Doosan Forklift D20G D25G D30G Spare Parts Catalog SB5136Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D20G, D25G, D30G Forklift
Part Number: SB5136Y
Number of Pages: 546 Pages
Section 1
Chassis Component
Steering Axle Gp
Cylinder Ass’y-Steer
Frame Gp(2.0/2.5 Ton)
Frame Gp(3.0 Ton)
Panel Gp-Top
Engine & Air Cleaner Gp
Muffler Gp
Lines Gp-Torque Converter Cooler
Radiator Gp
Reservoir Gp
Lines Gp-Fuel
Battery Gp
Wiring Gp Part 1 of 2
Wiring Gp Part 2 of 2
Instrument Gp
Mounting Gp-Transmission
Control Gp-Accel
Pedal Ass’y
Control Gp-Steering
Handle Steer
Steering Shaft Column
Steering Unit
Control Gp-Brake & Inching
Brake As
Lines Gp-Brake(2.0/2.5 Ton)
Lines Gp-Brake(3.0 Ton)
Parking Brake Gp
Floor Plate Gp
Cover Gp-HYD Oil Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Control Gp F/R
Control Linkage
Section 2
Capacity Module
Guard Gp-Overhead
Mirror Gp
Counter Weight Gp
Tire & Wheel Gp(PNEU)-2.0/2.5 Ton
Tire & Wheel Gp(PNEU)-3.0 Ton
Tire & Wheel Gp(PNEU)-Dual-2.0/2.5 Ton
Tire & Wheel Gp(PENU)-Dual-3.0 Ton
Tire & Wheel Gp(Solid)-2.0/2.5 Ton
Tire & Wheel Gp(Solid)-3.0 Ton
Tire & Wheel Gp-Dual-Solid-2.0/2.5 Ton
Tire & Wheel Gp-Dual-Solid-3.0 Ton
Fender Gp-Dual Tire-2.0/2.5 Ton
Fender Gp-Dual Tire-3.0 Ton
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine Ar.-Basic
Alternator Mounting Gp
Cylinder Block Gp
Gear Housing Gp
Flywheel Housing & Oil Pump Gp
Cylinder Head & Bonnet Gp
Suction & Exhaust Manifold Gp
Camshaft & Driving Gear Gp
Crankshaft & Piston Gp
LUB. Oil System Gp
Cooling Water System Gp
Fuel Injection Pump Gp
Fuel Injection Valve Gp
Fuel Filter Gp
Starting Motor Gp
Gasket Set Gp
Section 4
Power Train
Transmission Ass’y 1 of 2
Transmission Ass’y 2 of 2
Hydraulic Clutch Ass’y
Reduction & Differential Ass’y
Control Valve Gp-Solenoid
Inching Valve Ass’y
Charging Pump Ass’y
Drive Axle Gp-2.0/2.5 Ton
Wheel Brake Ass’y-LH-2.0/2.5 Ton
Wheel Brake Ass’y-RH-2.0/2.5 Ton
Drive Axle Gp-3.0 Ton
Wheel Brake Ass’y-LH-3.0 Ton
Wheel Brake Ass’y-RH-3.0 Ton
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Static & Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res., W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res., W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning Indicator Lamp For Unfastening Belt
Seat Belt Gp W/O Switch
Cabin Gp
Wiper & Washer Injection
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Cabin Ass’y
Door Gp-LH
Door Gp-RH
Heater Gp-Cabin
Fan Gp-Cabin
Extinguisher-Cabin
Light Group
Rear Lamp Gp-OVHG
Strobe Gp-OVHG(Amber)
Strobe Gp-OVHG(Red)
Rear Lamp Gp-Cabin
Strobe Gp-Cabin
Horn Gp
Valve Ar-3 Sec(3 Sec-2 Lever)
Control Valve Ass’y-3 Sec
Valve Ar-3 Sec(3 Sec-3 Lever)
Valve Ar-4 Sec(4 Sec-4 Lever)
Control Valve-4 Sec
Change Over Ar-3 Sec To 4 Sec
Valve Gp-Distributary
Valve Gp-Lift
Valve Gp-Tilt
Valve Gp-Section
Relief Valve Ass’y
Main Relief Valve Ass’y
Tool Gp
Fuel Cap With Key
Optn-Speedo Meter
Optn-Autoshift Controlle
LED Lamp Gp-W/Com. OVHG&A CABIN
LED Lamp Gp-W/Com.Full CABIN
LED Lamp Gp-W/Com. B&C CABIN
LED Lamp Gp-Front,OVHG&A CABIN
LED Lamp Gp-Front,B&C CABIN
Change Over Ar.-Safety(2.0/2.5Ton)
Change Over Ar.-Safety(3.0Ton)
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~3700mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH
Tilt Cylinder Ass’y-RH
Tilt Cylinder Gp
Tilt Cylinder Gp(NEW)
S/S Lines Gp(STD)-2.0/2.5Ton
S/S Lines Gp(STD)-3.0 Ton
S/S Lines Gp(FFL, FFT)-2.0/2.5 Ton
S/S Lines Gp(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-3.0Ton
Att Lines Gp-Sec(4 Way)-STD-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-STD-3.0 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-3.0 Ton
Lines GP-ATT-Secondary(3 Way-LH)-2.0/2.5/3.0 Ton
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-STD(NEW)
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Gp-2.0/2.5 Ton
Cylinder Ass’y
Side Shifter Cylinder Ass’y-3.0 Ton
Side Shifter Gp-3.0 Ton
Side Shifter As-2.0/2.5 Ton
Side Shifter As-3.0 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-3.0 Ton
Carriage Ass’y-2.0/2.5/3.0 Ton
Carriage Ar.-Integral Side Shifter-2.0/2.5/3.0 Ton
Carriage Group-Integral Side Shift-STD-2.0/2.5Ton
Carriage Group-Integral Side Shift-FFL-2.0/2.5Ton
Carriage Group-Integral Side Shift-FFT-2.0/2.5Ton
Carriage Group-Integral Side Shift-STD-3.0Ton
Carriage Group-Integral Side Shift-FFL-3.0Ton
Carriage Group-Integral Side Shift-FFT-3.0Ton
Backrest Ass’y-2.0/2.5 Ton
Backrest Ass’y-3.0 Ton
Carriage Ass’y-STD/FFL/FFT(2.0/2.5/3.0 Ton)
Carriage Mounting
Fork Gp
