Fendt Combine 5220E Parts Catalog 3906388 03.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5220E Combine (Stage 3B / Tier 4I)
Serial Number: 551600001-999, 551610001-999
Publication Date: 03.2019
Number of Pages: 891 Pages
Engine Assemblies
Filters
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Air Intake & Exhaust
Turbocharger
Oil Pump And Sump
Oil Cooler And Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Starter Motor
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Engine Installation
Engine Installation - Fan
Engine Installation - Engine Brackets
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Collector Brush
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank - (Components)
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank (Components)
Fuel System - Fuel Tank Bracket
Drive System
Belts & Link Chains - Left Side
Belts & Link Chains - Right Side
Hydrostatic Pump - Drive
Rotary Filter And Dust Aspiration - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Crop Elevator - Reverse Drive
Air Conditioning - Drive
Cylinder Variator
Threshing Mechanism - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Rear Axle - 4 Wheels Drive - Weight
Towing Hook
Towing Hook Cuna
Frame And Suspension
Frame
Beater - Body
Steering Column
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Reduction Gear - (Components)
Gearbox - Gear Lever
Gearbox
Brake Caliper - (Components)
Brake Pedal
Brake Master Cylinder & Brake Control Valve - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydrostatic Pump
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Pump - Safety Device
Hydrostatic Motor
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Tilt
Cutting Header - Tilt - Hydraulic Drive (Gsax)
Cutting Header - Lifting
Flow Capacity Reduction Solenoid Valve - (Components)
Steering
Steering - Rear Axle - 2 Wheels Drive
Steering - Rear Axle - 4 Wheels Drive
Control Valve (Header)
Control Valve (Header) - (Components)
Pipes Reel
Reel Speed Control
Lateral Header Flotation Control Valve
Lateral Header Flotation Control Valve - (Components)
Electrohydraulic Engagement Control Valve - With Straw Chopper
Electrohydraulic Engagement Control Valve - (Components)
Header Additional Lifting Ram
Central Lubrification
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Work Lights - For Folding Cutter Bar
Rotary Beacon
Battery Box & Battery Cable
Harness - Cab - Control Console
Harness - Cab - Operator Platform
Harness - Cab
Harness - Gearbox Sensors
Harness - Fuse Carrier
Harness - Grain Tank
Harness - Straw Hood
Harness - Engine
Harness Shield
Harness - Control Valve
Harness - Multifunction Lever
Harness - Straw Walker Loss
Harness - Straw Chopper
Agritronicplus
Return Auger - Sensors
Seat Holder
Access Ladder
Footstep - Left Side
Footstep - Right Side
Multifunction Lever
Rear View Mirror
Air Conditioning
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Access Ladder
Engine Compartment - Service Hatch
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Rear Sheet Metal - Weight
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Decals - Safety
Tracks (6 Rollers)
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Lower Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Lifting
Threshing System
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Rear Beater
Concave - Control System
Concave - Rice
Concave - Deflector Plate
Concave
Straw Walker - Body
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Elevator - Standard
Grain Elevator
Grain Tank
Grain Tank - Extension
Grain Tank - Filling Auger
Connecting Box - (Components)
Grain Tank Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Lifting Tools
Number Plate
Tool Box - Tools
Tool Box - Bracket
Additional Fire Extinguisher
Air Compressor
Weights For Header
Equipment - Official Approval
Accessories - Additional Fuel Filter
Accessories - Dust Collector Brush
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Beater - Blanking Plate
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Header Additional Lifting Ram
Accessories - Header Floatation
Conversion Kit - Wheat To Rice
Conversion Kit - Wheat To Maize
CONVERSION KIT - BELT TO CHAIN
Brand: Fendt
Engine Assemblies
Filters
Turbocharger
Oil Pump And Sump
Fuel Filters
Starter Motor
Fan Drive
Engine Installation
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Drive System
Cylinder Variator
Shaker Shoe - Drive
Rear Axle Support
Towing Hook
Towing Hook Cuna
Frame
Beater - Body
Steering Column
Front Axle
Gearbox
Brake Pedal
Hydraulic Oil Tank
Hydrostatic Pump
Hydrostatic Motor
Cutting Header
Steering
Pipes Reel
Reel Speed Control
Front Lighting
Rear Lighting
Rotary Beacon
Harness - Cab
Harness - Engine
Harness Shield
Agritronicplus
Seat Holder
Access Ladder
Multifunction Lever
Rear View Mirror
Air Conditioning
Sheet Metal - Rear
Decals - Safety
Tracks (6 Rollers)
Front Wheels
Wheels Wedges
Feeding System
Threshing System
Rear Beater
Concave - Rice
Concave
Straw Walker - Body
Straw Walker
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Sieve
Tailings Elevator
Grain Elevator
Grain Tank
Discharge System
Straw Deflector
Lifting Tools
Number Plate
Tool Box - Tools
Tool Box - Bracket
Air Compressor
Weights For Header
