Doosan Forklift D20SE D25SE D30SE Tier 3 Spare Parts Catalog SB5131Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D20SE, D25SE, D30SE Tier 3 Forklift
Part Number: SB5131Y
Number of Pages: 562 Pages
Section 1
Chassis Component
Steer Axle Gp
Cylinder As - Steer
Cylinder As-Steer
Mtg Gp - Steer Axle
Frame As-2.0/2.5Ton
Frame As-3.0Ton
Panel Gp-Top
Hood AS
Cleaner Gp-Air
Muffler Gp
Lines Gp - T.C Cooling
Radiator Gp
Reservoir Gp
Lines Gp-Fuel
Battery Gp
Wiring Gp
Mounting Gp - Power Train
Control Gp - Accel
Column Group
Control Gp - Inching & Brake
Pedal As-Inch&Brake
Lines Gp-Power Steering
Lines Gp - Power Steering
Control Gp - Parking Brake
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Mast Tilt
Lines Gp-Mast Lift
Pump Gp - Gear
Suppression Gp
Cover Gp-FCU
Instrument Gp - F.C.U
Section 2
Capacity Module
Guard Gp-Over
Counterweight Gp
Tire&Wheel Gp(Pneu)-2.0/2.5 Ton
Tire & Wheel Gp(Pneu) - 3.0 Ton
Tire&Wheel Gp(Pneu)-Dual-2.0/2.5/3.0 Ton
Tire & Wheel Gp-Solid-2.0/2.5 Ton
Tire & Wheel Gp-Solid-3.0 Ton
Tire & Wheel Gp-Dual-Solid-2.0/2.5/3.0 Ton
Fender Gp
Location Chart Part 1 Of 4
Location Chart Part 2 Of 4
Location Chart Part 3 Of 4
Location Chart Part 4 Of 4
Section 3
Engine Ar.-Basic
Alternator Mounting Gp
Cylinder Block Gp
Gear Housing Gp
Flywheel Housing & Oil Pump Gp
Cylinder Head & Bonnet Gp
Suction & Exhaust Manifold Gp
Camshaft & Driving Gear Gp
Crankshaft & Piston Gp
LUB. Oil System Gp
Cooling Water System Gp
Fuel Injection Pump Gp
Fuel Injection Valve Gp
Fuel Filter Gp
Starting Motor Gp
Gasket Set Gp
Section 4
Power Train
Drive Axle Gp
Differential As
Drive Axle Housing As
Transmission Gp-PART 1 OF 4
Transmission Gp-PART 2 OF 4
Transmission Gp-PART 3 OF 4
Transmission Gp-PART 4 OF 4
Valve As
Lines Gp-Brake
Master Cylinder
Brake Valve
Lines Gp - Brake Oil Circulation
Bracket As - Inching
Section 5
Option For Complete Truck
Anti-Sparkle Muffler Gp
Change Over Ar. - Pre Cleaner
Seat Gp - Static STD
Seat Gp - Static & Armrest
Seat Gp - Suspension
Seat Gp - Suspension & Armrest
Seat Belt As - With Switch
Lighting Gp
Rear Lamp Gp - OVHG
Strobe Gp - OVHG(Amber)
Strobe Gp - OVHG(Red)
Safety Gp-Muffler
Radiator Screen
Rear Grip Bar-With Horn Switch
Horn Gp
Valve Ar-2Sec 2Lever
Valve Gp-2Sec 2Lever
Valve Ar-3Sec 3Lever
Valve Gp-3Sec 3Lever
Valve Ar-4Sec 4Lever
Valve Gp-4Sec 4Lever
Valve As-2Sec
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Back Mirror Gp - Small
Speed Limit
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Full Cabin Gp
Full Cabin As
Door As-LH
Door As-RH
Radiator With Screen
Tire&Wheel Gp-Drive(2.0/2.5Ton)
Tire&Wheel Gp-Front(2.0/2.5Ton)
Tire&Wheel Gp-Inner(2.0/2.5Ton)
Tire&Wheel Gp-Inner(3.0Ton)
Tire&Wheel Gp-Outer(2.0/2.5Ton)
Tire&Wheel Gp-Outer(3.0Ton)
Rain Canopy
Oil Inlet Feed Valve Plate
CH/OV-Horizon Muffler
Section 6
Mast-Hydraulic
Lift Cylinder Gp - STD
Lift Cylinder Gp - Primary - FFL
Lift Gp - Primary - FFT
Lift Gp-Sceondary-FFL
Lift Gp - Secondary - FFT
MTG Gp - Tilt Cylinder
Tilt Cylinder Gp
Tilt Cylinder As - LH
Tilt Cylinder As - RH
Att Lines Gp-Sec(3 Way)-RH(FFL,FFT)-2.0/2.5
Att Lines Gp-Sec(3 Way)-RH(FFL,FFT)-3.0
Att Lines Gp - Sec(4 Way) - STD - 2.0/2.5
Att Lines Gp - Sec(4 Way) - STD - 3.0
Att Lines Gp-Sec(3Way)-LH(FFL,FFT)-2.0/2.5
Att Lines Gp-Sec(3Way)-LH(FFL,FFT)-3.0
Att Lines Gp-Sec(4 Way)-FFL,FFT-2.0/2.5
Att Lines Gp-Sec(4 Way)-FFL,FFT-3.0
Section 7
Mast-Implements
Mast Gp - Bsc(STD)
Mast Gp - Bsc(FFL)
Mast Gp - Bsc(FFT)
Mast Gp - STD
Mast Gp - FFL
Mast Gp - FFT
Mounting Gp - Lift & Tilt(STD)
Mounting Gp - Lift & Tilt(FFL)
Mounting Gp - Lift & Tilt(FFT)
Lift Relay Gp-STD
Lift Relay Gp - FFL
Lift Relay Gp - FFT
Att Lines Gp - Pri - 3 Way(STD)
Att Lines Gp - Pri - 3 Way(FFL)
Att Lines Gp - Pri - 3 Way(FFT)
Att Lines Gp - Pri - 4 Way(STD)
Att Lines Gp - Pri - 4 Way(FFL)
Att Lines Gp - Pri - 4 Way(FFT)
Side Shifter Gp - 2.0/2.5 Ton
Side Shifter Cylinder As-2.0/2.5
Side Shifter Cylinder As-3.0
Side shifter Gp - 3.0 Ton
Att Lines Gp-Sec-3 Way-LH(STD)-2.0/2.5
Att Lines Gp-Sec-3 Way-LH(STD)-3.0
Att Lines Gp-Sec-3 Way-RH(STD)-2.0/2.5
Att Lines Gp-Sec-3 Way-RH(STD)-3.0
Carriage As - 2.0/2.5/3.0 Ton
Carriage AR-Integral Side Shifter-2.0/2.5/3.0Ton
Backrest As - 2.0/2.5/3.0Ton
Carriage As-STD/FFL/FFT(2.0/2.5/3.0Ton)
Carriage Mounting
Fork Gp
