Doosan Forklift G20S2 G25S2 G30S2 Spare Parts Catalog D139175
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton GAS
Model: Doosan G20S2 G25S2 G30S2 Forklift
Part Number: D139175
Number of Pages: 737 Pages
[CHASSIS] Chassis
TANK GP-LP(43X1/2 Lb CAPACITY)(PLUG TYPE)
TANK GP-LP(43X1/2 Lb CAPACITY)(FILL VALVE TYPE)
ENGINE OIL LINES GP
PUMP ASSY,WATER
HOUSING & REGULATOR GP
CARBURETOR GROUP
ELBOW GROUP
FUEL PUMP GP (GAS)
EXHAUST MANIFOLD GP
WHEEL & TIRE ASSY
ARRANGEMENT,CHANGEOVER
GAUGE ASSY,LEVEL
PUMP
MANIFOLD GP-INTAKE
SWITCH ASSY
BRAKE ASSY
DISTRIBUTOR GROUP
LINES GP-COOLANT
MOUNTING GP
LINES GROUP-FUEL 1404 LP
MOUNTING GROUP
MOUNT GROUP
CONTROL GROUP
PUMP GROUP-GEAR
MTG GP-DRIVE AXLE
DRUM ASSY
MTG GP-WHEEL (DRIVE)
VALVE GROUP
FILTER ASSY
CARBURETOR ASSY
LINE GROUP
AXLE ASSY,STEER
CONSOLE ASSY
BAFFLE ASSY
CAP GROUP,FUEL
FRAME ASSY
LINES GP-BRAKE(DISC)
LINES GP-BRAKE(SHOE)
SAFETY SYSTEM
CLEANER GROUP,AIR
ACCELERATOR
MUFFLER GROUP
GAUGE ASSY,OIL LEVEL
CONT GP-CR & BR
RADIATOR GROUP
CHANGEOVER
LINES GP-TORQUE CONVERTER
WEIGHT GROUP,COUNTER
PIPE GROUP,FUEL
BATTERY
CLEANER,PRE
PUMP ASSY,GEAR
GEAR GROUP
BRAKE GROUP
ADAPTER
BRAKE GP-SERVICE DISC
CASE GROUP
AXLE,TRNSMISSION
COOLER ASSY,OIL
DRIVE GROUP,FAN
RADIATOR ASSY
AXLE GROUP,DRIVE
CONVERTER ASSY
CONVERTER
CASE
AXLE,DRIVE
FILTER,OIL
WIRING GROUP
CYLINDER ASSY
STEERING UNIT
LUBRICANT GROUP
LUBRICATION GROUP
MOUNT
CYLINDER GROUP
CYLINDER,TILT
FENDER
[CHASSIS] Driving Module
WHEEL,RIM
WHEEL & TIRE GP
STEER AXLE MOUNTING GP
WHEEL GP-TIRE & DRIVE
WHEEL
WHEEL & TIRE GROUP
WHEEL GROUP
[CHASSIS] Engine
CRANKSHAFT GROUP
CAMSHAFT GROUP
MOTOR GROUP,START
VALVE ARRANGEMENT
HOUSING GROUP
MOTOR,START
COVER GROUP
ALTERNATOR ASSY
PISTON & CONNECTING ROD
CRANKSHAFT PULLEY GP
HOUSING GROUP,FLYWHEEL
OIL PAN GP
BLOCK ASSY,CYLINDER
CAMSHAFT GP
HEAD ASSY,CYLINDER
PLUG GP-SPARK
FLYWHEEL GP
MOUNTING GP-E/G (1404)
HOUSING ASSY
PUMP ASSY
ARRANGEMENT
ENGINE ARRANGEMENT
FRONT HOUSING GP
CRANKSHAFT ASSY
VALVE
ALTERNATOR
[CHASSIS] Operating Module
VALVE GROUP,CONTROL
VALVE ASSY
VALVE ASSY,CONTROL
ARRANGEMENT,VALVE
VALVE,CONTROL
VALVE AR-3 SECTION-LTZ
VALVE AR-4 SECTION-LTZ
CHANGEOVER AR-3 WAY TO 4 WAY-LTZ
CONTROLLER GROUP,DRIVE
INSTRUMENT GROUP
COWLING GP (A)
GUARD GROUP,OVERHEAD
PANEL
HORN GROUP
LAMP,HEAD
SEE COMPONENTS - LIGHTING GP
LIGHT GP - OPTION
LIGHT GP-OPTION(2/2)
PLATE ASSY,FLOOR
SEAT GROUP
SEAT ASSY
SEAT,OPERATOR
SEAT GP - B (NACD)
[FRONT END] Mast
LINE GROUP,ATTACHMENT
PIPE,LINE
LINE,ATTACHMENT
PIPE ASSY
LIFT GROUP
LINE ASSY
LIFT GROUP,PRIMARY
RELAY ASSY
LIFTER GROUP
MAST ASSY
TAP
MAST-FFT
MAST-STD
MAST-FFL
STD MAST MFH 82IN/2075MM
STD MAST MFH 103IN/2625MM
STD MAST MFH 117IN/2995MM
MAST
STD MAST MFH 140IN/3550MM
STD MAST MFH 152IN/3850MM
STD MAST MFH 150IN/4000MM
STD MAST MFH 195IN/5000MM
FF MAST MFH 103IN/2625MM
FF MAST MFH 117IN/2995MM
FF MAST MFH 129IN/3275MM
FF MAST MFH 144IN/3650MM
FFT MAST MFH 156IN/3950MM
MAST ARRANGEMENT
FFT MAST MFH 238IN/6050MM
RELAY GP-LIFT
MTG GP-MAST
RELAY GP
MAST GP(BSC)
MAST GP-BSC
MOUNTING GP-LIFT & TILT
CYLINDER KIT,LIFT
MAST-FF
LIFT ASSY
[FRONT END] Fork
Fig. 6-001 [D390046A]
FORK GP
POSITIONER
[FRONT END] Carriage
MOUNT ASSY
REST ASSY,BACK
CARRIAGE AS
CARRIAGE AS-FF,FFT
CARRIAGE ARRANGEMENT
CARRIAGE ASSY
SHIFT GROUP,SIDE
SHIFT,SIDE
CYLINDER,SIDE SHIFT
SHIFTER GROUP
