Doosan Forklift G20G G25G G30G Spare Parts Catalog YSB1121
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton GAS
Model: Doosan G20G, G25G, G30G Forklift
Part Number: YSB1121
Number of Pages: 757 Pages
Section 1
Chassis Component
Steering Axle Gp(Code:A)
Steering Axle Gp(Code:L)
Cylinder As-Steer
Steering Axle Gp(Code: L)
Cylinder As-Steer(Code:L)
Frame Gp
Panel Gp-Top-Gas
Panel Gp-Top-LP
Air Cleaner Gp-Gas
Air Cleaner Gp-LP
MuffLer Gp
Lines Gp-Torque Converter
Radiator Gp
Reservoir Gp
Lines Gp-Fuel
Battery Tray Gp
Wiring Gp-LP
Wiring Gp-Dual Fuel
Instrument Gp-GAS
Instrument Gp-LP
Mounting Gp-Transmission
Accel Pedal Sub As
Control Gp-Steering
Steering Unit
Handle-Steer
Steering Column
Control Gp-Brake & Inching
Master Cylinder As
Lines Gp-Brake(2.0/2.5Ton)
Lines Gp-Brake(3.0Ton)
Parking Brake Gp
Floor Plate Gp-LP
Cover Gp-Hyd Oil Tank
Lines Gp-Hydraulic
Pump Mtg Gp
Gear Pump
Mtg. Gp-LP Tank
Section 2
Capacity Module
Guard Gp-Overhead
Counter Weight Gp
Tire&Wheel Gp-2.0/2.5Ton
Tire&Wheel Gp-Pneu-3.0 Ton
Tire&Wheel Gp-Dual-2.0/2.5Ton
Tire&Wheel Gp-(Pneu)-Dual-3.0Ton
Tire&Wheel Gp-Solid-2.0/2.5Ton
Tire&Wheel Gp-Solid-3.0Ton
Fender Gp-Dual Tire-2.0/2.5Ton
Fender Gp-Dual Tire-3.0Ton
Location Chart - 1 of 4
Location Chart - 2 of 4
Location Chart - 3 of 4
Location Chart - 4 of 4
Section 3
Engine Ar.-Primary-Dual Fuel
Engine Ar.-Primary-LP
PisTon & Rod Gp
Gauge Gp
Crankshaft Gp
Oil Pan Gp
Oil Filter & Pump Gp
Starter Gp
Cover Gp
Camshaft Gp
Ignition Wire Gp
Cylinder Block Gp
Thermostat Gp
Exhaust Manifold Gp
Timing Belt & Cover Gp
Pump Gp-Water
Ignition Coil Gp
Pulley Gp
Pcv Valve Gp
Intake Manifold Gp-Dual Fuel
Intake Manifold Gp-LP
Carburetor Gp
Regulator Gp-Dual Fuel
Regulator Gp-LP
Engine Control Module Gp-Dual Fuel
Engine Control Module Gp-LP
Label Gp
Fan Drive Gp
Alternator Gp
Alternator As
Fly Wheel Gp
Fuel Rail Gp-Dual Fuel
Cam Sensor Gp-Dual Fuel
Section 4
Power Train
Transmission As
Hydraulic Clutch As
Reduction & Differential As
Control Valve Gp-Solenoid
Inching Valve As
Charging Pump As
Drive Axle Gp-2.0/2.5 Ton(Code : X)
Drive Axle Gp-2.0/2.5 Ton(Code : L)
Wheel Brake As - LH (Code : L)
Wheel Brake As - RH (Code : L)
Wheel Brake As - LH (Code : X)
Wheel Brake As - RH (Code : X)
Drive Axle Gp-3.0 Ton(Code:X)
Drive Axle Gp-3.0 Ton(Code:L)
Wheel Brake As-LH-3.0 Ton
Wheel Brake As-RH-3.0 Ton
Wheel Brake As-LH-2.0/2.5 Ton
Wheel Brake As-RH-2.0/2.5 Ton
Wheel Brake As
Wheel Brake As - LH
Section 5
Option For Complete Truck
Pre Cleaner Gp
Seat Gp-Static STD
Seat Gp-Static&Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res.,W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res.,W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res.,W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res.,W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning
Seat Belt Gp W/O Switch
Cabin Gp
Cabin As
Door Gp - LH
Door Gp - RH
Door Gp-LH
Door Gp-RH
Heater Gp-Cabin
Fan Gp-Cabin
Extinguisher-Cabin
Lighting Gp
Rear Lamp Gp-Ovhg
Strobe Gp-Ovhg
Strobe Gp-Ovhg-Down
Rear Lamp Gp-Cabin
Strobe Gp-Cabin
Horn Gp
Valve Ar-2Sec
Contral Valve
Valve Ar-3 Sec(FF/FFT)Lines Gp
Valve Ar-4 Sec(FF/FFT)Lines Gp
Control Valve-4
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve-Revolve
Relief Valve As
Main Relief Valve As
Tool Gp
Change Over Ar.-Eu
Ch/Ov Ar Safty
Change Over Ar.-Eu LP Tank
Ch/Ov Ar Mtg Gp-Non Eu Lp Tank(S/O)
Ch/Ov Ar Mtg Gp-Eu Lp Tank(S/D)
Ch/Ov Ar Mtg Gp-Non Eu Lp Tank(S/D)
Ch/Ov Ar Mtg Gp-Crown Lp Tank(S/O)
Ch/Ov Ar Mtg Gp-Crown Lp Tank(S/D)
Plate As-LP Tank
Plate Ass’y-LP Tank-Swing Down
Change Over Ar.-Mtg Gp(Cosa)
Change Over Ar.-Vertical Stick
Fuel Cap With Key
Hyd.Locking Sys-FFL
Hyd.Locking Sys-FFT
Hyd.Locking Sys-STD
Rear Grip Bar-Ovhg
Rear Grip Bar-Cabin
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Convenience Box
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MFH2500mm~3700mm)(Code:B)
Lift Cylinder Gp-STD(MFH 4000mm~5000mm)
Lift Cylinder Gp-STD(Code:X)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cyl-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder As-LH(Code:B)
Tilt Cylinder As-RH(Code:B)
Tilt Cylinder As-LH(Code:X)
Tilt Cylinder As-RH(Code:X)
Tilt Cylinder Ass’y - LH (Code:W)
Tilt Cylinder Ass’y - RH (Code:W)
Tilt Cylinder-Option
S/S Lines Gp(STD)-2.0/2.5 Ton
S/S Lines Gp(STD)-3.0 Ton
S/S Lines Gp(FFL,FFT)-2.0/2.5 Ton
S/S Lines Gp(FFL,FFT)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL,FFT)-2.0/2.5Ton
Att Lines Gp-Sec(3 Way)-RH(FFL,FFT)-3.0Ton
Att Lines Gp-Sec(4 Way)-STD-2.0/2.5Ton
Att Lines Gp-Sec(4 Way)-STD-3.0Ton
Att Lines Gp-Sec(3 Way)-LH(FFL-FFT)-2.0/2.5Ton
Att Lines Gp-Sec(3 Way)-LH(FFL-FFT)-3.0Ton
Att Lines Gp-Sec(4 Way)-FFL,FFT-2.0/2.5Ton
Att Lines Gp-Sec(4 Way)-FFL,FFT-3.0Ton
Lines Gp-Att-Secondary(3Way-LH)-2.0/2.5/3.0Ton
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift&Tilt(STD)
Mounting Gp-Lift&Tilt-FFL
Mounting Gp-Lift&Tilt-FFT
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way-STD
Att Lines Gp-Pri-3 Way-FFL
Att Lines Gp-Pri-3 Way-FFT
Att Lines Gp-Pri-4 Way-STD
Att Lines Gp-Pri-4 Way-FFL
Att Lines Gp-Pri-4 Way-FFT
Sideshift Gp(2.0/2.5 Ton)
Cylinder As
Sideshifter Cylinder As-3.0 Ton
Sideshift Gp(3.0 Ton)
Side Shifter As-2.0/2.5 Ton
Side Shifter As-3.0 Ton
Cylinder Ass’y
Att Lines Gp-Sec(3 Way)-LH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-3.0 Ton
Carriage As-2.0/2.5/3.0Ton
Carriage Ar-Integral Side Shifter(2.0/2.5/3.0Ton)
Carriage Group-Integral Side Shift-STD-2.0/2.5Ton
Carriage Group-Integral Side Shift-FFL-2.0/2.5Ton
Carriage Group-Integral Side Shift-FFT-2.0/2.5Ton
Carriage Group-Integral Side Shift-STD-3.0Ton
Carriage Group-Integral Side Shift-FFL-3.0Ton
Carriage Group-Integral Side Shift-FFT-3.0Ton
Side Shifter Cylinder
Bracket As-2.0/2.5Ton
Bracket As-3.0Ton
Carriage As-STD/FFL/FFT-2.0/2.5/3.0Ton
Carriage Mounting
Fork Gp
SHIFTER ASSY,SIDE
