Fendt Combine 6270L Parts Catalog 3906254 07.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 6270L Combine
Serial Number: 318210001-999, 565810001-999
Publication Date: 07.2019
Number of Pages: 851 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Intake & Exhaust Manifold
Turbocharger
Oil Sump
Centrifugal Oil Filter
Fuel Injection System
Electronic Engine Management
Starter Motor
Alternator & Fitting Bracket
Engine Overhaul Parts
Engine Gasket Kits
Engine Installation
Belt Tensioner
Engine Brackets
Fan
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Fuel Tank Bracket
Air Compressor
Drive System
Hydrostatic Pump - Drive
Power Take-Off - Drive
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Air Conditioning - Drive
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Cylinder Variator
Cylinder Variator - (Components)
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Rear Axle - 4 Wheels Drive - Weight
Hitch
Steering Column
Steering - Hydraulic Lines
Final Drive (Components)
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Master Cylinder & Brake Control Valve - (Components)
Brake Caliper - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - (Components)
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Pump - Safety Device
Hydrostatic Motor
Hydrostatic Motor - (Components)
Cutting Header - Lifting
Cutting Header
Cutting Table Flotation
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Control Valve (Header + Grain Tank Unloading)
Control Valve (Header)
Control Valve (Header) - (Components)
Pipes Reel
Straw Chopper Clutch
Grain Bin Unloading
Header Additional Lifting Ram
Pipe Union
Front Lighting
Rear Lighting
Auxiliary Headlight
Work Lights - Flip-Up Header Light
Rotary Beacon
Battery & Main Switch
Battery & Cables
Harness - Front Axle
Harness - Cab
Harness - Cab Roof
Harness - Control Console
Harness - Fuse Carrier
Harness - Engine
Harness - Multi Crop Separator
Harness - Grain Bin
Harness - Control Valve
Harness - Multifunction Lever
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Return Auger - Sensors
Seat Holder
Seat & Passenger Seat
Feeder Reverser - Lever
Control Console
Multifunction Lever
Agritronicplus
Rear View Mirror
Platform - Right Side
Platform - Left Side
Access Ladder
Air Conditioning
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box - Tools
Tool Box
Tool Box - Bracket
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Engine Cover - Fitting Bracket
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Sheet Metal - Straw Hood
Straw Hood - Weight
Rear Sheet Metal - Weight
Signaling Panels
Number Plate
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Tracks (6 Rollers)
Rollers Elements & Idler Wheels - (Components)
Chain Elements
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Feeding System
Tools
Shield Plate
Tilt Frame
Tilt Frame - Control Lever
Feeder Frame
Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum - Link Belt
Collector Drum
Shields
Lifting
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Drum Bar Plates
Rear Beater
Concave - Control System
Concave - Maize & Sunflower
Concave - Maize, Cob & Mixed Crop
Concave - Deflector Plate
Concave - Without M.C.S. (Multi Crop Separator)
Multi Crop Separator - Left Side
Multi Crop Separator - Right Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker
Straw Walker - Maize & Sunflower
Straw Walker - Straw-Lifter Rider
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Bin
Grain Bin - Extension
Grain Bin - Unloader Gate
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator - Standard
Grain Elevator - Filling Auger
Connecting Box - (Components)
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Bracket - Right Side
Chaff Spreader - Bracket - Left Side
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield
Accessories - Additional Fuel Filter
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Header Additional Lifting Ram
Accessories - Autolevel Gsa (Ground Self Alignment)
Accessories - Front Elevator Support Kit
Spike Tooth Concave With 2 Complete Threshing Section
Chain Drive For Drum
Speed Reduction
Conversion Kit - Wheat To Maize
Conversion Kit - Belt To Chain
CONVERSION KIT - BELT TO CHAIN
Brand: Fendt
Engine Assemblies
Turbocharger
Oil Sump
Starter Motor
Engine Gasket Kits
Engine Installation
Belt Tensioner
Engine Brackets
Fan
Dust Aspirator
Engine Air Filter
Exhaust System
Fuel Tank Bracket
Air Compressor
Drive System
Cylinder Variator
Shaker Shoe - Drive
Front Axle
Rear Axle Support
Hitch
Steering Column
Gear Lever System
Brake Pedals
Hydraulic Oil Tank
Hydraulic Propel
Hydrostatic Motor
Cutting Header
Pipes Reel
Grain Bin Unloading
Pipe Union
Front Lighting
Rear Lighting
Auxiliary Headlight
Rotary Beacon
Battery & Cables
Harness - Cab
Harness - Cab Roof
Harness - Engine
Harness - Grain Bin
Seat Holder
Control Console
Multifunction Lever
Agritronicplus
Rear View Mirror
Access Ladder
Air Conditioning
Frame - Lower
Frame - Beater
Tool Box - Tools
Tool Box
Tool Box - Bracket
Engine Cover
Sheet Metal - Rear
Straw Hood - Weight
Signaling Panels
Number Plate
Tracks (6 Rollers)
Chain Elements
Front Wheels
Wheels Wedges
Feeding System
Tools
Shield Plate
Tilt Frame
Feeder Frame
Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum
Shields
Lifting
Threshing System
Thresher Concave
Rear Beater
Straw Walker
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Sieve
Grain Bin
Discharge System
Straw Deflector
Speed Reduction
