Fendt Combine 5275C Parts Catalog 3906391 06.2020
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5275C Combine (Stage 3B / Tier 4I)
Serial Number: 553900001-553900030
Publication Date: 06.2020
Number of Pages: 806 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Air Intake & Exhaust
Turbocharger
Oil Pump And Sump
Oil Cooler And Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment - Service Parts
Engine Overhaul Parts
Engine Gasket Kits
Engine Installation
Engine Installation - Fan
Engine Brackets
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank (Components)
Fuel Tank (Components)
Fuel Tank Bracket
Air Compressor
Drive System
Drive Belt System - Left Side
Drive Belt System - Right Side
Hydrostatic Pump & Power Take-Off - Drive
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Air Conditioning - Drive
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Cylinder Variator
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - (Components)
Rear Axle - 4 Wheels Drive - Weight
Tow Hook
Tow Hook - Cuna
Steering Column
Steering - Hydraulic Lines
Final Drive (Components)
Gearbox
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Master Cylinder & Brake Control Valve - (Components)
Brake Caliper - (Components)
Parking Brake - Pedal
Parking Brake - Pedal (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydraulic Propel - Hydrostatic Motor
Cutting Header - Lifting
Flow Capacity Reduction Solenoid Valve - (Components)
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Tilt
Cutting Table Flotation
Lateral Header Flotation Control Valve - (Components)
Reel Speed Control
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Control Valve (Header + Grain Tank Unloading)
Control Valve (Header + Grain Tank Unloading) - (Components)
Grain Bin Unloading
Pipes Reel
Electrohydraulic Engagement Control Valve - With Straw Chopper
Electrohydraulic Engagement Control Valve - (Components)
Pipe Union
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Battery & Cables
Electronic Box - (Components)
Power Distributor Center Electrical
Harness - Front Axle
Harness - Cab
Harness - Control Console
Harness - Engine
Harness - Hydraulic Oil Tank & Hydrostatic Pump
Harness - Multi Crop Separator
Harness - Grain Bin
Harness - Control Valve
Harness - Control Unit
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness - Vertical Knives Control
Return Auger - Sensors
Seat Holder
Control Console
Feeder Reverser - Lever
Rear View Mirror
Platform - Right Side
Platform - Left Side
Access Ladder
Air Conditioning
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box - Tools
Tool Box
Stone Trap
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Sheet Metal - Straw Hood
Rear Ballast (300 Kg)
Number Plate
Signaling Panels
Decals - Safety & Warning
Tracks (7 Rollers)
Front Wheels
Rear Wheels - 2 Wheels Drive
Rear Wheels - 4 Wheels Drive
Rear Wheels - Weight
Wheels Wedges
Lifting Tools
Feeding System
Tools
Shield Plate
Tilt Frame
Tilt Frame - Control Lever
Feeder Frame
Upper Shaft - Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum - Link Belt
Collector Drum
Shields
Lifting
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Rear Beater
Concave - Control System
Concave - Rice
Multi Crop Separator - Right Side
Multi Crop Separator - Left Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Bin
Grain Bin - Extension
Grain Bin - Unloader Gate
Grain Bin Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Elevator - Filling Auger
Connecting Box - (Components)
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Accessories - Additional Fuel Filter
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (7 Rollers)
Accessories - Rear Ballast (300 Kg)
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Seed Riddle - Elec. Adjustable
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Parking Brake
Conversion Kit - Wheat To Rice
Conversion Kit - Rice To Wheat
Conversion Kit - Rice To Maize
Conversion Kit - Wheat To Maize
FILTERS
