Fendt Baler Medium Square 12130 12130S Parts Catalog 3906198 01.2011
Brand: Fendt
Type of Machine: Hay Equipment, Baler Medium Square
Model: Fendt 12130, 12130S Baler Medium Square
Publication Date: 01.2011
Number of Pages: 429 Pages
Linkage - Safety Chain
Transmission - Drive Shaft
Transmission - Secondary
Transmission - C.E - Type 2 1 -3 8 X 21 Splines - Auto Lock - Up To A.H.B 05100
Transmission - C.E - Type 2 1 -3 8 X 21 Splines - Auto Lock - From A.H.B 05101
Transmission - C.E - Type 3 1 -3 4 X 20 Splines - Auto Lock - Up To A.H.B 05100
Transmission - C.E - Type 3 1 -3 4 X 20 Splines - Auto Lock - From A.H.B 05101
Transmission - Flywheel
Transmission - Flywheel Brake
Transmission - Flywheel Clutch
Gearbox - Attachment
Gearbox
Chain Drive - Left Side - Up To H.U 91100
Chain Drive - Left Side - From H.U 91101
Chain Drive - Right Side
Chain Drive
Chain Drive - Clutch
Cutter Drive Assembly - Left
Cutter Drive Assembly - Left - Clutch
Gearbox - Cutter
Pick-Up
Pick-Up - Windguard - Up To H.T 91100
Pick-Up - Windguard - From H.T 91101
Pick-Up - Wrapper, Wearplate & Scraper - Up To H.U 91404
Pick-Up - Wrapper, Wearplate & Scraper - From H.U 91405
Pick-Up - Flotation
Pick-Up - Feed Auger
Pick-Up - Chain Drive - Left Side
Pick-Up - Chain Drive - Right Side - Up To H.T 91100
Pick-Up - Chain Drive - Right Side - From H.T 91101
Pick-Up - Clutch
Pick-Up - Rotor
Pick-Up - Shields - Left Side
Pick-Up - Shields - Right Side - Up To H.T 91100
Pick-Up - Shields - Right Side - From H.T 91101
Pick-Up - Gauge Wheel
Pick-Up - Cutter - Feed Auger - Up To H.U 91574
Pick-Up - Cutter - Feed Auger - From H.U 91575
Pick-Up - Cutter
Pick-Up - Cutter - Rotor
Pick-Up - Cutter - Knife
Electrical Wiring
G.T.A - G.T.A 1 - Monitor
G.T.A - G.T.A 2 - Monitor
G.T.A - C1000 - Monitor
G.T.A - Optional Parts
Electrical Wiring - Cutter
Electrical Wiring - Kit
Electrical Wiring - Rampe Kit
Lighting
Lighting - Without Cutter
Lighting - With Cutter
Lighting - Rotating Light
Electrical Plug
Stuffer
Packer - Feed Auger - Without Cutter - Up To H.T 91100
Packer - Feed Auger - Without Cutter - From H.T 91101 - Up To H.U 91404
Packer - Feed Auger - Without Cutter - From H.U 91405
Packer
Stuffer - Left Side
Stuffer - Right Side
Stuffer - Brake
Hay Dog
Feeder - Up To Serial Or Engine Number Ht 91210
Feeder - From Serial Or Engine Number Ht 91211
Feeder - Wrapper - Up To B.H.B 05100
Feeder - Wrapper - From B.H.B 05101
Feeder - Clutch Control - Up To H.U 91100
Feeder - Clutch Control - From H.U 91101
Feeder - Finger Packer - Up To H.U 91404
Feeder - Finger Packer - From H.U 91405
Plunger
Plunger - Up To Serial Or Engine Number Hu 91100
Plunger - From Serial Or Engine Number Hu 91101
Bale Ejector
Bale Chute
Knotter
Needle - Up To Serial Or Engine Number Hu 91560
Needle - From Serial Or Engine Number Hu 91561
Knotter - Attachment
Knotter - Frame
Knotter - Twine Guide
Knotter Control - Cam Assembly
Knotter - Knotter Head
Knotter - Clutch
Knotter - Brake
Knotter - Arm
Knotter - Twine Finger & Hay Dog
Knotter - Tension Adjusting
Knotter - Twine Tensioner - Lower
Knotter - Twine Tensioner - Arm
Knotter - Reflector
Star Wheel - Attachment
Star Wheel - Tower
Star Wheel - Up To Serial Or Engine Number Hu 91375
Star Wheel - From Serial Or Engine Number Hu 91376
Star Wheel - Star Wheel
Star Wheel - Universal Joint
Lubrication
Lubrication - Pump
Lubrication - Primary Valve
Lubrication - Secondary Valve
Frame, Wheels & Shields
Bale Chamber - Up To Serial Or Engine Number Hu 91100
Bale Chamber - From Serial Or Engine Number Hu 91101
Bale Chamber - Doors & Arms - Up To H.T 91331
Bale Chamber - Doors & Arms - From H.T 91332
Shields - Hood & Fitting
Shields - Top
Shields - Knotter - Up To A.H.B 05357
Shields - Knotter - From A.H.B 05358
Shields - Knotter
Shields - Knotter - Without Blower
Twine Box - Twine Box Fitting & Ladder - Left Side
Twine Box - Twine Box Fitting - Right Side
Twine Box - Left Side
Twine Box - Right Side
Shields - Holder - Left Side
Shields - Holder - Right Side
Shields - Doors - Left Side
Shields - Left Side
Shields - Doors - Right Side
Shields - Single Axle - Front - Without Cutter - Up To H.U 91244
Shields - Single Axle - Front - Without Cutter - From H.U 91245
Shields - Single Axle - Front - With Cutter
Shields - Single Axle - Rear
Shields - Tandem Axle - Front - Without Cutter - Up To H.U 91270
Shields - Tandem Axle - Front - Without Cutter - From H.U 91271
Shields - Tandem Axle - Front - With Cutter
Shields - Tandem Axle - Rear
Crawl Of Safety - Up To Serial Or Engine Number Ahb 05100
Crawl Of Safety - From Serial Or Engine Number Ahb 05101
Tool Box
Single Axle - Frame
Single Axle - Brake - Up To A.H.B 05238
Single Axle - Brake - From A.H.B 05239
Tandem Axle - Frame
Tandem Axle - Steering Axle
Tandem Axle - Wheel Hub
Tandem Axle - Brake - Rigid Axle
Tandem Axle - Brake - Steering Axle
Tandem Axle - Brake
Wheel
Parking Brake - Single Axle
Parking Brake - Tandem Axle
Parking Brake - Actuator
Hydraulic
Hydraulic - Pick-Up
Hydraulic - Front
Hydraulic - Valve
Hydraulic - Auto Brake
Hydraulic - Tank
Hydraulic - Bale Chamber
Hydraulic - Blower
Blower
Hydraulic - Cutter
Hydraulic Cylinder
Hydraulic - Bale Ejector - Up To A.H.B 05107
Hydraulic - Bale Ejector - From A.H.B 05108
Hydraulic - Brake - Single Axle
Hydraulic - Brake - Tandem Axle
Hydraulic - Air Brake - Tandem Axle
Hydraulic - Air Brake - Single Axle
Hydraulic - Steering Axle - Tandem Axle
Decals & Attachments
Decals - Without Cutter
Decals - With Cutter
Attachments - Pull Eye Bolt
Attachments - Transmission - Up To Serial Or Engine Number Ahb 05100
Attachments - Transmission - From Serial Or Engine Number Ahb 05101
Attachments - Shear Bolt
Attachments - Bale Chute
Attachments - Hydraulic - Blower
Attachments - Bale Ejector
Attachments - Bale Weight & Lenght
Attachments - G.T.A - G.T.A 1
Attachments - G.T.A - G.T.A 2
Attachments - G.T.A - C1000
Literature
