Fendt Combine 5220 5250 Parts Catalog 1637410 04.2003
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5220, 5250 Combine
Publication Date: 04.2003
Number of Pages: 643 Pages
Knives And Fingers - Freeflow - 14' - 20'
Table Auger Right Hand - Freeflow - 14' - 20'
Table Auger Left Hand - Freeflow - 14' - 20'
Guarding And Transmissions - Freeflow - 14' - 20'
Table Housing And Guarding - Freeflow - 14' - 20'
Knives And Fingers - Powerflow - 14' - 20'
Table Auger Right Hand - Powerflow - 14' - 20'
Tabel Auger Left Hand - Powerflow - 14' - 20'
Guarding And Transmissions - Powerflow - 14' - 20'
Table Housing And Guarding - Powerflow - 14' - 20'
Powerflow Band - Left Hand - 14' - 20'
Powerflow Band - Right Hand - 14' - 20'
Oilseed Rape Auger
Straw Dividers
Table Trailer - From No 0000500
Table Trailer - Up To No. 7374033
Lightening Bracket - Up To No. 7374033
Electric Vertical Knife
Reel
Reel - Right Hand
Reel Suspension And Hydraulic Motor
Reel - Left Hand
Reel Suspension And Hydraulic Cylinders
Table Channel
Elevator Shaft - Top And Pivot
Feeder Chain And Protective Plates
Table Clutch
Hydraulic Cylinder
Reversing Device
Feeder Shaft - Lower
Transmission Auto Level Combine
Transmission Auto Level - Table
Transmission Std. Combine
Adapter And Cover Plate
Concave, Threshing Drum And Rear Beater
Concave
Convave Adjustment
Threshing Drum
Drum Cover And Stone Trap
Rear Beater
Check Flaps
Concave, Cylinder And Grain Separator
Straw Shaker
Straw Shaker And Cranks
Second Grain Pan
Cleaning Unit And Main Fan
Fan Housing, Mantle And Rotary Air Intake
Fan Housing And Guarding
Main Fan Blade And Bottom Auger
Fan Housing - Doors And Batteries
Main Fan Variator
Counter Drive
Eccentric Drive
Lower Shaker Shoe And Sieves
Lower Shaker Shoe And Suspension
Upper Shaker Shoe And Sieves
Upper Shaker Shoe And Suspension
Conveyor Pan And Suspension
Chaff Spreader - Rekord - From 57723
Chaff Spreader - Rekord - Up To No 57722
Hydraulic Pump For Chaff Spreader - From No 58010
Hydraulic Pump For Chaff Spreader - Up To No 58009
Windbreak And Side Guard For Chaff Spreader
Electric Screen - From 57867
Elevators
Filling Elevator
Filler Pipe
Return Elevator
Returns Thresher
Starter
Crankshaft, Pistons And Connecting Rods
Timing Gear Housing
Flywheel Housing
Rocker Arm
Cylinder Head Cover
Thermostat
Lubricating Oil Sump
Lubricating Oil Filter And Integral Cooler
Injector
Inlet And Exhaust Manifold
Turbocharger
Turbocharger - Pipes And Heat Shields
Feed Pump
Hydraulic Pump Drive
Belt Details Engine Gaskets Sets
Engine Harness
Grain Tank - Guards
Unloading Auger - Horizontal
Unloading Auger - Vertical Part
Unloading Auger - Transmission
Guards - Grain Tank Top
Guards - Grain Tank Bottom
Grain Tank Covers - 8000 L
Grain Tank Covers - 6600 L
Drive Unit
Hydraulic Cooler
Cooling System And Ventilator Screen
Cooling System And Ventilator Ring
Rotary Screen
Engine Bracket
Hydrostatic Pump And Hydraulic Pump
Power Take-Off
Fan Housing
Gangway Over Engine
Exhaust And Air Filter
Fuel Tank - 600 L
Transmissions
Countershaft
Cylinder Transmission
Belt Mounting, Left Side
Belt Mounting, Right Side
Traction Wheels And Final Drives - Std. Combine
Traction Wheels And Final Drives - Auto Level
Front Axle And Gearbox - Standard Combine - Combine 5250
Front Axle And Gearbox - Standard Combine - Combine 5220
Front Axle And Gearbox - Auto Level - Combine 5250
Front Axle And Gearbox - Auto Level - Combine 5220
Rear Axle
Working Brake
Gear Box - No. D46148600 - Cb 5250
Gear Box Parking Brake - No. D46148600 - Cb 5250
Gear Box Front Axle - No. D46147500 - Cb 5220
Gear Box Front Axle
4 Wheel Drive
Final Drive - Up To No. 57540 - 5250 Up To No. 57531 - 5220
Final Drive - From No. 57532 - 5220
Final Drive - From 57541 - 5250
Operator Platform
Back Plate, Platform And Bottom Mat
Brake Pedals And Handbrake
Right-Hand Control Panel
Operator Seat And Terminal
Door And Windows
Front And Rear Inner Roof And Panel
Air Conditioner
Ladder And Light Bar
Steering Wheel And Column
Hydraulic
Hydraulic Symbols
Hydraulics - Reel Up Down
Hydraulic - Reel Fore Aft.
Hydraulics - Cylindervariator
Auto Level Combine - Table
Hydraulics - Reel Speed
Propulsion Hydraulic
Hydraulics - Gearshift
Hydraulics - Table Up Down
Hydraulics - Steering Gear
Hydraulics - Unloading Auger Out In
Hydraulics - Chaff Spreader - Rekord
Auto Level Combine
Pipe Support
Machine Housing - Guards
Top Rh Guard And Ladder - Engine
Bottom Rh Guard
Top + Rear Lh Guard
Bottom Lh Guard
Straw Hood Inside, Top, And Air Intake
Straw Hood Inside, Bottom, And Straw Guides
Straw Hood Outside
Tools & Electrical System
Tools - Paint
Wiring Harness Dv2 +
Electric Box - Standard Machine
Electric Box - Auto Level Combine
Electrical Parts
Wiring Harness Dv2 + - Electrical Cable A.L.
Wiring Harness Dv2 + - Electrical Cable B.R. B.X.
Wiring Harness Dv2 + - Electrical Cable C.A.N. C.K.
Wiring Harness Dv2 + - Electrical Cable C.L.
Wiring Harness Dv2 + - Electrical Cable C.R.
Wiring Harness Dv2 + - Electrical Cable D.N. E.M. + Miscs.
Mobil Gps Receiver Antenna
Mobil Landstar Dgps
Mobil Rds Dgps
Straw Chopper
Straw Chopper - Rekord - Rekord M401 - M801
Straw Chopper - Rekord - Rekord M400 - M800
Straw Chopper - Rekord - Rekord M97
Deflector Plate - Rekord M401 - M801
Straw Deflector And El.Adjustment - Rekord M97 M400 - M800 M401 - M801
Counter Drive - Straw Chopper - Rekord M401 - M801
Counter Drive - Straw Chopper - Rekord M97 M400 - M800
Straw Chopper Clutch - Rekord - Rekord M400 - M800 M401 - M801
Straw Chopper Clutch - Rekord - Rekord M97
Straw Chopper Maize Equipment - Rekord M97 M400 - M800 M401 - M801
Decal, Front And Right Side
Decal, rear and left side
Brand: Fendt
Oilseed Rape Auger
Straw Dividers
Reel
Reel - Right Hand
Reel - Left Hand
Table Channel
Table Clutch
Hydraulic Cylinder
Reversing Device
Concave
Convave Adjustment
Threshing Drum
Rear Beater
Check Flaps
Straw Shaker
Second Grain Pan
Main Fan Variator
Counter Drive
Eccentric Drive
Elevators
Filling Elevator
Filler Pipe
Return Elevator
Returns Thresher
Starter
Timing Gear Housing
Flywheel Housing
Rocker Arm
Cylinder Head Cover
Thermostat
Injector
Turbocharger
Feed Pump
Engine Harness
Grain Tank - Guards
Drive Unit
Hydraulic Cooler
Rotary Screen
Engine Bracket
Power Take-Off
Fan Housing
Gangway Over Engine
Fuel Tank - 600 L
Transmissions
Countershaft
Rear Axle
Working Brake
Gear Box Front Axle
4 Wheel Drive
Operator Platform
Door And Windows
Air Conditioner
Hydraulic
Hydraulic Symbols
Auto Level Combine
Pipe Support
Bottom Rh Guard
Top + Rear Lh Guard
Bottom Lh Guard
Straw Hood Outside
Tools - Paint
Electrical Parts
Mobil Landstar Dgps
Mobil Rds Dgps
Straw Chopper
