Doosan Forklift BR13S7 BR15S7 BR18S7 Spare Parts Catalog SB1125
Brand: Doosan
Type of Machine: Forklift, BR 1 Ton Standing REACH, Electric Powered Truck
Model: Doosan BR 1 Ton BR13S7, BR15S7, BR18S7 Forklift
Part Number: SB1125
Number of Pages: 970 Pages
[CHASSIS] Chassis
HANDLE & LINKAGE GROUP
AXLE GROUP,STEER
WIRE GROUP
EPS KIT
LINE GROUP
TANK MODULE,HYDRAULIC
CARRIER
ACCELERATOR
GUARD GROUP,OVERHEAD
PANEL ASSY
PANEL
INSTRUMENT GROUP
PUMP ASSY,HYDRAULIC
PUMP,GEAR
GUIDE
MOUNT GROUP
ARRANGEMENT,CHANGEOVER
BED ASSY,BATTERY
CYLINDER,REACH
BATTERY ASSY
TOOL GROUP
REACH CYLINDER GROUP
GROUND STRAP OPTION
PUMP ASSY,WATER
PANEL ASSY,CONTROL
CONTROLLER ASSY
MOTOR GROUP,PUMP
BATTERY CARRIER
ARRANGEMENT,GENERAL
MODULE,BASIC
TELEMATICS SYSTEM
CHANGEOVER
CONTROL GROUP,BRAKE
SPARE PARTS
TOOL GP
BRAKE
[CHASSIS] Driving Module
TRANSFER GROUP
TRANSFER ASSY
WHEEL,DRIVE
TIRE AND WHEEL GROUP
TIRE
WHEEL GROUP
WHEEL
WHEEL ASSY
TIRE ARRANGEMENT
TRANSFER GP;BR;STEERING ANGLE
[CHASSIS] Electric Power
BATTERY GP
BATTERY, STANDARD
CHARGER ASSY
CHARGER ASSY,BATTERY
CHARGER, 230AH, 380V(3P-50HZ,
CHARGER, 230AH, 440V(3P-50HZ,
CHARGER, 230AH, 440V(3P-50HZ)
CHARGER, 230AH, 220V(3P-60HZ)
CHARGER, 230AH, 220V(3P-50HZ)
CHARGER, 230AH, 380V(3P-50HZ)
CHARGER, 230AH, 440V(3P-60HZ)
CHARGER, 230AH, 220V(3P-50HZ,
CHARGER, 230AH, 380V(3P-60HZ)
CONNECTER GP
CONNECTOR GP
CONNECTER ASSY
COVER ASSY,BATTERY
CHARGER GP
CHANGEOVER ARRANGEMENT
CHARGER AS (230AH/48V/220V/1P/
CHARGER GP; BATTERY
BATTERY CHARGER, 268~300AH, 22
CHARGER, 268~300AH, 220V(1P-60
BATTERY CHARGER, 268~300AH, 38
BATTERY CHARGER, 268~300AH, 44
BATTERY, EC 230AH
BATTERY, NON-EC 230AH
MOTOR ASSY
MOTOR ASSY,DRIVE
MOTOR ASSY,PUMP
MOTOR GROUP,DRIVE
BATTERY ASSEMBLY, 300AH(NON EE
[CHASSIS] Operating Module
VALVE GROUP,CONTROL VALVE
VALVE,MAIN CONTROL
VALVE SECTION,CONTROL
OVERHEAD GUARD-SCREEN
STROBE
OVERHEAD GUARD VINYL COVER
OPTION ARRANGEMENT
VALVE,SECTION
VALVE ASSY,CONTROL
VALVE GROUP,CONTROL
SECTION ASSY
LIGHT GROUP
DRIVE & LIFT WARNING
MIRROR GP,REAR VIEW
MIRROR GP,PANORAMIC REAR VIEW
LITHIUM BATTERY
BUZZER,BACK UP
GUARD GP-PROTECTOR
EXTINGUISHER,FIRE
[FRONT END] Mast
MAST ASSY
LIFT GP
LIFT GROUP,STANDARD
RELAY ASSY
CYLINDER,LIFT
CYLINDER,PRIMARY
LIFT GROUP
MAST ARRANGEMENT
MAST GROUP
LIFT GROUP,PRIMARY
LIFT ASSY
CYLINDER GROUP,LIFT
MAST AR-STD 2.0M
MAST
CYLINDER ASSY
LINE GROUP,ATTACHMENT
PIPE ASSY
CYLINDER ASSY,TILT
CYLINDER,TILT
PROTECTOR ASSY
[FRONT END] Fork
FORK ARR.(BR SHAFT TYPE)
FORK EXTENSION GROUP
FORK CAP
FORK
FORK, ATTACHMENT
[FRONT END] Carriage
BACKREST GROUP
SHIFTER,SIDE
CARRIAGE
CARRIAGE ASSY
CARRIAGE ARR.
CARRIAGE AR.:W=875MM
CARRIAGE ARRANGEMENT
CARRIAGE GROUP
REST ASSY,BACK
LOAD BACKREST
LINE GROUP,SIDE SHIFT
[MISCELLANEOUS] Location Chart
LOCATION CHART-BR13S-7
