FAW Automotive Sirius Series S80 Workshop Manual
Brand: FAW
Type of Machine: Automotive
Type of Manual: Workshop Manual
Model: FAW Sirius Series S80 Automotive
List of Files:
Vol.1.pdf (712 Pages)
Index
1-IN
How to use this manual
Identification information
Service instructionHow to eliminate faults of ECU control system
Terms
2-pp
Engine control system
Engine mechanic
Lubrication
Emission control
Air exhaust
Cooling
Lubrication
Ignition
Start
Charging
A4Q automatic transmission
Clutch
Manual transmission
Transmission shaft
Axle
Suspension
Tires and wheels
Brake control
Brake
Parking brake
Steering column
Power steering mechanism
Air conditioner
Sub-passenger protection system
Anti-theft system
Lighting
Wiper and washer
Door lock
Instrument
Audio/ visual system
Horn
Other system
Windscreen/ glass for vehicle window
Rearview mirror
Dashboard
Engine hood/ door
Appearance of vehicle
Inner trim of vehicle
3-ES
EFI system
Precautions
Part positions
System diagram
How to conduct analysis for fault shooting
Inspect intermittent fault
Basic inspection
Fault symptom table
ECM terminal
Diagnostic system
DTC inspection/ elimination
Frame data
Fail-safe table
Data list/ active test
List of diagnostic trouble code (DTC)
P0105/31
P0110/43
P0115/42
P01165/42
P01120/41
P0130/21
P0133/21
P0135/23
P0141/24
P0136/22
P0171/25
P0172/26
P0325/18
P0335/13
P0340/14
P0350/16
P0420/27
P0443/76
P0500/52
P0505/71
P0535/44
P1105/32
P1300/36
P1346/75
P1394/73
P1351/62
P1510/54
P1560/61
P1656/74
U0101/82
U1000/85
U1002/88
ECM power supply circuit
VC output circuit
Fuel pump control circuit
Oil injector circuit
MIL circuit
Components
Dismantling
Inspection
Installation
Components
Dismantling
Inspection
Installation
Components
Dismantling
Inspection
Installation
Components
Dismantling
Inspection
Installation
On - board inspection
Components
Dismantle
Removal
Inspection
Reassembly
Installation
Components
Dismantling
Inspection
Installation
On-board inspection
On-board inspection
Components
Dismantling
Installation
On-board inspection
4-EM
5-FU-EC-质检
Fuel system
Fuel injector
Fuel pump
Fuel tank
6-EX质检好
Air exhaust pipe
Component
Dismantle
Install
7-CO
Cooling system
On-board inspection
Part position
System diagram
On-board inspection
Replacement
Component
Dismantle
Inspection
Installation
Component
Dismantle
Inspection
Installation
On-board inspection
Component
Dismantle
On-board inspection
Criteria
On-board cleaning
Installation
8-LU-IG
Lubrication system
Oil and oil filter
Oil pump(3SZ-VE Engine)
Oil pump(K3-VE Engine)
9-ST--CH
Starting System
Component location
System diagram
Components
Remove
Install
Check
Components
Remove
Check
Install
Vol.2.pdf (752 Pages)
Index
1-AT
03
01
02
2-CL-MT
Manual Transmission System
Manual Transmission Oil
Manual Transmission Extension Case Oil Seal
Floor Shift Lever assembly
Transmission Control Shift Cable and Select Cable
Manual Transmission Assembly (For 3SZ-VE)
Manual Transmission Unit
Clutch System (For 3SZ-VE)
Clutch System (For K3-VE)
Clutch Pedal (For 3SZ-VE)
Clutch Pedal (For K3-VE)
Clutch Master Cylinder (For 3SZ-VE)
Clutch Release Cylinder (For 3SZ-VE)
Clutch Release Cable Assembly (For K3-VE)
Clutch Unit (For 3SZ-VE)
Clutch Unit (For K3-VE)
3-pr-ah
Drive Shaft System
Drive Shaft Assembly
Differential system
Gear oil
The main retarder housing oil seal
Drive axle housing assembly (For 3SZ-VE)
Differential housing assembly (For K3-VE)
4-SP-TW-BC
Tire and Wheel System
Anti-Lock Brake System
Brake actuator
Front speed sensor Components
Rear speed sensor
Suspension System
Front Wheel Alignment
Front Shock Absorber
Front Lower Suspension Arm
Front Stabilizer Bar
Rear Coil Spring
Rear Shock Absorber
Rear Upper Arm
Rear Lower Arm
Rear Transverse Control Link
5-BR-PS
Steering Column Assembly
Parking Brake System
Parking Brake Lever
Parking Brake Cable
Brake Fluid
Brake Pedal (For 3SZ-VE)
Brake Pedal (For K3-VE)
Brake Master Cylinder
Vacuum Booster
Front Brake
Front Brake Hose
Rear Brake
Rear Brake Hose
Power Steering System
Impeller Pump
Power Steering Gear
6-AC
1
2
空白页面
Vol.3.pdf (708 Pages)
Index
1-RS
Air Bag System
Notes
Part Location
System Diagram
System Description
How to Make Troubleshooting Analysis
ECU Terminals
Fault Symptom Table
Diagnosis System
DTC check/clearing
Check mode steps
DTC List
B1000/31
B1800/13
B1801/14
B1802/11
B1803/12
B1805/53
B1806/54
B1807/51
B1808/52
B1905/73
B1906/74
B1907/71
B1908/72
Power supply voltage drop
SRS alarm lamp is always lit.
SRS alarm lamp is not lit.
Diagnosing electrical circuit
Components
Check in the vehicle
Remove
Install
Disposal
Components
Remove
Check
Install
Components
Remove
Install
Disposal
Components
Remove
Install
2-SB
Front seat inside belt assembly
Components
Dismantle
Installation
Components
Dismantle
Installation
Components
Dismantle
Installation
Components
Dismantle
Installation
3-TD
Part location
System diagram
How to make troubleshooting analysis
System Description
Customize parameters
Engine hood control lamp switch circuit
Horns circuit
Ignition switch circuit
Safety indicator lamp circuit
Danger alarm switch circuit
Door control lamp switch circuit
Interior lamp circuit
Door control switch circuit
ECU power circuit
ECU power circuit
Dismantling
Check
Installation
4-LI
Lighting system
Headlamp assembly
Side steering signal lamp assembly
Fog lamp assembly
Rear combination lamp assembly
License plate lamp assembly
Interior lamp assembly(for front side)
Interior lamp assembly(for rear side)
Headlamp dimmer switch
Emergency alarm switch
Rear fog lamp switch
Brake lamp switch
Front door control lamp switch
Rear door control lamp switch
Back door control lamp switch
Steering signal flasher assembly
Headlamp Relay
Fog lamp relay
5-WW
Wiper and washer system
Precaution
Part location
System diagram
Fault symptom table
Module
Dismantling
Check
Installation
Module
Dismantling
Installation
Module
Dismantling
Check
Installation
Module
Dismantling
Installation
Module
Dismantling
Check
Installation
Module
Dismantling
Installation
Adjustment
6-DL
Electric door lock control system (only trunk lid adopts electric door lock)
7-ME
Instrument/gauge system
8-AV-OT
Radio
9-WS
Electric window control system
WS.pdf---.pdf
10-MI-IP-SE-ED
Control System of Power Rearview Mirror
Location of Components
System Diagram
Table of Fault Phenomenon
Components
Dismantling
Installation
Components
Dismantling
Inspecting
Installation
Components
Dismantling
Inspecting
Installation
11-ET-IR
Front Bumper
Brand: FAW
List of Files:
Index
1-IN
Terms
2-pp
Engine mechanic
Lubrication
Emission control
Air exhaust
Cooling
Lubrication
Ignition
Start
Charging
Clutch
Manual transmission
Transmission shaft
Axle
Suspension
Tires and wheels
Brake control
Brake
Parking brake
Steering column
Air conditioner
Anti-theft system
Lighting
Wiper and washer
Door lock
Instrument
Horn
Other system
Rearview mirror
Dashboard
Engine hood/ door
3-ES
EFI system
Precautions
Part positions
System diagram
Basic inspection
Fault symptom table
ECM terminal
Diagnostic system
Frame data
Fail-safe table
P0105/31
P0110/43
P0115/42
P01165/42
P01120/41
P0130/21
P0133/21
P0135/23
P0141/24
P0136/22
P0171/25
P0172/26
P0325/18
P0335/13
P0340/14
P0350/16
P0420/27
P0443/76
P0500/52
P0505/71
P0535/44
P1105/32
P1300/36
P1346/75
P1394/73
P1351/62
P1510/54
P1560/61
P1656/74
U0101/82
U1000/85
U1002/88
VC output circuit
MIL circuit
Components
Dismantling
Inspection
Installation
Components
Dismantling
Inspection
Installation
Components
Dismantling
Inspection
Installation
Components
Dismantling
Inspection
Installation
Components
Dismantle
Removal
Inspection
Reassembly
Installation
Components
Dismantling
Inspection
Installation
On-board inspection
On-board inspection
Components
Dismantling
Installation
On-board inspection
4-EM
5-FU-EC-质检
Fuel system
Fuel injector
Fuel pump
Fuel tank
6-EX质检好
Air exhaust pipe
Component
Dismantle
Install
7-CO
Cooling system
On-board inspection
Part position
System diagram
On-board inspection
Replacement
Component
Dismantle
Inspection
Installation
Component
Dismantle
Inspection
Installation
On-board inspection
Component
Dismantle
On-board inspection
Criteria
On-board cleaning
Installation
8-LU-IG
Lubrication system
Oil and oil filter
9-ST--CH
Starting System
Component location
System diagram
Components
Remove
Install
Check
Components
Remove
Check
Install
Index
1-AT
03
01
02
2-CL-MT
3-pr-ah
Drive Shaft System
Differential system
Gear oil
4-SP-TW-BC
Brake actuator
Rear speed sensor
Suspension System
Rear Coil Spring
Rear Shock Absorber
Rear Upper Arm
Rear Lower Arm
5-BR-PS
Parking Brake Lever
Parking Brake Cable
Brake Fluid
Vacuum Booster
Front Brake
Front Brake Hose
Rear Brake
Rear Brake Hose
Impeller Pump
Power Steering Gear
6-AC
1
2
空白页面
Index
1-RS
Air Bag System
Notes
Part Location
System Diagram
System Description
ECU Terminals
Fault Symptom Table
Diagnosis System
DTC check/clearing
Check mode steps
DTC List
B1000/31
B1800/13
B1801/14
B1802/11
B1803/12
B1805/53
B1806/54
B1807/51
B1808/52
B1905/73
B1906/74
B1907/71
B1908/72
Components
Remove
Install
Disposal
Components
Remove
Check
Install
Components
Remove
Install
Disposal
Components
Remove
Install
2-SB
Components
Dismantle
Installation
Components
Dismantle
Installation
Components
Dismantle
Installation
Components
Dismantle
Installation
3-TD
Part location
System diagram
System Description
Horns circuit
ECU power circuit
ECU power circuit
Dismantling
Check
Installation
4-LI
Lighting system
Headlamp assembly
Fog lamp assembly
Brake lamp switch
Headlamp Relay
Fog lamp relay
5-WW
Precaution
Part location
System diagram
Fault symptom table
Module
Dismantling
Check
Installation
Module
Dismantling
Installation
Module
Dismantling
Check
Installation
Module
Dismantling
Installation
Module
Dismantling
Check
Installation
Module
Dismantling
Installation
Adjustment
6-DL
7-ME
8-AV-OT
Radio
9-WS
WS.pdf---.pdf
10-MI-IP-SE-ED
System Diagram
Components
Dismantling
Installation
Components
Dismantling
Inspecting
Installation
Components
Dismantling
Inspecting
Installation
11-ET-IR
Front Bumper
- Ingersoll Rand SD-100 Schematic, Repair & Troubleshooting Manual 2022
- Kalmar Reach Stackers 40-45T DRF 400-450 Maintenance Manual
- Parts catalog Isuzu 3LA1, 3LB1, 3LD1
- Hamm 3516, 3518 ,3520 ,3516 P, 3518 P ,3520 P Spare parts List
- HATZ Diesel 2W35,3W35,3W35T,4W35,4W35T Workshop Manual
- Schwing Service Training - Training Manual
- HBM Motor Grader NOBAS BG160T-4
- Yuchai Diesel Engine YC4D Parts Catalog
- ZF – ERGOPOWER TRANSMISSION 4 WG-190/210 Service
- PALFINGER PK4501 PK5001 Hydraulic Crane Spare Parts List
- Tamrock Ranger 700-2 Operator and Maintenance Manual
- XGMA XG 955II Wheel Loader Parts Catalog
- MF 50H, MF 50HX, MF 60HX Turbo Operator Manual
- VOITH Retarder 115 Actors After Sales Service Manual
- O&K RH23.5 Crawler Excavator Hydraulics Schematics and Spare Parts Catalogue
