Doosan Forklift D20S5 D25S5 D30S5 D33S5 D35C5 Spare Parts Catalog SB1182
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D20S5, D25S5, D30S5, D33S5, D35C5 Yanmar 34kw T3 Forklift
Part Number: SB1182
Number of Pages: 4642 Pages
[CHASSIS] Chassis
ARRANGEMENT,CHANGEOVER
LEVER ASSY
CH/OV-BIGGER RADIATOR
RADIATOR ASSY
ARRANGEMENT,GENERAL
CAP GROUP,FUEL
PANEL ASSY
FRAME GROUP
PLATE ASSY,FLOOR
PEDAL ASSY
LINK ASSY
AXLE GROUP,STEER
KNUCKLE ASSY
HUB ASSY
CYLINDER,STEERING
SEAL KIT,OIL
MODULE,BASIC
BRAKE MODULE
LINE GROUP
BRAKE GROUP,PARKING
CONTROL GROUP,BRAKE
CYLINDER ASSY,MASTER
VALVE,BRAKE
HORN
HOSE GROUP,HYDRAULIC
BATTERY GROUP
MOUNT GROUP
MOUNTING GP
MOUNTING GROUP
MUFFLER GROUP
COVER ASSY
HOOD ASSY
PANEL
RADIATOR GROUP
WIRING GROUP
PIN ASSY
CLEANER GROUP,AIR
SHIELD
COVER ASSY,RADIATOR
AIR CON&BIGGER RAD
SQ-BIGGER RAD & AIR CON
CH/OV AR-BELLY PLATE
BELLY PLATE PROTECTION
WEIGHT GROUP,COUNTER
CHANGEOVER
CAP,FUEL
CH/OV AR-FAN RATIO
CH/OV AR-EXPORT TO CHINA
HARNESS ASSY,ENGINE
HOSE,FUEL
ARRANGEMENT
OPTION-VENTED SIDE PANEL
MAST LOWERING SPEED
OPEN CORE RADIATOR
BAFFLE
CH/OV AR-VERTICAL TUBE(LOW OHG
RADIATOR SCREEN
RUBBER BELLOWS COVER
SUPPRESSION ASSY
SPARK ARRESTOR
STRAP
CYLINDER GROUP,TILT
LIMITER GROUP
CYLINDER,TILT
SHIM SET
TOOL GROUP
OPTION,SOUND SUPPLIER
TILT GP - BASIC
RADIATOR
CH/OV AR-BIGGER RAD&AIR CON
[CHASSIS] Driving Module
PUMP,GEAR
VALVE ASSY,CONTROL
HOUSING ASSY,AXLE
FENDER
TIRE AR
TIRE AND WHEEL GROUP
TIRE
WHEEL & TIRE GROUP
TIRE GROUP
TIER AR
AXLE GROUP,DRIVE
JOINT,UNIVERSAL
AXLE ASSY,DRIVE
GEAR ASSY,DIFFERENTIAL
DIFFERENTIAL ASSY
CH/OV AR-DRIVEAXLE,AUTOSHIFT,D
[CHASSIS] Engine
INCREASE OF CRS PULLEY SIZE
INSIDE EXHAUST MUFFLER
[CHASSIS] Operating Module
ALARM GROUP
SQ-AUDIABLE BACK-UP ALARM GP
BACK ALARM-INSIDE,LOCAL
OPTION-ROUND REAR VIEW MIRROR
EVAPORATOR ASSY
CONDITIONER,AIR,ROOF MOUNTED
CONDENSER ASSY
COMPRESSOR MTG
CONTROLLER GROUP
AXLE,DRIVE
AUTO TILT LEVELING
BRACKET ASSY
COVER ASSY,ROOF
CABIN GROUP,MODULAR
COVER ASSY,FRONT
M/CABIN B
M/CABIN C
CABIN,MODULAR
FULL CABIN
CABIN ASSY
DOOR ASSY,OPEN
VALVE AR
VALVE ASSY
VALVE GROUP,TILT SECTION
VALVE GROUP
REST,ARM
VALVE,FINGER TIP
ALTERNATOR
WIRE GROUP
WIRING GROUP,OPTION
CH/OV AR-MONO PED,FCU
CONTROL GROUP
PEDAL ASSY,MONO
ENGINE SHUTDOWN
FCU,DIESEL
WHEEL GROUP
STEERING GROUP
PARKING SYSTEM
RESERVOIR
PEDAL GROUP
INSTRUMENT GROUP
COVER GROUP
FCU,FINGER TIP,DIESEL
SWITCH ASSY
EXTINGUISHER ASSY,FIRE
EXTINGUISHER,FIRE
MOUNTING LOCATION
FRONT WIPER W/O HEATER,F/CABIN
FRONT WIPER WITH HEATER,F/CABI
WIPER
FRONT WIPER W/O HEATER,M/CABIN
FRONT WIPER WITH HEATER,M/CABI
FRONT LAMINATED GLASS
HEATER GROUP
WASHER
KNOB-WHEEL
LAMP GP-COMB F/R,HOME
LAMP GROUP
LAMP ASSY,COMBINATION
LAMP ASSY
LAMP ASSY,HEAD
WIRING GR,CONST FLASH,FCU
Fig. 4-109 [301005-00209]
LAMP GP-COMB F/R,FCU
LAMP GP-FRONT
LAMP GP-4 FRONT FLOOD LIGHT,HA
LAMP GP-FRONT,HALOGEN
LAMP GP-FRONT,F/CABIN
LAMP GP-FRONT,HALOGEN,F/CABIN
Fig. 4-132 [A408581]
LAMP GP-FRONT,LED,F/CABIN
LAMP GP-COMB F/R,LED
LAMP GP-REAR,F/CABIN
LAMP GP-REAR,HALOGEN,F/CABIN
LAMP GP-2 REAR LIGHT,F/CABIN
LAMP GP-2 REAR LIGHT,HALOGEN,F
LAMP GP-2 REAR LIGHT WITH PRE-
LAMP GP,REAR
LAMP GP-REAR,LED
STROBE ASSY
STROBE
MIRROR
MIRROR ASSY
MIRROR GP,BACK,LARGE,NO GLASS
LEG GROUP
GUARD ASSY,OVERHEAD
GUARD GROUP,OVERHEAD
Fig. 4-159 [D812584]
Fig. 4-161 [D812302]
Fig. 4-162 [D812264]
Fig. 4-165 [D812289]
Fig. 4-167 [D812216]
Fig. 4-169 [D812233]
Fig. 4-171 [D812276]
Fig. 4-173 [D812916]
Fig. 4-175 [D812244]
Fig. 4-178 [A402870]
Fig. 4-180 [101534-00087]
WIRING GP-WITH COMB,REAR AIR C
WIRING GP-OPTIONAL LIGHT,HOME
OPTION-PANORAMIC MIRROR
GRIP
GRIP ASSY
REAR WIPER,F/CABIN
REAR WIPER,M/CABIN
BELT,SEAT
SEAT GROUP
SEAT ASSY
SEAT,SUSPENSION
SPARE PARTS
OPTION-SPEEDOMETER
CH/OV AR-SPEEDOMETER
SCALE
Fig. 4-221 [800232-00064]
SEAT,OPERATOR
VALVE ARRANGEMENT
STEREO,CAR
PLAYER,CD
FCU
SEAT GROUP-GRAMMER
SEAT GP-GRAMMER
FAN,DEFROST
FAN WITH TOP WIPER,F/CABIN
FAN,F/CABIN
DEFROSTER FAN FOR FULL CAB
FAN,ELECTRIC
TWIN FAN WITH TOP WIPER,F/CABI
CONTROLLER,SPEED
OPTION-LED BLUE SPOT LIGHTS
OPTION-WIRE FOR SPOT LIGHT
LEVER,TILT
Fig. 4-332 [A408581]
LAMP GP-COMB. F/R
LAMP GP-REAR
2 STROBE,AMBER,ABOVE,CROWN
CH/OV AR-MONO PEDAL
PEDAL SUB ASSY
CH/OV AR-ENGINE SHUTDOWN
Fig. 4-414 [101534-00147]
Fig. 4-415 [101534-00096]
[FRONT END] Mast
ACCUMULATOR GROUP
PIPE ASSY
LINE GROUP,ATTACHMENT
PIPE,LINE
HOSE,HYDRAULIC
MERCHANDIZING
ARRANGEMENT,MERCHANDISING
Fig. 5-029 [D802312]
LINE GROUP,FUEL
MAST ARRANGEMENT
SHEAVE,HOSE
CYLINDER ASSY,LIFT
MAST GROUP
BEARING
MAST ASSY
RELAY ASSY
CYLINDER,SECONDARY
LIFTER GROUP
MOUNT GROUP,LIFT
CYLINDER ASSY
SHEAVE GROUP
CYLINDER GROUP,LIFT
MAST ARR.
MAST
CYLINDER,LIFT
CYLINDER,PRIMARY
MOUNT
RELAY
LIFT GROUP,STANDARD
LIFT GROUP
LIFT ASSY
MAST ARR STD MFH 5300MM
LIFT,CYLINDER
MAST ASSY,INTER
UPRIGHT ASSY,INNER
[FRONT END] Fork
FORK EXTENSION GROUP
FORK CAP
FORK
POSITIONER,FORK
Fig. 6-019 [D802108]
FORK ASSY
FORK, ATTACHMENT
Fig. 6-042 [D802108]
[FRONT END] Carriage
LOAD BACKREST
REST ASSY,BACK
REST,BACK
CARRIAGE ARRANGEMENT
CARRIAGE ARR
MOUNT ASSY
FORK MOVER, ATTACHMENT
S/S & F/M, ATTACHMENT
POSITIONER GROUP,FORK
CARRIAGE GROUP
CYLINDER,GAS
CYLINDER,FORK
FORK,POSITIONAL
S/S & F/M
SHIFTER GROUP
SIDE SHIFTER & FORK MOVER ARR
COUPLING GROUP
COUPLING,QUICK
SIDE SHIFTER ASSY
SHIFT GROUP,SIDE
SIDE SHIFTER
SHIFTER,INTEGRAL SIDE CARRIAGE
Fig. 7-134 [230109-00263]
CARRIAGE ARRANGEMENT,STANDARD
LIFT,MOVEABLE HYDRAULIC
[MISCELLANEOUS] Location Chart
CHART,LOCATION
