Doosan Forklift D30G-CH50 Spare Parts Catalog SB5143Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D30G-CH50 Forklift
Part Number: SB5143Y
Number of Pages: 417 Pages
Section 1
Chassis Component
Mtg Gp.-Steer Axle
Steering Axle Gp(Code L)
Cylinder Ass’y-Steer
Steering Axle Gp(Code A)
Steering Axle Gp
Cylinder As-Steer
Frame Gp
Panel Gp-Top
Air Cleaner Gp
Muffler Gp
Lines Gp - Torque Converter Cooler
Radiator Gp
Reservoir Gp
Lines Gp - Fuel
Battery Gp
Wiring Gp
Instrument Gp
Mtg Gp - Powertrain
Control Gp - Accel
Control Gp-Steering
Steering Unit
Column As
Control Gp - Brake & Inching
Master Cylinder Ass’y
Lines Gp-Brake
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Control Gp-F/R(P/S)
Section 2
Capacity Module
Guard Gp-Overhead
Counter Weight Gp
Tire & Wheel Gp(PNEU)
Tire & Wheel Gp(PENU)-Dual
Tire & Wheel Gp(Solid)
Tire & Wheel Gp-Dual-Solid
Fender Gp-Dual Tire
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine Ar. - Basic
Fan Drive Gp
Engine Mounting Gp
Alternator Gp
Cylinder Block Gp
Gear Housing Gp
Flywheel Housing & Oil Sump Gp
Cylinder Head & Bonnet Gp
Suction Manifold Gp
Exhaust Manifold Gp
Camshaft & Driving Gear Gp
Crankshaft & Piston Gp
LUB.Oil System Gp
Cooling Water System Gp
Fuel Injection Pump Gp
Governor Gp
Fuel Injection Valve Gp
Fuel Line Gp
Starting Motor Gp
Electronic Control Unit Gp
Gasket Set & Tools Gp
Section 4
Power Train
Transmission Ass’y
Hydraulic Clutch Ass’y
Reduction & Differential Ass’y
Control Valve Gp-Solenoid
Inching Valve Ass’y
Charging Pump Ass’y
Drive Axle Gp
Wheel Brake Ass’y-LH
Wheel Brake Ass’y-RH
Drive Axle Gp-3.0 Ton(Code L)
Drive Axle Gp-3.0 Ton(Code X)
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Static & Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res., W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res., W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning Indicator Lamp For Unfastening Belt
Seat Belt Gp W/O Switch
Light Group
Rear Lamp Gp - OVHG
Strobe Gp - OVHG(Amber)
Strobe Gp - OVHG(Red)
Horn Gp
Valve Ar-2Sec 2Lev
Valve Gp-2Sec 2 Lev
Valve Ar-3Sec 3Lev
Valve Gp-3Sec 3 Lev
Valve Ar-4Sec 4Lev
Valve Gp-4Sec 4 Lev
Valve As-2Sec
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Optn-Speedo Meter
Optn-Autoshift Controlle
LED Lamp Gp-W/Com. OVHG&A CABIN
LED Lamp Gp-W/Com.Full CABIN
LED Lamp Gp-W/Com. B&C CABIN
LED Lamp Gp-Front,OVHG&A CABIN
LED Lamp Gp-Front,B&C CABIN
Change Over Ar.-Safety
Mirror Gp
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~3700mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH
Tilt Cylinder Ass’y-RH
Tilt Cylinder Gp
S/S Lines Gp(STD)
S/S Lines Gp(FFL, FFT)
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)
Att Lines Gp-Sec(4 Way)-STD
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)
Att Lines Gp-Sec(4 Way)-FFL, FFT
Lines GP-ATT-Secondary(3 Way-LH)
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Cylinder Ass’y
Side Shifter Gp
Side Shifter As
Cylinder Ass’y
Att Lines Gp-Sec(3 Way)-LH(STD)
Att Lines Gp-Sec(3 Way)-RH(STD)
Carriage Ass’y
MAST-FFL
Carriage Arrangement;INT S/S-STD
Carriage Assy;Integra S/S-FFL
Carriage Arrangement;Int S/S-FFT
Carriage Assy;Int S/S-STD
Backrest Ass’y
Carriage Ass’y-STD/FFL/FFT
Carriage Mounting
Fork Gp
Brand: Doosan
Section 1
Chassis Component
Mtg Gp.-Steer Axle
Steering Axle Gp
Cylinder As-Steer
Frame Gp
Panel Gp-Top
Air Cleaner Gp
Muffler Gp
Radiator Gp
Reservoir Gp
Lines Gp - Fuel
Battery Gp
Wiring Gp
Instrument Gp
Mtg Gp - Powertrain
Control Gp - Accel
Control Gp-Steering
Steering Unit
Column As
Lines Gp-Brake
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Control Gp-F/R(P/S)
Section 2
Capacity Module
Guard Gp-Overhead
Counter Weight Gp
Fender Gp-Dual Tire
Section 3
Engine Ar. - Basic
Fan Drive Gp
Engine Mounting Gp
Alternator Gp
Cylinder Block Gp
Gear Housing Gp
Suction Manifold Gp
Exhaust Manifold Gp
LUB.Oil System Gp
Governor Gp
Fuel Line Gp
Starting Motor Gp
Section 4
Power Train
Transmission Ass’y
Inching Valve Ass’y
Charging Pump Ass’y
Drive Axle Gp
Section 5
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Suspension
Light Group
Rear Lamp Gp - OVHG
Horn Gp
Valve Ar-2Sec 2Lev
Valve Gp-2Sec 2 Lev
Valve Ar-3Sec 3Lev
Valve Gp-3Sec 3 Lev
Valve Ar-4Sec 4Lev
Valve Gp-4Sec 4 Lev
Valve As-2Sec
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Optn-Speedo Meter
Mirror Gp
Section 6
Mast-Hydraulic
Lift Gp-Primary-FFT
Tilt Cylinder Gp
S/S Lines Gp(STD)
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Side Shifter Gp
Side Shifter As
Cylinder Ass’y
Carriage Ass’y
MAST-FFL
Backrest Ass’y
Carriage Mounting
Fork Gp
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
