Fendt Combine 5255L Parts Catalog 6246182 03.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5255L Combine (Stage 4 / Tier 4F & Tier 2)
Serial Number: 555010001-221
Publication Date: 03.2019
Number of Pages: 1006 Pages
Engine V835077149 74 Awf
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons - Up To Engine Serial Number B69999
Crankshaft And Pistons - Starting From Engine Serial Number C50000 Jld291001
Camshaft And Valve Mechanism
Valve Rocker Cover - Up To Engine Serial Number B65418
Valve Rocker Cover - Starting From Engine Serial Number B65367
Intake Manifold
Oil Pump And Sump - Up To Engine Serial Number A77999
Oil Pump And Sump - Starting From Engine Serial Number B50000
Oil Cooler And Filter
Closed Crankcase Ventilation (Ccv) - Up To Engine Serial Number D51660
Closed Crankcase Ventilation (Ccv) - Starting From Engine Serial Number D51661
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters - Engine Serial Number Range B50000-C71172
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Installation
Engine Installation - Fan
Engine Installation - Engine Brackets
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Collector Brush
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank - (Components)
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank (Components)
Fuel System - Fuel Tank Bracket
Drive System
Belts & Link Chains - Left Side
Belts & Link Chains - Right Side
Hydrostatic Pump - Drive
Rotary Filter And Dust Aspiration - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Crop Elevator - Reverse Drive
Cylinder Variator
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Rear Axle - 4 Wheels Drive - Weight
Towing Hook
Towing Hook Cuna
Towing Hook Rockinger
Frame And Suspension
Frame
Beater - Body
Steering Column
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Reduction Gear - (Components)
Gearbox - Gear Lever
Gearbox
Brake Caliper - (Components)
Brake Pedal
Brake Master Cylinder & Brake Control Valve - (Components)
Parking Brake - Pedal
Parking Brake - Pedal (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Tilt
Cutting Header - Lifting
Cylinder Head Automatic Function Control Valve - (Components)
Cutting Table Flotation
Lateral Header Flotation Control Valve - (Components)
Steering
Steering - Rear Axle - 2 Wheels Drive
Steering - Rear Axle - 4 Wheels Drive
Header Flotation Deflector Control Unit - (Components)
Control Valve (Header)
Control Valve (Header) - (Components)
Pipes Reel
Reel Speed Control
Reel Speed Proportional Control Unit - (Components)
Electrohydraulic Engagement Control Valve - With Straw Chopper
Electrohydraulic Engagement Control Valve - (Components)
Central Lubrification
Pipe Union
Front Lighting
Rear Lighting
Rotary Beacon
Work Lights - For Folding Cutter Bar
Number Plate - Lighting
Battery & Main Switch - Battery Box & Battery Cable
Power Distributor Center Electrical
Harness - Left Side
Harness - Right Side
Harness - Cab - Control Console
Harness - Cab
Harness - Cab - Roof
Harness - Front Axle
Harness - Rear Axle
Harness - Grain Tank
Harness - Engine Tier 2
Harness - Engine Tier 4f Stage 4
Harness - Oil Tank
Harness - Multi Crop Separator
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness - Vertical Knives Control
Harness Shield
Return Auger - Sensors
Seat Holder
Seat - (Components)
Access Ladder
Footstep - Left Side
Footstep - Right Side
Control Console
Control Console (Components)
Monitoring Display
Rear View Mirror
Air Conditioning
Air Conditioning - (Components)
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Service Hatch
Engine Compartment - Access Ladder
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Rear Sheet Metal - Weight
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Decals - Safety
Tracks (6 Rollers)
Tracks (7 Rollers)
Front Wheels
Rear Wheels - 2 Wheels Drive
Rear Wheels - 4 Wheels Drive
Rear Wheels - Weight
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Floating Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Collector Drum
Crop Elevator - Lifting
Threshing System
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Rear Beater
Concave - Control System
Concave - Rice
Concave - Deflector Plate
Concave - Without M.C.S. (Multi Crop Separator)
Multi Crop Separator - Left Side
Multi Crop Separator - Right Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker - Body
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Chaffer - Electrical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Tank
Grain Tank - Extension
Grain Tank - Filling Auger
Connecting Box - (Components)
Grain Tank Unloading - Drain Pipe
Grain Tank Unloading - Inner Protection
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Lifting Tools
Tool Box - Tools
Tool Box - Bracket
Additional Fire Extinguisher
Air Compressor
Equipment - Official Approval
Accessories - Additional Fuel Filter
Accessories - Dust Collector Brush
Accessories - Fuel Tank Cover
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Tracks (7 Rollers)
Accessories - Beater - Blanking Plate
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Modular Grain Pan
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Seed Riddle - Elec. Adjustable
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Inner Protection Of Grain Tank Unloading
Accessories - Rubber Spout Long
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Rear View Mirror
Accessories - Wind Canvas
Accessories - Multimedia Navigation
Accessories - Autoradio
Accessories - Tool Box
Accessories - Kit Return Camera
Conversion Kit - Wheat To Rice
Conversion Kit - Rice To Wheat
Conversion Kit - Rice To Maize
Conversion Kit - Wheat To Maize
CONVERSION KIT - WHEAT TO MAIZE
Brand: Fendt
Engine Assemblies
Intake Manifold
Starter Motor
Fan Drive
Engine Installation
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Drive System
Cylinder Variator
Shaker Shoe - Drive
Rear Axle Support
Towing Hook
Towing Hook Cuna
Frame
Beater - Body
Steering Column
Front Axle
Gearbox
Brake Pedal
Hydraulic Oil Tank
Hydraulic Propel
Cutting Header
Steering
Pipes Reel
Reel Speed Control
Pipe Union
Front Lighting
Rear Lighting
Rotary Beacon
Harness - Left Side
Harness - Cab
Harness - Rear Axle
Harness - Oil Tank
Harness Shield
Seat Holder
Seat - (Components)
Access Ladder
Control Console
Monitoring Display
Rear View Mirror
Air Conditioning
Sheet Metal - Rear
Decals - Safety
Tracks (6 Rollers)
Tracks (7 Rollers)
Front Wheels
Wheels Wedges
Feeding System
Threshing System
Rear Beater
Concave - Rice
Straw Walker - Body
Straw Walker
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Sieve
Tailings Elevator
Grain Elevator
Grain Tank
Discharge System
Straw Deflector
Lifting Tools
Tool Box - Tools
Tool Box - Bracket
Air Compressor
