter Motor
Fan Drive
Fuel Filters
Engine Installation
Engine Brackets
Rotary Screen Brush
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Fuel Tank Bracket
Air Compressor
Drive System
Cylinder Variator
Shaker Shoe - Drive
Front Axle
Front Axle - Shield
Rear Axle Support
Tow Hook
Tow Hook - Cuna
Steering Column
Gearbox
Gear Lever System
Brake Pedals
Hydraulic Oil Tank
Hydraulic Propel
Cutting Header
Reel Speed Control
Grain Bin Unloading
Pipes Reel
Pipe Union
Front Lighting
Rear Lighting
Rotary Beacon
Battery & Cables
Harness - Left Side
Harness - Rear Axle
Harness - Cab
Harness - Steering
Harness
Harness - Engine
Harness - Grain Bin
Rear View Camera
Taskdoc
Agcommand
Seat Holder
Seat - (Components)
Refrigerator
Control Console
Monitoring Display
Rear View Mirror
Access Ladder
Air Conditioning
Frame - Lower
Frame - Beater
Tool Box - Tools
Tool Box
Stone Trap
Engine Cover
Sheet Metal - Rear
Number Plate
Signaling Panels
Tracks (7 Rollers)
Front Wheels
Wheels Wedges
Lifting Tools
Feeding System
Tools
Shield Plate
Tilt Frame
Feeder Frame
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum
Shields
Lifting
Threshing System
Thresher Concave
Rear Beater
Concave - Rice
Straw Walker
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Sieve
Tailings Elevator
Grain Bin
Grain Elevator
Discharge System
Straw Deflector
Guidance Receiver
