Doosan Forklift D20GP D25GP D30GP 34KW Spare Parts Catalog SB1254E
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D20GP, D25GP, D30GP 34KW Forklift
Part Number: SB1254E
Number of Pages: 906 Pages
Section 1
Chassis Component
Mtg Gp.-Steer Axle
Steering Axle Gp(Code L)
Cylinder Ass’y-Steer
Steering Axle Gp
Cylinder As-Steer
Frame Gp(2.0/2.5Ton)
Frame Gp(3.0Ton)
Panel Gp-Top
Hood Ass’y
Air Cleaner Gp
Muffler Gp
Lines Gp - Torque Converter Cooler
Radiator Gp
Radiator Ass’y
Reservoir Gp
Lines Gp - Fuel
Battery Gp
Wiring Gp
Instrument Gp
Mtg Gp - Powertrain 2.0/2.5Ton
Mtg Gp - Powertrain 3.0Ton
Control Gp - Accel
Pedal Ass’y
Control Gp-Steering
Steering Unit
Column As
Control Gp - Brake & Inching
Brake As
Lines Gp-Brake(2.0/2.5 Ton)
Lines Gp-Brake(3.0 Ton)
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp-F/R(P/S)
Section 2
Capacity Module
Guard Gp-Overhead
Mirror Gp
Guard Gp-Overhead-2032mm(80inch)
Counter Weight Gp
Tire & Wheel Gp(PNEU)-2.0/2.5 Ton
Tire & Wheel Gp(PNEU)-3.0 Ton
Tire & Wheel Gp(PNEU)-Dual-2.0/2.5 Ton
Tire & Wheel Gp(PENU)-Dual-3.0 Ton
Tire & Wheel Gp(Solid)-2.0/2.5 Ton
Tire & Wheel Gp(Solid)-3.0 Ton
Tire & Wheel Gp-Dual-Solid-2.0/2.5 Ton
Tire & Wheel Gp-Dual-Solid-3.0 Ton
Fender Gp-Dual Tire-2.0/2.5 Ton
Fender Gp-Dual Tire-3.0 Ton
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine_4TNE94L 34KW
Engine Ar. Basic
Fan Drive Gp
Alternator Mounting Gp
Cylinder Block Gp
Gear Housing Gp
Flywheel Housing & Oil Pump Gp
Cylinder Head & Bonnet Gp
Suction & Exhaust Manifold Gp
Camshaft & Driving Gear Gp
Crankshaft & Piston Gp
LUB. Oil System Gp
Cooling Water System Gp
Fuel Injection Pump Gp
Fuel Injection Valve Gp
Fuel Filter Gp
Starting Motor Gp
Gasket Set Gp
Section 4
Power Train
Transmission Ass’y -GZ
Transmission Ass’y
Hydraulic Clutch Ass’y -GZ
Reduction & Differential Ass’y -GZ
Control Valve Gp-Solenoid -GZ
Inching Valve Ass’y -GZ
Charging Pump Ass’y -GZ
Drive Axle Gp-2.0/2.5 Ton
Wheel Brake Ass’y-LH-2.0/2.5 Ton
Wheel Brake Ass’y-RH-2.0/2.5 Ton
Drive Axle Gp-3.0 Ton
Wheel Brake Ass’y-LH-3.0 Ton
Wheel Brake Ass’y-RH-3.0 Ton
Drive Axle Gp-3.0 Ton(Code L)
Transmission Ass’y 1 of 2 SXJD
Transmission Ass’y 2 of 2 SXJD
Hydraulic Clutch Ass’y SXJD
Charging Pump Ass’y SXJD
Control Valve Gp-Solenoid SXJD
Inching Valve Ass’y SXJD
Reduction & Differential Ass’y SXJD
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Static & Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res., W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res., W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning Indicator Lamp For Unfastening Belt
Seat Belt Gp W/O Switch
Lamp Gp
Rear Lamp Gp - OVHG
Strobe Gp - OVHG(Amber)
Strobe Gp - OVHG(Red)
Horn Gp
Valve Ar-2Sec 2Lev
Valve Gp-2Sec 2 Lev
Valve Ar-3Sec 3Lev
Valve Gp-3Sec 3 Lev
Valve Ar-4Sec 4Lev
Valve Gp-4Sec 4 Lev
Valve As-2Sec
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Tool Gp
FAN ASSY - Full Cabin
FAN ASSY -Cabin A,B,C OR OVHD
Extinguisher
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
FULL CABIN GP
FULL CABIN ASSY
DOOR GP-RH
DOOR GP-LH
Heater GP
Optn-Speedo Meter
Optn-Autoshift Controlle
LED Lamp Gp-W/Com. OVHG&A CABIN
LED Lamp Gp-W/Com.Full CABIN
LED Lamp Gp-W/Com. B&C CABIN
LED Lamp Gp-Front,OVHG&A CABIN
LED Lamp Gp-Front,B&C CABIN
Valve Ar-3SEC 3 Lever Plus ISO3691
Valve Gp-3SEC 3 Lever Plus
VALVE 3691 3SEC;PLUS
VALVE DISTRIBUTARY PLUS
LIFT SECTION
TILT SECTION
VALVE REVOLVE
RETURN SECTION
VALVE GP 3SEC,3LEVER,3691
Valve Ar-4SEC 4 Lever Plus ISO3691
Valve Gp-4SEC 4 Lever Plus
VALVE 3691 4SEC;PLUS
VALVE GP 4SEC,4LEVER,3691
CH/OV AR-EU
OSS Gp
Valve Gp-4SEC 3 Lever
Injection For Moduar B&C PLUS
Fuel Cap With Key
Valve Ar-4SEC 3 Lever Plus ISO3691
CH/OV AR-EU;SMC HOOD
Engine Shut Down
Engine Shut Down-3691
Pre Cleaner
Autoshift Controller
Tire&Wheel Gp-Drive(2.0/2.5Ton)
Tire&Wheel Gp-Front(2.0/2.5Ton)
Tire&Wheel Gp-Inner(2.0/2.5Ton)
Tire&Wheel Gp-Inner(3.0Ton)
Tire&Wheel Gp-Outer(2.0/2.5Ton)
Tire&Wheel Gp-Outer(3.0Ton)
Rain Canopy
Bar Plate Radiator
Speed Limit
Integral Shifting-Fork Positioner 1120mm-FFL(2.0/2.5T)
Integral Shifting-Fork Positioner 1120mm-FFT(2.0/2.5T)
Integral Shifting-Fork Positioner 1170mm-FFL(3.0T)
Integral Shifting-Fork Positioner 1170mm-FFT(3.0T)
Integral Shifting-Fork Positioner 1440mm-FFT(3.0T)
CH/OV Ar-Engine Sell Off Yanmar 4TNE94L
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~3700mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH
Tilt Cylinder Ass’y-RH
Tilt Cylinder Gp
S/S Lines Gp(STD)-2.0/2.5Ton
S/S Lines Gp(STD)-3.0 Ton
S/S Lines Gp(FFL, FFT)-2.0/2.5 Ton
S/S Lines Gp(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-3.0Ton
Att Lines Gp-Sec(4 Way)-STD-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-STD-3.0 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-3.0 Ton
Lines GP-ATT-Secondary(3 Way-LH)-2.0/2.5/3.0 Ton
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Gp-2.0/2.5 Ton
Side Shifter Cylinder Ass’y-2.0/2.5 Ton
Side Shifter Cylinder Ass’y-3.0 Ton
Side Shifter Gp-3.0 Ton
Side Shifter As-2.0/2.5 Ton
Side Shifter As-3.0 Ton
Cylinder Ass’y-2.0/2.5Ton
Cylinder Ass’y-3.0Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-3.0 Ton
Carriage Ass’y-2.0/2.5/3.0 Ton
Carriage Ar.-Integral Side Shifter-2.0/2.5/3.0 Ton
Carriage Arrangement;Int S/S-STD-2.0/2.5Ton
Carriage Assy;Integral S/S-2.0/2.5Ton
Carriage Arrangement;Int S/S-FFT-2.0/2.5Ton
Carriage Assy;Int S/S-STD-3.0Ton
Carriage Assy;Integral S/S-3.0Ton
Carriage Arrangement;Int S/S-FFT-3.0Ton
Backrest Ass’y-2.0/2.5 Ton
Backrest Ass’y-3.0 Ton
Carriage Ass’y-STD/FFL/FFT(2.0/2.5/3.0 Ton)
Carriage Mounting
Fork Gp
Integral Shifting-Fork Positioner 1120mm-STD(2.0/2.5T)
Integral Shifting-Fork Positioner 1170mm-STD(3.0T)
