Doosan Forklift D20NXP to D35NXP Parts Book SB1800E00 2020
Brand: Doosan
Type of Machine: Forklift
Type of Manual: Parts Book
Model: Doosan D20NXP, D25NXP, D30NXP, D33NXP, D35NXP Forklift
FDA42-00001~UP, FDA43-00001~UP
Engine Type: Kubota V2403 Stage-V
Model Code: FDA39 D20NXP, FDA40 D25NXP, FDA41 D30NXP, FDA42 D33NXP, FDA43 D35NXP
CV Value: 3500 V2403 ENGINE
Part Number: SB1800E00
Publication Date: 2020
Number of Pages: 768 Pages
GROUP,FUEL
GROUP
GROUP;GEAR PUMP
GROUP,OVERHEAD
DPF GP
;GP;KUBOTA V2403
GROUP;STAGE5;KUBOTA V2403
BRAKE GROUP
GROUP;STAGE5;KUBOTA;V2403
GROUP-HYD
GP BRAKE
GROUP;T.C COOLER;
ASSY
GROUP;ACCEL
AXLE ASSY,3.0T
Brake As-LH-3.0 Ton
Brake As-RH-3.0 Ton
AXLE,3.3-3.8T
BRAKE ASSY LH,3.3-3.8T
BRAKE ASSY RH,3.3-3.8T
ASSY;D30NXP STAGE-V
SUB ASSY,TRANSMISSION
ASSY,TRANSMISSION
&WHEEL GP;PNEUMATIC TIRE,ZX
SOLID DOUBLE,REAR PNEUMATIC
&WHEEL GP;SOLID TIRE,DOUBLE
&WHEEL GP;SOLID TIRE,NON MARKING
&WHEEL GP;SOLID TIRE,NON MARKING,DOUBLE
&WHEEL GP;FRONT SOLID,REAR PNEUMATIC
&WHEEL GP;FRONT PNEUMATIC,REAR SOLID
&WHEEL GP;PNEUMATIC TIRE,DOUBLE
&WHEEL GP;SOLID TIRE,ZX
WEIGHT,3.5T
WEIGHT,2.0T
WEIGHT,2.5T
WEIGHT,3.3T
WEIGHT,3.0T
ARRANGEMENT
GROUP;ENGINE
ASSY;KUBOTA V2403
SWITCH AND THERMOMETER
AND GUIDE
FAN
FLANGE AND THERMOSTAT
PIPE
HOSE
VALVE
AND SERVICE PARTS
VALVE AND EXHAUST
PUMP
PUMP ASSY
AND GLOW PLUG
CLEANER
FILTER
COOLER
SENSOR ASSY
AND PULLEY
ASSY,WATER
ASSY,OIL
MUFFLER
MAINIFOLD
RAIL
PAN
HEAD
CHARGER
CAMSHAFT
AND IDLE GEAR SHAFT
ARM SHAFT
AND CRANKSHAFT
CASE
BEARING CASE
COVER
HARNESS BEACKET
GROUP,CONTROL;3691 3SEC
GP;3SEC/3LEVER
GROUP,CONTROL;3SEC/3LEVER
GP;4 SECTION,4 LEVER
GROUP,CONTROL;4 SEC/4 LEVER
GP;3 SEC,3 LEV,ISO3691
GP;4 SEC,4 LEV,ISO3691
GROUP,CONTROL;4SEC;3691;NXP
;ISO3691;4SEC;D30G PLUS
GP;4 SEC,3 LEV,ISO3691
GROUP,CONTROL;4SEC/3LV;3691;NXP
GP-HIP NO BELT
GP,SUSPENSION;W/HIP
SEAT
Gp-Vinyl Suspension(W/O Hip Res., W/O Arm.)
Gp-Vinyl Suspension(W/O Hip Res., W/Arm.)
Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Gp-Cloth Suspension(W/Hip Res, W/O Arm.)
Gp-Static-STD
Gp-Suspension
STATIC
STATIC WTIH ARM
STATIC WTIH HIP
GP,SUSPENSION
GP,SUSPENSION;W/ARM
Gp-Suspension Arm Rest-Crown
CLEANER-WET
CONDITIONER
PLATE
AR-FUEL CAP WITH KEY;PLUS
GROUP;3WAY
;4WAY
WIRING;FOR REAR LAMP& STROBE
&WIPER FOR B&C CABIN
FOR MODULAR CABIN
Gp-Cabin
CABIN A
CABIN B
CABIN C
BLUE SPOT LIGHTS;C &FULL CABIN
BLUE SPOT LIGHTS;OVHG;A&B CABIN
CLEANER GP
Lamp Gp-Cabin
Lamp Gp-OVHG
SUSPENSION-NXP
ASSY;ROTATING TYPE OHG
GP;AMBER,ABOVE CABIN
Gp-OVHG(Amber)
Gp-OVHG(Red)
;OVHG(AMBER),DOWN
;OVHG(RED),DOWN
REAR,STANDARD LAMP,OVHG
GP
ARR;STD 2500;2-3T
GROUP;STD 2500;2-3T
ASSY;LIFT
ARR;STD 2500;3.5T
;GROUP,TD/STD MAST;3.5T
ARR;STD 2700;2-3T
GROUP;STD 2700;2-3.5T
ARR;STD 2700;3.5T
ARR;STD 3000;2-3T
GROUP;STD 3000;2-3.5T
ARR;STD 3000;3.5T
ARR;STD 3300;2-3T
GROUP;STD 3300;2-3.5T
ARR;STD 3300;3.5T
ARR;STD 3500;2-3T
GROUP;STD 3500;2-3.5T
ARR;STD 3500;3.5T
ARR;STD 3700;2-3T
GROUP;STD 3700;2-3.5T
ARR;STD 3700;3.5T
ARR;STD 4000;2-3T
GROUP;STD 4000;2-3.5T
ARR;STD 4000;3.5T
ARR;STD 4250;2-3T
GROUP;STD 4250;2-3.5T
ARR;STD 4250;3.5T
ARR;STD 4500;2-3T
GROUP;STD 4500;2-3.5T
ARR;STD 4500;3.5T
ARR;STD 4750;2-3T
GROUP;STD 4750;2-3.5T
ARR;STD 4750;3.5T
ARR;STD 5000;2-3T
GROUP;STD 5000;2-3.5T
ARR;STD 5000;3.5T
ARRANGEMENT;FFL2560;2.0-3.5T
GROUP;-FFL 2560;2-3.5T
ARRANGEMENT;FFL2930;2.0-3.0T
GROUP;-FFL 2930;2-3.5T
ARRANGEMENT;FFL3210;2.0-3.0T
GROUP;-FFL 3210;2-3.5T
ARRANGEMENT;FFL3580;2.0-3.0T
GROUP;-FFL 3580;2-3.5T
ARRANGEMENT;FFT3880;2-3T
GROUP;FFT 3880;2-3.5T
ARRANGEMENT;FFT3880;3.5T
ARRANGEMENT;FFT4270;3.5T
GROUP;FFT 4270;2-3.5T
ARRANGEMENT;FFT4710;2-3T
GROUP;FFT 4710;2-3.5T
ARRANGEMENT;FFT4710;3.5T
ARRANGEMENT;FFT5540;2-3T
GROUP;FFT 5540;2-3.5T
ARRANGEMENT;FFT5540;3.5T
ARRANGEMENT;FFT5990;2-3T
GROUP;FFT 5990;2-3.5T
ARRANGEMENT;FFT5990;3.5T
ARRANGEMENT;FFT6170;2-3T
GROUP;FFT 6170;2-3.5T
ARRANGEMENT;FFT6170;3.5T
ARRANGEMENT;FFT6700;2-3T
GROUP;FFT 6700;2-3.5T
ARRANGEMENT;FFT6700;3.5T
ARRANGEMENT;FFT7060;2-3T
GROUP;FFT 7060;2-3.5T
ARRANGEMENT;FFT7060;3.5T
ARRANGEMENT;FFT7810;2-3T
ARRANGEMENT;FFT7810;3.5T
ASSY TILT,(6/12) 2.0-3.0T
;NX
ASSY TILT,(6/10) 2.0-3.0T
ASSY TILT,(6/6) 2.0-3.0T
ASSY TILT,(6/4) 2.0-3.0T
ASSY TILT,(8/10) 2.0-3.0T
CYLINDER ASSY,( FORWARD 8°) 2.0-3.0T
ASSY TILT,(8/6) 2.0-3.0T
ASSY TILT,(8/4) 2.0-3.0T
ASSY TILT,(6/10) 3.3-3.5T
ASSY TILT,(6/6) 3.3-3.5T
ASSY TILT(6/4) 3.3-3.5T
ASSY TILT,(6/12) 3.3-3.5T
ASSY TILT,(8/10) 3.3-3.5T
ASSY TILT,(8/6) 3.3-3.5T
ASSY TILT,(8/4) 3.3-3.5T
LINES GP,PRI;3WAY,FFT
LINES GP,PRI;4WAY,FFT
GROUP,ATTACHMENT;3WAY FFL
GROUP,ATTACHMENT;4WAY FFL
GROUP;S/S
GROUP,SIDE SHIFT;FF
LINE GP,SEC 3WAY,RH,(FFL,FFT) 3.0-3.5T
LINE GP,SEC 3WAY,LH,(FFL,FFT) 3.0-3.5T
LINE GP,SEC 4WAY,(FFL,FFT) 3.0-3.5T
Lines Gp-Sec(3 Way)-RH(STD)-3.0 Ton
LINE GP,SEC 4WAY,(STD) 3.0-3.5T
Lines Gp-Sec(3 Way)-LH(STD)-3.0 Ton
;45×100×900,2.0-2.5T
;45×100×1000,2.0-2.5T
;45×100×1050,2.0-2.5T
;45×100×1150,2.0-2.5T
;45×100×1200,2.0-2.5T
;45×100×1350,2.0-2.5T
;50×100×1500,2.0-2.5T
;50×100×1600,2.0-2.5T
;50×100×1700,2.0-2.5T
;50×100×1800,2.0-2.5T
;45×122×1000,3.0-3.5T
;45×122×1050,3.0-3.5T
;45×122×1150,3.0-3.5T
;45×122×1200,3.0-3.5T
;45×122×1350,3.0-3.5T
;50×122×1500,3.0-3.5T
;50×122×1600,3.0-3.5T
;50×122×1700,3.0-3.5T
;50×122×1800,3.0-3.5T
;50×100×2000,2.0-2.5T
;50×122×2000,3.0-3.5T
ARRANGEMENT,FFL;2.0-2.5T
ARRANGEMENT,FFL;3.0-3.5T
ARRANGEMENT,FFT;2.0-2.5T
ARRANGEMENT;FFL DUAL TIRE;2.0-2.5T
ARRANGEMENT;FFL DUAL TIRE;3.0-3.5T
ARRANGEMENT;FFT DUAL TIRE;2.0-2.5T
ARRANGEMENT;FFT DUAL TIRE;3.0-3.5T
ARR-STD,2.0-2.5T
ARR-STD,3.0T
ASSY;CARRIAGE
ASSY,STD DUAL TIRE 3.0-3.5T
GP;STD DUAL TIRE 2.0-2.5T
BACKREST,W=1150, H=1000
BACKREST;STD DOUBLE;2.0-2.5T
BACKREST;STD DOUBLE;3.0-3.5T
ASSY,BACK;STD/FFL/FFT
SHIFTER;INT-STD;2.0-2.5T
GROUP;CARRIAGE
ARRANGEMENT;INT S/S-STD
ASSY;INT S/S-STD
SHIFTER,STANDARD for SINGLE,2.0-2.5T
SHIFTER ASSY, STANDARD for SINGLE;2.0-2.5T
SHIFTER,STANDARD for DOUBLE;3.0T
SHIFTER ASSY,STANDARD for DOUBLE;3.0T
SHIFTER,STANDARD for DOUBLE;2.0-2.5T
SHIFTER ASSY,STANDARD for DOUBLE;2.0-2.5T
INTEGRAL,1170MM;STD 3.0T
INTEGRAL,1120MM;STD 2.0-2.5T
INTEGRAL,1120MM;FFT 2.0-2.5T
INTEGRAL,1120MM;FFL 2.0-2.5T
LINE GROUP;3.0T
LINE GROUP;2.0-2.5T
GROUP,FORK;1440MM,FFT 3.0T
GROUP,FORK;1170MM;FFT-3.0T
GROUP,FORK;1170MM;FFL-3.0T
FORK, 3.0-3.5T
FORK, 2.0-2.5T
ARR,INT S/S FFT,3.0T
ARRANGEMENT;INT S/S;FFT 3.0-3.5T
ARR,INT S/S FFT,2.0-2.5T
ARRANGEMENT;INT S/S FFT,2.0-2.5T
ARR,INT S/S FFL,3.0T
ARRANGEMENT;INT S/S FFL,3.0T
ARR,INT S/S FFL,2.0-2.5T
ARRANGEMENT;INT S/S FFL,2.0-2.5T
Brand: Doosan
GROUP,FUEL
GROUP
GROUP;GEAR PUMP
GROUP,OVERHEAD
DPF GP
;GP;KUBOTA V2403
BRAKE GROUP
GROUP-HYD
GP BRAKE
GROUP;T.C COOLER;
ASSY
GROUP;ACCEL
AXLE ASSY,3.0T
Brake As-LH-3.0 Ton
Brake As-RH-3.0 Ton
AXLE,3.3-3.8T
ASSY;D30NXP STAGE-V
ASSY,TRANSMISSION
WEIGHT,3.5T
WEIGHT,2.0T
WEIGHT,2.5T
WEIGHT,3.3T
WEIGHT,3.0T
ARRANGEMENT
GROUP;ENGINE
ASSY;KUBOTA V2403
AND GUIDE
FAN
PIPE
HOSE
VALVE
AND SERVICE PARTS
VALVE AND EXHAUST
PUMP
PUMP ASSY
AND GLOW PLUG
CLEANER
FILTER
COOLER
SENSOR ASSY
AND PULLEY
ASSY,WATER
ASSY,OIL
MUFFLER
MAINIFOLD
RAIL
PAN
HEAD
CHARGER
CAMSHAFT
AND IDLE GEAR SHAFT
ARM SHAFT
AND CRANKSHAFT
CASE
BEARING CASE
COVER
HARNESS BEACKET
GP;3SEC/3LEVER
GP-HIP NO BELT
GP,SUSPENSION;W/HIP
SEAT
Gp-Static-STD
Gp-Suspension
STATIC
STATIC WTIH ARM
STATIC WTIH HIP
GP,SUSPENSION
GP,SUSPENSION;W/ARM
CLEANER-WET
CONDITIONER
PLATE
GROUP;3WAY
;4WAY
FOR MODULAR CABIN
Gp-Cabin
CABIN A
CABIN B
CABIN C
CLEANER GP
Lamp Gp-Cabin
Lamp Gp-OVHG
SUSPENSION-NXP
Gp-OVHG(Amber)
Gp-OVHG(Red)
;OVHG(AMBER),DOWN
;OVHG(RED),DOWN
GP
ARR;STD 2500;2-3T
GROUP;STD 2500;2-3T
ASSY;LIFT
ARR;STD 2500;3.5T
ARR;STD 2700;2-3T
ARR;STD 2700;3.5T
ARR;STD 3000;2-3T
ARR;STD 3000;3.5T
ARR;STD 3300;2-3T
ARR;STD 3300;3.5T
ARR;STD 3500;2-3T
ARR;STD 3500;3.5T
ARR;STD 3700;2-3T
ARR;STD 3700;3.5T
ARR;STD 4000;2-3T
ARR;STD 4000;3.5T
ARR;STD 4250;2-3T
ARR;STD 4250;3.5T
ARR;STD 4500;2-3T
ARR;STD 4500;3.5T
ARR;STD 4750;2-3T
ARR;STD 4750;3.5T
ARR;STD 5000;2-3T
ARR;STD 5000;3.5T
;NX
GROUP;S/S
GROUP,SIDE SHIFT;FF
ARR-STD,2.0-2.5T
ARR-STD,3.0T
ASSY;CARRIAGE
GROUP;CARRIAGE
ASSY;INT S/S-STD
LINE GROUP;3.0T
LINE GROUP;2.0-2.5T
FORK, 3.0-3.5T
FORK, 2.0-2.5T
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
