702,019
Fendt Combine 5180E Parts Catalog 3906256 03.2019
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5180E 5180E Combine
Serial Number: 551110001-492, 551100001-492, ZN205511K03000493-568
Publication Date: 03.2019
Number of Pages: 798 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel
Flywheel Housing
Crankshaft And Pistons
Camshaft
Valve Mechanism
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
Turbocharger
Turbocharger - Oil Pipe
Oil Sump
Oil Pump
Oil Filter
Fuel Injection Pump
Fuel Injection Pipes
Fuel Pipes
Fuel Pump
Thermostat
Alternator & Fitting Bracket
Alternator - (Components)
Starter Motor
Fan Drive
Engine Installation
Engine Installation - Fan
Engine Installation - Filters
Engine Installation - Engine Brackets
Engine Installation - Belt Tensioner
Engine Installation - Radiator Support
Engine Installation - Throttle Control
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank Bracket
Drive System
Belts & Link Chains - Left Side
Belts & Link Chains - Right Side
Hydrostatic Pump - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Crop Elevator - Reverse Drive
Air Conditioning - Drive
Cylinder Variator
Threshing Mechanism - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Towing Hook
Towing Hook Cuna
Frame And Suspension
Frame
Beater - Body
Steering Column
Front Axle
Reduction Gear - (Components)
Gearbox - Gear Lever
Gearbox
Brake Caliper - (Components)
Brake Pedal
Brake Master Cylinder & Brake Control Valve - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Cutting Header
Cutting Header - Lifting
Valve Block (Components)
Steering
Control Valve (Header)
Control Valve (Header) - (Components)
Pipes Reel
Electrohydraulic Engagement Control Valve - With Straw Chopper
Header Additional Lifting Ram
Hydrostatic Pump
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Motor
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Work Lights - Grain Tank
Battery Box & Battery Cable
Harness - Fuse Carrier
Harness - Cab - Operator Platform
Harness - Cab
Harness - Grain Tank
Harness - Engine
Harness - Control Valve
Harness - Hydraulic Oil Tank & Hydrostatic Pump
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness Shield
Return Auger - Sensors
Seat Holder
Access Ladder
Footstep - Left Side
Footstep - Right Side
Control Console
Multifunction Lever
Rear View Mirror
Rear View Mirror - Electrically Adjustable
Mechanical Header Height Indicator
Air Conditioning
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Access Ladder
Engine Compartment - Service Hatch
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Rear Sheet Metal - Weight
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Tracks (6 Rollers)
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Lower Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Drive Lever
Threshing System
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Threshing Mechanism - Drive Lever
Rear Beater
Concave - Control System
Concave - Rice
Concave - Deflector Plate
Straw Walker - Body
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Grain Bin And Elevator System
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Tank
Grain Tank - Hand Rail
Grain Tank - Filling Auger
Grain Tank Unloading - Drive & Clutch
Grain Tank Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Number Plate
Tool Box - Tools
Additional Fire Extinguisher
Equipment - Official Approval
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Beater - Blanking Plate
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Mechanical Header Height Indicator
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Seed Riddle - Elec. Adjustable
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Straw Walker Loss
Accessories - Header Additional Lifting Ram
Conversion Kit - Wheat To Rice
Conversion Kit - Wheat To Maize
