Doosan Forklift D33F D33FM D35F D35FM Spare Parts Catalog SB5138Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D33F, D33FM, D35F, D35FM Forklift
Part Number: SB5138Y
Number of Pages: 603 Pages
Section 1
Chassis Component
Steering Axle Gp(Code A)
Steering Axle Gp(Code L)
Cylinder As-Steer
Steering Axle Gp
Frame Gp
Panel Gp-Top
Engine & Air Cleaner Gp
Muffler Gp
Lines Gp-Torque Converter Cooler
Radiator Gp(D33 35F)
Radiator Gp(D33 35FM)
Reservoir Gp
Lines Gp-Fuel
Battery Gp
Wiring Gp Part
Instrument Gp
Mounting Gp-Transmission(D33 35F)
Mounting Gp-Transmission(D33 35FM)
Control Gp-Accel(D33 35F)
Pedal Ass’y(D33 35F)
Control Gp-Accel(D33 35FM)
Pedal Ass’y(D33 35FM)
Control Gp-Steering
Handle Steer
Steering Shaft Column
Steering Unit
Control Gp-Brake & Inching(Tor-Con Type)
Control Gp-Brake & Inching(Clutch Type)
Master Cylinder As(整?式)
Master Cylinder As(分?式)
Lines Gp-Brake
Parking Brake Gp
Floor Plate Gp(机械式)
Floor Plate Gp(液力式)
Cover Gp-HYD Oil Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp F/R
Control Linkage
Section 2
Capacity Module
Guard Gp-Overhead
Mirror GP
Counter Weight Gp
Tire & Wheel Gp-Non Marking
Tire & Wheel Gp(PNEU)
Tire & Wheel Gp;Solid(Front)/PNEU(Rear)
Tire & Wheel Gp(PENU)-Dual
Tire & Wheel Gp;Dual Solid(Front)/PNEU(Rear)
Tire & Wheel Gp(Solid)
Tire & Wheel Gp-Dual-Solid
Fender Gp-Dual Tire
Tire Group(Solid)
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine Block Group
Erankcase Pre-Assembly
Oil Seal Group
Flywheel Housing Group
Gear Housing Cover Group
Timing Gear Housing Group
Crankshaft Group
Main Bearing Set
Thrust Plate Set
Flywheel Group
Flywheel Assembly
flywheel housing
Piston Assembly
Piston Ring Set
Connecting Rod
Connecting Rod Bearing Set
Cylinder Head Group
Cylinder Head Subassembly
Cylinder Head Front Cover Group
Eye Ring Group
Cylinder Head Cover Group
Oil filling Port Cover Assembly
Valve Train Group
Rocker Arm Shaft Set
Rocker Arm Set
Gear Drive Group
Intermediate Gear Set
Crankshaft Pulley Group
Oil Pan Group
Oil Pan Assembly
Oil Dipstick Group
Oil Pump Group
Oil Strainer Group
Oil Filter Group
Oil Filter
Water Pump Group
Water Draining Valve Group
Thermostat Group
Fan and Hub Group
Water Pump Inlet Pipe Group
Fuel Injection Pump Group
Fuel Injector Group
Fuel Filter Group
Fuel Filter Assembly
High Pressure Fuel Pipe Group
High-pressure Fuel Pipe Assembly
Low Pressure Fuel Pipe Group
Intake Manifold Group
Exhaust Manifold Group
Hydraulic Pump Group
Tensioner And Belt Group
Starter Motor Group
Engine Bracket Group
Parts Kit
Electronic Control Unit Group
Engine Harness Group
Alternator Group
Alternator Bracket Group
Section 4
Power Train
Transmission Ass’y
Transmission Ass’y(1)(机械式)
Transmission Ass’y(2)(机械式)
Clutch Ass’y
Reduction & Differential
Hydraulic Clutch Ass’y
Reduction & Differential Ass’y
Control Valve Gp-Solenoid
Inching Valve Ass’y
Charging Pump Ass’y
Drive Axle Gp
Wheel Brake Ass’y-LH
Wheel Brake Ass’y-RH
Drive Axle Gp-(Code L)
Drive Axle Gp(Code X)
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Seat Gp
Cabin Gp
Cabin As
Door Gp-LH
Door Gp-RH
Heater Gp-Cabin
Fan Gp-Cabin
Strobe Gp-Cabin
Extinguisher-Cabin
Rear Lamp Gp-Cabin
Lamp Gp
Rear Lamp Gp-Ovhg
Strobe Gp-Ovhg
Horn Gp
Valve Gp-2 Sec-FFL/FFT
Valve Gp-2 Sec-STD
Valve Ar-3 Sec(3 Sec-3 Lever)-FFL/FFT
Valve Ar-3 Sec(3 Sec-3 Lever)-STD
Control Valve Ass’y - 3 Sec
Valve Ar-4 Sec(4 Sec-4 Lever)-FFL/FFT
Valve Ar-4 Sec(4 Sec-4 Lever)-STD
Control Valve-4 Sec
Valve Gp-Distributary
Valve Gp-Lift
Valve Gp-Tilt
Valve Gp-Section
Relief Valve Ass’y
Main Relief Valve Ass’y
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Seat Gp-Suspension
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Engine Assy
Body Assembly And Accessory
Flywheel Housing
Fuel Supply System Assembly
Circuit Group Assembly
Oil Pump Assembly
Glow Plug Assembly
Air Intake Assembly
Fan
Thermostat Assembly
Starter Assembly
Cylinder Head And Gas Exchanging System Assembly
Generator And Belt Assembly
Timing Gear Train Assembly
Oil Sump Assembly
Piston And Connecting Rod Assembly
Crankshaft Assembly
Ntake Exhaust Assembly
Cylinder Head Cover And Name Plate Assembly
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~5000mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH
Tilt Cylinder Ass’y-RH
Tilt Cylinder Gp
S/S Lines Gp(STD)
S/S Lines Gp(FFL, FFT)
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)
Att Lines Gp-Sec(4 Way)-STD
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)
Att Lines Gp-Sec(4 Way)-FFL, FFT
Lines GP-ATT-Secondary(3 Way-LH)
Lines Gp-Sideshifter - STD,Double Tire
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Cylinder Ass’y
Side Shifter Gp
Side Shifter Gp-Wide Carriage
Att Lines Gp-Sec(3 Way)-LH(STD)
Att Lines Gp-Sec(3 Way)-RH(STD)
Carriage Ass’y
Carriage Ar.-Integral Side Shifter
Carriage Group-Integral Side Shifter
Carriage Group-Integral Side Shift-STD
Carriage Group-Integral Side Shift-FFL
Carriage Group-Integral Side Shift-FFT
Backrest Ass’y
Load Backrest Gp-1000mm Height
Carriage Ass’y-STD/FFL/FFT
Carriage Mounting
Fork Gp
Integral Shifting
Brand: Doosan
Section 1
Chassis Component
Cylinder As-Steer
Steering Axle Gp
Frame Gp
Panel Gp-Top
Muffler Gp
Reservoir Gp
Lines Gp-Fuel
Battery Gp
Wiring Gp Part
Instrument Gp
Control Gp-Steering
Handle Steer
Steering Unit
Lines Gp-Brake
Parking Brake Gp
Floor Plate Gp(机械式)
Floor Plate Gp(液力式)
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp F/R
Control Linkage
Section 2
Capacity Module
Guard Gp-Overhead
Mirror GP
Counter Weight Gp
Fender Gp-Dual Tire
Tire Group(Solid)
Section 3
Engine Block Group
Oil Seal Group
Crankshaft Group
Main Bearing Set
Thrust Plate Set
Flywheel Group
Flywheel Assembly
flywheel housing
Piston Assembly
Piston Ring Set
Connecting Rod
Cylinder Head Group
Eye Ring Group
Valve Train Group
Rocker Arm Set
Gear Drive Group
Oil Pan Group
Oil Pan Assembly
Oil Dipstick Group
Oil Pump Group
Oil Strainer Group
Oil Filter Group
Oil Filter
Water Pump Group
Thermostat Group
Fan and Hub Group
Fuel Injector Group
Fuel Filter Group
Starter Motor Group
Parts Kit
Alternator Group
Section 4
Power Train
Transmission Ass’y
Clutch Ass’y
Inching Valve Ass’y
Charging Pump Ass’y
Drive Axle Gp
Section 5
Pre Cleaner Gp
Seat Gp
Cabin Gp
Cabin As
Door Gp-LH
Door Gp-RH
Heater Gp-Cabin
Fan Gp-Cabin
Strobe Gp-Cabin
Extinguisher-Cabin
Rear Lamp Gp-Cabin
Lamp Gp
Rear Lamp Gp-Ovhg
Strobe Gp-Ovhg
Horn Gp
Valve Gp-2 Sec-STD
Control Valve-4 Sec
Valve Gp-Lift
Valve Gp-Tilt
Valve Gp-Section
Relief Valve Ass’y
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Seat Gp-Suspension
Engine Assy
Flywheel Housing
Oil Pump Assembly
Glow Plug Assembly
Air Intake Assembly
Fan
Thermostat Assembly
Starter Assembly
Oil Sump Assembly
Crankshaft Assembly
Section 6
Mast-Hydraulic
Lift Gp-Primary-FFT
Tilt Cylinder Gp
S/S Lines Gp(STD)
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Side Shifter Gp
Carriage Ass’y
Backrest Ass’y
Carriage Mounting
Fork Gp
Integral Shifting
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
