Doosan Forklift BR15S-5 BR18S-5 Spare Parts Catalog SB5082Y
Brand: Doosan
Type of Machine: Forklift, BR 1 Ton Standing REACH, Electric Powered Truck
Model: Doosan BR 1 Ton BR15S-5, BR18S-5 Forklift
Part Number: SB5082Y
Number of Pages: 291 Pages
Section 1
Chassis Componet Part
Wiring Gp-CTS
Wire Groep
Wiring Gp-SME
EPS Kit
Instruments Gp-CTS
Instruments Gp-SME
Tank Gp - Hydraulic
Lines Gp - Mast Operating
Mounting Gp - Head Guard
Guard Group,Overhead
Mounting Gp - Reach Cylinder
Mount Group;Reach Cyl
Reach Cylinder Ass’y
Motor Gp - Drive
Drive Motor Ass’y-SME
Drive Motor Ass’y
Motor Gp - Hydraulic
Motor Gp - Hydraulic-SME
Motor Gp - Pump
Motor Gp - Pump-SME
Lighting Gp
Control Gp - Accel
Accelerator;Group
Pump Gp - Hydraulic
Pump - Hydraulic
Panel Gp - Control
Panel Gp - Control-SME
Controller Ass’y
Controller Ass’y-SME
Section 2
Power Train&Brake System
Mounting Gp - Transfer
Transfer Gp Part 1 of 2
Transfer Gp Part 2 of 2
Control Gp - Brake
Drive Wheel Mounting Gp - Rubber-Plain/Rubber-LUG/Urethane-Plain/Rubber-Non Marking
Load Wheel Mounting Gp - Urethane/Rubber
Caster Wheel Ass’y
Section 3
Steer Axle Gp
Handle & Linkage Gp
Section 4
Control Valve & Options
Valve Ar. - 3 Section
Valve Gp - Control - 3 Section
Valve, Section - Inlet
Valve, Section - Reach
Valve, Section - Tilt
Valve, Section - Lift
Valve, Section - Outlet - 3 Section
Valve, Section - Outlet - 4 Section
Valve Ar. - 4 Section
Valve Gp,Control;4Sec
Valve Gp,Control;3Sec
Valve Gp - Control - 4 Section
Option Lighting & Warning Gp - Strobe, Back Up Alarm
Tool Gp
Connector Gp - Battery(SB Type) - Non EEC-CTS
Connector Gp - Battery(SB Type) - Non EEC-SME
Connector Gp - Battery(SBE Type) - EEC-CTS
Connector Gp - Battery(SBE Type) - EEC-SME
Battery Ass’y
Battery Cover Ass’y/Hose Guide
Charger Ass’y - Battery, Non EEC - 3P - 60Hz - AC 220 Volt - 230AH/300AH
Charger Ass’y - Battery, Non EEC - 3P - 60Hz - AC 380 Volt - 230AH/300AH
Charger Ass’y - Battery, Non EEC - 3P - 60Hz - AC 440 Volt - 230AH/300AH
Charger Ass’y - Battery, Non EEC - 3P - 50Hz - AC 220 Volt - 230AH/300AH
Charger Ass’y - Battery, Non EEC - 3P - 50Hz - AC 380 Volt - 230AH/300AH
Charger Ass’y - Battery, Non EEC - 3P - 50~60Hz - AC 380 Volt - 300AH
Charger Ass’y
Safety Kit Gp - Tilt Drift Prevention-SME
Safety Kit Gp
Section 5
Frame & Panel Group
Panel Gp - Outer
Panel Assy - Outer
Battery Bed Gp
Bed Assy,Battery
Bed Ass’y - Battery
Battery Carrier
Location Chart
Section 6
Mast - Hydraulic
Lift & Tilt Mounting Gp - STD
Lift & Tilt Mounting Gp - FFT
Tilt Cylinder Mounting Gp - STD
Tilt Cylinder - LH/RH
Tilt Cylinder Mounting Gp - FFT
Lines Gp - Attachment - Primary - 4 Way - STD
Lines Gp - Attachment - Primary - 4 Way - FFT
Lines Gp - Side Shifter - STD
Lines Gp - Side Shifter - FFT
Side Shifter Gp
Cylinder Gp
Section 7
Mast - Implements
Mast Gp - STD
Mast Gp - FFT
Mast Ass’y - STD
Mast Ass’y - FFT
Relay Gp - Lift - STD
Relay Gp - Lift - FFT
Mounting Gp - Reach
Carriage Ass’y - STD/FFT
Carriage Mounting Gp
Lift Gp - Secondary Cylinder - STD
Lift Gp - Secondary Cylinder - FFT
Lift Gp - Primary Cylinder - FFT
Board Ass’y
Backrest Gp
Fork Gp
