Fendt Combine 5250L Parts Catalog 3906253 07.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5250L Combine
Serial Number: 258110001-999, 268110001-999 AL
Publication Date: 07.2019
Number of Pages: 954 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel Housing
Flywheel
Crankshaft And Pistons
Camshaft
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
Turbocharger
Turbocharger - Lube Oil Lines
Oil Sump
Oil Pump
Oil Filter
Oil Dipstick
Water Lines
Fuel Injection System
Injection Pump - (Components)
Injector
Fuel Filter - (Components)
Fuel Pipe
Supercharging Lines
Breather
Thermostat
V-Belt
Suspension
Electronic Engine Management
Starter Motor
Engine Installation
Belt Tensioner
Engine Brackets
Fan
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Fuel Tank Bracket
Air Compressor
Drive System
Hydrostatic Pump - Drive
Power Take-Off - Drive
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Air Conditioning - Drive
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Cylinder Variator
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Rear Axle - 4 Wheels Drive - Weight
Hitch
Steering Column
Steering - Hydraulic Lines
Final Drive (Components)
Final Drive
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Master Cylinder & Brake Control Valve - (Components)
Brake Caliper - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - (Components)
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Pump - Safety Device
Hydrostatic Motor
Hydrostatic Motor - (Components)
Cutting Header - Lifting
Cutting Header
Cutting Header - Tilt
Cutting Table Flotation
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Control Valve (Header + Grain Tank Unloading)
Control Valve (Header)
Control Valve (Header) - (Components)
Grain Bin Unloading
Pipes Reel
Hydraulic Levelling
Straw Chopper Clutch
Header Additional Lifting Ram
Front Lighting
Rear Lighting
Auxiliary Headlight
Work Lights - Flip-Up Header Light
Rotary Beacon
Battery & Main Switch
Battery & Cables
Harness - Front Axle
Harness - Cab
Harness - Cab Roof
Harness - Control Console
Harness - Hydraulic Levelling
Harness - Fuse Carrier
Harness - Engine
Harness - Multi Crop Separator
Harness - Grain Bin
Harness - Control Valve
Harness - Multifunction Lever
Harness - Digital Instrumentation
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Return Auger - Sensors
Seat Holder
Seat & Passenger Seat
Feeder Reverser - Lever
Control Console
Multifunction Lever
Agritronicplus
Rear View Mirror
Platform - Right Side
Platform - Left Side
Access Ladder
Air Conditioning
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box - Tools
Tool Box
Tool Box - Bracket
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Engine Cover - Fitting Bracket
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Sheet Metal - Straw Hood
Rear Sheet Metal - Weight
Signaling Panels
Number Plate
Decals - Standard
Decals - Autolevel
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Tracks (6 Rollers)
Rollers Elements & Idler Wheels - (Components)
Chain Elements
Front Wheels - Standard
Front Wheels - Autolevel
Rear Wheels - Weight
Wheels Wedges
Feeding System
Tools
Shield Plate
Tilt Frame
Tilt Frame - Control Lever
Feeder Frame
Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum - Link Belt
Collector Drum
Shields
Lifting
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Thresher Concave - Drum Bar Plates
Rear Beater
Concave - Control System
Concave - Maize & Mixed Crop
Concave - Maize, Cob & Mixed Crop
Concave - Rice
Concave - Deflector Plate
Multi Crop Separator - Left Side
Multi Crop Separator - Right Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker
Straw Walker - Maize & Sunflower
Straw Walker - Straw-Lifter Rider
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Bin
Grain Bin - Extension
Grain Bin - Unloader Gate
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator - Filling Auger
Connecting Box - (Components)
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Bracket - Right Side
Chaff Spreader - Bracket - Left Side
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield
Accessories - Additional Fuel Filter
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Header Additional Lifting Ram
Accessories - Autolevel Gsa (Ground Self Alignment)
Accessories - Front Elevator Support Kit
Parts For Sandy Soils
Spike Tooth Concave With 2 Complete Threshing Section
Speed Reduction
Conversion Kit - Wheat To Maize
Conversion Kit - Belt To Chain
CONVERSION KIT - BELT TO CHAIN
