702,019
Fendt Combine 6280 Parts Catalog 1637488 07.2005
Brand: Fendt
Type of Machine: Combine
Model: Fendt 6280 Combine
Publication Date: 07.2005
Number of Pages: 550 Pages
Knives And Fingers - Freeflow - 14' - 20'
Table Auger Right Hand - Freeflow - 14' - 20'
Table Auger Left Hand - Freeflow - 14' - 20'
Guarding And Transmissions - Freeflow - 14' - 20'
Table Housing And Guarding - Freeflow - 22'
Knives And Fingers - Powerflow - 14' - 20'
Table Auger Right Hand - Powerflow - 14' - 20'
Tabel Auger Left Hand - Powerflow - 14' - 20'
Guarding And Transmissions - Powerflow - 14' - 20'
Table Housing And Guarding - Powerflow - 14' - 20'
Powerflow Band - Left Hand - 14' - 20'
Powerflow Band - Right Hand - 14' - 20'
Oilseed Rape Auger
Straw Dividers
Table Trailer
Lightening Bracket - Up To No. 7374033
Electric Vertical Knife
Knives And Fingers - Freeflow - 22'
Table Auger Right Hand - Freeflow - 22'
Table Auger Left Hand - Freeflow - 22'
Guarding And Transmissions - Freeflow - 22'
Table Housing And Guarding - Freeflow - 14' - 20'
Knives And Fingers - Powerflow - 22'
Table Auger Right Hand - Powerflow - 22'
Tabel Auger Left Hand - Powerflow - 22'
Table Housing And Guarding - Powerflow - 22'
Guarding And Transmissions - Powerflow - 22'
Powerflow Band - Left Hand - 20-22'
Powerflow Band - Right Hand - 22'
Reel
Reel - Right Hand
Reel Suspension And Hydraulic Motor
Reel - Left Hand
Reel Suspension And Hydraulic Cylinders
Table Channel
Main Crop Elevator
Main Crop Elevator - Shaft
Feed Passage - Rollers & Chains
Feed Passage - Driving Parts
Feed Passage Clutch - Belt Guide
Feed Passage Reversing Devise
Concave, Threshing Drum And Rear Beater
Threshing Drum
Threshing Drum Drive Idler Pulley
Threshing Drum Countershaft
Threshing Drum Reducing Transmission - Optional
Concave
Concave - Stone Trap
Concave Adjustment
Concave - Segment - Optional
Threshing Drum - Segment Grain Maize- Optional
Threshing Equipment Grain Maize & C.C.M.
Concave - Segment Grain Maize- Optional
Threshing Drum - Rice Equipment - Optional
Rear Beater
Straw Stripper Drum Speed Variator
Variator Regulation Electric
Threshing Mechanism Engaging Parts
Threshing Mechanism Engaging Parts - Belt Guide
Turbo-Separator - Drum
Turbo-Separator - Control
Turbo-Separator - Concave - Optional
Straw Shaker
Straw Shaker And Cranks
Straw Walkers Countershaft
Straw Walker Drive
Grain Returning Floor
Stepped Floor
Cleaning Unit And Main Fan
Sieve Box - Upper Compoments
Sieve Box - Lower Component
Sieves Equipment Standard
Sieves Equipment - Maize
Sieves Equipment C C M
Stepped Floor And Sieve Box Driving Parts - Standard
Grain Pan
Grain Pan - Air Guide Parts
Cleaning Fan
Main Fan Variator
Main Fan Variator - Belt Tensioner
Guard - Right Side
Elevators
Return Elevator
Elevator Auger
Grain Elevator
Elevator Head
Elevator Head With Auger
Measurement Of Elevator Throughput & Grain Humidity
Timing Gear And Camshaft
Flywheel & Flywheel Housing
Lubricating Oil Sump
Rocker Arm
Crankshaft, Pistons And Connecting Rods
Air Induction And Exhaust System
Turbocharger - Pipes
Lubricating Oil Filter And Integral Cooler
Water Pump, Thermostat And Heat Exchanger
Fuel Injection Equipment (Diesel)
Low Pressure Fuel System
Alternator And Bracket
Starter
Lubricating Oil Filler And Breather
Belt Details
Grain Tank - Guards
Grain Tank
Guards - Grain Tank Top
Device For Grain Samples
Grain Tank Covers
Grain Tank Clutch
Grain Tank Emptying
Grain Tank Emptying - Angle Drive Below
Outlet Augers For Grain Tank
Grain Tank Emptying Angle Drive
Discharging Tube For Grain Tank
Drive Unit
Engine Bracket
Service Platform
Silencer
Fan Engine
Cooling System - Engine
Air Manifolds
Air Filter
Air Compressor
Condensator
Compressor - Component Parts
Oil Cooler Hydraulic Tank For Traveling And Filter
Working Hydraulic - Oil Cooler
Transmissions
V-Belts And Chains
Belt Tensioner
Front Axle
Gear Box
Gear Box - Countershaft
Working Brake
Lateral Gears
Steering Axle
Steering Axle - Adjustable
Tyres
Operator Platform
Operating Platform
Platform And Ladder
Steering Column
Operator Seat
Shift Levers
Hydraulic Brake
Driver's Cab - Glass And Hinges
Driver's Cab - Locks
Driver's Cab - Control Console
Driver's Cab - Dressing Roof
Driver Cab Roof
Driver's Cab Roof -Fan
Hydraulic
Lube Device At The Right
Lube Device At The Right - With Balance
Flow Divider
Working Hydraulic - Engine
Working Hydraulic - Control Valves
Working Hydraulic - Cutting Table
Hydraulic Cylinder - Cutting Table
Working Hydraulic - For Reel
Working Hydraulic - For Grain Tank Tube
Working Hydraulic - Hopper
Steering Hydraulic Lines
Working Hydraulic
Working Hydraulic - With Balance
Working Hydraulic - Cutting Table With Balance
Hydraulic Pump - With Balance
Working Hydraulic - Valve Block
Control Valve
Hydraulic Cylinder - For Grain Tank Tube
Hydrostatic- Steering
Hydraulic Cylinder
Variable Pump Accessories
Traveling Hydraulic Equipment - Impeller
Multi-Coupling
Machine Housing - Guards
Guard - Left Side
Straw Hood
Tools & Electrical System
Tools & Accessories
Electrical Wiring - Engine Harness
Electric Box
Electric Equipment & Instrument Panel
Electric Equipment & Instrument Panel - Operating Platform
Electrical Equipment - Chassis
Electrical Equipment - Clutch Control
Electrical Equipment - Chopper Electric Adjusting Device
Electrical Equipment - Engine
Electrical Equipment - Beacon
Electrical Equipment - Grain Tank
Electrical Equipment - Rear
Electrical Equipment Rear - W
Electrical Equipment - Position Control
Debit Electronic Sensor
Board Computer - Area Measure
Lighting
Straw Chopper
Straw Chopper - For Type Srx Only
Kpab - Straw Chopper - Distributor Box
Kpab - Straw Chopper - Distributor Box - For Type Srx Only
Distributor - Chopper Electric Adjusting Device
Distributor
Kpab - Straw Chopper Mounting Frame
Kpab - Straw Chopper V-Belt Clutch
Kpab - Straw Chopper Deflector Sheets
Kpab - Straw Chopper Chaff Spreader
Kpab - Straw Chopper Chaff Spreader - From Straw Chopper No.05756
Straw Chopper Knives
Security Decal
