B
Bray Asser
Guest
Electronic Technician
Hey guys I'm looking for a Cat ET for calibrating Cat engines and transmissions in a D5G dozer.
Communications Adapter 3 is the latest generation of the Communication Adapter group, and replaces the Comm Adapter II. This is the only recommended communication device for ET 3,and the only data link device that will allow you to properly communicate with a CA engine on dual datalinks. This function is needed for some ET (Electronic Technician) functions.
B
Bray Asser
Guest
CATERPILLAR ELECTRONIC TECHNICIAN (CAT ET)
CAT Caterpillar ET Diagnostic Interface (Cat ET) is diagnostic software required to communicate, diagnose and service electronically controlled Caterpillar engines and machines.
When connected to an Electronic Control Module (ECM), a technician has the ability to diagnose existing and potential problems,
configure the product, and obtain data for analysis.
Here is the latest version of Caterpillar Electronic Technician 2023A.
With the CAT ET 3 tool, you can connect to all vehicles using CAT brand and CAT Engine, and perform all operations such as troubleshooting, parameter and programming.
CAT diagnostic tool works by means of a computer and necessary installations must be made on the computer.
B
Bray Asser
Guest
Caterpillar ET 2023A 2021B 2019C 2018A Electronic Technician Software Free Download
Caterpillar ET Functions List:
1.View active and logged diagnostics.
2.View events where irregularities occurred and were logged by the ECM.
3.View the status of a group of parameters (temperatures, pressures, etc.) simultaneously.
4.Record and log performance data.
5.Graph a group of status parameters.
6.View the current configuration of an ECM.
7.Change ECM configurations.
8.Perform diagnostic tests.
9.Perform calibrations.
10.Print reports and diagnostic results.
11.Please keep in mind that some ecm settings for example, speed limit requires factory password. The factory password generator is not included in this application
Caterpillar ET Support Languages:
English,Chinese,Danish,French,German,Italian,Portuguese,Spanish
Caterpillar ET Support OS:
Window 7,Window 8,8.1,Window 10 32 bit and 64 bit
