Doosan Forklift G20GP G25GP G30GP MMC Spare Parts Catalog SB1257E
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton GAS
Model: Doosan G20GP G25GP G30GP MMC Forklift
Part Number: SB1257E
Number of Pages: 1032 Pages
Section 1
Chassis Component
Steer Axle Gp
Steering Axle
Cylinder As-Steer
Frame Gp
Panel Gp-Top
Hood Ass’y
Air Cleaner Gp
Muffler Gp(N-C)
Muffler Gp(Tier-3)
Lines Gp-Torque Converter
Radiator Gp
Reservoir Gp
Fuel Lines Gp - DF
Fuel Lines Gp - LP
Battery Tray Gp
Wiring Gp-DF
Wiring Gp-LP
Instrument Gp-DF
Instrument Gp-LP
Mounting Gp-Power Train(2.0/2.5Ton)
Mounting Gp-Power Train(3.0Ton)
Accel Pedal Sub As
Control Gp-Steering
Steering Unit
Handle Wheel
Steering Column
Control Gp-Brake & Inching
Brake As
Lines Gp-Brake
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Oil Tank
Lines Gp-Hydraulic
Pump Mtg Gp
Gear Pump
Mtg. Gp-LP Tank
Section 2
Capacity Module
Guard Gp-Overhead
Mirror Gp
Counter Weight Gp
Tire&Wheel Gp-2.0/2.5Ton
Tire&Wheel Gp-Pneu-3.0 Ton
Tire&Wheel Gp-Dual-2.0/2.5Ton
Tire&Wheel Gp-(Pneu)-Dual-3.0Ton
Tire&Wheel Gp-Solid-2.0/2.5Ton
Tire&Wheel Gp-Solid-3.0Ton
Fender Gp-Dual Tire-2.0/2.5Ton
Fender Gp-Dual Tire-3.0Ton
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine_MMC 2.4L
Engine Ar.-Primary
Cylinder Block GP
Rocker Cover GP
Cylinder Head GP
Front Cover And Oil Pan GP
Piston And Crankshaft GP
Camshaft And Valve GP
Balancer GP
Oil Pump GP
Thermostat Gp
Water Pump GP
Intake Manifold Gasket GP
Exhaust Manifold Gasket GP
PS Pump Bracket GP
Ignition GP
Starter GP
ECU Mount GP
Electrical GP - G424P, Dual Fuel
Electrical GP - G424P, LP
Electrical GP - G424PE, Dual Fuel
Electrical GP - G424PE, LP
EPR GP
BI - Fuel (Loose Part) - Dual Fuel Only
Fuel Rail GP - Dual Fuel Only
Fuel Throttle Body GP
Fuel Lock Off Valve GP
Regulator GP
Flywheel GP
Flywheel Housing GP
Oil Filter Adapter GP
Dipstick GP
HI-Fan Tensioner GP
HI-Fan Drive GP
Coolant Heater GP
Regulator Coolant GP
Water Outlet GP
Intake Manifold GP
PCV Air Fresh Hose GP
Exhaust Manifold GP
PCV Foul Hose GP
Mounting Gp - Engine
Fuel Hose Gp
5000 Hour Service Kit
Gasket Kit
Sprocket Kit
Section 4
Power Train
Transmission As
Hydraulic Clutch As
Reduction & Differential As
Control Valve Gp-Solenoid
Inching Valve As
Charging Pump As
Drive Axle Gp2.0/2.5 Ton
Wheel Brake As-LH-2.0/2.5 Ton
Wheel Brake As-RH-2.0/2.5 Ton
Drive Axle Gp-3.0 Ton
Wheel Brake Ass’y-LH-3.0 Ton
Wheel Brake Ass’y-RH-3.0 Ton
Section 5
Option For Complete Truck
Pre Cleaner Gp
Spark & Arrestor
Seat Gp-Static STD
Seat Gp-Static&Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res.,W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res.,W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res.,W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res.,W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning
Seat Belt Gp W/O Switch
Cabin Gp
Cabin As
Door Gp - LH
Door Gp - RH
Full Cabin Group
Heater Gp-Cabin
Heater Gp -Cabin
Fan Gp-Cabin
Extinguisher-Cabin
Lighting Gp
Rear Lamp Gp-Ovhg
Strobe Gp-Ovhg
Rear Lamp Gp-Cabin
Strobe Gp-Cabin
Horn Gp
Valve Ar-3 Sec(3 Sec-2 Lever)
Control Valve As-2 Sec
Valve Ar-3 Sec(FF/FFT)Lines Gp
Contral Valve
Valve Ar-4 Sec(FF/FFT)Lines Gp
Control Valve-4
Valve Hyd Ravlic-STD-3SEC
Valve Hyd Ravlic-STD-4SEC
Valve Hyd Ravlic-FFT/FFL-3SEC
Valve Hyd Ravlic-FFT/FFL-4SEC
Valve Ar-3SEC 3691-STD
Valve Ar-4SEC 3691-STD
Valve Ar-3SEC 3691-FFL/FFT
Valve Ar-4SEC 3691-FFL/FFT
Control Valve-3 Sec 3691
Control Valve-4 Sec 3691
Valve-Distributary
Valve
Valve - Tilt
Valve-Revolve
Relief Valve As
Main Relief Valve
Tool Gp
Change Over Ar.-Eu
Change Over Ar.-Eu LP Tank
Plate As-LP Tank
Change Over Ar.-Mtg Gp(Cosa)
Change Over Ar.-Vertical Stick
Change Over Ar.-Safety
Change Over Ar Muffler Gp-Spark(With CABIN)
Change Over Ar For Eu-Vertical Stick(Without CABIN)
Change Over Ar For Eu-Vertical Stick & Arrestor
Reargripbar-Ovhg;For Modular-C
Rear Lamp Gp-Vohg(Two Lamps)
Fuel Cap With Key(2.0/2.5T)
Hyd.Locking Sys-FFL
Hyd.Locking Sys-FFT
Hyd.Locking Sys-STD
Rear Grip Bar-Ovhg
Rear Grip Bar-Cabin
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Convenience Box
Optn-Speedo Meter
Optn-Autoshift Controlle
OPTN-GROUD SPEED
Valve,Hydraulic;3SEC-FFL/FFT,ISO3691
Valve,Hydraulic;4SEC-STD,ISO3691
Valve,Hydraulic;4SEC-FFL/FFT,ISO3691
LED Lamp Gp-W/Com. OVHG&A CABIN
LED Lamp Gp-W/Com. B&C CABIN
LED Lamp Gp-W/Com. Full CABIN
LED Lamp Gp-Front,OVHG&A CABIN
LED Lamp Gp-Front,B&C CABIN
Spot Lamp Gp-OVHG(BLUE)-Down
Rear Lamp Gp-One Lamp-LED W/O CABIN
CH/OV AR-Autoshift Controller
CH/OV AR For EU
CHA/OV AR-Safety;LP TO LPS
Valve Ar-3SEC 3 Lever Plus ISO3691
VALVE GROUP,CONTROL;3SEC
VALVE,CONTROL;ISO3691;3SEC;
VALVE;DISTRIBUTARY;3691 PLUS
VALVE;LIFT;3691 PLUS
VALVE;TILT;3691 PLUS
VALVE;REVOLVE 3691 PLUS
VALVE;RETURN;3691 PLUS
Valve Ar-4SEC 4 Lever Plus ISO3691
VALVE GROUP,CONTROL;4SEC
VALVE,CONTROL;ISO3691;4SEC;
Injection For Moduar B&C PLUS
Valve Ar-2 Sec 2 Lev
Valve Gp-2 Sec 2 Lev
Valve As-2 Sec
Valve Ar-3 Sec 3 Lev
Valve Gp-3 Sec 3 Lev
Valve As-3 Sec
Valve Ar-4 Sec 4 Lev
Valve Gp-4 Sec 4 Lev
Valve As-4 Sec
Valve-Distributary PLUS
Valve-Lift
Valve-Tilt
Valve Gp-4 Sec 3 Lever
Fuel Cap With Key
Cabin Gp-For Crown Plus
Valve Ar-4SEC 3 Lever Plus ISO3691
Sound Supperssion
Cylinder Assy 8/4;Tilt-2.5Ton
Tire&Wheel Gp-Drive(2.0/2.5Ton)
Tire&Wheel Gp-Front(2.0/2.5Ton)
Tire&Wheel Gp-Inner(2.0/2.5Ton)
Tire&Wheel Gp-Inner(3.0Ton)
Tire&Wheel Gp-Outer(2.0/2.5Ton)
Tire&Wheel Gp-Outer(3.0Ton)
Rain Canopy
CH/OV Ar-Engine Sell Off MMC
Integral Shifting-Fork Positioner 1120mm-FFL(2.0/2.5T)
Integral Shifting-Fork Positioner 1120mm-FFT(2.0/2.5T)
Integral Shifting-Fork Positioner 1170mm-FFL(3.0T)
Integral Shifting-Fork Positioner 1170mm-FFT(3.0T)
Integral Shifting-Fork Positioner 1170mm-STD(3.0T)
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MFH 2500mm~3700mm)
Lift Cylinder Gp-STD(MFH 4000mm~5000mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cyl-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder As-LH
Tilt Cylinder As-RH
Tilt Cylinder-Option
S/S Lines Gp(STD)-2.0/2.5 Ton
S/S Lines Gp(STD)-3.0 Ton
S/S Lines Gp(FFL,FFT)-2.0/2.5 Ton
S/S Lines Gp(FFL,FFT)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL,FFT)-2.0/2.5Ton
Att Lines Gp-Sec(3 Way)-RH(FFL,FFT)-3.0Ton
Att Lines Gp-Sec(4Way)-STD-2.0/2.5Ton
Att Lines Gp-Sec(4Way)-STD-3.0Ton
Att Lines Gp-Sec(3Way)-LH(FFL-FFT)-2.0/2.5Ton
Att Lines Gp-Sec(3Way)-LH(FFL-FFT)-3.0Ton
Att Lines Gp-Sec(4 Way)-FFL,FFT-2.0/2.5Ton
Att Lines Gp-Sec(4 Way)-FFL,FFT-3.0Ton
Lines Gp-Att-Secondary(3Way-LH)-2.0/2.5/3.0Ton
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift&Tilt(STD)
Mounting Gp-Lift&Tilt-FFL
Mounting Gp-Lift&Tilt-FFT
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way-STD
Att Lines Gp-Pri-3 Way FFL
Att Lines Gp-Pri-3 Way FFT
Att Lines Gp-Pri-4 Way-STD
Att Lines Gp-Pri-4 Way-FFL
Att Lines Gp-Pri-4 Way-FFT
Sideshift Gp(2.0/2.5 Ton)
Cylinder As
Cylinder As - Sideshift
Sideshift Gp(3.0 Ton)
Side Shifter As-2.0/2.5 Ton
Side Shifter As-3.0 Ton
Cylinder Ass’Y-2.0/2.5 Ton
Cylinder Ass’Y-3.0 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-3.0 Ton
Carriage As-2.0/2.5/3.0Ton
Carriage Ar-Integral Side Shifter-(2.0/2.5/3.0Ton)
Carriage Group-Integral Side Shift-STD-2.0/2.5Ton
Carriage Group-Integral Side Shift-FFL-2.0/2.5Ton
Carriage Group-Integral Side Shift-FFT-2.0/2.5Ton
Carriage Group-Integral Side Shift-STD-3.0Ton
Carriage Group-Integral Side Shift-FFL-3.0Ton
Carriage Group-Integral Side Shift-FFT-3.0Ton
Side Shifter Cylinder
Bracket As-2.0/2.5Ton
Bracket As-3.0Ton
Carriage As-STD/FFL/FFT2.0/2.5/3.0Ton
Carriage Mounting
Fork Gp
Integral Shifting-Fork Positioner 1120mm-STD(2.0/2.5T)
Brand: Doosan
Section 1
Chassis Component
Steer Axle Gp
Steering Axle
Cylinder As-Steer
Frame Gp
Panel Gp-Top
Hood Ass’y
Air Cleaner Gp
Muffler Gp(N-C)
Muffler Gp(Tier-3)
Radiator Gp
Reservoir Gp
Fuel Lines Gp - DF
Fuel Lines Gp - LP
Battery Tray Gp
Wiring Gp-DF
Wiring Gp-LP
Instrument Gp-DF
Instrument Gp-LP
Accel Pedal Sub As
Control Gp-Steering
Steering Unit
Handle Wheel
Steering Column
Brake As
Lines Gp-Brake
Parking Brake Gp
Floor Plate Gp
Lines Gp-Hydraulic
Pump Mtg Gp
Gear Pump
Mtg. Gp-LP Tank
Section 2
Capacity Module
Guard Gp-Overhead
Mirror Gp
Counter Weight Gp
Section 3
Engine_MMC 2.4L
Engine Ar.-Primary
Cylinder Block GP
Rocker Cover GP
Cylinder Head GP
Balancer GP
Oil Pump GP
Thermostat Gp
Water Pump GP
PS Pump Bracket GP
Ignition GP
Starter GP
ECU Mount GP
EPR GP
Regulator GP
Flywheel GP
Flywheel Housing GP
Dipstick GP
HI-Fan Tensioner GP
HI-Fan Drive GP
Coolant Heater GP
Water Outlet GP
Intake Manifold GP
Exhaust Manifold GP
PCV Foul Hose GP
Fuel Hose Gp
Gasket Kit
Sprocket Kit
Section 4
Power Train
Transmission As
Hydraulic Clutch As
Inching Valve As
Charging Pump As
Section 5
Pre Cleaner Gp
Spark & Arrestor
Seat Gp-Static STD
Seat Gp-Suspension
Cabin Gp
Cabin As
Door Gp - LH
Door Gp - RH
Full Cabin Group
Heater Gp-Cabin
Heater Gp -Cabin
Fan Gp-Cabin
Extinguisher-Cabin
Lighting Gp
Rear Lamp Gp-Ovhg
Strobe Gp-Ovhg
Rear Lamp Gp-Cabin
Strobe Gp-Cabin
Horn Gp
Contral Valve
Control Valve-4
Valve-Distributary
Valve
Valve - Tilt
Valve-Revolve
Relief Valve As
Main Relief Valve
Tool Gp
Change Over Ar.-Eu
Plate As-LP Tank
Hyd.Locking Sys-FFL
Hyd.Locking Sys-FFT
Hyd.Locking Sys-STD
Rear Grip Bar-Ovhg
Rear Grip Bar-Cabin
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Convenience Box
Optn-Speedo Meter
OPTN-GROUD SPEED
CH/OV AR For EU
Valve As-2 Sec
Valve As-3 Sec
Valve As-4 Sec
Valve-Lift
Valve-Tilt
Fuel Cap With Key
Sound Supperssion
Rain Canopy
Section 6
Mast-Hydraulic
Lift Gp-Primary-FFT
Tilt Cylinder As-LH
Tilt Cylinder As-RH
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Cylinder As
Bracket As-3.0Ton
Carriage Mounting
Fork Gp
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
