Doosan Forklift CD20GP CD25GP CD30GP Spare Parts Catalog XSB5056Y
Brand: Doosan
Type of Machine: Forklift, Engine Powered Truck, Engine 2 Ton DIESEL
Model: Doosan CD20GP, CD25GP, CD30GP Forklift
Part Number: XSB5056Y
Number of Pages: 753 Pages
Section 1
Chassis Component
Mtg Gp.-Steer Axle
Steering Axle Gp(Code L)
Cylinder Ass’y-Steer
Steering Axle Gp(Code A)
Steering Axle Gp
Cylinder As-Steer
Frame Gp(2.0/2.5Ton)
Frame Gp(3.0Ton)
Panel Gp-Top
Hood Ass’y
Air Cleaner Gp
Muffler Gp
Lines Gp - Torque Converter Cooler
Radiator Gp
Reservoir Gp
Lines Gp - Fuel
Battery Gp
Wiring Gp
Instrument Gp
Mtg Gp - Powertrain 2.0/2.5Ton
Mtg Gp - Powertrain 3.0Ton
Control Gp - Accel
Pedal Ass’y
Control Gp-Steering
Steering Unit
Column As
Control Gp - Brake & Inching
Master Cylinder Ass’y
Lines Gp-Brake(2.0/2.5 Ton)
Lines Gp-Brake(3.0 Ton)
Parking Brake Gp
Floor Plate Gp
Cover Gp-Hyd Tank
Lines Gp-Hydraulic
Pump Mounting Gp
Gear Pump Ass’y
Control Gp-F/R(P/S)
Section 2
Capacity Module
Guard Gp-Overhead
Counter Weight Gp
Tire & Wheel Gp(PNEU)-2.0/2.5 Ton
Tire & Wheel Gp(PNEU)-3.0 Ton
Tire & Wheel Gp(PNEU)-Dual-2.0/2.5 Ton
Tire & Wheel Gp(PENU)-Dual-3.0 Ton
Tire & Wheel Gp(Solid)-2.0/2.5 Ton
Tire & Wheel Gp(Solid)-3.0 Ton
Tire & Wheel Gp-Dual-Solid-2.0/2.5 Ton
Tire & Wheel Gp-Dual-Solid-3.0 Ton
Fender Gp-Dual Tire-2.0/2.5 Ton
Fender Gp-Dual Tire-3.0 Ton
Location Chart Part 1 of 4
Location Chart Part 2 of 4
Location Chart Part 3 of 4
Location Chart Part 4 of 4
Section 3
Engine Ar.-Basic
Alternator Mounting Gp
Alternator Ass’y
Cylinder Block Gp
Gear Housing Gp
Flywheel Housing & Oil Pump Gp
Cylinder Head & Bonnet Gp
Suction & Exhaust Manifold Gp
Camshaft & Driving Gear Gp
Crankshaft & Piston Gp
LUB. Oil System Gp
Cooling Water System Gp
Fuel Injection Pump Gp
Fuel Injection Valve Gp
Fuel Filter Gp
Starting Motor Gp
Gasket Set Gp
Section 4
Power Train
Transmission Ass’y
Hydraulic Clutch Ass’y
Reduction & Differential Ass’y
Control Valve Gp-Solenoid
Inching Valve Ass’y
Charging Pump Ass’y
Drive Axle Gp-2.0/2.5 Ton
Wheel Brake Ass’y-LH-2.0/2.5 Ton
Wheel Brake Ass’y-RH-2.0/2.5 Ton
Drive Axle Gp-3.0 Ton
Wheel Brake Ass’y-LH-3.0 Ton
Wheel Brake Ass’y-RH-3.0 Ton
Drive Axle Gp-3.0 Ton(Code L)
Drive Axle Gp-3.0 Ton(Code X)
Section 5
Option For Complete Truck
Anti-Spark Muffler Gp
Pre Cleaner Gp
Seat Gp-Static-STD
Seat Gp-Static & Hip Restraint
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip Res., W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip Res., W/Arm.)
Seat Gp-Vinyl Suspension(W/Hip Res., W/O Arm)
Seat Gp-Cloth Suspension(W/Hip Res., W/O Arm.)
Seat Gp-Suspension & Hip Restraint
Seat Belt And Warning Indicator Lamp For Unfastening Belt
Seat Belt Gp W/O Switch
Lamp Gp
Rear Lamp Gp - OVHG
Strobe Gp - OVHG(Amber)
Strobe Gp - OVHG(Red)
Horn Gp
Valve Ar-2Sec 2Lev
Valve Gp-2Sec 2 Lev
Valve Ar-3Sec 3Lev
Valve Gp-3Sec 3 Lev
Valve Ar-4Sec 4Lev
Valve Gp-4Sec 4 Lev
Valve As-2Sec
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve As-3Sec
Valve-Revolve
Valve As-4Sec
Tool Gp
Modular Cabin Gp-A
Modular Cabin Gp-B
Modular Cabin Gp-C
Optn-Speedo Meter
Optn-Autoshift Controlle
LED Lamp Gp-W/Com. OVHG&A CABIN
LED Lamp Gp-W/Com.Full CABIN
LED Lamp Gp-W/Com. B&C CABIN
LED Lamp Gp-Front,OVHG&A CABIN
LED Lamp Gp-Front,B&C CABIN
Change Over Ar.-Safety(2.0/2.5Ton)
Change Over Ar.-Safety(3.0Ton)
Valve Gp-4SEC 3 Lever
Cabin Gp-For Crown Plus
Rear Grip Bar-Ovhg
Rear Grip Bar-C Cabin
Rear Grio Bar-Full Cabin
Engine Shut Down
Tire&Wheel Gp-Drive(2.0/2.5Ton)
Tire&Wheel Gp-Front(2.0/2.5Ton)
Tire&Wheel Gp-Inner(2.0/2.5Ton)
Tire&Wheel Gp-Inner(3.0Ton)
Tire&Wheel Gp-Outer(2.0/2.5Ton)
Tire&Wheel Gp-Outer(3.0Ton)
Rain Canopy
Bar Plate Radiator
Speed Limit
Integral Shifting-Fork Positioner 1120mm-FFL(2.0/2.5T)
Integral Shifting-Fork Positioner 1120mm-FFT(2.0/2.5T)
Integral Shifting-Fork Positioner 1170mm-FFL(3.0T)
Integral Shifting-Fork Positioner 1170mm-FFT(3.0T)
Section 6
Mast-Hydraulic
Lift Cylinder Gp-STD(MHF 2500mm~3700mm)
Lift Cylinder Gp-Primary-FFL
Lift Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH
Tilt Cylinder Ass’y-RH
Tilt Cylinder Gp
S/S Lines Gp(STD)-2.0/2.5Ton
S/S Lines Gp(STD)-3.0 Ton
S/S Lines Gp(FFL, FFT)-2.0/2.5 Ton
S/S Lines Gp(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(FFL, FFT)-3.0Ton
Att Lines Gp-Sec(4 Way)-STD-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-STD-3.0 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(FFL, FFT)-3.0 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-2.0/2.5 Ton
Att Lines Gp-Sec(4 Way)-FFL, FFT-3.0 Ton
Lines GP-ATT-Secondary(3 Way-LH)-2.0/2.5/3.0 Ton
Section 7
Mast-Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3 Way(STD)
Att Lines Gp-Pri-3 Way(FFL)
Att Lines Gp-Pri-3 Way(FFT)
Att Lines Gp-Pri-4 Way(STD)
Att Lines Gp-Pri-4 Way(FFL)
Att Lines Gp-Pri-4 Way(FFT)
Side Shifter Gp-2.0/2.5 Ton
Cylinder Ass’y
Side Shifter Cylinder Ass’y-3.0 Ton
Side Shifter Gp-3.0 Ton
Side Shifter As-2.0/2.5 Ton
Side Shifter As-3.0 Ton
Cylinder Ass’y-2.0/2.5Ton
Cylinder Ass’y-3.0Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-LH(STD)-3.0 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-2.0/2.5 Ton
Att Lines Gp-Sec(3 Way)-RH(STD)-3.0 Ton
Carriage Ass’y-2.0/2.5/3.0 Ton
MAST-FFL
Carriage Arrangement;INT S/S-STD
Carriage Assy;Integral S/S;
Carriage Arrangement;INT S/S-FFT
Carriage Assy;INT S/S-STD
Backrest Ass’y-2.0/2.5 Ton
Backrest Ass’y-3.0 Ton
Carriage Ass’y-STD/FFL/FFT(2.0/2.5/3.0 Ton)
Carriage Mounting
Fork Gp
Integral Shifting-Fork Positioner 1120mm-STD(2.0/2.5T)
Integral Shifting-Fork Positioner 1170mm-STD(3.0T)
