702,019
Fendt Combine 5185E Parts Catalog 3906379 03.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5185E Combine (Stage 4 / Tier 4F)
Serial Number: 551200001-043, ZN205512X03000044-999
Publication Date: 03.2019
Number of Pages: 759 Pages
Engine V834677326 49 Awf
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons - Up To Engine Serial Number B69999
Crankshaft And Pistons - Starting From Engine Serial Number C50000 Jld291001
Camshaft And Valve Mechanism
Valve Rocker Cover - Up To Engine Serial Number B65200
Valve Rocker Cover - Starting From Engine Serial Number B65230
Intake Manifold
Oil Pump And Sump - Up To Engine Serial Number C55790
Oil Pump And Sump - Starting From Engine Serial Number C55791
Oil Cooler And Filter
Closed Crankcase Ventilation (Ccv) - Up To Engine Serial Number D52835
Closed Crankcase Ventilation (Ccv) - Starting From Engine Serial Number D54867
Coolant Pump And Thermostat
Fuel Injection System
Electronic Engine Management
Starter Motor
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Installation
Engine Installation - Fan
Engine Installation - Engine Brackets
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank - (Components)
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank (Components)
Fuel System - Fuel Tank Bracket
Drive System
Belts & Link Chains - Left Side
Belts & Link Chains - Right Side
Engine Fan - Drive
Hydrostatic Pump - Drive
Rotary Filter And Dust Aspiration - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Crop Elevator - Reverse Drive
Cylinder Variator
Threshing Mechanism - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Towing Hook
Towing Hook Cuna
Towing Hook Rockinger
Frame And Suspension
Frame
Beater - Body
Steering Column
Front Axle
Reduction Gear - (Components)
Gearbox - Gear Lever
Gearbox
Brake Caliper - (Components)
Brake Pedal
Brake Master Cylinder & Brake Control Valve - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydrostatic Pump
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Motor
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Cutting Header - Lifting
Valve Block (Components)
Steering
Control Valve (Header)
Control Valve (Header) - (Components)
Pipes Reel
Electrohydraulic Engagement Control Valve - With Straw Chopper
Header Additional Lifting Ram
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Work Lights - Grain Tank
Work Lights - For Folding Cutter Bar
Battery Box & Battery Cable
Main Harness
Harness - Fuse Carrier
Harness - Cab - Operator Platform
Harness - Cab - Roof
Harness - Grain Tank
Harness - Engine
Harness - Control Valve
Harness - Hydraulic Oil Tank & Hydrostatic Pump
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness Shield
Return Auger - Sensors
Seat Holder
Access Ladder
Footstep - Left Side
Footstep - Right Side
Control Console
Multifunction Lever
Rear View Mirror
Rear View Mirror - Electrically Adjustable
Mechanical Header Height Indicator
Platform
Support Frame
Hand Rail & Sun Canopy
Air Conditioning
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Service Hatch
Engine Compartment - Access Ladder
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Rear Sheet Metal - Weight
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Tracks (6 Rollers)
Front Wheels
Rear Wheels - With Half-Tracks
Rear Wheels - Weight
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Floating Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Drive Lever
Threshing System
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Threshing Mechanism - Drive Lever
Rear Beater
Concave - Control System
Concave - Rice
Concave - Deflector Plate
Concave
Straw Walker - Body
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Grain Bin And Elevator System
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Tank
Grain Tank - Filling Auger
Grain Tank Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Lifting Tools
Number Plate
Tool Box - Tools
Additional Fire Extinguisher
Equipment - Official Approval
Accessories - Additional Fuel Filter
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Beater - Blanking Plate
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Mechanical Header Height Indicator
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Straw Walker Loss
Accessories - Header Additional Lifting Ram
Conversion Kit - Wheat To Rice
Conversion Kit - Wheat To Maize
CONVERSION KIT - RICE TO WHEAT
