Doosan Forklift D33G D35G Spare Parts Catalog SB5137Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D33G D35G Forklift
Part Number: SB5137Y
Number of Pages: 475 Pages
Section 1
Chassis Component
Mtg Gp.-Steer Axle
Steering Axle Gp(Code L)
Cylinder Ass’y-Steer
Steering Axle Gp(Code A)
Steering Axle Gp
Cylinder As-Steer
Frame Gp
Panel Gp-Top
Air Cleaner Gp
Muffler Gp
Lines Gp - Torque Converter Cooler
Radiator Gp
Radiator Ass’y
Reservoir Gp
Lines Gp - Fuel
Battery Gp
Wiring Gp
Instrument Gp
Mtg Gp - Powertrain
Control Gp - Accel
Pedal Ass’y
Control Gp-Steering
Steering Unit
Column As
Control Gp - Brake & Inching
Master Cylinder Ass’y
Lines Gp-Brake
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp-F/R(P/S)
Section 2
Capacity Module
Guard Gp-Overhead
Counter Weight Gp
Tire & Wheel Gp-Non Marking
Tire & Wheel Gp;Solid(Front)/PNEU(Rear)
Tire & Wheel Gp;Dual Solid(Front)/PNEU(Rear)
Tire Group(Solid)
Tire & Wheel Gp(Solid)
Tire & Wheel Gp-Dual-Solid
Fender Gp-Dual Tire
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine Ar.-Basic
Alternator Mounting Gp
Alternator Ass’y
Cylinder Block Gp
Gear Housing Gp
Flywheel Housing & Oil Pump Gp
Cylinder Head & Bonnet Gp
Suction & Exhaust Manifold Gp
Camshaft & Driving Gear Gp
Crankshaft & Piston Gp
LUB. Oil System Gp
Cooling Water System Gp
Fuel Injection Pump Gp
Fuel Injection Valve Gp
Fuel Filter Gp
Starting Motor Gp
Gasket Set Gp
Section 4
Power Train
Transmission Ass’y
Hydraulic Clutch Ass’y
Reduction & Differential Ass’y
Control Valve Gp-Solenoid
Inching Valve Ass’y
Charging Pump Ass’y
Wheel Brake Ass’y-LH
Wheel Brake Ass’y-RH
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Static & Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res., W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res., W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning Indicator Lamp For Unfastening Belt
Seat Belt Gp W/O Switch
Lamp Gp
Rear Lamp Gp - OVHG
Strobe Gp - OVHG(Amber)
Strobe Gp - OVHG(Red)
Horn Gp
Valve Ar-2Sec 2Lev
Valve Gp-2Sec 2 Lev
Valve Ar-3Sec 3Lev
Valve Gp-3Sec 3 Lev
Valve Ar-4Sec 4Lev
Valve Gp-4Sec 4 Lev
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Optn-Speedo Meter
Optn-Autoshift Controlle
LED Lamp Gp-W/Com. OVHG&A CABIN
LED Lamp Gp-W/Com.Full CABIN
LED Lamp Gp-W/Com. B&C CABIN
LED Lamp Gp-Front,OVHG&A CABIN
LED Lamp Gp-Front,B&C CABIN
Change Over Ar.-Safety(2.0/2.5Ton)
Change Over Ar.-Safety(3.0Ton)
OSS Gp
Rain Canopy
Bar Plate Radiator
Valve Gp,2 SEC,2 Lever Plus
Valve Gp,3 SEC,3 Lever Plus
Valve Gp,4 SEC,4 Lever Plus
Valve,Control;2 SEC;3691
Valve,Control;3 SEC;3691
Valve,Control;4 SEC;3691
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~3700mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH
Tilt Cylinder Ass’y-RH
Tilt Cylinder Gp
S/S Lines Gp(STD)
S/S Lines Gp(FFL, FFT)
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)
Att Lines Gp-Sec(4 Way)-STD
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)
Att Lines Gp-Sec(4 Way)-FFL, FFT
Lines GP-ATT-Secondary(3 Way-LH)
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Cylinder Ass’y
Side Shifter Gp
Side Shifter As
Cylinder Ass’y
Att Lines Gp-Sec(3 Way)-LH(STD)
Att Lines Gp-Sec(3 Way)-RH(STD)
Carriage Ass’y
MAST-FFL
Carriage Assy;Int S/S-STD
Carriage Assy;Integral S/S;
Carriage Arrangement;Int S/S-FFT
Backrest Ass’y
Carriage Ass’y-STD/FFL/FFT
Carriage Mounting
Fork Gp
