Doosan Forklift D20F to D35FM-WP3.2 Spare Parts Catalog SB5174Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan D20F, D20FM, D25F, D25FM, D30F, D30FM, D33F, D33FM, D35F-WP3.2, D35FM-WP3.2 Forklift
Part Number: SB5174Y
Number of Pages: 878 Pages
Section 1
Chassis Component
Steering Axle Gp
Cylinder As-Steer
Cylinder Ass’y-Steer
Frame Gp
Panel Gp-Top
Engine & Air Cleaner Gp
Muffler Gp
Lines Gp-Torque Converter Cooler
Radiator Gp(F)
Radiator Gp(FM)
Lines Gp-Fuel
Battery Gp
Wiring Gp Part
Instrument Gp
Mounting Gp-Transmission(F)
Mounting Gp-Transmission(FM)
Control Gp-Accel
Pendal Assy
Control Gp-Steering
Handle Steer
Steering Shaft Column
Steering Unit
Control Gp-Brake & Inching(Tor-Con Type)
Control Gp-Brake & Inching(Clutch Type)
Brake Assy
Master Cylinder As(整?式)
Master Cylinder As(分?式)
Lines Gp-Brake(D30 33 35 F)
Lines Gp-Brake(D30 33 35 FM)
Lines Gp-Brake(D20 25FM)
Lines Gp-Brake(D20 25F)
Parking Brake Gp
Floor Plate Gp(机械式)
Floor Plate Gp(液力式)
Cover Gp-HYD Oil Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp F/R
Control Linkage
Section 2
Capacity Module
Guard Gp-Overhead
Mirror GP
Counter Weight Gp
Tire & Wheel Gp-CHAO YANG 2.0 2.5T
Tire & Wheel Gp(前?) 2.0~2.5T
Tire & Wheel Gp(前?) 3.0~3.5T
Tire & Wheel Gp(ZHENGXIN) 3.0~3.5T
Tire & Wheel Gp(DOUBLECOIN) 3.0~3.5T
Tire & Wheel Gp-CHAO YANG 3.0~3.5T
Tire & Wheel Gp-Dual-PENU CHAO YANG 3.0~3.5T
Fender Gp-Dual Tire
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine(?柴)
Engine Block Group
Erankcase Pre-Assembly
Oil Seal Group
Flywheel Housing Group
Gear Housing Cover Group
Timing Gear Housing Group
Crankshaft Group
Main Bearing Set
Thrust Plate Set
Flywheel Group
Flywheel Assembly
Piston Assembly
Piston Ring Set
Connecting Rod
Connecting Rod Bearing Set
Cylinder Head Group
Cylinder Head Subassembly
Cylinder Head Front Cover Group
Eye Ring Group
Cylinder Head Cover Group
Oil filling Port Cover Assembly
Valve Train Group
Rocker Arm Shaft Set
Rocker Arm Set
Gear Drive Group
Intermediate Gear Set
Crankshaft Pulley Group
Oil Pan Group
Oil Pan Assembly
Oil Dipstick Group
Oil Pump Group
Oil Strainer Group
Oil Filter Group
Oil Filter
Water Pump Group
Water Draining Valve Group
Thermostat Group
Fan and Hub Group
Water Pump Inlet Pipe Group
Fuel Injection Pump Group
Fuel Injector Group
Fuel Filter Group
Fuel Filter Assembly
High Pressure Fuel Pipe Group
High-pressure Fuel Pipe Assembly
Low Pressure Fuel Pipe Group
Intake Manifold Group
Exhaust Manifold Group
Hydraulic Pump Group
Tensioner And Belt Group
Starter Motor Group
Engine Bracket Group
Parts Kit
Electronic Control Unit Group
Engine Harness Group
Alternator Group
Alternator Bracket Group
Section 4
Power Train
Transmission Ass’y(1)机械式
Transmission Ass’y(1)液力式
Transmission Ass’y(2)机械式
Transmission Ass’y(2)液力式
Transmission Ass’y(1)(机械式)
Transmission Ass’y(2)(机械式)
Clutch Ass’y
Reduction & Differential
Hydraulic Clutch Ass’y
Charging Pump Ass’y
Control Valve Gp-Solenoid
Inching Valve Ass’y
Clutch Assy
Shift Gear Part (1)
Shift Gear Part (2)
Reduction & Differential Ass’y
Drive Axle Gp-(2.0/2.5 ton)
Wheel Brake Ass’y-LH (2.0/2.5 ton)
Wheel Brake Ass’y-RH (2.0/2.5 ton)
Drive Axle Gp-(3.0 ton)
Wheel Brake Ass’y-LH(3.0 ton)
Wheel Brake Ass’y-RH(3.0 ton)
MTG GP- Powertrain D35FM
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Cabin Gp
Cabin As
Door Gp-LH
Door Gp-RH
Heater Gp-Cabin
Fan Gp-Cabin
Strobe Gp-Cabin
Extinguisher-Cabin
Rear Lamp Gp-Cabin
Lamp Gp
Rear Lamp Gp-Ovhg
Strobe Gp-Ovhg
Horn Gp
Valve Gp-2 Sec-FFL/FFT
Valve Gp-2 Sec-STD
Valve Ar-3 Sec(3 Sec-3 Lever)-FFL/FFT
Valve Ar-3 Sec(3 Sec-3 Lever)-STD
Control Valve Ass’y - 3 Sec
Valve Ar-4 Sec(4 Sec-4 Lever)-FFL/FFT
Valve Ar-4 Sec(4 Sec-4 Lever)-STD
Control Valve-4 Sec
Valve Gp-Distributary
Valve Gp-Lift
Valve Gp-Tilt
Valve Gp-Section
Relief Valve Ass’y
Main Relief Valve Ass’y
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Seat Gp-Suspension
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Seat Gp
Engine Assy(新柴)
Body Assembly And Accessory(新柴)
Flywheel Housing(新柴)
Fuel Supply System Assembly(新柴)
Circuit Group Assembly(新柴)
Oil Pump Assembly(新柴)
Glow Plug Assembly(新柴)
Air Intake Assembly(新柴)
Fan(新柴)
Water Pump(新柴)
Thermostat Assembly(新柴)
Starter Assembly(新柴)
Cylinder Head And Gas Exchanging System Assembly(新柴)
Generator And Belt Assembly(新柴)
Timing Gear Train Assembly(新柴)
Oil Sump Assembly(新柴)
Piston And Connecting Rod Assembly(新柴)
Crankshaft Assembly(新柴)
Flywheel Assembly(新柴)
Ntake Exhaust Assembly(新柴)
Cylinder Head Cover And Name Plate Assembly(新柴)
Duble & Pre Air Cleaner Gp
Spark & Arrestor
Muffler Gp,Vertical
Step Lamp Gas Spring
Tire&Wheel Gp-Drive(2.0/2.5Ton)
Tire&Wheel Gp-Front(2.0/2.5Ton)
Tire&Wheel Gp-Inner(2.0/2.5Ton)
Tire&Wheel Gp-Inner(3.0Ton)
Tire&Wheel Gp-Outer(2.0/2.5Ton)
Tire&Wheel Gp-Outer(3.0Ton)
Carriage Assy
Rain Canopy
Wet Pre Cleaner
Wet Pre Cleaner And Double Clean
Pre-Cleaner+Double Cleaner
Radiator Copper & Bar Plate
Fuel Cap With Key-2.0/2.5T
Fuel Cap With Key-3.0/3.3/3.5T
Fuel Heater
Wheel &Tire Gp-Solid
Wheel&Tire Gp-Front
Wheel&Tire Gp-Rear
Muffler DPF
Muffler DPF With Monitoring
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~5000mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH 2.0~3.5Ton
Tilt Cylinder Ass’y-RH 2.0~3.5Ton
Tilt Cylinder Gp 2.0~3.5Ton
S/S Lines Gp(STD)-2.0/2.5Ton
S/S Lines Gp(STD)-3.0~3.5 Ton
S/S Lines Gp(FFL, FFT)-2.0/2.5 Ton
S/S Lines Gp(FFL, FFT)-3.0~3.5 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-3.0~3.5 Ton
Att Lines Gp-Sec(4 Way)-STD-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-STD-3.0~3.5 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-3.0~3.5 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-3.0~3.5 Ton
Lines GP-ATT-Secondary(3 Way-LH)
Lines Gp-Sideshifter - STD,Double Tire
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(TD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-TD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD) 2.0~3.0Ton
Mounting Gp-Lift & Tilt(TD) 3.0~3.5 Ton
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD 2.0~3.0Ton
Relay Gp-TD 3.0~3.5Ton
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Gp-2.0/2.5 Ton
Cylinder Ass’y
Side Shifter Cylinder Ass’y
Side Shifter Gp
Side Shifter Gp-Wide Carriage
Att Lines Gp-Sec(3 Way)-LH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-3.0~3.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-3.0~3.5 Ton
Carriage Ass’y-3.0~3.5 Ton STD
Carriage Ar.-Integral Side Shifter
Carriage Group-Integral Side Shifter
Carriage Group-Integral Side Shift-FFL-2.0/2.5Ton
Carriage Group-Integral Side Shift-FFT-2.0/2.5Ton
Carriage Group-Integral Side Shift-STD-3.0~3.5 Ton
Carriage Group-Integral Side Shift-FFL-3.0~3.5 Ton
Backrest Ass’y-2.0/2.5 Ton
Backrest Ass’y-3.0~3.5 Ton
Load Backrest Gp-(1000mm Height OPTN) STD
Carriage Ass’y-STD/FFL/FFT
Carriage Mounting 2.0~3.5ton STD
Carriage Mounting 2.0~3.5ton TD
Fork Gp
Integral Shifting
Brand: Doosan
Section 1
Chassis Component
Steering Axle Gp
Cylinder As-Steer
Frame Gp
Panel Gp-Top
Muffler Gp
Radiator Gp(F)
Radiator Gp(FM)
Lines Gp-Fuel
Battery Gp
Wiring Gp Part
Instrument Gp
Control Gp-Accel
Pendal Assy
Control Gp-Steering
Handle Steer
Steering Unit
Brake Assy
Parking Brake Gp
Floor Plate Gp(机械式)
Floor Plate Gp(液力式)
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp F/R
Control Linkage
Section 2
Capacity Module
Guard Gp-Overhead
Mirror GP
Counter Weight Gp
Fender Gp-Dual Tire
Section 3
Engine(?柴)
Engine Block Group
Oil Seal Group
Crankshaft Group
Main Bearing Set
Thrust Plate Set
Flywheel Group
Flywheel Assembly
Piston Assembly
Piston Ring Set
Connecting Rod
Cylinder Head Group
Eye Ring Group
Valve Train Group
Rocker Arm Set
Gear Drive Group
Oil Pan Group
Oil Pan Assembly
Oil Dipstick Group
Oil Pump Group
Oil Strainer Group
Oil Filter Group
Oil Filter
Water Pump Group
Thermostat Group
Fan and Hub Group
Fuel Injector Group
Fuel Filter Group
Starter Motor Group
Parts Kit
Alternator Group
Section 4
Power Train
Clutch Ass’y
Charging Pump Ass’y
Inching Valve Ass’y
Clutch Assy
Shift Gear Part (1)
Shift Gear Part (2)
Section 5
Pre Cleaner Gp
Cabin Gp
Cabin As
Door Gp-LH
Door Gp-RH
Heater Gp-Cabin
Fan Gp-Cabin
Strobe Gp-Cabin
Extinguisher-Cabin
Rear Lamp Gp-Cabin
Lamp Gp
Rear Lamp Gp-Ovhg
Strobe Gp-Ovhg
Horn Gp
Valve Gp-2 Sec-STD
Control Valve-4 Sec
Valve Gp-Lift
Valve Gp-Tilt
Valve Gp-Section
Relief Valve Ass’y
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Seat Gp-Suspension
Seat Gp
Engine Assy(新柴)
Fan(新柴)
Water Pump(新柴)
Spark & Arrestor
Muffler Gp,Vertical
Carriage Assy
Rain Canopy
Wet Pre Cleaner
Fuel Heater
Wheel&Tire Gp-Front
Wheel&Tire Gp-Rear
Muffler DPF
Section 6
Mast-Hydraulic
Lift Gp-Primary-FFT
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(TD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-TD
Mast-FFL
Mast-FFT
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Cylinder Ass’y
Side Shifter Gp
Fork Gp
Integral Shifting
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
