Fendt Combine 5270C Parts Catalog 3906038 07.2020
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5270C Combine
Serial Number: 552310001-999, 552410001-999 AL
Publication Date: 07.2020
Number of Pages: 1227 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Intake & Exhaust Manifold
Turbocharger
Oil Pump And Sump
Oil Cooler And Filter
Centrifugal Oil Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Starter Motor
Alternator & Fitting Bracket
Engine Gasket Kits
Engine Overhaul Parts
Engine Installation
Belt Tensioner
Engine Brackets
Fan
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Fuel Tank Bracket
Fuel Lines
Air Compressor
Drive System
Hydrostatic Pump & Power Take-Off - Drive
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Air Conditioning - Drive
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Cylinder Variator
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive - (Components)
Rear Axle - 4 Wheels Drive - Weight
Tow Hook - Cuna
Tow Hook
Steering Column
Steering - Hydraulic Lines
Final Drive (Components)
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Master Cylinder & Brake Control Valve - (Components)
Brake Caliper - (Components)
Parking Brake - Pedal
Parking Brake - Pedal (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - (Components)
Hydraulic Propel - Hydrostatic Motor
Cutting Header - Lifting
Flow Capacity Reduction Solenoid Valve - (Components)
Cutting Header
Cutting Header - Tilt
Cutting Table Flotation
Reel Speed Control
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Control Valve (Header + Grain Tank Unloading)
Control Valve (Header + Grain Tank Unloading) - (Components)
Grain Bin Unloading
Pipes Reel
Electrohydraulic Engagement Control Valve
Hydraulic Levelling - Pump
Hydraulic Levelling - Hydraulic Lines
Hydraulic Levelling - Distributor
Hydraulic Levelling - Distributor (Components)
Hydraulic Levelling - Front Lift
Header Additional Lifting Ram
Pipe Union
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Additional Work Lights
Flip-Up Header Light
Battery & Cables
Battery & Cables - Main Switch
Power Distributor Center Electrical
Electronic Box - (Components)
Harness - Front Axle
Harness - Cab
Harness - Digital Instrumentation
Harness - Engine
Harness - Hydraulic Oil Tank & Hydrostatic Pump
Harness - Multi Crop Separator
Harness - Grain Bin
Harness - Control Valve
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness - Hydraulic Levelling
Return Auger - Sensors
Seat Holder
Control Console
Agritronic Plus
Feeder Reverser - Lever
Rear View Mirror
Platform - Right Side
Platform - Left Side
Access Ladder
Air Conditioning
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box - Tools
Tool Box
Stone Trap
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Sheet Metal - Straw Hood
Rear Ballast (300 Kg)
Number Plate
Signaling Panels
Decals - Standard
Decals - Autolevel
Decals - Safety & Warning
Tracks (7 Rollers)
Rollers Elements & Idler Wheels - (Components)
Chain Elements - (Components)
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Feeding System
Tools
Shield Plate
Tilt Frame
Tilt Frame - Control Lever
Feeder Frame
Upper Shaft - Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum - Link Belt
Collector Drum
Shields
Lifting
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Maize & Mixed Crop
Thresher Concave - Rice
Thresher Concave - Drum Bar Plates
Rear Beater
Concave - Control System
Concave - Maize & Sunflower
Concave - Maize, Cob & Mixed Crop
Concave - Grain & Maize
Concave - Rice
Multi Crop Separator - Right Side
Multi Crop Separator - Left Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Bin
Grain Bin - Access Ladder
Grain Bin - Extension
Grain Bin - Unloader Gate
Grain Bin Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator - Filling Auger
Connecting Box - (Components)
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Bracket - Right Side
Chaff Spreader - Bracket - Left Side
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield
Accessories - Additional Fuel Filter
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (7 Rollers)
Accessories - Rear Ballast (300 Kg)
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Flip-Up Header Light
Accessories - Front Elevator Support Kit
Spike Tooth Concave With 2 Complete Threshing Section
Speed Reduction
Muddy Soil Guards
Conversion Kit - Wheat To Maize
Conversion Kit - Wheat To Rice
Conversion Kit - Rice To Wheat
CONVERSION KIT - RICE TO MAIZE
