Doosan Forklift D20G D25G D30G Spare Parts Catalog SB5056Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D20G, D25G, D30G Forklift
Part Number: SB5056Y
Number of Pages: 905 Pages
Section 1
Chassis Component
Mtg Gp.-Steer Axle
Steering Axle Gp(Code L)
Cylinder Ass’y-Steer
Steering Axle Gp(Code A)
Steering Axle Gp
Cylinder As-Steer
Frame Gp(2.0/2.5Ton)
Frame Gp(3.0Ton)
Panel Gp-Top
Hood Ass’y
Air Cleaner Gp
Muffler Gp
Lines Gp - Torque Converter Cooler
Radiator Gp
Reservoir Gp
Lines Gp - Fuel
Battery Gp
Wiring Gp
Wiring Gp Part 2 of 2
Instrument Gp
Mtg Gp - Powertrain
Mtg Gp - Powertrain 2.0/2.5Ton
Mtg Gp - Powertrain 3.0Ton
Control Gp - Accel
Pedal Ass’y
Control Gp-Steering
Steering Unit
Column As
Control Gp - Brake & Inching
Master Cylinder Ass’y
Lines Gp-Brake(2.0/2.5 Ton)
Lines Gp-Brake(3.0 Ton)
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp-F/R(P/S)
Section 2
Capacity Module
Guard Gp-Overhead
Counter Weight Gp
Tire & Wheel Gp(PNEU)-2.0/2.5 Ton
Tire & Wheel Gp(PNEU)-3.0 Ton
Tire & Wheel Gp(PNEU)-Dual-2.0/2.5 Ton
Tire & Wheel Gp(PENU)-Dual-3.0 Ton
Tire & Wheel Gp(Solid)-2.0/2.5 Ton
Tire & Wheel Gp(Solid)-3.0 Ton
Tire & Wheel Gp-Dual-Solid-2.0/2.5 Ton
Tire & Wheel Gp-Dual-Solid-3.0 Ton
Fender Gp-Dual Tire-2.0/2.5 Ton
Fender Gp-Dual Tire-3.0 Ton
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine Ar.-Basic
Alternator Mounting Gp
Alternator Ass’y
Cylinder Block Gp
Gear Housing Gp
Flywheel Housing & Oil Pump Gp
Cylinder Head & Bonnet Gp
Suction & Exhaust Manifold Gp
Camshaft & Driving Gear Gp
Crankshaft & Piston Gp
LUB. Oil System Gp
Cooling Water System Gp
Fuel Injection Pump Gp
Fuel Injection Valve Gp
Fuel Filter Gp
Starting Motor Gp
Gasket Set Gp
Section 4
Power Train
Transmission Ass’y
Hydraulic Clutch Ass’y
Reduction & Differential Ass’y
Control Valve Gp-Solenoid
Inching Valve Ass’y
Charging Pump Ass’y
Drive Axle Gp-2.0/2.5 Ton
Wheel Brake Ass’y-LH-2.0/2.5 Ton
Wheel Brake Ass’y-RH-2.0/2.5 Ton
Drive Axle Gp-3.0 Ton
Wheel Brake Ass’y-LH-3.0 Ton
Wheel Brake Ass’y-RH-3.0 Ton
Drive Axle Gp-3.0 Ton(Code L)
Drive Axle Gp-3.0 Ton(Code X)
Transmission Ass’y 1 of 2 SXJD
Transmission Ass’y 2 of 2 SXJD
Hydraulic Clutch Ass’y SXJD
Charging Pump Ass’y SXJD
Control Valve Gp-Solenoid SXJD
Inching Valve Ass’y SXJD
Reduction & Differential Ass’y SXJD
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Static & Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res., W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res., W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning Indicator Lamp For Unfastening Belt
Seat Belt Gp W/O Switch
Lamp Gp
Wiper & Washer Injection
Modular Cabin Gp-A1
Modular Cabin Gp-B1
Cabin Ass’y
Door Gp-LH
Door Gp-RH
Rear Lamp Gp - OVHG
Strobe Gp - OVHG(Amber)
Strobe Gp - OVHG(Red)
Horn Gp
Valve Ar-2Sec 2Lev
Valve Gp-2Sec 2 Lev
Valve Ar-3Sec 3Lev
Valve Gp-3Sec 3 Lev
Strobe Gp-OVHG(Amber)
Valve Ar-4Sec 4Lev
Valve Gp-4Sec 4 Lev
Valve As-2Sec
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Tool Gp
Control Valve Ass’y-3 Sec
Modular Cabin Gp-A
Modular Cabin Gp-B
Control Valve-4 Sec
Modular Cabin Gp-C
Cabin Assy
Optn-Speedo Meter
Valve Gp-Distributary
Valve Gp-Lift
Valve Gp-Tilt
Valve Gp-Section
Relief Valve Ass’y
Main Relief Valve Ass’y
Optn-Autoshift Controlle
LED Lamp Gp-W/Com. OVHG&A CABIN
LED Lamp Gp-W/Com.Full CABIN
LED Lamp Gp-W/Com. B&C CABIN
LED Lamp Gp-Front,OVHG&A CABIN
LED Lamp Gp-Front,B&C CABIN
Change Over Ar.-Safety(2.0/2.5Ton)
Change Over Ar.-Safety(3.0Ton)
Valve Gp-4SEC 3 Lever
Engine Shut Down
Tire&Wheel Gp-Drive(2.0/2.5Ton)
Tire&Wheel Gp-Front(2.0/2.5Ton)
Tire&Wheel Gp-Inner(2.0/2.5Ton)
Tire&Wheel Gp-Inner(3.0Ton)
Tire&Wheel Gp-Outer(2.0/2.5Ton)
Tire&Wheel Gp-Outer(3.0Ton)
Rain Canopy
Bar Plate Radiator
Speed Limit
Integral Shifting-Fork Positioner 1120mm-FFL(2.0/2.5T)
Integral Shifting-Fork Positioner 1120mm-FFT(2.0/2.5T)
Integral Shifting-Fork Positioner 1170mm-FFL(3.0T)
Integral Shifting-Fork Positioner 1170mm-FFT(3.0T)
Integral Shifting-Fork Positioner 1440mm-FFT(3.0T)
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~3700mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH
Tilt Cylinder Ass’y-RH
Tilt Cylinder Gp
S/S Lines Gp(STD)-2.0/2.5Ton
S/S Lines Gp(STD)-3.0 Ton
S/S Lines Gp(FFL, FFT)-2.0/2.5 Ton
S/S Lines Gp(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-3.0Ton
Att Lines Gp-Sec(4 Way)-STD-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-STD-3.0 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-3.0 Ton
Lines GP-ATT-Secondary(3 Way-LH)-2.0/2.5/3.0 Ton
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Gp-2.0/2.5 Ton
Cylinder Ass’y
Side Shifter Cylinder Ass’y-3.0 Ton
Side Shifter Gp-3.0 Ton
Side Shifter As-2.0/2.5 Ton
Side Shifter As-3.0 Ton
Cylinder Ass’y-2.0/2.5Ton
Cylinder Ass’y-3.0Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-3.0 Ton
Carriage Ass’y-2.0/2.5/3.0 Ton
MAST-FFL
CARRIAGE ARRANGEMENT;INT S/S-STD
CARRIAGE ASSY;INTEGRAL S/S;
CARRIAGE ARRANGEMENT;INT S/S-FFT
CARRIAGE ASSY;INT S/S-STD
Backrest Ass’y-2.0/2.5 Ton
Backrest Ass’y-3.0 Ton
Carriage Ass’y-FFL/FFT(2.0/2.5/3.0 Ton)
Carriage Mounting
Fork Gp
Integral Shifting-Fork Positioner 1120mm-STD(2.0/2.5T)
Integral Shifting-Fork Positioner 1170mm-STD(3.0T)
Brand: Doosan
Section 1
Chassis Component
Mtg Gp.-Steer Axle
Steering Axle Gp
Cylinder As-Steer
Frame Gp(3.0Ton)
Panel Gp-Top
Hood Ass’y
Air Cleaner Gp
Muffler Gp
Radiator Gp
Reservoir Gp
Lines Gp - Fuel
Battery Gp
Wiring Gp
Instrument Gp
Mtg Gp - Powertrain
Control Gp - Accel
Pedal Ass’y
Control Gp-Steering
Steering Unit
Column As
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp-F/R(P/S)
Section 2
Capacity Module
Guard Gp-Overhead
Counter Weight Gp
Section 3
Engine Ar.-Basic
Alternator Ass’y
Cylinder Block Gp
Gear Housing Gp
LUB. Oil System Gp
Fuel Filter Gp
Starting Motor Gp
Gasket Set Gp
Section 4
Power Train
Transmission Ass’y
Inching Valve Ass’y
Charging Pump Ass’y
Section 5
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Suspension
Lamp Gp
Modular Cabin Gp-A1
Modular Cabin Gp-B1
Cabin Ass’y
Door Gp-LH
Door Gp-RH
Rear Lamp Gp - OVHG
Horn Gp
Valve Ar-2Sec 2Lev
Valve Gp-2Sec 2 Lev
Valve Ar-3Sec 3Lev
Valve Gp-3Sec 3 Lev
Valve Ar-4Sec 4Lev
Valve Gp-4Sec 4 Lev
Valve As-2Sec
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Control Valve-4 Sec
Modular Cabin Gp-C
Cabin Assy
Optn-Speedo Meter
Valve Gp-Lift
Valve Gp-Tilt
Valve Gp-Section
Relief Valve Ass’y
Engine Shut Down
Rain Canopy
Bar Plate Radiator
Speed Limit
Section 6
Mast-Hydraulic
Lift Gp-Primary-FFT
Tilt Cylinder Gp
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Cylinder Ass’y
MAST-FFL
Carriage Mounting
Fork Gp
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
