Fendt Combine 5180 C Parts Catalog 1637438 07.2005
Brand: Fendt
Type of Machine: Combine
Model: Fendt 5180 C Combine
Publication Date: 07.2005
Number of Pages: 431 Pages
Knives And Fingers - Freeflow
Table Auger Right Hand - Freeflow
Table Auger Left Hand - Freeflow
Guarding And Transmissions - Freeflow
Table Housing And Guarding - Freeflow
Knives And Fingers - Powerflow
Table Auger Right Hand - Powerflow
Tabel Auger Left Hand - Powerflow
Guarding And Transmissions - Powerflow
Table Housing And Guarding - Powerflow
Powerflow Band - Left Hand
Powerflow Band - Right Hand
Oilseed Rape Auger
Straw Dividers
Table Trailer - From No 0000500
Lightening Bracket
Electric Vertical Knife
Reel
Reel - Right Hand
Reel Suspension And Hydraulic Motor
Reel - Left Hand
Reel Suspension And Hydraulic Cylinders
Table Channel
Main Crop Elevator
Feed Passage - Rollers & Chains
Elevator Top Shat & Slip Clutch - Shaft & Torque Limiter
Feed Passage - Driving Parts
Feed Passage Clutch
Feed Passage Clutch - Belt Guide
Reversing Device
Locking Device For Cutting Table
Concave, Threshing Drum And Rear Beater
Threshing Drum
Threshing Drum Drive Idler Pulley
Threshing Drum Countershaft
Threshing Drum Reducing Transmission - Optional
Concave
Concave Stone Strap - From 6064
Concave Adjustment
Threshing Equipment Grain Maize & C.C.M.
Rear Beater
Straw Stripper Drum Speed Variator
Variator Regulation Electric
Threshing Mechanism Engaging Parts
Threshing Mechanism Engaging Parts - Belt Guide
Straw Shaker
Straw Shaker And Cranks
Straw Walkers Countershaft
Grain Returning Floor
Cleaning Unit And Main Fan
Stepped Floor - Standard
Sieve Box Standard
Sieves Equipment Standard
Sieves Equipment - Maize
Sieves Equipment C C M
Rocker Bars For Stepped Floor And Sieve Box
Stepped Floor And Sieve Box Driving Parts - Standard
Wind Adjusting Tunnel
Adjusting Device For Wind Tunnel
Cleaning Fan Idler Pulley
Cleaning Fan Idler Pulley - Belt Tensioner
Grain Pan
Elevators
Return Elevator
Elevator Auger
Grain Elevator
Elevator Head
Elevator Head With Auger
Crankcase - Up To 59067
Crankcase - From 59068
Timing Gear Housing - From 59068
Timing Gear Housing - Up To 59067
Flywheel Housing - Up To 59067
Flywheel Housing - From 59068
Lubricating Oil Sump And Oil Pump
Cylinder Head - Up To 59067
Cylinder Head - From 59068
Valve Mechanism And Camshaft - Up To 59067
Valve Mechanism And Camshaft - From 59068
Crankshaft, Pistons And Connecting Rods
Joints And Gaskets
Inlet And Exhaust Manifold - Up To 59067
Inlet And Exhaust Manifold - From 59068
Turbocharger
Oil Filter
Injection Pump - Up To 59067
Injection Pump - From 59068
Guard - Up To 59067
Guard - From 59068
Fan Engine
Engine Harness
Starter
Oil Breather - From 59068
Grain Tank - Guards
Grain Tank
Device For Grain Samples
Grain Tank Covers
Grain Tank Clutch
Grain Tank Emptying
Grain Tank Emptying - Angle Drive Below
Outlet Augers For Grain Tank
Grain Tank Emptying Angle Drive
Discharging Tube For Grain Tank
Discharging Tube For Grain Tank Swiveling Device
Drive Unit
Engine Bracket And Silencer
Oil Cooler Hydraulic Tank For Traveling And Filter
Air Manifolds
Air Filter
Compressor
Compressor - Component Parts
Condensator
Evaporator - Optional
Engine Speed Adjusting Parts
Transmissions
V-Belts And Chains
Belts
Belt Tensioner
Front Axle
Gear Box - Gearbox Fork Drive Shaft
Gear Box - Countershaft
Working Brake
Lateral Gears
Steering Axle - Standard
Steering Axle - Adjustable
Tyres
Operator Platform
Operating Platform
Steering Column
Operator Seat
Shift Levers
Hydraulic Brake
Driver's Cab - Glass And Hinges
Driver's Cab - Mirror Holder
Driver's Cab - Windscreen Wiper
Driver Cab Roof
Driver's Cab Roof -Fan
Forward Speed Control
Driver's Cab - Switch
Instrument Panel - Fuse Box And Relays
Instrument Panel - Joystick
Hydraulic
Working Hydraulic
Steering Hydraulic Lines
Working Hydraulic - Platform
Drive - Driving S4 & Hydraulic Lines - Reel
Working Hydraulic - Hopper
Working Hydraulic - Valve Block
Hydrostatic- Steering
Variable Pump
Traveling Hydraulic Equipment - Impeller
Flow Divider
Machine Housing - Guards
Guard - Left Side
Guard - Right Side
Straw Hood
Service Platform
Tools & Electrical System
Electrical Equipment - Engine
Electrical Equipment - Grain Tank
Electrical Equipment - Beacon
Electrical Equipment - Rear
Electrical Equipment - Revolutions Control
Electrical Equipment - Cutting Table
Electrical Equipment - Operating Platform
Relief Indicator Cutting Table
Position Transmitter Wind Tunnel
Work Lamp
Board Computer - Area Measure
Debit Electronic Sensor - For Grain Tank With Board Computer
Cutting Level Equipment
Lighting - Export Only
Straw Chopper
Straw Chopper Knives
Straw Chopper - From Straw Chopper No. 05148
Kpab - Straw Chopper - Distributor Box - From Straw Chopper No. 05148
Distributor - Chopper Electric Adjusting Device
Kpab - Straw Chopper Mounting Frame
Kpab - Straw Chopper Deflector Sheets
Kpab - Straw Chopper V-Belt Clutch - From Straw Chopper No. 06201
Kpab - Straw Chopper Chaff Spreader - From Straw Chopper No. 06937
Security Decal
